#1 2008-01-09 1:12:59 pm
elmo
firefox 3 beta 2 with the EEEE
just wondering if anyone else out there is using the new firefox beta? i want to run the fullscreen plugin  and mini firefox theme to give more space. but they incompatible at the moment
anyone else tryed it, edited them to fix it or got any other plugins that work with the beta?
Asus EEE PC 701 4G (Black)
1GB RAM, Full install of Windows XP
8SDHC Card, 3G DONGLE
Photoshop | Illlstrutor | Flash | WAMP Server | notepad++ | MS SQL Managerment server | CIV 2 (RULEZZ)
#2 2008-01-09 2:22:27 pm
hunnymonster
Re: firefox 3 beta 2 with the EEEE
Nope - tried the first beta on a desktop, didn't like the bookmark handling (seemed counter intuitive to me) so I removed it.
Thanks for the heads up on the mini theme though.
edit: Is this any use to you?
#3 2008-01-09 2:54:01 pm
ziddan
im using the firefox "Minefield" beta version 3.03pre.
Its working  great and ive installed the zoom toolbar meaning i get zoom functionality like in opera but in a browser im a lot more comfortable in.
#4 2008-01-09 5:12:20 pm
eeepclover
Oh definitely I'm using Firefox 3, I can't believe anyone would really want to use Firefox 2 on the eeePC! The full page scaling is almost a necessity for when web pages are wider than the screen by default.
#5 2008-01-09 7:31:17 pm
Kirby
Isn't Firefox Beta 3 only in test mode now? When I checked it out it says add-ons may not work. Sure enough, when I installed it on my regular laptop, it turned off all of my add-ons. Does it really make a difference on the Eee for viewing?
Thank you,
Kirby
-Kirby
Pearl White 8g (702) 7B - 0201 bios; 1G (DDR2); Full XP Pro SP3; Word 2007; Avast; Ad-Aware 2008; 8GB A Data SDHC Class 6; 4GB Lexar Secure II Thumb Drive
#6 2008-01-09 8:22:11 pm
Ultimate Chicken
Once again, you can edit add-ons to work on firefox 3. To do so:
1. Instead of attempting to install the .xpi file, save it to the desktop.
2. Rename the .xpi extension to .zip.
3. Extract the install.rdf to your desktop, and open it with a text editor.
4. Change the value of "maxversion". I suggest 4.0.0.0  <_<. Save.
5. Put the edited install.rdf back into the zip, _overwriting the old one_
6. Rename the .zip back to .xpi.
7. Drag and drop the .xpi into Firefox.
Most extensions, aside from the more complicated ones, work this way. I have tested this method on the following:
Downloadhelper
Firebug
Firesomething
ieTab
Does not work on the following:
FireFTP (grab the beta from the forums instead). If you try to force-install this it's guaranteed to crash the browser on first load, then not work at all on subsequent tries.
These extensions have 3.0 support already:
Flashgot
FoxyProxy
Adblock Plus
3.0b2 is tons more stable and less memory hungry than 2.0 release, which is quite a feat if you ask me, especially on WinDOS. Switch IMMEDIATELY. You won't regret it.
Oh, and it passes ACID2.
#7 2008-01-09 9:58:57 pm
Diverge
Downloadhelper
Firebug
Firesomething
ieTab
Flashgot
FoxyProxy
Adblock Plus
thanks for this tip on how to edit the addons. I got fullerscreen to work on firefox 3 beta 2 with that method smile
#8 2008-01-09 10:13:03 pm
sgosnell
Certainly I'm a noob, but how do you install this tarball?  I can't find any configure or install scripts in it.
#9 2008-01-09 10:51:50 pm
FrayAdjacent
I just tap F11 once I get the browse to the site I want to be on... plus I added the 'minimize to tray' add-on.
#10 2008-01-10 12:17:06 am
superslacker
If you want to keep FF2, you can install FF3b2 from PortableApps into another directory so it won't overwrite your FF2 install. It works great.
#11 2008-01-10 9:31:00 am
Addio EEE
Thank you guys you are legends!
I installed the new firefox with fullerscreen, adblock plus and littlefox and it works a treat!
I started off with opera but now firefox has the zoom feature, it can finally get rid!
thanks again!
701,2GB OZ 800mhz Sodimm Ram,Overclocked to 900mhz via EEEctl),Full XP Home SP2, 1st Black & White EEE, (Check out black bezel=Spraypaint)
#12 2008-01-10 10:10:05 am
Kirby
I am trying it out on my regular laptop. When you say, "Instead of attempting to install the .xpi file, save it to the desktop." Where is the .xpi file? I'm not sure where to locate it to change it to .zip.
Any suggestions are appreciated.
Sincerely,
Kirby
-Kirby
#13 2008-01-10 11:48:43 am
elmo
download what ever plugin u want from the net when it says install right click and save location. (pic where ever you want desktop for example) and follow instructions above
anyone know where on ur pc the themes are saved???
also this works with the betawithout edit it is the littlefox theme
https://addons.mozilla.org/en-US/firefox/addon/307
#14 2008-01-10 11:55:25 am
vw195
I did this and there is no editing necessary
http://thatsquality.com/ubuntu/all-in-o … x-3-0b2pre
#15 2008-01-10 1:08:33 pm
Kirby
Thank you!  I will give it a go.
Kirby
-Kirby
#16 2008-01-10 1:36:41 pm
Kirby
Sadly, I couldn't get the extensions to work with the suggested instructions. I'm sure it's my error somewhere. When I did what I thought I was to do, Firefox would open, but then freeze. Where it says to open the rdf file with a text editor, I used Word 2003. Every spot where it said maxversion I changed it to 4.0.0.0.  I think this might be where I messed up?
Thank you,
Kirby
-Kirby
#17 2008-01-10 6:55:53 pm
fro
has anyone gotten any of the compact menu extensions to work?  they install, but when you click on the button the menu's do not drop down
#18 2008-01-10 7:05:51 pm
Ultimate Chicken
ROT is, you do not use Word to edit text files - this word processor inserts formatting symbols which you can't see. Always edit full text files, XML files and HTML files with a text editor, not a word processor.
#19 2008-01-12 10:07:33 am
elmo
like notepad.exe ;)just incase you didnt know smile
#20 2008-01-19 6:52:45 pm
Newsguy
I have FF3 beta 2 installed on my eee, but I can't seem to figure out how to use the pagezoom feature. Can anyone help with this please?
4G Galaxy Black EEE 701 7C - 2GB RAM - XP Pro
C2D 6550@2.6ghz - 2GB RAM - 320 GB 2x40GB HDD - GeForce 7900gs 512
#21 2008-06-20 3:00:12 pm
foomf
I think I did something WORNG.
I installed from the FF3 tarball that was released earlier this week.
Now, Firefox will not run at all - wants a newer GTK - but I cannot find a valid distro that I can convince my box to find.  I can't even find GTK on my system, none of the packages seems to be a GTK.
Complicate this with the "at work, I can only access internet if I authenticate with the guest system first, and that requires a browser that works."
So ... anyone dealt with this yet?  I'm guessing I need to find another repository somewhere and add it to the list.
#22 2008-06-20 3:01:42 pm
foomf
You can actually edit with Word safely, but you have to save it in text mode, or as the Ultimate Chicken says, it will insert "other stuff" in front.
