Converting My asus eee pc 701 in to a tablet
i cut a screen bezil from a spare case i had, and stuck that on the lid, so that it looks alot more eee like rather then just a laptop with a hole on top
Edit: neatened up picture
after the disappointment of the aeeeris kit, i decided to have a go of making my own tablet mod.
tools needed:
screw driver
dremel (i didnt have 1 i made the hole with a stanly knife)
i cut a opening in the "lid" of the eee pc about the same size as the screen removed a few of the plastic clips inside, so that i could rearange everything. the lcd controller is near where the webcam used to be.
everything else is prety much self explanatory.
i had to remove the magnet from the screen, first time i put it all together and the screen wudnt turn on i was abit woried lol. then i relized what was wrong
here are a few pics, the opening for the screen isnt finished yet. and my touch panel is cracked
i will neaten the opening up when i can buy some files
all in all i think it looks nicer the the aeeeris "Kit" and fits better, and didnt cost me $60 :@ lol
i will post some pics of it when i have neatened it up
http://i246.photobucket.com/albums/gg10 … mg9585.jpg
http://i246.photobucket.com/albums/gg10 … mg9586.jpg
http://i246.photobucket.com/albums/gg10 … mg9587.jpg
http://i246.photobucket.com/albums/gg10 … mg9588.jpg
http://i246.photobucket.com/albums/gg10 … mg9589.jpg
http://i246.photobucket.com/albums/gg10 … mg9590.jpg
http://i246.photobucket.com/albums/gg10 … mg9591.jpg
http://i246.photobucket.com/albums/gg10 … mg9592.jpg
Cool !
Sorry to hear about the TS ... does it still work ?
Did the stanley knife cut through the plastic easily ?
2 points ...
1) Stella is nicer than Guinness
2) COOL THUMB ![]()
gtisingh wrote:
Cool !
2 points ...
2) COOL THUMB
na, ts is non functional, new one is on they way. cost me £20, so its not a big lost, just anoying lol .
no it wasnt that easy with the Stanley knife, i didnt realize how thick the plastic was lol .
i get alot of comments on my thumb, its always been able to bend like that, dont know why :S it doesnt stick out to the right like that in real life, must be the camera angle
Great work, thanks for posting this, it has inspired me to do the same to mine.
A little bit of detail about how the connections are arranged back to the mobo would be appreciated, and I wonder if maybe the speakers could be moved to the top?
Thanks, Ron
great work, might give this a try and scrap my "kit"
should've done this from the start instead of wasting the damn $60, looks much better aswell
Looks hardcore man......when is someone going to do this sort of mod to a 1000xx ![]()
send me yours and i'll mod your 1000xx. :p
Thanks, Ron
here are a few pics with the lid open, the video cable is a tight fit. when i completely finish it i will use dome double sided tape to stop the laptop from opening, as it may damage the video cable if any one tries to open it
http://i246.photobucket.com/albums/gg10 … mg9593.jpg
http://i246.photobucket.com/albums/gg10 … mg9594.jpg
http://i246.photobucket.com/albums/gg10 … mg9595.jpg
http://i246.photobucket.com/albums/gg10 … mg9596.jpg
http://i246.photobucket.com/albums/gg10 … mg9597.jpg
currently my speakers are in the ram door. i moved them there when i was using the aeeeris "kit" because the speakers didnt fit in the top half
Cool. Volunteers, any, for the 901 tablet?
i may be getting a 901 soon, a friend of mine is selling his for £75, then il sell my black 701 to a family member for £50 so it will be all good , and only costing me £ 25 but i will probably be keeping this one as stock ![]()
Thanks Mark, those pictures make it very clear.
Ron
i just cut a the screen frame from an old case, and taped it to the lid of my tablet. now it looks alot more finished
just need to get the touch screen through and i will be done
http://i246.photobucket.com/albums/gg10 … mg9598.jpg
http://i246.photobucket.com/albums/gg10 … mg9599.jpg
http://i246.photobucket.com/albums/gg10 … mg9600.jpg
Looks good. I better pull my finger out and get my ts ordered
What if you mount the screen where the keyboard use to be? It'd be much thinner. =P
i bet the heat would wreak havoc on the LCD.
i mite see if i can make it thiner at a later date, im just focusing on getting it working first , as soon as i get my touch screen through i will be happy ![]()
im not sure how the heat would affect the screen? on the **** aeeeris kit, the screen was laying on the metal, and would of got hot during extended use. but i know he didnt do any research or testing, as it didnt even fit lol , so that probably not all that much to go by
This is definitely what I would look into doing only using a dremel for accurate cutting but this whole concept is just great
one problem im having is that if i put my thumb on the area in the red box, it turns on, or shutdown, if i do it, i hear the power button click
your thumb scares me.....
And You should learn to use masking tape and a straight edge before cutting.
it doesnt look like that in real life, honest
And maybe you should learn what couth is. ![]()
The perspective in that pictures makes it look scary LOL
Did you not understand my post as constructive criticism?
i understod it , i didnt really plan this, just did it spur of the moment, and it worked out rather well, i was to do this again i would buy a dremel rather then using a stanly knife :p
my touch screen still isnt here ![]()
LazerTag wrote:
on a 701 with the lid down isn't heat an issue? or is that only true on the 900 and 1000 series?
i dont know, im running super pi, and im using eeectl to check temperatures. is let you know how i get on
edit: temps are 58C under load
