#1 2008-01-08 7:01:55 pm
dci
eeectl / eeeclock
eeectl is a tiny yet powerful program for Asus EEE PC 701/702 series, it runs on Windows® and allows you to control & overclock your eee on the fly.
please note that this kind of software is(and always will be) potentially dangerous for your hardware, you can use this software at your own risk, i accept no responsibility to any accidents or injury from this software(however none has been reported so far).
Home page:
http://www.cpp.in/dev/eeectl/
If you like this program, you can make a donation. Visit home page for details.
Jun 23, 2008 eeectl 0.2.4
http://cpp.in/dev/eeectl/?get_latest_bin (23kb)
Bugfix release, no new features, just working.
eeectl source code is now available under the terms of the GNU Public License. Visit the home page for details.
dciio source code remains closed, you won't need it to build eeectl or alter its logic.
Feb 17, 2008: eeectl 0.2.3
http://www.cpp.in/dev/eeectl/eeectl_0.2.3.zip (21kb)
New features:
- Backlight control in 0511-style with ANY BIOS (twice brighter than 0401)!
- Suspend configuration is applied on shutdown to fix PCIE issues.
- Improved Vista support.
- Brief documentation on 0.2.* features included.
Other features:
- FSB speed control.
- PCIE speed control.
- CPU voltage control.
- Fan speed control(incl. used-defined automatic mode).
- Temperature monitor.
Notes:
- 700(2G) is still not supported.
IF YOU'VE GOT COLORFUL SCREEN WHILE ATTEMPTING TO RISE SPEEDS PLEASE READ THE THREAD BEFORE ASKING ANY QUESTIONS.
eeeclock is no longer supported, this link is provided for your information:
Jan 11, 2008: eeeclock 0.1.2
http://www.cpp.in/dev/eeectl/eeeclock_0.1.2.zip (16kb)
#2 2008-01-08 7:07:15 pm
.:Cyb3rGlitch:.
Re: eeectl / eeeclock
I'm using a combination of 0511 and SetFSB. Maybe I should try yours instead.
#3 2008-01-08 7:11:31 pm
.:Cyb3rGlitch:.
How do I set the Custom FSB? Mine is greyed out and says 165Mhz with a tick next to it. My Eee is running at 110Mhz FSB via SetFSB.
#4 2008-01-08 7:15:51 pm
dci
.:Cyb3rGlitch:.
I didn't try it with 0511, only with 0401, 8804 and 0201 . However worst that can happen -- it won't work.
You can edit ini to add your freqs, something like this:
Freqs = 70,0,Stock; 80,0; 85,1,Medium; 95,1; 100,1,Full; 110,1,Even higher
#5 2008-01-08 7:17:57 pm
.:Cyb3rGlitch:.
Ahh, cool. I'll give it a try. smile
#6 2008-01-08 7:22:23 pm
.:Cyb3rGlitch:.
Err, there is a major bug with the 0511 BIOS and this software. :S
I'll see if I can fix it.
#7 2008-01-08 7:26:03 pm
dci
What kind of bug?
SetFSB works on 0511 with same settings? eeeclock modifies pll another way, but data should be the same.
Maybe it's time for me to flash 0511.)
#8 2008-01-08 7:29:14 pm
.:Cyb3rGlitch:.
Ok, it seems that there is a different FSB ratio (of 1 : 1.5).
e.g.
A 110MHz FSB (CPUz) = 165MHz FSB on your program
A  FSB 46.7MHz (CPUz) = 70MHz FSB on your program etc.
#9 2008-01-08 7:32:49 pm
dci
Wow, thats strange, but not critical, i think.
Anyway, can you make ACPI DSDT dump for me?
#10 2008-01-08 7:34:19 pm
.:Cyb3rGlitch:.
Anyway, can you make ACPI dump for me?
Tell me how to do it and I'll gladly do it. smile
#11 2008-01-08 7:39:22 pm
dci
download this file:
http://developer.intel.com/technology/i … 061109.zip
unpack, run(on eee) "iasl.exe -d", mail resulting dsdt_****.dsl at dci@4pda.ru.
thanks.)
#12 2008-01-08 8:02:21 pm
dougeeebear
dci,
It seems to work very nicely.
Can I enter a lower value in the ini file to underclock to around 500MHz without worrying about causing problems?
Thanks for this neat app,
Doug
Asus EeePC 1000H - WinXP Home SP3, 64GB Super Talent 150/100 SSD
"If it ain't broke, fiddle with it until it breaks, then fiddle with it until you get it fixed"
#13 2008-01-08 8:09:33 pm
dci
dougeeebear
Well, you can try.smile
I can get stable 55MHz FSB with an intermediate step at 60, so you may be able too.
Try adding something like "55,0,Low energy;60,0;" to freqs param in ini.
#14 2008-01-08 8:37:12 pm
dougeeebear
dci,
Yes, that takes me down to exactly 500MHz as reported by MobileMeter which is exactly what I wanted. I can also notice the difference in speed.
If I added eeeclock to my startup folder and set "SuspFreq = 55,0" would it start at that frequency every time I restarted the computer?
I'm going to keep track of the temperature and see if I will be able to safely disable the fan.
Thanks,
Doug
#15 2008-01-08 8:46:11 pm
gokong
I just tried it but it just crashes every time I set it to one of the other speeds.
Eee PC 8G rev. 702
8GB SSD/ 2GB DDR2/ 8GB SDHC
BIOS ver. 0201
WINXP @ 900mhz by dci eeeclock v0.1.2 XD
#16 2008-01-08 9:24:45 pm
dci
dougeeebear
No, first of all, re-download eeeclock from the link in the first post, there was a bug and a frequency wasn't set at startup.
Then, add the frequency to the startup shortcut as an argument, something like this:
"C:\Program Files\eeeclock\eeeclock.exe" 55 0
SuspFreq is what to set before suspending to be able to resume later.
#17 2008-01-08 9:25:51 pm
dci
gokong
Can you dump&send me DSDT as described above?
#18 2008-01-08 9:26:53 pm
.:Cyb3rGlitch:.
Is there a way to overclock in steps like SetFSB?
#19 2008-01-08 9:34:02 pm
dci
.:Cyb3rGlitch:.
That's the only way.
From the eeeclock.ini:
; Note that changing the frequency includes a step-by-step transfer through all intermediate
; values, i.e. if you change the frequency from 70 to 100 MHz and settings contain also 80
; and 95MHz, first the frequency will be changed to 80, then to 95 and only then to 100MHz.
; This applies to ALL frequency changes, even to those done in noui mode.
So all intermediate values should be added manually. If the value isn't named -- it doesn't appear in the menu, but can still be used in the described process.
#20 2008-01-08 9:44:19 pm
JeePea
Crashed XP the first time I tried it at 60Mhz FSB and now it looks like I might have to reinstall.  (Telling me that I have corrupt files in the system menu and I need to do a repair.  Hope it works.)
Eee PC 8G rev. 702 w/1GB RAM
#21 2008-01-08 9:51:01 pm
dci
JeePea
Seems the 702 needs to be re-tested.
What exact file you got corrupted? If you have XP(NOT Windows FLP) it all can be repaired.
#22 2008-01-08 9:55:08 pm
.:Cyb3rGlitch:.
dci wrote:
.:Cyb3rGlitch:.
So all intermediate values should be added manually. If the value isn't named -- it doesn't appear in the menu, but can still used in the described process.
Cheers. smile
#23 2008-01-08 10:08:23 pm
JeePea
dci wrote:
JeePea
I'll be honest, I don't have the exact file name, because it looked more like a directory.  It was a secondary directory in the windows/system folder.  Sorry, but I didn't write it down.
What happened was that I setup the ini file as suggested and tried to underclock to 60Mhz.  When I clicked on the menu the screen immediately went crazy, turning into a bunch of pulsating colored blocks.  I could get no response from any standard way of turning it off, so I removed the battery and rebooted.  That's when windows told me that it could not start.
I'm in the middle of recovery right now and it seems to be going OK.
Stuff happens.
#24 2008-01-08 11:02:36 pm
tebore
Is there away to tie in some voltage controls?
#25 2008-01-08 11:10:17 pm
.:Cyb3rGlitch:.
I was just about to ask that. tongue
