#1 2009-08-10 6:16:27 am
nicolaerugina
Transfer Original Asus CD to USB and recover the System from USB
For many of us it is dificult to have a CD/DVD external drive at the time when we want to reinstall the Windows XP system from the Original Asus CD (a Ghost Image).
Here are the steps to transfer the Asus CD  to USB (or SDHC) and to install from. You will need at least a 4GB USB Flash (or SDHC)
Only format the stick on FAT format (not FAT32) using the HP USB Disk Storage Format Tool : http://www.eocfiles.com/bdc86eb1ed2989c … P27608.exe
Copy all the folder (without Software) from the Original (Ghost 9.0) Disk onto the memory stick.
Rename \I386 file to \minint
Copy the file \minint\NTDETECT.COM to the root folder of the memory stick
Copy the file \minint\SETUPLDR.BIN to the root folder and rename it to NTLDR (without an extension)
You are done.
Now, when your pc it is on boot screen, hit tasta ESC to go on Boot option and chouse your USB (or SDHC).
Enjoy
Eee PC 1000HE | 64GB SSD Samsung | OCZ 2GB 800Mhz | Windows XP SP3, Windows 7, EEEBuntu
#2 2009-08-12 8:42:16 am
KneeOn
Re: Transfer Original Asus CD to USB and recover the System from USB
Its not bootable... how do you make it bootable?
Using an 8GB memory stick with a 3.91 gb partition formatted to FAT.
EEE Pc 701SD, 8GB SSD, 630Mhz, 512mb Ram, Black, running Windows XP with eeebuntu standard running off my 8gb memory stick!
Elonex One T+ 2GB SSD 335Mhz MIPS, 128mb Ram, white, running 3MX Linux distro - the worlds worst laptop according to Engadget. I theme it!
#3 2009-08-12 10:55:13 am
nicolaerugina
Just format using HP USB Disk Storage Format Tool on FAT and check the quick formay.
After that, like I say, copy all the folders. You can copy the software folder, because on 8GB will fit.
Rename "\I386" folder to "\minint"
Copy from the  \minint folder the NTDETECT.COM file to the root of the memory stick \NTDETECT.COM
Copy from the  \minint folder the SETUPLDR.BIN file to the root of the memory stick \SETUPLDR.BIN and rename to NTLDR (without an extension)(please, uncheck from explorer, tools,  folder option, view the "Hide extension for known file types" to can see and delete the extension *.BIN)
Again, please COPY not CUT!!!
From the boot order menu, chouse your USB stick.
And is done!!!
#4 2009-08-12 11:55:31 am
KneeOn
Yes, that was my bad. I didn't have a HP stick so thought it wouldn't work. Thanks. Trying it out now
and i'll format to NTFS. Beacuse FAT only goes up to 4gb size. I have 8 so it won't work otherwise
#5 2009-08-12 12:31:51 pm
KneeOn
Nope. Just goes straight to boot from the SSD. sad
#6 2009-08-13 12:57:46 am
nicolaerugina
You don't need a HP stick. U can use any memory, even the SD SDHC.
You must find a support to can accept FAT format. Will not work on other format.
And try to disable the fast booting from Bios. Like this you have time to hit the ESC during boot screen to get the booting order menu.
#7 2009-08-13 3:46:01 am
KneeOn
I can get to the boot select screen. I can't format it as FAT because its an 8gb stick.
#8 2009-08-13 6:51:05 am
nicolaerugina
Try with a SD or microSd up to 4 GB. It will work, Or if you have a USB stick up to 4GB.
Borrow one and if it's work (and will work) buy one, the cheapest one.
#9 2009-08-13 9:44:38 am
KneeOn
So it can be a maximum of 4gb. Will it fit on a 2gb?
#10 2009-08-14 1:04:38 pm
nicolaerugina
I don't try, but you can, copy with out drivers folder. and see what something else you can take out to fit on 2Gb. but the main important file it is \I386.
#11 2009-10-08 7:59:14 am
Burriello
I have a French dictionary on CD, and the program needs to have the CD in the drive when you launch the program (afterwards you can take out the CD from drive and the program works), but as my EEEPc has no CD drive attached to it permantly, how can I pass the CD to a USB strick?
#12 2009-10-08 8:18:51 am
nicolaerugina
You can create an image of that CD, copy the image on USD and use VirtualCD or any other program which allow you to month a virtual CD and run the CD (the image of your CD) from USB.
#13 2009-10-16 12:54:54 pm
sledwards
This is my first post. I have just bought a 1005HA P series netbook and I also bought a 4 GB USB stick to use in place of the DVD provided for backup. I followed the above instructions and ran into two major roadblocks. First, the HP utility would not allow FAT formatting, only FAT32. Second, I knew the space would be tight so I tried to copy the restore DVD contents minus the Software folder to the USB stick. It wouldn't fit - I got a drive full message near the end of the copy process. I would appreciate any input on these issues. For example, could I also not copy the Drivers folder, or any other of the folders? Any assistance would be gratefully received!
#14 2009-10-16 4:20:00 pm
josepfg
Hello;
I made the process , the program run, but went I tipe the ok appear the next message : can not find recovery DVD.
Can you hepme?
#15 2009-10-17 1:42:33 am
zeo
EEEmazing User
Alternate method, just get a 4GB USB and download. . .
Windows 98 System Files
HP USB Disk Storage Format Tool - v2.1.8
Norton Ghost v11 (Mirror:: http://rapidshare.com/files/207687854/GHOST.rar )
Then extract the Windows 98 Files and then install the HP Format USB utility.  You can then launch the HP Format USB Utility and select to make a dos system disk.
From there select the source folder of the files to include, click on to browse then locate the folder where you extracted the windows98 boot files to. Once that's done click on start then select yes on the warning message to make the USB bootable.
Now just copy the Ghost.exe app you downloaded to the USB and from the Recovery DVD just copy the "EEEPCAH.GHO" file to the USB and you're set to install the Recovery on your Eee PC.
Basic procedure is to put the prepared USB into a free USB port and when starting up just hit Esc key to get into the BIOS boot menu and choose the USB.  You'll boot to a Win98 Dos Command prompt.  Alternatively you can hit F2 to enter BIOS and change boot priority/order to USB.
Once at the command prompt just type Ghost to run the Ghost.exe program and you'll enter the Norton Ghost GUI interface.  The 2nd drive on the list should be your new SSD, select it and run. . . 10-12 minutes later and you're done.  Don't worry if you don't see the resulting installation since DOS can't see NTFS partitions.
Return boot to SSD, if you changed it, and then boot normally.
#16 2009-10-17 2:20:21 am
nicolaerugina
HP utility it is made to can format also on FAT only!!!!
Yes, you can copy only the Windows xp file!!!
#17 2009-10-17 6:11:21 am
0sm0sis
lol
Uh... that's exactly what they did... scary how 98 haunts us to this day. 98se *shudders* I used it... sad You should sticky post this or something. Even I understood that...hmm
--==<(Eee PC 900(0S)Win XP Pro SP3+(M0)RunCore 64GB SSD(SIS)LG Slim GSA-E50L)>==--
Recent Post
#18 2009-10-17 6:49:51 am
zeo
EEEmazing User
I didn't invent that method, just summarized it, and it's up to the mods, they can't sticky everything but this does seem to be turning up a few times lately. . .  besides telling people to not post their emails tongue
@nicolaerugina - HP USB Disk Storage Format Tool - v2.1.8 supports FAT16, FAT32, and NTFS.  You can actually use FAT32 in most cases, and only have to limit yourself to FAT16 if what you are installing requires it or you're working with an older computer with a BIOS that may not support the newer formats.
#19 2009-10-19 1:26:14 pm
sledwards
I tried zeo's solution and it seems to work fine. I was able to get to the Ghost GUI and choose the drive. I have a 1005HA P version with a 160GB hard drive. Would anyone know if the restore also recreates the hd partitions (including the xp recovery one)? Also. in the DVD restore folder there were two other files - envir.gho and envir.cmd. I copied them to the usb stick as well. Is that OK?. Thanks, zeo, for your suggestion.
#20 2009-11-22 11:43:57 am
blimeyguv
Hi there. Mr n00b here.
Last week I got my shiny new 1005ha, and after stripping all the **** out of XP, updating, config'ing etc, I installed Norton Ghost 9 and took an image of C to an external drive. This is so that if I ever do have to recover, I can restore my image rather than the factory default image.
Of course, my n00bishness caused me to be blind to the fact that I cant recover using the NG9 disc unless I have an external CD-ROM drive. Ouch.
I have been googling for two days in trying to get the method as described in the OP to work. Even when using a 1gig FAT-formatted stick (using the HP tool) and following the instructions, it's as if when I select the USB key for boot, the eeepc doesnt even find the boot sector that is apparently created by the HP tool and so just carries on booting into windows. So today I found an old 98 machine at work, and created a dos disc with my USB key, stripped out the files it put there (but leaving the boot sector intact) and then proceeded to copy over \I386 etc etc. Now it recognises the USB drive as being bootable, but says 'Invalid system disk. Replace the disk, and then press any key'
So Im kind of half-way there, but cant for the life of me work out what I do to fix this.
My earlier solution was to make a bootable DOS disk, stick ghost.exe from Symantec Ghost 11, and run that from the key. That was all very good, but a) SG11 doesnt recognise the .v2i image file NG9 created b) when I thought I should just start making images with SG11, it wanted 4 hours just to create an image of a 30gig partition with only 15gig used :S
So do I persevere in trying to get NG9 to boot, or give up and use another solution? I had a look at Acronis True Image 2009, and I *think* that has an option to create a USB-bootable recovery thingy.
Thanks for any guidance and advice smile
edit: After some thought, I am wondering if my key is not being made bootable by the HP tool. Is there a way to check? I only say this as I would think there would be an error of some sort when I tell it to boot from my supposedly bootable USB drive, yet it cant read the files etc.
edit2: Also, it would be interesting to know what make and type of USB key people have had success with.
