#1 2009-03-27 8:50:37 pm
Rena Rune
Windows very stuttery
XP performs poorly on my 901, lots of locking up especially with Firefox and Trillian. Is this due to windows being bad on SSDs? Is there some kind of optimisation(besides installing Linux).
#2 2009-03-27 9:05:37 pm
odious_m
Re: Windows very stuttery
How much RAM do you have?
Do you use a RAMdisk?  Have you done a malware scan recently?  How much room is left on your SSD?  What size is it?  Who is the manufacturer (is it the stock 4 GB SSD ?)  Did you install Windows yourself?  Do you defrag or have you tried optimizing your SSD?
What kind of performance tweaks have you tried?  Please provide more info when you ask ??? so that we may be better able to help.
Eee PC 2G Surf | Lush Green | 800 MHz | 512 RAM | Win2k Pro SP4
Eee PC 901 XP | Pearl White | 1.6 GHz | 2048 RAM | Runcore 64GB PATA SSD | Kingston 32GB SDHC | XP Home SP3
#3 2009-03-27 10:13:12 pm
Rena Rune
It's only just new sad
#4 2009-03-28 10:29:45 am
Bascule
Out of the box, it may be due to much of the stuff Asus installs by default:
1. Uninstall anything you don't want, including the antivirus
2. install a good free antivirus (or even better go to http://portableapps.com/apps/utilities/clamwin_portable and use a portable AV)
3. Dowwnload, install & run CCleaner
See how you go after that
I've had Cheryl Cole and thought it was a bit rubbish
#5 2009-03-28 2:55:18 pm
odious_m
Read this about firefox tweaks:
http://forum.eeeuser.com/viewtopic.php?id=64150
#6 2009-03-28 9:49:13 pm
carmenara
Disable NTFS timestamp and journaling, disable indexing service.
Also note that the C drive on the 901 is the 'fast' one, and D has a slower write speed.
Ph.D. in pillowlogy and cat psychology
1000 posts on a 1000H in 4 months
This user has retired tongue
