#1 2008-01-14 9:27:09 am
kkjj
EEEPC intel 915GM Virtual Resolution with Native Driver (without IEDG)
Some User told that this application as a trash.
And i remove this application , and stop develop.
If you really need the tool for change resolution. Please look the post as LT post. Because my application is a trash.
For All friends you need this application.
i open my site to download the newest version.
you need the read the readme.txt in the file.All functions are have sample in the readme.txt
http://140.126.130.41/~kkjj/trash/EEEPC_RESV1.ZIP
Best Regards,
Jim Wei Huang
#2 2008-01-14 9:42:07 am
kkjj
Re: EEEPC intel 915GM Virtual Resolution with Native Driver (without IEDG)
sorry i forget one thing.
because asus astray.exe will set resolution.
Before you run this application, please close astray from tray icon.
if this can not down. please intall asus R2h xp vga driver.
#3 2008-01-14 10:09:01 am
Fluffywings
OMG I love it.  Can you enable 1000x600? Will you post your source code?
#4 2008-01-14 11:01:03 am
fazz33
Wow... This takes the cake for a first post! Thanks! And Welcome! And did I say Thanks!? O_o
EEE PC 901 Black
#5 2008-01-14 11:26:24 am
Diverge
Nice little program smile
#6 2008-01-14 11:36:09 am
prouted
Anyone has tested ? Any screenshots ? I can't wait to try this !!!
#7 2008-01-14 11:40:24 am
NoZ
I tried it on the computers while I was still in school and it works perfect.
#8 2008-01-14 11:46:13 am
alanbcohen
Does this work on the delivered Xandros Linux in either easy or advanced mode?  It is unusual for Linux executables to use the .exe filename extension.
All opinions, information etc in this forum post is copyrighted by me (alanbcohen) unless indicated otherwise.
#9 2008-01-14 11:47:59 am
dupreciate
While my Eee is in the RMA process, how about someone posts pics of 1024x600 and 1000x600. I'm interested in how well text reads when interpolated, but at a proper aspect ratio.
#10 2008-01-14 12:09:06 pm
cr0ssy
it says only for xp users @alanbcohen so i guess it doesn't work on xandros wink
some screens would be truly nice am i right there are no standby ,display turn off etc crashs with this programm? pretty neat thing thank you very much
#11 2008-01-14 12:13:49 pm
Fluffywings
1000x600, 1024x600 and 1024x768 do not work.  I then installed the R2H Drivers and still not change.
#12 2008-01-14 12:15:47 pm
kkjj
To Fluffywings
        please uncheck "Hidden the supported mode"
        display Setting -> Advanced -> Monitor. It will be ok.
#13 2008-01-14 12:17:08 pm
dupreciate
kkjj....Pics!
#14 2008-01-14 12:19:33 pm
kkjj
TO dupreciate
       The Video is uploading to YouTuBe . Now in my time zone is AM 1:00 and i will open it at AM 4:00
         because i will go to HK at AM 7:00 i need sleep.
#15 2008-01-14 12:51:32 pm
no1knows
anyone else prepared to upload some screenshots, it worth me changing from LazerTag's drivers?
Cheers
Eee PC 4G 701 7C | Bios: 511 -> 703 @ 900Mhz, OC to 1.1Ghz | 2GB Ram | Win XP Pro SP2 | Mods | Modem pins switch | Final layout?
#16 2008-01-14 1:10:01 pm
fazz33
Well, the resolution scaler this guy made is much better for me ^_^ I would recommend the change, and this is because standby now works, however the resolution changes back to default 800x480, but its better than not comming out of standby at all.
All in all Great work, I'see if I can post pics in an hour or 2, I cant now I'm sitting in a lecture, and taking pictures would be rude smile
EEE PC 901 Black
#17 2008-01-14 1:19:23 pm
ndondo
wow I am psyched excited smile
can't wait to try 1024 x 600 resolution
#18 2008-01-14 1:30:26 pm
alanbcohen
OOPs;  Sorry guys!  I sometimes have a problem reading too fast!
#19 2008-01-14 1:35:24 pm
Diverge
check this out for linux:
http://mandrivaonadellx1.50webs.com/display.htm
http://www.geocities.com/stomljen/
not sure if it works, but you can try it if ya want tongue
#20 2008-01-14 1:37:27 pm
dupreciate
maybe i misread as well:
Feature work:
add support 1024x600 and 1000x600
I take it this means that widescreen resolutions are not yet working.
#21 2008-01-14 1:42:44 pm
javili23
wowww nice program, now I can use 800x600 big_smile big_smile
Thanks for the program
Can i put it in a spanish blog??
#22 2008-01-14 2:04:37 pm
Matizek
This program only needs resolutions like 1000x600 and 1024x600, option to add it to startup and only icon in system tray. smile I'm looking forward to it!
#23 2008-01-14 2:35:41 pm
geoelectric
kkjj,
Haven't checked this out yet, but can you or do you enable 640x480 (truecolor) as a supported resolution?  This would enable gamers, who need that resolution for most older games to initialize.
#24 2008-01-14 4:00:15 pm
ruairiSpain
great...no problems with truetype fonts like before...
but anything over 800x600 is fairly hard to see with my eyes.
Very impressed..where can I make a donation?
This 800x600
http://img175.imageshack.us/img175/4295/800x600qc5.jpg
#25 2008-01-14 4:09:03 pm
SOL
Checked out - I grabbed the R2H drivers from here - http://dlsvr01.asus.com/pub/ASUS/nb/R2H … 060831.zip - as it doesn't seem to want to play with the latest Intel ones.
Popped them on, went into the Display Properties, Advanced, Monitor and Unchecked the 'Don't display modes my monitor doesn't support' box, went back to the Desktop and then clicked 1024x768 on the app, closed my eyes....
Opened them and pop - 1024x768. Looks a little funky due to the scaling, but definately works smile
Sad thing is I cleared a load of games off that required 800x600 screens, else I'd tell you what they look like and performed like. I use Mame32 and providing you avoid DirectDraw (which slows things down anyway) there's not too much difference between running in 800x480 to 800x600. Even then I don't know if it's just due to the bigger resolution needing more drawn (I generally use STUN Runner as a benchmark).
Forbrowsing though, much better at 800x600! I will echo the call for more widescreen resolutions, but first a well done kkjj!
S0L
