...because it feels so good when I stop...
This time you can play along at home!
Click thumbnail for larger version of the stress reduction kit which can be used over and over again!
This is Bugfixing and Working Around Ubuntu 10.4 LTS Lucid Lynx Guide v.004
Now with 90% more sarcasm! If you act now we'll double your bitterness! But wait there's more! I can't stop using exclamation marks!!!1111
I've begun to think Linus' law ("given enough eyeballs, all bugs are shallow") is like Godwin's Law--it doesn't work when invoked directly. I'm sorry, my bad.
Lucid reinstalls now totaling 00399, but who's counting? Things I have learned so far...
The default kernel will not consistently give eeepc users a wifi signal. Sometimes it is possible to get a short lived connection by toggling the WiFi on and off, but you will need a wired connection to update and fix your Lucid install. Once you get your system updated to the latest default kernel this actually gets worse ninety nine percent of the time.
Powermanagement is still broken and there are strange run away processes that hide in the background and ramp up your processor usage. For some reason this mysteriously goes away or stops happening so frequently after a few days time. I don't know why. At first it was thought that UbuntuOne was the culprit, or that the kernel had an issue with the ext4 filesystem, but although removing UbuntuOne and changing to a different filesystem seemed to have helped some neither really fixed things a hundred percent.
How Lucid Lynx was allowed out the door with these and so many other bugs is beyond me.
Before proceeding I should warn you that I am not an expert and that many if not all of the tips and tweaks that follow are "dirty hacks" which could cause your eeepc to spontaneously turn into yogurt, make your significant other start chasing after moving vehicles in the street, cause your vision to go dim, etc etc etc. Proceed with caution. I am not responsible if things go awry. I will try to credit the sources of my information when at all possible, but no guarantees.
NOTE: I am performing all these operations using the EeePC 901 2103 BIOS with SLIC and a changed OEM image. Using a different bios will have different results in some cases. Your mileage may vary.
Installing Ubuntu...
Speed up your Lucid Lynx (re)installs
There are several things you can do to help speed along the process of doing your Ubuntu (re)installs.
Do not connect to the internet during install time
Do not connect to the WiFi or the Ethernet during install and you won't sit there for an additional hour staring at the screen while the overloaded default servers download unneeded language packs.
I've seen install times drop down to almost nothing just by not connecting. If Canonical wants to install language packs it can include them on the ISOs, and not waste our time downloading them during installation. 'Almost done installing' my ***...
Backup your debs
When planning on doing a reinstall of Ubuntu make it a practice to navigate to the apt directory and copy all the *.debs over to a flash drive or SD card before doing the install. Believe it or not but there are now over five hundred megabytes of updates to do after Ubuntu is installed. If you back up the previous updates you've done you'll be able to apply many of them without having to wait for them to download again. This can shave off hours depending on your download speeds!
Where you want to go is:
/var/cache/apt/archives
Select all the files (minus the one named lock) and copy them to a safe place on an external drive.
Once you have Ubuntu installed you can copy them back by opening the terminal and getting a root nautilus session::
sudo nautilus
Now copy your backed up .debs from your portable drive back to the archives directory path listed above. Now once you connect to the internet and run update manager, you won't have as many files to download from the internet.
Technically the above is really more for post installation, but I've moved it up so that people don't blow away their previous installs and then wish they'd saved their debs.
The file system
Previously I recommended not to install using ext4 because there is a kernel process that is calling constantly and needing to check the disk if you do and will be one of many many processes that will screw up your power management. This issue seems to be fixed in the recommended kernel I list below. You can still read about the issue people were having on the ArchLinux Forums, home to tons of good information for eeepc owners. In particular, user lagagnon explains the issue as follows:
lagagnon wrote:
More info: using "iotop" the culprit appears to be "jbd2/sda1-8", which appears to be a kernel process associated with journaling on the ext4 filesystem, if my googling around is correct. And yes it is an Atom processor here also. Strange, guess will just have to wait and see if future updates fixes it. Does not seem correct that it has to access the disc so often.
Just for fun it appears this issue did not get seem to be fixable by noatime so simply disabling journaling was not a fix. The only fix appeared to be in not using ext4. So we had to ask ourselves whether the speed in boot times is worth the random processor overruns, the overheating that seems to result, and the inability to use many commercial backup imaging programs? Thankfully this no longer seems to be an issue and the trade offs are no longer necessary if you use the kernel recommended further down below.
Still, there are some situations where ext3 is better in Lucid than ext4, so you'll have to do some homework. I do not recommend reiserfs, because you will find yourself doing disk checks nearly every other day and it is an unsupported filesystem with a very limited future.
Update!
User Ceno reports that there is a way to use ext4 and disable journaling thus fixing the jbd2/sda1-8 bug, but it is a bit involved, so your mileage may vary! Personally I intend to stick with the kernel mentioned above and explained below, but for those who might be interested, here is that fixed:
Ceno wrote:
Regarding the jbd2/sda1-8 "bug", if you will, mentioned in the File System section of the 1st post, disabling journaling does indeed solve it.
First thing's first, we can confirm that our ext4 partition is running a journal withCode:
$sudo dumpe2fs /dev/sdaX | grep has_journalDisabling journaling is rather easy, the only drag is that to make structural changes to a filesystem, the filesystem cannot be mounted with read/write privileges. So, run a live cd and hit
$sudo tune2fs -O ^has_journal /dev/sdaXAnd it's done. Now when you boot, the change will be noted and the disk will be checked for errors. When the system is finally up we can run this again to confirm that in fact ext4 is running without a journal
$sudo dumpe2fs /dev/sdaX | grep has_journalshould now return nothing.
With this quick fix, no more constant IO peaks. I can now watch youtube videos without constant freezes.
Thanks for sharing this with us!
Partitioning
Everyone has their own preferences on this, but this is what I do:
4GB SSD
/---/4GBs
---/efi 8mbs
16GB
/----swap 1GB
/-------/usr/share 4GB
/---------data 11GB
I find that my system slows down dramatically when I partition the 16GB SSD (the slower one) as my /home so what I do now is partition /usr/share on the slower SSD and that not only saves me some space for applications it also frees up space for those configuration files and themes in /home. I get around the limitations of the User Folders for media (Music, Videos, Public, etc) with symbolic links.
I will continue to add more preinstall tips as they become available, so please feel free to share any you come across that you know work!
After the installation...
You now have Ubuntu Lucid Lynx installed—now what? You're just getting started! Read on to see how much more tweaking there is to do. ![]()
Fix Plymouth...
First things first. When booting up you might notice the speed of the boot, this is Plymouth and it makes the boot really really FAST! Unfortunately it doesn't seem to work and we have an ugly blinking cursor then suddenly a login screen. We don't get to see any animations or any indicators that the system is doing something. rayraven from the UbuntuForums has a possible fix:
rayraven wrote:
Try this, as root: [sudo su]
echo FRAMEBUFFER=y > /etc/initramfs-tools/conf.d/splash update-initramfs -uThat should make plymouth appear. But, it might delay your boot a tad-bit.
Considering how fast things can boot on our eeepcs already I don't think we'll miss the few seconds it takes, and at least now we know that the system is booting! You'll need to reboot to see the changes take effect.
Reduce writes to your SSDs
These used to be tips that fell under the category of stuff "everyone knows" but as new people come in and the information gets bitrots as wikis get ignored in favor of forum posts (like this one,) people forget. So here they are all in one place because not everyone does know about these and because I notice a major reduction in heat with them enabled and a major speed up in Firefox using them.
From the EasyPeasy Wiki and Fedora-netbook HOWTO:
sudo gedit /etc/fstab
For each of your partitions (/, /usr/share, /data) add ",noatime" after "defaults".
For example (from desktop, not eeepc do not copy exactly):
# / was on /dev/sda1 during installation UUID=6079da5f-faef-4c8a-b5c1-2685cd47fa8a / ext3 noatime,errors=remount-ro 0 1 # /home was on /dev/sda3 during installation UUID=51a9de0a-fdfc-47f7-a96e-9b705edd2e8f /home ext3 defaults,noatime 0 2
Then add the following to the end of the file:
# reduce the number of writes tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0 tmpfs /var/tmp tmpfs defaults,noatime,mode=1777 0 0
Save the file and close the editor.
Now let's do something about the swap!
sudo gedit /etc/sysctl.conf
Scroll down to the end of the file and copy the following:
# # reduces the likelihood of the system using the swap partition as swap vm.swappiness = 1 vm.vfs_cache_pressure = 50
Save this and close the editor. Now open Firefox.
In the URL bar enter the following and type enter:
about:config
Ignore the warning about voiding your warranty and hit the button with the text "I'll be careful, I promise!"
Right click and select New --> String --> Paste the following:
browser.cache.disk.parent_directory
as the name and as the string value type in:
/tmp
This will instead store the cache in RAM if you created the tmpfs entries in fstab as described above. You did didn't you? Other wise skip this last step altogether as it will slow down your browser! Only do this step if you've aded tmpfs to your fstab!
Now save the file close the editor and go on to the next step. Settings won't take effect until rebooting.
The broken theme support:
Some people like the new themes, because finally they're getting the dark themes they've always wanted in workable fashion! Except, the themes have this sense of being unfinished about them for some strange reason...![]()
I couldn't imagine why it looks unfinished! Seriously, does this look finished to you? Unfortunately there's nothing we can do about it, since as far as Canonical is concerned everyone else needs to fix their programs to accommodate Ubuntu...what was that about tribalism again Mark?
Of course these issues are no big deal right? It's only a few apps that break this way, right? Not so much...
Obviously Ubuntu is perfect and all 337 people who took the time to join Launchpad and report this bug (not to mention how many duplicates are all nuts. Oh and pointing out these facts and the way so many bugs are being ignored so Shuttleworth can play retro skin designer is "pointless bashing" and totally not a reflection of anger at seeing bugs ignored for so long...
Then again this is the same guy who thinks that 'windicators' are a good idea, so I guess some stupidity is to be expected.
Hey Mark, here's a clue—this type of thing was tried by almost everyone back in the early days of GUI skinning and there's a reason why it didn't make it as a default theme anywhere, and that's because it sucks as a work environment! But hey if you really want to go back to 1998, it's your dime...![]()
Those $#&% buttons...
If by this point you've found yourself suffering from disorientation due to muscle memory constantly having you mouse to the wrong location for the window buttons, maybe this would be a good time to change them back to the defaults?
In terminal:
gconftool-2 --set /apps/metacity/general/button_layout --type string menu:minimize,maximize,close
You could also just get Ubuntu-Tweak and move them around to your heart's content... ![]()
Personally after some time I've gotten used to the window controls being on the left and use the "Black Fruit" emerald theme because it complements the default theme so well. Your mileage may vary.
Make the default themes more compact...
Okay, you've rebooted and hopefully everything has gone smoothly and you've logged into your desktop without issue. You should be seeing the new Ambiance and Radiance themes... Unfortunately these new themes are slightly larger than any of us would like to see on the small screens of our eepcs. Elwood, a blogger has a tip for us to make the theme look a bit more compact:
Elwood wrote:
Just add this line to the theme’s gtkrc and all the stuff became more compact and finally suitable for the small eeepc display.
gtk-icon-sizes = "panel-menu=14,14:gtk-button=12,12"Have a nice day, even with 1280×600.
PS: To have all the changes working I had to reboot in order to reload the gnome-settings-daemon
Personally I find that I like my icons smaller than this on my eeepc, so I've amended that slightly by copying the sizes from one of the older HumanCompact themes to this:
gtk-icon-sizes = "panel-menu=16,16 : gtk-menu=16,16 : gtk-button=16,16 : gtk-small-toolbar=16,16 : gtk-large-toolbar=16,16 : gtk-dialog=32,32 : gtk-dnd=32,32"
You'll need to run sudo when you open the gtkrc:
Ambiance:
sudo gedit /usr/share/themes/Ambiance/gtk-2.0/gtkrc
Radiance:
sudo gedit /usr/share/themes/Radiance/gtk-2.0/gtkrc
Find the line that says:
gtk-icon-sizes = "panel-menu=22,22:gtk-button=16,16"
change the line so it reads to:
# gtk-icon-sizes = "panel-menu=22,22:gtk-button=16,16"
and paste the above lines directly under the now blocked off lines of text. Save the theme and reboot to refresh the system and reload gnome-settings-daemon.
If the above seems too daunting you could also try just downloading the "AmbianceCompact" theme from gnome-look.org, which can be found here. Of course if you're having troubles with the above then the rest of this guide will probably be a nightmare for you! Still I recommend doing something with your themes to make them more compact!
It really makes a difference:
Remove unused panel applets...
Here's another annoyance. Shuttleworth in his brilliance surpassing mortal men has decided to break the system tra^^^notification area because it was inconsistent by...wait for it--making it even more inconsistent!
Just to make things more fun, if you try removing items the way it worked in previous versions of Ubuntu you can end up "losing" items completely unrelated to the one you removed!
Thankfully there is a way to remove stuff selectively if you follow the advice given by Didius Falco...
Didius Falco wrote:
If you want the "envelope" gone, remove the indicator-messages package, and keep indicator-sound (which is for the volume) and indicator-application installed. Don't remove indicator-applet, which is the host applet that all of the above plug into.
sudo aptitude purge indicator-messages
You may have to log out to make things show up or go away the way you want them to.
NOTE: This does not fix the spacing issues or the random movement of icons which seems to happen once in a while.
make panels customizable again!
One of the better features in previous versions of Ubuntu was the ability to set your own panel backgrounds. Then mysteriously the feature disappeared around the release of Jaunty or Karmic. Thanks to stinkeye you can customize your panels again:
stinkeye;9629583 wrote:
In your theme's gtkrc file search for panel
and look for a line that looks similar toCode:
bg_pixmap[NORMAL] = "panel.png" or bg_pixmap[NORMAL] = "panel_bg.png"Put a hash mark(#) in front of that line.
Your theme will be in ~/.themes or /usr/share/themes
If it's in /usr/share/themes you will need to edit as root.Code:
gksu nautilus /usr/share/themesLog out and Log in for changes to work.
Thank you very much stinkeye! You have no idea how much I missed being able to do this!
Now that we've gotten the GUI worked out a bit, let's move on to other things. We'll come back to making the mouse work as it did in previous versions of Ubuntu further on down...
Updates!
Apparently there are all kinds of issues in Lucid still being worked out and fixed. Who knew?
Now is the time to try to connect to your WiFi or plug in your ethernet cable. If using WiFi, you'll probably have to reconnect a few times by toggling the Fn + F2 key a few times if it doesn't connect right away. Keep enabling and disabling until you get somewhere, it'll happen eventually. (You're reading this somehow, aren't you?)
You'll notice there is a kernel updated listed in the update manager. When you install it WiFi becomes even more flaky. Oh joy! maybe we should try installing something else? I hear Red Hat Fedora works pretty good...LOL just kidding!
If you are doing this guide and reinstalling from a previous installation of Ubuntu Lucid Lynx you should have backed up your *.debs as recommended up above, otherwise you're going to be waiting quite a bit as Ubuntu downloads and installs updates...
Assuming that you have already copied the *.debs over to the proper directory or are prepared to download them all now, let's open Software Sources and add a repository which will fix our WiFi issues.
System-->Administration-->Software Sources
You will be asked for your password, enter it and the Software Sources applet will load, you want the tab that is named Updates.
You should see a screen like this one:
See how the Unsupported updates (lucid-backports) list box is checked? You need to check it also. Now click close and reload the repositories as instructed.
Once you've reloaded the repositories open the terminal and type in the following:
sudo apt-get install linux-backports-modules-wireless-lucid-generic-pae
The above package is a metapackage pointing towards the latest version of the wireless modules for the PAE kernel. Installing it will automatically add the linux-image-generic-pae package, another metapackage which will install the latest version of the kernel with PAE support. You'll notice this kernel is intended for systems with more than 4GB RAM according to Synaptic, yet strangely enough this is the only default kernel that has good WiFi support for my eeepc and I only have the stock 1GB RAM installed.
Before rebooting the eeepc you should probably add the wireless card to the modules list, so you'll want to run the following commands:
sudo gedit /etc/modules
At the end of the file add this:
rt2860sta
Save and reboot. Your wireless should be working again without issues.
It works. That's all I know. And much much easier than the older method endorsed by this guide, included below for completeness sake:
bornagainpenguin wrote:
WiFi doesn't work? Install the modules from Ralink!
For whatever reason the drivers for the RT2860sta WiFi card found in many netbooks was broken in the last few kernels. There are all sorts of reasons for this, but as far as I can see the chief one seems to be politics. Whatever. The fact is drivers do exist and the manufacturer has provided them, unfortunately you'll have to compile these yourself.
I am aware that an alternate kernel is available from Ricardo Salveti that works for some people. I never had any success with it though and there were reports of bad side effects. Also suggested as a possible fix is to update to the latest bleeding edge kernel possible. errr...yeah, I think I'll stick with the manufacturer's drivers even if I have to redo them every kernel release...
Fortunately there are guides for working around this long standing bug, including one from Fass over at Ubuntu Forums who walks you through installing the module on Intrepid. Sheesh! This bug really has been around for awhile, hasn't it? Thankfully there are more updated guides available we can follow...
Sven6210 (also from UbuntuForums) updates the instructions given by Chris Barker and fills in some of the information he glossed over. Namely what to do when one of the files mentioned by Barker gets a character encoding error! Thankfully Sven6210 walks us through it:Sven6210 wrote:
Here the description step by step:
Step 1
Download latest RT2860 driver source code from Ralink
Go to http://www.ralinktech.com/
Click on Software
Click on Linux
Download the driver "RT2860PCI/mPCI/CB/PCIe(RT2760/RT2790/RT2860/RT2890)“ dated 01/29/2010, version 2.3.0.0
You need to enter a name and an email and press accept to download
Step 2
Open and extract the downloaded file to your Home directory. Accept the standard folder and to not change the name
Open a terminal windowCode:
cd 2010*Step 3
gedit ./os/linux/config.mkUse the find command to locate HAS_WPA_SUPPLICANT and make sure it is set to y for yes. It should look like this when finished:
HAS_WPA_SUPPLICANT=yUse the find command to locate HAS_NATIVE_WPA_SUPPLICANT_SUPPORT and make sure it is set to y for yes. It should look like this when finished:
HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=yClose and save this file.
Step 4Code:
gedit ./common/cmm_wpa.cYou will get a message that the character encoding was not recognised, choose "Western“ and press "Retry“
Use the find command to locate MIX_CIPHER_NOTUSE. Replace with this code:Code:
WPA_TKIPAES_WPA2_TKIPAES;Step 5
Now we need to compile a new module, in order to do so we first need to install gcc and we need a network connection for that. So now you either need a wired or 3G connection to the internet.
Go to System
Go to Administration
Click Synaptic Package Manager
Look for "gcc“ and choose it to be installed
After successfully installing gcc please execute the following commands step by step in a terminal window.
sudo su make && make install sudo ifconfig wlan0 down sudo rmmod rt2860staStep 6
Rename the old rt2860sta.ko driver file to rt2860sta.ko.dist using:Code:
sudo mv /lib/modules/2.6.32-24-generic/kernel/drivers/staging/rt2860/rt2860sta.ko rt2860sta.ko.distAttention: If you are not for whatever reason using the 2.6.32-24-generic kernel you need to replace the 2.6.32-24-generic with the actual directory name of your kernel, please check the folder name with Nautilus.
Step 7Code:
sudo depmod -a sudo modprobe rt2860staAfter you issue the previous command you should see the Desktop top panel wireless icon come to life as it tries to connect. You will be prompted for a WPA password. Give it a little while and it should connect.
Not sure this command is necessary but you can use if the Wireless isn’t started automatically.Code:
sudo ifconfig wlan0 upStep 8
Okay at this point you have made a lot of progress and should be happily surfing.
But, and this is a biggie, what happens if you reboot? Unfortunately, you are back at square one without the RT2860 driver being loaded after a reboot. To remedy this situation, continue with step 9.
Step 9
cd 2010* cd os cd linux sudo cp rt2860sta.ko /lib/modules/2.6.32-24-generic/kernel/drivers/staging/rt2860/Attention: you need to replace the 2.6.32-24-generic with the actual directory name of your kernel if not using the one listed, same as step 6
Step 10
Update your modules boot file with the following command:
gksudo gedit /etc/modulesAdd the rt2860sta on a line at the end of the file and close and save the file.
Step 11
Reboot and check to see that you are now automatically connecting to your wireless network!
I hope it works for you as wellAs do I. I made some modifications from the original directions as listed, mostly by adding the exact kernel name as of this writing. If you updated like you were supposed to then there shouldn't be any issues here. You did update, didn't you? Otherwise as it says in the instructions, you'll have to navigate to the directory and see which kernel you're running.
Again, please note that this is no longer the way I recommend to get WiFi working; it is only included for the sake of completeness.
Make the mouse work right again!
Restoring the previous handling of middle-clicking links in Firefox
Randomly upon the release of Karmic 9.10 Canonical developers decided to change the two finger middle click that had been the default for well over two years and three releases of Ubuntu. Worse they removed any way to revert the changes. The only solution for many people on Karmic was to drop in a replacement module compiled by people on the Italian eeepc forums and hope an update didn't break things. Thankfully there is an easier way on Lucid, using a PPA.
Just add Yuri Khan's PPA to your system in terminal:
sudo add-apt-repository ppa:yurivkhan/proposed
Now update for the system to find the fixed gnome-settings-daemon...
sudo apt-get update sudo apt-get upgrade
Hit y to allow the update to download and install then reboot for the changes to take effect.
Back? Now you need to change an entry in the gconf-editor. Get the run box by hitting Alt+F2, then type in "gconf-editor" no quotes and navigate your way to:
/desktop/gnome/peripherals/touchpad
Then you will need to change the keys to your preferred handling:
Yuri Khan wrote:
Edit values tap_button_rt, tap_button_rb, tap_button_lt, tap_button_lb, tap_button_1, tap_button_2 and tap_button_3 as desired. These are, respectively: right top, right bottom, left top, left bottom, one-finger, two-finger and three-finger taps. (Corner tap settings are in Lucid version only. In Karmic, gnome-settings-daemon didn’t control corners.)
The values meaning is:
0: disabled
1: left click
2: middle click
3: right click
(If you feel adventurous, you might try 4, 5, 6, 7 (scrolling), 8, 9 (browser Back/Forward) but you don’t really want these on taps.)
If this works for you, please post feedback in the bug #563276. If it doesn’t… well, give feedback anyway, we’ll try to work it out somehow.
Thank you very much! This has been a life saver on my eeepc!
While we're configuring the mouse, now might be a good time to enable two finger scrolling again too.
System-->Preferences-->Mouse
On the Touchpad tab there will be an option to allow this click it and your mouse will function again like it had under the last several versions of Ubuntu.
Depending on your personal preferences you can also go to the General tab and enable the Locate Pointer option which will show the mouse position when the control key is pressed.
Laptop_Mode?
NOTICE: There have been reports of problems with this next tweak. I haven't had any issues with it on my eeepc 901L, but DavAlan reported having some trouble on his eeepc 900 after using this. Your mileage may vary...
DavAlan wrote:
Just brought my raid lvm install down earlier when the updater installed HAL for some weird reason (warning - the added "nohal download" line did not work out so well :S )
The following may be removed in an update unless I hear confirmation that the errors caused by HAL being installed despite the --no-install-recommends flag being used were a one time thing. I am including it for now for completeness sake.
Thanks to the removal of HAL it is a bit tricker to get Laptop_Mode_Tools installed. Also there will be a warning about removing the ""pm-utils-powersave-policy" package" which so far as I can tell can safely be ignored unless you were planning on writing your own power management scripts...
The command you want is:Code:
sudo apt-get install --no-install-recommends laptop-mode-tools sdparm ethtoolThe --no-install-recommends should prevent installation of HAL. All credit (and blame) can be given to the Doesn't Not Compute blog, where I saw this.
Power savings? Kind of...
scripts
Previously I had posted here a list of scripts by Axx83 from the Ubuntu Forums, but many of them were reported to be less than useful in Lucid and I didn't even enable them at all in the last few installs I did. If you still want them or feel that they make more of a difference than I think feel free to post and explain why and what your results are. For now these are no longer included directly into this increasingly large post. You can still find the original posting here. Bear in mind they were originally written for Karmic and may behave wildly differently on Lucid.
eee-control
Since the posting of this guide in its previous form, marx (Grigori Goronzy) has surfaced again with a new release of his application:
marx wrote:
2010-05-23 Version 0.9.6
Hi, I'm still alive!
Version 0.9.6 contains various bugfixes plus support for newer DBus APIs and Linux kernels. The deb package is designed for Ubuntu Lucid. A few rough edges remain, but everything works fine for me.
What's new:
* Disabled hotkey-setup/hotkey handling - now handled correctly out of the box
* Use upstart instead of sysv init
* Switched to UDisks and UPower DBus APIs
* Cleaned up eee-control-setup
* Misc fixes
Ubuntu package: Lucid (10.04)
Get the source code from Git: git clone git://greg.geekmind.org/eee-control.git && cd eee-control && git checkout 0.9.6
PS: Version 0.9.5 was supposed to introduce compatibility for Ubuntu Karmic, but was never released.
So now we know. I've installed the application and it works perfectly for me, triggering the WiFi, setting the powersaving mode automatically when the eeepc is taken off the power supply. If you're tied to Ubuntu this is an application you want installed!
Other power management options...
Since the last posting of this guide there have been updates to Fewt's Jupiter applet, which while no longer supported on Ubuntu is not explictedly hostile to it either. Packages and information can be found here. In case you were thinking of switching to Fedora, the good news is that Fedora is offcially listed as a supported distro by fewt! Just saying...
There is also a new one called entwjne written by eeeuser.com member Arvigeus. Unfortunately it is a commandline only application for the time being, but people wishing to help speed development along can help by beta testing. See entwjne here.
batteryStatus vs ye olde battstat
One of the more grievious removals in Lucid was the battstat applet which was more accurate an indicator on eeepcs than the default gnome-powermanager battery applet. In previous versions of Ubuntu this was only a few clicks away and could easily be added to your system tr^^^notification area. In Lucid Canonical decided to simply make it impossible to launch the applet despite it still being listed as present. If you were to open Synaptic and do a search for "battstat" (no quotes) you would discover it still listed in the information panel under the gnome-applets package.
Despite there being 192 people who went through the effort to create a Launchpad account, never mind the tweleve duplicate threads on this issue this guy has decided it is unneccessary.
Thanks alot Mark. You're a brick, a real... $#&* brick, pal!
Thankfully there are still options available:
perky wrote:
To install: Save and extract BattStatus.zip to a temporary directory, then cd to where you extracted the files and type:
sudo sh install.shGNOME Panel will reload and the applet should now appear in the 'Add to Panel' list as 'Battery Status Applet'.
Known bugs:
Most bugs are caused by conflicting gconf settings from older versions and can be fixed by:
[LIST=1]
[*]Removing the applet
[*]Running as regular user: gconftool-2 --recursive-unset '/apps/battery-status-applet'
[*]Re-adding the applet
[/LIST]
The error: ...OAFIID:GNOME_PythonPanelApplet... means that the OAFIID in the .server file does not match the last line in the .py file.
Installing the latest version fixes this.
Other distros display a default icon unless Humanity icon theme is installed (will be fixed when I get around to making my own icons)
Thanks to all that have helped identify bugs
Uninstall instructions:Code:
sudo rm /usr/lib/bonobo/servers/battery_status.server sudo rm /usr/local/bin/batteryStatus.py
If you do not have an account at the UbuntuForums you will not be able to download the applet. Here's a mirror:
http://www.mediafire.com/?fsq4ustr8iosvfc
Otherwise if you really prefer to use the old battstat that was included with every previous version of Ubuntu you can try this dirty hack:
I was able to "cheat" by going to the nearest Debian mirror and installing the appropriate gnome-applets AND gnome-applets-data for my version of Gnome. I ignored warnings that I was installing newer versions of the software than what was in the channel and after some dependencies were installed and I did a quick logout I was able to add back the battstat icon to my panel.
Here's a heads up for any Canonical developers: If you want to remove or "depreciate" a piece of system software, it's usually a good idea to make sure that the replacement works just as well as what is being removed...
What I did was go to:
http://debian.osuosl.org/debian/pool/main/g/gnome-applets/
Then download these two files:
gnome-applets_2.30.0-3_i386.deb gnome-applets-data_2.30.0-3_all.deb
Ubuntu Lucid demands that you have a later version of gconf2 and libnotify1 installed, so you'll have to grab those too.
Go to:
http://debian.osuosl.org/debian/pool/main/libn/libnotify/]
download this file:
libnotify1_0.5.0-2_i386.deb
Go to:
http://debian.osuosl.org/debian/pool/main/g/gconf/
download this file:
gconf2_2.28.1-3_i386.deb
Now from within the terminal navigate to the directory where you downloaded these files and enter this command:
sudo dpkg -i *deb
Do a restart and the battstat applet will be right where it used to be before developer stupidity caused Canonical to remove it from the distro.
Personally I prefer the older battstat applet, but am happy to see Perky's battery status applet being devloped and I have high hopes for it still being around even after Canonical manages to completely cripple battstat from working even with this typs of dirty hack.
NOTICE: Canoncial could invalidate this dirty hack at any time so if you are nervous you are best to just use Perky's applet.
Curb the heat by using the latest video drivers
Personally I'm still not convinced it is any one thing that causes the eeepc to no longer overheat, but a combination of little things that each reduce the heat bit by bit. Nevertheless I've been using this PPA also and have definitely seen improvements in both heat reduction and video playing.
Vredley wrote:
Oh, and one other thing - my 4G seems to be running a bit cooler since I installed the latest stable video driver from the X-swat PPA:
https://launchpad.net/~ubuntu-x-swat/+a … x-updates/
To do this you need to add the repository:
sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
Then you'll need to refresh and upgrade your packages:
If for some reason the xserver-xorg-video-intel package gets held back, you can install it manually:
sudo apt-get install xserver-xorg-video-intel
This will pull in the missing packages holding you back and allow everything to install. To see things take effect, reboot the eeepc.
Elevators
A few tips for improving battery via passing along options to the kernel in Grub2. Fair warning: the acpi_osi option may not apply to all eeepcs, although they have been very helpful to many users with eeepc 1xxx models! Your mileage may vary.
Any text editor will work at reading the below files. nano, kate, gedit, etc. You will have to be root or use sudo before the commands.
e.g.
$ sudo gedit /etc/default/grub
Grub
1. Change IO scheduler:Code:
elevator=deadline2. Use the integrated HPET timer (saves about 30 CPU wake ups per second)
hpet=force3. Make sure the eeepc-laptop kernel module is loaded properly (does not load correctly with kernel 2.6.32):
acpi_osi=Linux$ lsmod | grep eee # if nothing is listed, it isn't loaded
How to load the above in grub2:
/etc/default/grubCode:
GRUB_CMDLINE_LINUX_DEFAULT="acpi_osi=Linux elevator=deadline hpet=force quiet"# update-grub2
I've also seen reports that elevator=noop is a good option to use instead of elevator=deadline.
I recommend changing the grub2 configuration to wait a few seconds while testing these tweaks to allow you to edit them out if they prevent booting. to do that simply make the following changes:
Where it says GRUB_HIDDEN_TIMEOUT=0 add a "#" in front of it to allow the count down to work again.
# GRUB_HIDDEN_TIMEOUT=0
Then change the count down from ten seconds to something smaller, like three or two if you're fast enough to hit the keys before it starts. You can do that by changing the number here:
GRUB_TIMEOUT=10
GRUB_TIMEOUT=2
Save the file and as instructed above don't forget to update the configuration!
sudo update-grub
Reboot to see the changes.
Still to do and errata...
I'd like to add a small section on what can be removed for space saving reasons and lack of usefulness to the average user. Things to include here are fspot, brasero, tomboy etc. Usually I just use the guide here, but it is sadly out of date and much much care needs to be taken with this or users will find themselves without a network manager installed!
More tweaks and something on the benefits of using Nautilus Elementary:
Next version...
I want to investigate adding Konstantinos Natsakis' repository as a possible solution to the theming issues mentioned above. Depends on whethe ror not it actually solves the problem.
I'd still like to explain how I set up my /data with symbolic links and hopefully have a better way to do it than I currently use. I had a thread open on UbuntuForums on the subject, and the guy responding was great about trying to help me figure things out, but unfortunately much of what was posted went waaaaay over my head. Maybe someone from the eeeuser.com forums can take it and run with it?
Would like to know if there is a good way to back up and restore a music collection and podcast directory like can be done in iTunes, but using Banshee or Rhythmbox? If there is it should definitely be added to the guide for those of us who distro hop!
Feel free to suggest items to add for future versions!
Hopefully this will be of use to someone. Considering it has taken me nearly an entire day to do, I certainly plan on using it myself in the future... Nice to have all the information in one place, you know?
--bornagainpenguin
EDIT - added panel customization tip
New guide up and available!
--bornagainpenguin
This thread also seems to be a bug(fix) for Fn keys on a 1005HA.
I've got my USB LiveCD image ready, but I think I'm going to wait until later in the day to see what else has popped up here by then...
JK
Edit: I'm toying with the LiveCD on my 1000, and Fn keys and wireless seem work without any further setup. Firefox seems quite quick, too. I got a crash from gnome-panel before long, but it doesn't seem to have amounted to anything. The third comment on this blog post has a possible fix for the button location which I'll try as soon as I've installed Lucid to my hard disk. I'll also try Flash, since that's my biggest complaint about Linux when it comes to typical usage.
Edit2: Okay, I can vouch for moving the buttons. Just go to Apps / Metacity / General in gconf-editor and change button-layout to "menu:minimize,maximize,close". Actually, you can toy around with it to any other strange combination you might like! I'm not sure why the ability to change this isn't in GUI though. (At least, I couldn't find it.)
I've also installed Flash on my USB image, and wow, playback of YouTube videos is a bajillion times better. The Modern Warfare 2 Launch Trailer was smooth in 480p, although it suffered when I went fullscreen or tried the HD (720p). The interface is generally quite quick, so I'll probably be installing to my hard drive this afternoon. ![]()
Visual effects are disabled and greyed out. This is happening with Netbook Remix on a 1000H and on a 1005PE.
On 9.10 I had Visual Effects available and set to Extra. And they worked pretty well.
Do you have this problem also? How to turn it on?
There is, it's called Ubuntu-Tweak! ![]()
--bornagainpenguin
PS: Any ideas on what do do for eee-control? It isn't doing cpu\fsb scaling for me at all on my eeepc 901 Linux, and the heat on the left side of the hand rest is starting to concern me. The grub lines (acpi_osi="Linux") don't seem to do anything for me, of course I'm on the 901, not the 1000 or higher models which seem to primarily have that fix working for them...
Thanks, nice collection of tweaks. I've been running Lucid on my 7014G since the first Beta release, and I'm pretty pleased with it so far.
Not sure what animations I'm supposed to be seeing with Plymouth, so I haven't messed with that - but I do like the boot time.
I had already tweaked the icon sizes and moved those pesky buttons back "where they belong" ![]()
I used your suggestion to get rid of the Empathy/Evolution/Gwibber/Whatever icon. I hadn't quite figured out that new indicator applet, so your link was a big help there.
Thanks again!
Chuck
Glad to be of service!
I had no issues with Visual Effects in Gnome on my eeepc 901, but that doesn't have the same video as the 1000 series do. I assume you've looked in the Ubuntu Forums already?
--bornagainpenguin
thanks for the tips! good stuff and much appreciated...
having an external bootable DVD makes experimentation much easier on my 901 and 1000...
but getting UNR 10.4 was annoying with the lack of a torrent link at the main download page (WTF?)
and not really that impressed, as UNR 10.4 doesn't seem as inclusive or polished at Crunchbang Lite...
lacking codecs as well, and no Skype (although advertised as such)
i'm look forward to EB4.0
I would like to know what are your experiences with 3G mobile broadband dongles and Lucid. Do they work? My Huawei E220 isn't recognized and I haven't got internet connection no matter what I have tried. With Jaunty everything was so nice and easy, but after that it has been continuos struggle for me to get mobile broadband connections work. I just can't take it anymore. I'm looking forward to EB4 too...![]()
Nice to see all these fixes listed in one place.
The gentoo wiki has quite a nice guide to power management on an eeepc via command line. It's instructions are perfectly compatible with ubuntu with two minor points. You need to be logged in as root in order to run the commands (sudo -i) and if you want to activate wireless power-saving you need to remember that the wireless connection is now referred to as "wlan0" in lucid, not "ra0".
http://en.gentoo-wiki.com/wiki/Asus_Eee … Management
There are probably multiple options to make these changes permanent. If you want to save power all the time you could just add "echo 2 > /sys/devices/platform/eeepc/cpufv" as a start-up application and then switch to performance mode when needed (e.g. flash videos). Personally though I use the "laptop-mode-tools" package.
http://ubuntuforums.org/showthread.php? … ttery+life
I solved the problem with the Visual Effects not available. Compiz was not installed.... After installing itverything is working as expected.
My 3G dongle was recognized (Portugal TMN) and works <flawlessly (better than the windows drivers
. I gave up on 9.10 because of that, so its a pleasure to see it working great.
I gave up on Netbook remix and installed the full release. I was fed up with the interface and a lot of stuff missing. I prefer the real estate of the full version.
Right now Im after a strange problem with wifi. I have a n router and a g router in repeater mode. I can connect with the g router no prob, but the n router isn't accepting connections! No need to say that every other stuff around connects with both routers no prob, This problem also happened while I had the netbook remix installed but I managed to connect. Now with the full release didn't connect yet....
Keep on trying to solve it.
Also I'm noticing now... a enormous lag of the keyboard while I'm writing this post. Totally stops responding and buffers the strokes for several seconds...uuummmm...!
Just saw this mentioned in the comments on DistroWatch.com...
Jesse wrote:
Lovely. So what you are saying is that it looks like *buntu regularly calls home, just like the rest of the corporate shovelware OSes. How "helpful".
No, I'm not saying that. What I said was the service is doing something in the background. It could be checking for folders to sync, it could be monitoring file system changes, it could be aggressively polling for status changes. Or, maybe it is contacting the One servers. What I was saying is it was doing something when I felt it should be idle. I'm not certain the One service was accessing the network, but it was churning on the CPU.
Could someone with Lucid on their eeepc try disabling\removing UbuntuOne and report back if this makes any difference with CPU scaling or with how hot the handrest gets? I seem to recall similar issues with Tracker when it was first introduced in Gutsy or around-there-abouts and people reported the service was constantly polling and causing issues. Could this be a similar issue with UbuntuOne? The fix then was in removing the application and services, it could be again for this...
--bornagainpenguin
/BUMP for update --added WiFi information
I'm having some transfer speed issues in ubuntu lucid with sata power saving. As I already have fitted in a ssd, can somebody with 1005P/PE, hdd, ubuntu lucid and some linux experience please try the following as root and report the results.
echo medium_power > /sys/class/scsi_host/host0/link_power_management_policy
hdparm -t --direct /dev/sda
hdparm -t /dev/sda
echo min_power > /sys/class/scsi_host/host0/link_power_management_policy
hdparm -t /dev/sda
Could someone with Lucid on their eeepc try disabling\removing UbuntuOne and report back...
--bornagainpenguin
How to do that?
--bornagainpenguinHow to do that?
You can try to uninstall indicator-me.
cobra11 wrote:
What about EEE-control program? Anyobdy gets worked it in lucid?
I've had some people tell me it runs fine if they use the eee-control from this PPA, but although it installs I've not had much luck with getting the ACPI events to work in eee-control, or the CPU\FSB scaling to work automatically. I'm not even sure if it does anything if I manually set the performance to power-saving or not...
You can give it a try and report back if it works for you. I know that if you have an eeepc 1000 series or higher you need to add acpi_osi=Linux to your grub, like so...
and locate string:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Change this to be:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux"
then make sure you run update grub:
sudo update-grub
After rebooting the eee-control applet should just work, according to what others have told me.
I think it should be possible if you do this:
sudo apt-get purge ubuntuone*
Then remove the various (now) unneeded dependencies by running apt-get autoremove, like this:
sudo apt-get autoremove
Assuming everything went okay, you can check to be sure there isn't a UbuntuOne service still set to start at boot by disabling it in "Startup Applications" like this:
Menu: System → Administration → Startup Applications
Uncheck UbuntuOne if it is listed. Reboot, and then see if the eeepc is running hot or if it seems there is unneeded activity going on in the background making the CPU stay active even on idle.
--bornagainpenguin
There seems to be a ubuntuone-client-gnome package...also I see one can remove Ubunto One from the software manager GUI.
sudo apt-get purge ubuntuone*Then remove the various (now) unneeded dependencies by running apt-get autoremove, like this:
sudo apt-get autoremoveAssuming everything went okay, you can check to be sure there isn't a UbuntuOne service still set to start at boot by disabling it in "Startup Applications" like this:
--bornagainpenguin
Note the bits in bold? My apologies to those with Lucid installed who were confused at this bit of advice...that should've been:
Menu: System → Preferences → Startup Applications
In my defense all I can say is I did not have access to a Lucid box at the time I wrote that post...sorry!
Meanwhile I've reinstalled Lucid on my eeepc 901 Linux and have removed the ubuntuone packages with the command above, then I did a search for ubuntuone in synaptic. I found there was a package installed that mentioned couchdb (evolution-couchdb), which is somehow tied to the ubuntuone system. I removed that and did a search for couchdb, removing all those packages too.
WARNING: removing couchdb will also remove gwibber and the various social media aspects, know this going in and do not whine about it if you remove couchdb and find gwibber gone too. You have been warned!
Meanwhile I allowed synaptic to remove those packages and rebooted. The handrest feels much much cooler to me, but that could just be the placebo effect. I will keep using the system and report back. As far as I can tell it DOES make a difference though.
I would love to hear what others feel is the difference (if any) after doing this also!
--bornaginpenguin
Does anyone have some instructions how to UNINSTALL the a failed rt2860 driver installation? As on 9.10 the drivers aren't working for me, loading the module fails.
But now after having made "make install" and so on, my eee 1008ha does have some process running in the background the whole time, thus the loading icon won't stop turning back into a mousepointer and I can see the processing icon blinking like every second. Reboot doesn't help.
EDIT: Nevermind, figured it out but still -
EDIT2: Ok uninstalling the driver's didn't help anything. My eee is constantly loading, whatever it is ARGH.
Apart from that the fn shortcuts don't work for me anymore.
Okay it's been a couple of hours now and I can say with some certainty that removing ubuntuone and couchdb does reduce some of the constant CPU polling and reduce the heat. I came across an interesting post on the ArchLinux forums about another possible factor while trying to figure out the lack of CPU idling in Powertop. You can see that thread here.
The executive summary is that a process in the kernel intended for ext4 journaling is spamming logs on the disk causing the cpu to be unable to idle. I've reinstalled Lucid as ext3 instead of my usual ext4 whenever I've tried it out and have noticed a major reduction in heat. Would appreciate if others could confirm these results for me!
--bornagainpenguin
Is this potentially a lifetime issue for the SSD? i.e. if ext4 seems to be writing so often, will it wear out the SSD more quickly?
JK
--bornagainpenguin
can you isolate what process in the kernel is doing this?
im using the newest kernel (2.6.34rc6) and my system gets pretty hot as well, i would like to know what process causes this problem so i can disable it and see how it helps.
Any tip for fan control? It's reached near 80ºC without a fan response.
I'm running Ubuntu10.04 on a 900 eeepc, kernel 2.6.32-22-generic-pae.
Thanks for the tweaks!
