#1 2009-03-20 6:19:15 am
azanutta
TouchPad on JAUNTY
i'm wondering if there's a way to enable the full potential of the elantech touchpad OoTB in Jaunty.
without modifying anything in xorg.conf or in other files the situation now is:
vertical scrolling with 2 fingers  OK
3 fingers tap = right click  OK
2 fingers tap = middle clik  OK
i've readed that other options such, orizzontal 2 finger scrolling or mac-like zooming is also possible with new drivers from elantech...
has anyone figure out a procedure to make this happen?
eeePc 1000h - ubuntu 9.04 - official kernel - Openbox WM - no SCRIPTS - SDHC 4 Gb - wacom bamboo fun tablet
#2 2009-03-20 6:26:06 am
azanutta
Re: TouchPad on JAUNTY
#3 2009-03-20 6:37:50 pm
lanzen
Fewt suggested to add a few lines to his xorg.conf for Intrepid. Haven't had time to try it, yet.
What about this GPointingDevice, any good?
EeePC 1000H K/Ubuntu 9.04
EeePC 4G Ubuntu NR 9.04
#4 2009-03-21 5:50:27 am
azanutta
here's a jaunty topic, i don't know if that method works, but i doubt because i've noticed that the xorg.confS are even more empty with the time flowing...
that gpoint could be a solution but i don't want to compile it, i'll wait a deb vesion, and i'm not sure if that's only a configuration program or contains also a sort of driver... buh
#5 2009-04-03 2:05:48 pm
il1019
Anyone else not like the driver for Jaunty? I booted up a Live system this morning, and the touchpad movement was much slower. Did they change the driver? In Intrepid, I have my mouse settings to the middle, and in Jaunty I maxed it out and it was still slow. Anyone else notice this?
White 901 12G: Ubuntu, 80GB HDD, Mark VII bag.
#6 2009-04-04 10:19:58 am
DeathsShadow77
having problems here too on jaunty. every time i put my finger on the touchpad it jumps the mouse across the screen and 2 finger scrolling is extremely sensitive
#7 2009-04-04 11:52:11 am
lanzen
Are you by any chance using the Remix?
#8 2009-04-04 6:09:34 pm
DeathsShadow77
nope, just regular jaunty
#9 2009-04-04 10:06:43 pm
sgosnell
I don't see any difference between Jaunty, Intrepid, and Hardy.  They all work fine on my 900.
900 with Ubuntu 10.04 on 32GB SSD
#10 2009-04-05 5:32:50 am
wabre
working fine yes, but have you actually tried them? an out-of-the-box installation of jaunty just works as with intrepid you need to tweak big time to get mostly everything to work. so appearance is not everything, it's the power beneath it. speed and performance in jaunty is way better than intrepid. i don't even bother with hardy since it's older.
eee 901, karmic 9.10 starting from alpha 2
#11 2009-04-06 4:35:56 am
sgosnell
This thread is about the touchpad, and nothing else.  Yes, I've actually tried them, and my touchpad worked the same in all three, no problems at all.  Other things didn't work as well with the older versions, I agree.
#12 2009-04-16 9:16:49 am
thornomad
I have the same problem with jaunty (netbook remix) on my 900a -- jumping all over the place.  Haven't found a fix yet - am running with the latest updates.
#13 2009-04-16 10:17:01 am
fewt
I copied the xorg.conf I used for intrepid and changed the driver to UXA.  I don't have any touchpad issues.
[ Blog ] - [ Software ] - [ ~/Forum ] - [ Aurora ]
#14 2009-04-16 1:02:41 pm
thornomad
Would you mind posting the changes you made in xorg (the driver, I would guess) ?  I don't have a copy of my old setup.
#15 2009-04-16 2:48:08 pm
fewt
My xorg.conf is already posted here, search for 'fewt xorg'
#16 2009-04-16 11:22:37 pm
DeathsShadow77
nice xorg. for me it helped somewhat but the mouse will still occasionally jump when i touch the touchpad and scrolling is now very slow
#17 2009-04-17 3:21:33 am
lanzen
I have the same happening on a Jaunty Netbook Remix on the 701 while Easy Peasy Inprepid  does not do it.  What's more, when I tested UNR 9.04 the 1000H this didn't happen, but 701 and 1000H have different touchpads.
#18 2009-04-18 12:32:18 pm
thornomad
There is a bug report filed, it seems, for the jerky touchpad issue in jaunty - adding comments may help increase the priority.
https://bugs.launchpad.net/bugs/355326
#19 2009-04-24 5:21:50 am
Andy80
Hi, I'm having exactly the same problem here: I tried Ubuntu Jaunty LIVE, starting it from USB stick and the mouse movement is very very slow. Is there any way to fix it?
#20 2009-04-24 5:53:17 am
jarreboum
I've had the same problem on USB Live and worried like you. But it appears its only a matter of the live distro, as after an installation the touchpad reacts normally.
#21 2009-04-24 5:54:15 am
Andy80
This is really a good news for me! Thanks for your suggestion! smile
#22 2009-04-26 12:33:40 am
sirdu
I also have the same problem - jerky cursor  movement on main screen (jaunty netbook remix but not  jaunty desktop on my 900 installed from Live USB).
#23 2009-04-26 7:43:26 am
Olorin
There's a workaround for this jerky cursor. I've found it somewhere in this forum, but I don't remember in which topic.
Anyway, you need to add this line
options psmouse proto=imps
in /etc/modprobe.d/options (create the file option if it doesn't exist).
It fixes the slow cursor problem too.
#24 2009-04-26 7:51:28 am
Andy80
I'll try this if I'll have more problems, thank you smile
#25 2009-04-26 8:15:49 am
bornagainpenguin
I can confirm this makes a HUGE difference on my EeePC 901!  Thanks for this tip, it's made it so I can stay with Jaunty after all.  Now if only there was a fix for the intel drivers issue...
--bornagainpenguin
Grigori Goronzy (Marx) has updated his eee-control, Adam McDaniel where are you?  Our eeepcs need a new array.org kernel!
I'm working on a guide to getting Lucid to work well on the eeepc, join me here!
