#1 2009-06-30 8:51:34 pm
Cms
The Paper Keyboard Skining Project (for 1000he)
Well here is the thread where we discus this idea I had, (inspired by Bigears metal keyboard skin)
Thread for the metal keyboard: http://forum.eeeuser.com/viewtopic.php?id=64033
Brief Synapse of his product here: http://portablemonkey.com/article/keybo … pc-1000he/
Basicaly, making a template out of paper for a design that you can lay in between the keyboard keys after cutting it out.
If anyone wants to join in the project (you only need basic photoediting skills) I will provide some stuff to get started smile
Basic step one: get a template
http://i213.photobucket.com/albums/cc55/CMStudio/SCAN0295.jpg
I scanned my 1000he keyboard, lets see what we can do smile
Step 2 - Photoshop it till you get just the template (remove the buttons)
http://i213.photobucket.com/albums/cc55/CMStudio/photoshops.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/photoshops-1.jpg
Step 3 - deciding how to work with the skin
http://i213.photobucket.com/albums/cc55/CMStudio/dsc013991copy-2.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/photoshops-2.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/dsc013991copy-3.jpg
Step 4 - Find out how to print it in exact dimensions (this is the tricky part)
http://i213.photobucket.com/albums/cc55/CMStudio/Untitled-2-1.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/Untitled-2-2.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/Untitled-2-3.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/Untitled-2-4.jpg
http://i213.photobucket.com/albums/cc55/CMStudio/Untitled-2-5.jpg
Every printer is different, so change the % and margins when you print to match your keyboard
Cut out the green with an exacto knife.
Enjoy, (hopefully I got it right tongue )
Remember, this skin is less durable than BigEar's metal skins, If you want something more durable and professionaly cut with laser cutters visit the links I provided at the beginning wink
Current status: build'n mineral oil intel i5 wink
(1000he) PNF Duo Pen Tablet/Touchscreen2.05ghzOC,Geekbench:1131
See my Overclocking guide for the 1000he | Custom eeectrl config file | Keyboard heatsink mod
#2 2009-06-30 10:15:02 pm
bigears2277
Re: The Paper Keyboard Skining Project (for 1000he)
atleast throw a link in to my thread so people can see the original too and decide what they wanna do smile
#3 2009-06-30 10:47:58 pm
Cms
But of course smile
edit: fun fact, Defiantly and Definitely are quite similar in spelling, but mean two completely different things big_smile
#4 2009-06-30 10:58:38 pm
IskO
I want red overlay!
Eee 1000HE Black / 2 gig Crucial ram / 500GB WD Scorpio Blue HD / Windows 7 / Aircube Case from Sumdex & The Plasticase 645 Multi Kitcase (Red)
/ DecalGirl Skin (Dante)
#5 2009-06-30 11:55:36 pm
bigears2277
if you dont decide to do the paper project in red, let me know because i offer that color as well. actually, a few people have ordered it too. not sure if they are from the forum but if they are out there, upload some pics.
thanks for the links by the way Cms
#6 2009-07-01 12:10:42 am
Cms
No problem smile
I think the paper project is good because many people may use the paper one as a "test" to see what color they want
because paper will get nasty and wears out easily, I bet many people will opt to buy your higher quality product in the color they found smile
#7 2009-07-01 12:30:59 am
Cms
Ok, I think I finished smile
#8 2009-07-01 12:36:51 am
Cms
IskO wrote:
I want red overlay!
Its up there wink  ^
#9 2009-07-01 8:17:46 am
IskO
Very cool, thanks alot Cms!, when i get home from work today ill print out a copy and get out the xacto knife smile
Also a suggestion, you can get better quality high gloss photo paper to make this as well. It would prolly hold up better than just regular printer paper.
Ill post pics of finished product when im done. tongue
#10 2009-07-01 8:54:18 am
IskO
I just printed out a quick black & White copy and cut the surroundings with a siccor to see how it matched up and the template is a tad to small.
From my ruler, it looks to be about 1 CM off Horizontally and 3 MM off vertically, i could be off on the measurements, but its deffinatly a little off.
Here is a quick pic , i cut out the escape key to show a starting point then taped it in place. Also another suggestion the boarders around the keys could prolly be a tad thinner, with all the "Green" cut out from the ESC key it was very tight and it would prolly cause keys to stick and also possible ventalation problem? seeing as theres abount a MM space between the keys and the tray it fits into hot air also might vent out that way.
http://img.photobucket.com/albums/v719/isko718/OverlayProject.jpg
#11 2009-07-01 8:59:55 am
Cms
if its off laterally and vertically, then that would be why the key is tight, I know the proportions are right, its just the skew factor that needs to be changed wink
#12 2009-07-01 9:01:23 am
Cms
I would try printing it in microsoft word
make the orentation landscape, and insert the picture, stretch the picture to the exact edges of the paper, and then print
#13 2009-07-01 9:10:21 am
IskO
I'm not to Microsoft Word savy, but ill try and find what you are talking about lol.
#14 2009-07-01 9:28:36 am
Cms
basicaly if your using 2007 word:
First rightclick on image in thread -> save picture
open word:
pagesetup -> orientation -> landscape
then either drag the picture from the folder ontop of word, or go to Insert-> image -> navigate to picture
put cursor over the edge of picture until new stretch mouse icon which looks like this <->
drag sides of image to the edge of the paper.
do the same for the top and bottom of the paper
print and enjoy smile
#15 2009-07-01 9:30:54 am
croquet9
Congrats man, you made GottaBeMobile.com:
http://www.gottabemobile.com/2009/07/01 … oard-skin/
#16 2009-07-01 9:34:45 am
Edot2214
Nice job CMS!
EEE-PC 900 | WN | MATT BLACK, CeleronM: 360MHZ<>1.25GHZ | 16+4GB SSD, 16GB SDHC, 2GB RAM  | XP |
EEE-PC 901 | BT+WN+3G | GLOSS BLACK, Atom: 1.3GHZ<>2.1GHZ | 16+4GB SSD, 16GB SDHC, 2GB RAM | XP |
EEE-PC 1000H | BT+WN | GLOSS BLACK, Atom: 1.3GHZ<>2.1GHZ | 160GB HDD, 16GB SDHC, 2GB RAM | XP |
EEE-PC 1000HE | BT+WN+TS+3G+64GB | GLOSS BLACK, Atom: 1.45GHZ<>2GHZ | 500GB HDD, 32GB SDHC, 2GB RAM | XP |
#17 2009-07-01 10:05:26 am
IskO
open word:
grrr. i have Microsoft Office 2003, i did all these steps, and still not coming out the right size sad
Ill keep playing with it, not sure what im doing wrong, its in Landscape mode, i drag the picture on, then stretch it side to side and up and down to the edge, it doesnt stay on edge but it does get bigger.
#18 2009-07-01 10:35:02 am
Cms
trial and error then tongue big_smile
Im home now so Im going to try as well wink
#19 2009-07-01 10:37:48 am
Cms
Oops you need to change the picture format as well,
rightclick on picture and go to format picture, change orentation to "behind text"
mine came out perfect smile
#20 2009-07-01 11:11:09 am
IskO
Woot, that worked!, looks like it will fit right in, if i cut it right, gonna be a nice fun daunting tast when i get home lol cutting out all those boxes. smile Thanks alot Cms.
#21 2009-07-01 11:25:59 am
Cms
Ive been just poking holes in the centers and then cutting them out with standard scissors smile
It works well when you watch TV big_smile
#22 2009-07-01 11:47:49 am
IskO
Well i "borrowed" some of that more sturdy glossy photo paper from work. so ill wait and use the xacto knife since there was only 2 sheets left lol and i have a shakey hand.
#23 2009-07-01 12:38:18 pm
Cms
tip, the keyboard will not work if ANY, I mean ANY of the green is still on the keyboard skin. wink
Im going to cut my slivers of green out later, It looks good like its going to fit, but its going to take another 20 mins to cut out what I didnt cut out the first time....
Make sure you get all the green out the first time sad
#24 2009-07-01 12:55:50 pm
Bohrier
Nice work, CMS!
And thanks for using my skin design in your project.... makes me wanna do it ASAP. Will do when my skin arrives (it´ll be quite a while, coming from the usa to brasil)...
eeePC 1000HE 2GB (generic lame PC6400 400MHz RAM), 160GB stock HDD. Windows 7 Ultimate RC
Wishlist: 2GB OCZ 800MHz RAM + WD Scorpio Black 320GB 7200 RPM
#25 2009-07-01 1:03:03 pm
Cms
Bohrier wrote:
Nice work, CMS!
no problem, I still had all the images from last time, so it was easy to do smile
