#1 2007-12-24 10:09:33 pm
monkeyhihi
Guide to installing Windows on External?
I know that the page at http://www.ngine.de/index.jsp?pageid=4176 tells you how to install XP from a different computer, but I don't have the capabilities to remove the internal HDD, that, and the fact that it wouldn't be set up correctly on the eee.
I also know that you have to go into the BIOS and change a bunch of settings there, so my real question is...
What [i]else[\i] do you need to change on the eee itself in order to install XP on an external hard drive? (SSD settings, BIOS, etc)
#2 2007-12-25 4:19:06 am
dave_mcconnell
Re: Guide to installing Windows on External?
Press F2 to enter bios settings
You need to change OS to [start] - and remember to change back to [finished] later on - this enables USB2.
Go to advanced tab in bios settings, >IDE configuration, > siliconmotion sm223ac, press [enter] – brings up a list – choose not installed. Exit and save.
Attach your ext HDD and use an ext CD/DVD-ROM drive as well. You need to add the modified files detailed in your link above to your windows XP disk (use Ultraiso or similiar to add and then burn a disk) - these allow the USB to be detected first (I think). Be METICULOUS in following the instructions - errors here will give boot errors later and it will be a no go. EMail me and I'll mail you the modded files I made.
Turn on your eee and press ESC to enter boot options - select your CDROM and away you go.
It takes quite a while for XP to load. When XP is running you also need to go to administrative tools, management, storage, and remove the drive letter for the BIOS partition.
That should be it.
Hope that helps - I found it quite frustrating whilst doing it because lots of things can go wrong - but eventually worked out.
Dave
Black 701 4G; 2GB RAM; SSD - Win XP SP2 nlited; 16GB A-Data SDHC; 40GB Ext HDD; Pioneer K-06 Ext DVD-RW
Medion Akoya E1210; 2GB RAM; 320 GB WD Scorpio; Triple-boot Vista/Mac OSX/Ubuntu 8.04
#3 2007-12-27 3:27:29 pm
SPCartmanland
i dont see the option in my bios to change the OS to start etc... i have the blue 2g surf
#4 2007-12-28 10:20:11 am
dave_mcconnell
sorry havent got a 2g surf to look at - I'm not even sure if it matters that much in doing that step. One time I installed windows I'm sure it changed it automatically.
Apart from that did you manage to do anything else?
#5 2007-12-28 11:15:21 am
SPCartmanland
well cant give it a go until later today when my usb hdd arrives
