#1 2007-10-29 6:42:29 am
TechKing
Using file compression to decrease Windows size
nLite can reduce the Windows installation size quite a lot. However, I'd like to let you know that you can use file compression selectively on installed files to further decrease the install size by several dozens of MB, if not another full 100MB less.
The trick is to try to compress only files that are used less often, such the folder c:\windows\system32\dllcache. Folder size was decreased from 349MB to 215MB on disk. I don't really want to completely wipe out the folder so its a safe alternative.
To use compression, right click on a file/folder and select Properties/General tab/Advanced button/Compress contents to save disk space.
#2 2007-10-31 6:04:50 am
Triple-E Wannabe
Re: Using file compression to decrease Windows size
Good idea! At the cost though, I would think, of a CPU overhead for on-the-fly decompression when those files are required. I take it this is why you advise to only do it on seldom-accessed files?
...and the black 4G!
#3 2007-10-31 11:46:02 am
TheBronze
Ya, I would stay away from using compression. The idea of this machine is small and fast. Compressing files is just going to slow things down. But, then again, that is the windows experience we are all used to, isn't it!?!
#4 2007-10-31 9:42:15 pm
TechKing
File compression slows down file access for that compressed file in particular. The is a lag time between file access and file execution/reading because the CPU has to decompress the file before being able to access it. That is why files that are commonly used (.exe and .dll) should probably not be compressed. There are however lots of files in Windows that you may want to keep. For example, the files in c:\windows\system32\dllcache are almost never accessed, but are still quite essential in case you computer crashes while you're away from home and don't have access to your Win CD. I have therefore compressed these files.
Other exemple of files that you may want to compress are .hlp files. I never read help but once or twice a year, I need to read them so I can compress these files without everyday performance slowing.
If you compress completely Windows's folder, then you'll run into serious performance issues.
#5 2008-02-15 10:15:26 am
ddlooping
Hi all smile
Yesterday I used the Windows compression on the whole "C" drive (SSD).
Result (used space):
1,167,630,xxx bytes => 795,590,656 bytes.
1113Mb => 758Mb
So far I have not noticed any slow-down during normal use.
Actually, the boot time seems to be slightly shorter!?
If my understanding is correct, any file subsequently added to the compressed drive will automatically be compressed. That includes program files.
Could our 4Gs become 6Gs? big_smile
If you want to follow a similar topic in French:
http://www.blogeee.net/forum/viewtopic. … amp;t=2477
#6 2008-02-15 10:46:17 am
san.salvador
Compression can even encrease performance (less data to read), so I use it and it works like a charm. smile
#7 2008-02-15 11:56:27 am
Molly
EEEmazing User
care to elaborate on how drive compression will affect the amount of data to be read?
Eee PC 701 4G Blk, 405-990 MHz, 2 GB Corsair DDR2 RAM 667 MHz - Custom XP Pro SP3
#8 2008-02-15 12:26:23 pm
DaveS
I think that I can see both of your points?  Of course, in the end the amount of data must be exactly the same with lossless compression( necessary in this case), but the amount of data transiting the medium interface will be less by the amount of compression. That is why it is used in some serial data link protocols.  However, for any possible speedup to occur the decompression time would have to be shorter than the time for uncompressed data to cross the data link.  Perhaps it would speed up a USB connected FLASH read, but I would expect that the SSD read would be fast enough to probably make the decompression phase the actual bottleneck?
--Dave
#9 2008-02-15 1:43:16 pm
Anarethos
I did compress
c:\windows\Driver Cache
c:\windows\help
c:\windows\inf
c:\windows\java
c:\windows\Microsoft.Net
c:\windows\mui (I use the french language pack)
c:\windows\winsxs
c:\windows\system32\drvstore
c:\program files\Java
c:\program files\Microsoft Office
c:\MSOCache
ALL DLL on the SSD.
Not slow at all. Saved me more that 300 mb.
Asus EEE 900HA - 2gb RAM
Windows 7 Ultimate
[Old EEE 701 Surf and Aspire One 150 user]
#10 2008-02-15 1:50:25 pm
Fluffywings
Well assuming we don't want to compress the entire drive, it would be a good idea to make a list of the folders that are rarely accessed to be compressed.  For example.
C:\windows\inf
C:\windows\ie7
C:\windows\ieupdates
#11 2008-02-15 5:54:01 pm
FrenchMatt
On the French link it is mentioned - and I had forgotten about it - that the Asus Intructions Manual suggested compression indeed. As for me I will not try since I have enough space after a clean Windows installation (more than 2.3 Go) and my programmes are on a SDHC. My data on a USB key so... smile
French user : white Eee 900 12G XP - 333-972 mHz - Corsair Value RAM 2Gb - Kingston SDHC 8Gb - My photos
#12 2008-02-17 12:31:18 pm
robbynaish
Hi to all,
in my Italian Xp pro, i dont find such choice. WHere i do mistake?
http://img178.imageshack.us/img178/994/11111yy1.jpg
thanks
#13 2008-02-17 12:52:46 pm
ddlooping
Good question, robbynaish, it does look like I can only compress entire drives or partitions too using this method.
How did you guys manage to compress files/folders?
Edit: found it!! You have to click on "Advanced..." to have access to the compression option. smile
Edit 2: robbynaish, it looks like you are missing the "Advanced" button.
Maybe you need to be logged in as administrator?
#14 2008-02-17 1:00:37 pm
The Coolest
You need WinXP with service pack2 and all the latest updates.
EEEPC Tool
EEEPC Tool v2 - In development
#15 2008-02-17 1:01:56 pm
ddlooping
Thanks for the info, The Coolest. smile
#16 2008-02-17 2:45:07 pm
tyau
Fluffywings wrote:
C:\windows\ie7
You can essentially delete these two folders if you do not plan to rollback to ie6.
After you have deleted these two folders, use ccleaner to clean out the uninstaller registry related to ie7 uninstallation.
4G 701 OCZ 2GB DDR2
Internal USB Hub mod, bluetooth, 16GB Flash, SDHC reader
#17 2008-02-18 4:45:51 am
robbynaish
I have Sp2..... can i update only this thing i need,or i have to update all?
thanks
alex
#18 2008-05-15 7:19:48 am
rodneyh
I compressed the whole drive including system32 folder.  Some files did not compress, I suspect because they were in use at the time or windows prevented it.
I have encountered the occasional problem where dll calls have failed.  I found that I needed to uncompress the following ddl's:  wiashext.dll, asycfilt.dll and shgina.dll.  There may be more that I have not come aross before.
Has anyone encontered any similar problem?
I have not particularly noticed any severe performance penalty.
#19 2008-05-15 8:00:21 am
Windkracht13
I have compresed the hole C: , No problems at all...
#20 2008-05-15 9:53:36 am
ddlooping
Welcome to the forums, rodneyh. smile
I have also compressed the whole C: drive and haven't encountered any problems.
No noticeable slow-downs either (2GB ram).
#21 2008-05-15 10:04:59 am
treare
Compressed whole c: on my eee. Overal it indeed doesn't slow down but sometimes opening things has a small delay though.
#22 2008-05-15 10:10:17 am
ddlooping
treare wrote:
Hello treare,
I personally think a fraction of a second delay in opening certain files is not a bad trade-off considering the gain in space. wink
#23 2008-05-15 10:17:08 am
treare
Aloha,
Certainly true but was just FYO smile
#24 2008-05-15 11:09:49 am
Molly
EEEmazing User
in the end, it's all about personal preferences, but file compression does cause an increased CPU usage (up to 3%) which has an impact on the battery life time and overall system performance. file compression also will increase the number of write requests on the SSD by 25%.
implications that have been acknowledged and addresseded by Microsoft recently in their 'Guidelines for Designing Flash-Based Ultra Low Cost PCs for Windows XP".
http://download.microsoft.com/download/ … SFT%20.pdf
#25 2008-05-15 11:13:14 am
SteveLawUK
Doesn't wear levelling work better with more free space?
2G Surf - "A cracking little machine."
If it ain't broke, don't fix it.
