Being a linux newbie, I'm looking to install some free linux Xandros games on my 4g. I'm specifically looking for the game MahJong for my wife. I searched some of the threads on the forum and was reading how some games have to be compiled and how that can be tricky..... I'm not sure how "tricky" this is and couldn't find a procedure on how to do this. If this is a pain, does anyone know where I can find free Xandros games that are already compiled and how to install them on my 4g? My wife likes puzzle type games in general.
Thanks for any help!
run synaptic
Open up a terminal window (CTRL-ALT-T) and type:
sudo apt-get install mah-jong and press ENTER
Answer Y to the confirmation question and this should install a version of Mahjong for you.
Of course, you'll have to set up some Debian repositories, first (if you haven't already). You can learn about that here:
http://wiki.eeeuser.com/addingxandrosrepos?s=apt%20get
O.K. I might be missing something, but I followed the link and I am still confused. I see some web addresses, but not how to add the repositories. Can someone post a step by step on what to do?
I am particularly confused by this:
"EDITOR NOTE: You can add the following lines to your /etc/apt/sources.list"
I won't have my EEE until tomorrow, but I would like to learn how to add a few games and stuff before I get it. Thanks in advance to all of those that are patient with the Linux newbies!
You will need to edit sources.list, and add the details of the relevant repositories. You edit the list (which is a text file) by using:
sudo nano /etc/apt/sources.list
and adding the relevant repositories from the wiki.
Then, save the file (Ctl + O) and exit (Ctl + X).
Then, update your package cache:
sudo apt-get update
Can you I use this method to install an action type game or some strategy games that is fun to play? I am reffering to the method described by the first reply? Thanx.
I am a newbie and will like to know too.
What other good game can one install like this? Championship manager or something similar like a strategy based games or an action game?
Answer Y to the confirmation question and this should install a version of Mahjong for you.What other good game can one install like this? Championship manager or something similar like a strategy based games or an action game?
Well, if you followed the process of adding Debian repositories to your sources list, you could get a list of available software by running synaptic. In a terminal window, type: sudo synaptic and press ENTER.
This should launch the Syanptic package manager (it's a graphical front end to the apt-get installer). Down the left hand column, scroll down to find the "Games and Amusement" section. Click on it and in the column to the right,you'll get a list of games that's available to you.
Click on one of them and, in the window below, Synaptic will give you a short description.
To install something, click on the check-box to the left of the file name. When you're done making your selections, click the "Apply" check box.
Thank you very much for your help. I also noticed that this can be used to access most things installed on the eeepc in a way right? I am currently having loads of issue with my IM I cannot connect using my msn, however, Yahoo chat is ok on the IM. After doing a quick search on the forum here, it is obvious that people have issue with the msn actually working on the IM.
What am trying to ask is that how do I go about in fixing this please. The solution apparently is to remove the installed pidgin and get the latest version. I have tried updating but the machine is not doing this.
With the above command, can i remove the version of pidgin i have 1:2.0.2 and install the new version? If yes, can you please give me a guide line of how to do this. Thanx.
All help is appreciated.
I followed the above instructions to install mah-jong. It seemed to work - but now how do I run it - how do I play the game?
Sorry to hijack your thread buddy. I have used the above command to install pidgin and it says I have the latest. Can someone then explain to me why I cannot connect to msn?
You'll have to launch the game via the terminal. I'm guessing, but you'll most likely type mah-jong and press ENTER.
If you want to add it to the desktop as an icon (I'm assuming you're using the default Easy GUI), you'll have to do a few manual changes to the simplegui.rc script, as described here:
http://wiki.eeeuser.com/howto:customizeeasymode
Scroll down the page to the part that explains how to add new items.
I detest all things Microsoft, so I can't help you out much on your issues with MSN as I'm not a subscriber. Maybe someone else will be able to give advice on this issue.
I did a quick Google search for "pidgin and MSN" and found this: http://developer.pidgin.im/wiki/FAQ
Maybe it can provide some assistance.
sudo nano /etc/apt/sources.listand adding the relevant repositories from the wiki.
Then, update your package cache:Code:
sudo apt-get update.
I have copied the repositories list from the wiki, when I try to run the update it tells me there is an error on the lines I have copied and pasted. Any help?
Can you post the contents of your sources.list file here?
Neil, I have the follwoing
deb http://update.eeepc.asus.com/p701 p701 main
deb http://update.eeepc.asus.com/p701/en p701 main
deb http://xnv4.xandros.com/xs2.0/upkg-srv2 etch main contrib non-free
deb http://dccamirror.xandros.com/dccri/ dccri-3.0 main
deb http://www.geekconnection.org/ xandros4
deb http://download.tuxfamily.org/eeepcrepos/ p701 m
A straight copy and paste from the wiki.
Sam
What happens if you put "main" after deb http://www.geekconnection.org/ xandros4 , so it becomes:
deb http://www.geekconnection.org/ xandros4 main
and remove the tuxfamily repo?
Neil,
That seems to help but when I run the Synaptic nothing come up. I get the message
"E: Invalid record in the preferences file, no Package header
W: Couldn't stat source package list http://download.tuxfamily.org p701/m Packages (/var/lib/apt/lists/download.tuxfamily.org_eeepcrepos_dists_p701_m_binary-i386_Packages) - stat (2 No such file or directory)"
Any suggestions?
Have you removed the tuxfamily line from sources.list?
If so, run sudo apt-get update and see if that helps.
Neil,
I have now removed tuxfamily then re run the update again. When I go into synaptic i now get:
"E: Invalid record in the preferences file, no Package header"
any suggestions?
Sorry- on my phone so can't easily re-read the entire thread. Have you run
sudo apt-get update
Re: "E: Invalid record in the preferences file, no Package header"
I got that message after following the procedure for "pinning" & it turned out to be an extra space at the beginning of the first line.
I'm also looking for a mahjong game & have added the recommended repositories to synaptic but couldn't find mah-jong or gnome-games (which I heard has a good mahjong game) listed - only kmahjong which turned out to need some other library or file that looked iffy (something like libqtc102?). Wonder if I should try a debian repository from http://ruckman.net/tech/2007/08/17/eeep … ositories/ ?
I had the same problem with my Eee PC (apt-get update does not connect). I have temporarily solved the problem by entering the IP addresses in the source.list file. This points to a DNS resolution problem in the terminal window and I will investigate further to see what could causing it...
Cheers,
Paddy.
I have the same problem with updating (either via add/remove software or via the command line), How does one find out the IP addresses for the various repositories?
Type ping www.domain.com in a command window...
