#1 2009-01-22 3:19:28 pm
zeze
Mugen Power Battery on Eee Pc 900 11200mah – REVIEW - Fantastic !
Hello Eeepc fans !
I'm a Comercial Agent, and take advantage of my Eee Pc 900 all day long, so I quickly realised that the 4400mah battery wouldn't serve my needs. After many searching on the web, one of the best blogs on theses gadgets (JKKMobile) is clear about Eee Pc Batteries, Mugen is best, and he is correct. Battery tested by Jkk is Mugen 7800mah, mine is 11200mah. It's an  expensive acessory, but really is a quality product, well built, fit's perfect the pc and boosts a working day of performance, office, web browsing and emailing.
Opening office files, sites, some softwares I use at work and emailing, my Eeepc 900 worked for 8 hours with light at 25 % and Wifi On.
Weight with 4400mah original battery = 993gr
Weight with 11200mah Mugen Battery = 1179gr
Weight increase = + 186gr
Eeepc still fits the original neoprene case.
Writing position is much better.
Mugen Power is maybe the best Eeepc battery money can buy, my mobility problems are solved, now most days I use 40 to 50% of the battery.
Note: pay atencion to fake copies on the net, genuine is from Mugen Power Batteries site.
Regards
zeze
#2 2009-01-22 3:37:24 pm
mick4394
Re: Mugen Power Battery on Eee Pc 900 11200mah – REVIEW - Fantastic !
Is this that huge, hammerhead, battery?
Eee Pc 1000HE | Black
#3 2009-01-22 3:59:02 pm
zeze
You can bet on it m8.
#4 2009-01-22 4:28:19 pm
odious_m
Nope, I bet it's this one...
http://img407.imageshack.us/img407/5039/42183699dm1.jpg
Eee PC 2G Surf | Lush Green | 800 MHz | 512 RAM | Win2k Pro SP4
Eee PC 901 XP | Pearl White | 1.6 GHz | 2048 RAM | Supertalent 16GB SATA SSD | Kingston 32GB SDHC | XP Home SP3
#5 2009-01-22 4:32:42 pm
mick4394
I thought he was talking about this one:
http://i236.photobucket.com/albums/ff284/mick4394/DSC01741.jpg
But, you're probably right. There's no way this thing would fit in a sleeve.
#6 2009-01-22 9:30:22 pm
DutchNelson
On what website can you order the real one?
I dont wanna risk getting a fake.
EEE PC 900 - 16 GB - 2GB Ram - Nlite XP SP2 NL -
320 USB Drive - HSDPA 4 MB USB Internet Dongle -
Good Freeware Games for XP
#7 2009-01-22 10:17:02 pm
odious_m
What site?  Mugen's own, natch. They advertise, "Free Shipping Worldwide!"  I wish I was in Amsterdam again........  wonderful place!
http://shop.eten.hu/mugen-power-11200ma … p-501.html
#8 2009-01-22 10:19:45 pm
odious_m
Oh yeah, here's a white one...........
http://shop.eten.hu/mugen-power-11200ma … p-502.html
#9 2009-01-23 3:53:51 am
xiaoxun
Hi, I bought one of these at www.mugenpowerbatteries.com and great service as well, because I made a mistake with payment and they helped me all the way to correct it.  I received mine (in Macao) very fast as well (4 days) and that for free shipping is excellent. it is the best battery I ever had!
#10 2009-01-23 6:32:09 am
meanie
advertisement spotted
#11 2009-01-23 11:07:17 am
jakfish
$180--that's insanity.  Almost half the price of the machine.  Give me the cheap knock-off any time smile
Jake
#12 2009-01-23 12:51:09 pm
zimo
Jake
yes, mugen batts are really nice... But for this price is almost and EEE 700... tongue
#13 2009-01-24 7:12:12 am
meanie
how long did a full charge took?
#14 2009-01-24 7:24:16 am
zeze
Arround 4 hours to fully charged from flat.
#15 2009-01-27 2:38:49 pm
xiaoxun
Here is a review of the Mugen Power battery  on GadgetNutz.com: http://www.gadgetnutz.com/modules/news/ … ryid=00508
#16 2009-01-27 4:27:29 pm
Peltz
I'm amazed that not one of these battery manufacturers have put any kind of rubber pads at the bottom of their batteries. As review said the battery gets scratched and doesn't laptop slide away from your hands on flat and smooth surface?
#17 2009-01-28 4:14:17 am
Djhg2000
That should be easy to fix, though I agree I'd expect some kind of rubber pads on a new battery like this one...
#18 2009-01-28 8:30:47 am
jakfish
The 10400mah that I bought from Hong Kong came with pads, but poorly glued, and one fell off.  I ended up cutting very small circles of bicycle innertube, and gluing them to the battery with epoxy.  Worked okay so far.
Jake
#19 2009-01-28 10:52:32 am
dt
Dang that's expensive...I bought my 900 for $129...the battery would cost more than the 900 itself!
Asus EEE PC 900 - Galaxy Black - Windows 7 7600.16385
G1 Android + Arduino + eee pc = smile
