#1 2008-01-10 4:21:53 pm
Anarethos
Bios Update Tools
Updated on september 7th 2008
Hi everyone!
I made a simple tool that allow you to format a Usb drive (Usb key, SD card, etc.) to make it bootable to allow bios flashing.
Right now, the following bios are available in the "kit"
EEE 2G Surf (Model 700)
2G Surf (700) - 0129
2G Surf (700) - 0127
2G Surf (700) - 0128
2G Surf (700) - 0207
2G Surf (700) - 0401
EEE 4G and 4G Surf (Model 701)
4G / 4G Surf (701) - 0401
4G / 4G Surf (701) - 0511
4G / 4G Surf (701) - 0703
4G / 4G Surf (701) - 8804
4G / 4G Surf (701) - 0801
4G / 4G Surf (701) - 0906
4G / 4G Surf (701) - 0910
EEE 8G (Model 702)
8G (702) - 0103
8G (702) - 0201
8G (702) - 0404
Please note that this will format the Usb device, so make a backup before!
Please note that since I switche to a 900HA, no futher development or support will be available for this product.
Download - Link 1
Download - Link 2 [SSL error is normal and can be ignored]
Asus EEE 900HA - 2gb RAM
Windows 7 Ultimate
[Old EEE 701 Surf and Aspire One 150 user]
#2 2008-01-10 4:46:36 pm
Echostrike
Re: Bios Update Tools
Looks like you did a good job. thanks!
Although I must ask--how is this different from DL'ing the bios .bin file, throwing it onto the flash stick and then pressing alt + f2 to go into asus ez flash to change the bios?
i guess im saying why do you have to format the drive?
--pardon my ignorance.
#3 2008-01-10 4:49:48 pm
Anarethos
Sometime, you are not able to "go back" to an older bios.
Like, if you install 0511, you can just upgrate to 0703 with the normal updater or with the ALT+F2 option. And once at 0703, you can't go back to any previous version.
With this, you can! big_smile
Windows 7 Ultimate
#4 2008-01-10 4:58:34 pm
Elddric
Umm just so you know, alot of the 8g (702) came with the 0201 bios which I believe is newer then the 0103. Might not be good or usefull to even have it there.
8G(702)7B-0404 bios-8GB SSD(XP)-2 8GB SDHCC6(storage)(Xandros)-2GB ram-touchscreen+bluetooth
astray+
EEEctl(Full speed)
IVC's research Read his resources. GREAT info from a lot of people!
#5 2008-01-10 5:09:59 pm
Echostrike
to OP-
Thanks, that is quite cool. I hate the no downgrade thing- it bit me in the a$$ on my maximus formula after I accidently upgraded to the latest (unstable) bios.
good tool.
#6 2008-01-10 5:20:25 pm
kevwalker
I'm extremely impressed.
This works really well, thanks!
#7 2008-01-10 9:17:19 pm
robin
You need WindowsXp to create th device. Don't know if it will work under Vista.
Great work.  Is there any way to get this to work without Windows?  FreeDOS or something?
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away."
--Antoine de Saint-Exupery
#8 2008-01-14 2:09:49 am
JDTucson
Anarethos, Thanks loads!!!
I have a 4GB 701 7B that came with 0401 bios at slow speed. I downloaded your tool and upgraded to 0511 bios and tried HiPerformance Mode. I loved the 900mhz but then the fan came on.sad   Even on slow BatterySave Mode the fan never shut off. It sounded like a mini hair dryer. So I booted up HiPerf Mode and used your tool to upgrade to 0703 bios. Now I have 900mhz, no fan noise, a bright screen, and I'm back under warrantieee. Thanks you made it really easy.
JDtucson
smile FOR SALE - Model 900-20G Linux White w/OCZ 32GB SSD modded to BT port, 52GB total SSD $239+sh
68GB 701-4G w/Touch Screen - 0703 BIOS - 1GB RAM - Black - XP Home
901XP-12G-Ebony Black w/ZIF - 2GB OCZ RAM - 1902 win 7 BIOS - Runcore SATA 64GB
#9 2008-01-14 12:09:29 pm
amf
Thanks Anarethos! I used it to upgrade to 0511.
#10 2008-01-16 12:05:49 pm
cpdave
Good effort Anarethos - was finally able to roll back the bios and get rid of that annoying fan issue.
Many thanks,
CPD
White 4G | 0703 BOIS @ 900MHz | 2Gb RAM | 16Gb Class 6 SDHC | XP Professional | Bluetooth HSDPA & GPS | Microsoft Office Enterprise 2007, Autoroute 2007, Half-Life & Counterstrike (1.6, Condition Zero & Deleted Scenes)
#11 2008-01-16 12:54:08 pm
Fluffywings
Thanks.
#12 2008-01-16 5:35:50 pm
Anarethos
Thanks to Elddric, the 8G 0201 bios has been added!
Windows 7 Ultimate
#13 2008-01-16 6:20:30 pm
Nu7a
Did it in Vista and it worked flawlessly.
#14 2008-01-17 12:50:20 am
Craigness
Fantastic!
Merci vraiment!
4gb Galaxy Black EEE, 2gb Kingston RAM, 8gb ADATA SDHC
#15 2008-01-28 7:01:11 am
energie
is there any reade me with istructions?
i don know how this work.sad
#16 2008-01-28 1:33:07 pm
billy_b0b
thanks man.  this was my fix to downgrading my bios, overclocking, then going back to the latest
Asus Eee PC 701 4G - Galaxy Black | Transcend 2GB RAM | A-Data 16GB SDHC | 900MHz - Overclocked | 0703 BIOS | WinXP SP2 | Brando Ultra Clear Screen Protector
#17 2008-01-28 1:39:43 pm
Anarethos
@Craigness  : Mais de rien mon cher (ou ma chère!)
@energie : No, sorry, I forgot to create a readme. Simply Unzip the file somewhere and run "MakeBoot.cmd". It will ask for the drive letter of the Usb drive you want to use and enter it (like, say, f: ). The drive will be formatted and all needed files will be copied on it. Then, put this drive in the EEE, turn-it on, press the ESC key when you see the Asus logo, select your drive and follow on-screen instructions.
Windows 7 Ultimate
#18 2008-02-01 2:04:56 pm
Elddric
Anarethos  MickJT found out link that if you kill the bios you can still recover the eee by having the bios file on a thumbdrive and just letting the system boot. does your utility allow you to specify a default bios that it would leave as the 701.rom? in this way it would be able to recover the system even from a some bios crashes?
if not you might add it in.
just a thought.
astray+
EEEctl(Full speed)
#19 2008-02-01 3:55:51 pm
ohyes
What would be the preferred bios for 4GB 701 7A?
John
new: 1g 1000H
#20 2008-02-05 6:30:35 pm
jonat
This won't be a good question here, but I still want to know before I risk my toy... Will this tool possibly brick it?
#21 2008-02-05 9:11:45 pm
Elddric
as long as you dont power off in the middle of it this program should be fine to use.
astray+
EEEctl(Full speed)
#22 2008-02-05 9:54:47 pm
LS650
I searched the wiki for info on the differences between the various BIOS updates, but there doesn't seem to be any such info there.
Is there a location or thread that outlines the various differences?  I currently have 0129 and would be interested to know if there's any point in upgrading the BIOS.
Acer Aspire One
http://wiki.eeeuser.com/   <-- A searchable knowledge base; very helpful for beginners!
#23 2008-02-05 10:10:02 pm
Elddric
We've been trying to get that information for a while. Asus didnt release most of the updates with a readme stating what changes there were.
astray+
EEEctl(Full speed)
#24 2008-02-08 11:30:51 am
IanB
So far, so good or, so I thought.
Loaded the update tool and then the 0511 Bios and restarted.  Increased to 900MHz and no fan noise, lovely and bright.
However the task bar icon showed 'no battery detected'.
So decided to return to 0703.  Hitting 'Esc' on seeing the Asus logo on startup has no effect except to place a string of  ^[^[^[^[   symbols at the top left of the screen.
When running, the 'Esc' key works correctly as do all the function keys.
Please advise!
#25 2008-02-08 1:54:09 pm
zaurus6k
Please advise!
Try to press ESC earlier and not once but twice or more. Sounds to me you hit it too late
4G Surf Black | 2G Ram | 8G SDHC |  Xandros on SSD WinXP on SDHC | Sprint U727
[img]http://www.speedtest.net/result/241653250.png[/img]
