Pages: 1
I have been reading a lot of information about the temperature of the eeepc, people overclocking, people running fanless and people complaining about the temperatures and teh noise of the fan etc, it seemed that there were two groups, one with cold eeepcs and other with extremely hot eeepcs. Here my findings and experience:
I have a green 4GSurf.
The eeepc has 2 ways of cooling, one passive and active, the pasive is the metal bay under the keyboard, the active is a fan under the board where the cpu is located.
The range of temperatures for the fan running are:
. - 54Celsius no active cooling
54C - 66C The fan is turned on in a quiet mode
67C - . The fan is turned on in "noisy" mode or fullpower.
Once the fan is turned on the temperature triggers are different:
- From noisy mode to quiet mode the trigger is around 58C
- From quiet mode to turn off is around 45C? I dont know this one as I have never been in this situation
With a room temperature of 22C and surfing in pages without a heavy flash load:
The normal temperature of the eeepc after 10 minutes is between 55C and 60C
The normal temperature of the eeepc after 1 hour is between 55C and 60C with peaks of 63 in periods of 10 seconds maximum and going under 60 strait away.
With a room temperature of 22C and doing heavy work (seing videos in youtube for instance) after 1 hour of using the eeepc it can reach to peaks of 64C but it seems very difficult to reach this mark.
With the eeepc overclocked at 900MHz and doing heavy work (for instance seing videos in youtube) the 65C mark is reached before the first minute, and the 67 mark (when the fan is turned on in full power)is reached before 2 minutes (having had the eeepc turned onn for 1 hour before the test). with the fan to full power it seems that is able to stop the temperature around the 68C not rising anymore
I hope this will solve some questions to people because I read some people saying that were reporting having normal temperatures well under 50C in normal conditions, something that scared me as my eeepc reaches the 60C in normal conditions without heavy work after one hour. Also I saw people saying that they would never allow their eeepc go higher than 65C in the overclocking test as it was dangerous, but now we can say that 65C in the eeepc is perfectly safe as the fan has a "full power" mode that is triggered at 68C and if they programmed that trigger is because they expected the eeepc to reach that temperature or even higher temperatures (for most of us we are yet in winter, lets see during the summer)
I hope this is useful for people like me that were worried to have the eeepc 10C hotter than normal laptops and what it seemed a "useless" fan, now I dont think it is so useless after seing it running in fullpower mode at 68C.
For people having the noisy fan problem I wonder if the problem is that their fan runs into fullpower at the 54 marc instead of the quiet mode, maybe it is a problem of the wiring of the fan?? a bios problem?
For people running fanless I would say that they should be carefull reaching the 68C and that the fan is not so useless when you heard it running in full power mode as it seems when it runs in quiet mode.
PD: My fan is not at all noisy in quiet mode, but it is loud enough to heard it at 2 oclock in the morning in a small room, but not loud enough to be heard in a library.
Can any of you confirm the triggers I put with their own experience? I have double checked my tests, I monitor the temperature with the gkrellm
Props for this mate, I'll have to check when i have some time
Yes, I can confirm your measurements. From the fan speed table in the embedded controller (the chip which controls the fan), the thresholds are:
55C and below: fan off
56C to 68C: fan at 40% of full speed
69C to 80C: fan at 65% of full speed
81C to 90C: fan at 80% of full speed
91C and above: fan at 100% of full speed
Once a threshold has been reached, the temperature must fall by 10C for the speed to drop back to the previous level. So the fan is at 40% when the temperature gets to 56C but won't turn off until the temperature drops back down to 46C.
Thank you for this - very formative and thorough. Sticky please!
The intel literature states that the max operating temp of the cpu is 90c so I'm confused over kiwidrew's chart. The cpu will start to throttle down at 90c to cool it'sself. If it cannot, it will SHUT DOWN! 90c is too hot, so how can the fan wait untill 91c to run at 100%. My experience based on gkrellm is a mirror of that of bulltza's exactly. I have run mine 100%cpu load for 1 hour at an fsb of 115!!! the cpu was runnning at over 1ghz. The fan stops temps in their tracks at 68c. I am not able to get any higher than that. Well within the safe zone.
I thought intel's M line has a limit of 100C but the celeron may be different. My laptop with a 1.86ghz pentium M is in the 80s and 90s all the time during heavy usage.
I'd feel really uncomfortable with a laptop CPU reaching more than 70C (and not just talking about my lap). Desktop CPU's tend to throw errors around 70C, and while laptop processors generally have a higher tolerance, it's still not good for the CPU in terms of lifespan and wear.
TacticalPenguin: How did you get a 1.86 Pentium M to hit 90C? I have a (older) gaming notebook with a 2.13ghz Pentium M, X700, and all kinds of other heat generators and even when gaming I've never seen it break 75 or so. I'd be worried about my laptop at temps of 90C.
juaqin - well uh i might have a fan control program running often and oh idk i usually set it to lock in silent speed and then oh idk forget to unlock it and then have it working at max speed for oh idk like an hour... lol
Haha, I see. Well, if it hasn't blown up yet... ![]()
I used this module on my 8G. Under Ubuntu I ran the hardware profiler and benchmark application
Before:
Compressing 64MB 6136.958
After:
9165.073
higher number is better
After all day running at 900mhz the internal sensor is only reporting 59 C
This is pretty good information, should be in the wiki! also for the fanless people
kiwidrew, congratulations for the recently achived "manual control" of the fan under linux, that work is very much appreciated!
The problem with EeePC's fan (at least in my unit) it's far too loud. Other 15" notebook which I use takes much more power yet when considering a fan it's quiter. I couldn't get my EeePC to be hotter than 70 degress even running fanless and at 900MHz.
Perhaps thermal sensor has a tolerance?
Pages: 1
