#1 2008-12-25 9:06:47 pm
peregrinefalc0n
turning on eeepc w/ magnet (by activating a reed switch)
I decided to post this in a new thread because I didn't want to hijack mark's power-by-key thread.
Thanks randy for the link in the other thread, but I eventually found a cheaper source for the reed switch. It seems like exactly what I need? http://www.sparkfun.com/commerce/produc … ts_id=8642
Now all I need are some pointers on how to actually do this... anyone willing to explain the pinout structure for the power button?
And I plan to keep the original power button intact. I'll be leaving a tiny hole so I could press the power button via paperclip if need be (like if I lost the magnet lol). I assume soldering the reed switch in parallel wouldn't cause a problem?
#2 2008-12-26 1:21:21 am
Vinhtvu2
Re: turning on eeepc w/ magnet (by activating a reed switch)
I think the power button has four pins... Idk what they are... but I'll test it when I take the thing apart next... which is soon......
just solder a wire to one pin to one side of the reed switch, then the other one to the other side... when a magnet hit, it'll trip the  reed switch and it turns on the laptop, very simple...
I just gotta figure out which two pins to use.... this is actually a good idea... I might actually do this, and remove the power button altogether so no one knows how to turn it on but me.... and whomever reading this.... haha
Eee 702 8G-XP nLite with bluetooth, 4g microSD, 4g SDHC extreme III, and 4g USB w/ Xandros
Eee 701 4G-XP nLite SP2 with Touchscreen, bluetooth, and 4 gig SDHC
Eee 901 4G-Xp nlite SP3 with touchscreen, 80gig hard drive, and wifi upgrade
1000HA- bluetooth module, tons of mods on the way... STILL LOOKING FOR 7xx black touchpad!
#3 2008-12-26 1:22:27 am
peggyjay
http://i41.tinypic.com/6tgys8.png
i havent tested yet,(next time i open my eee i will)
the pinouts could go 2 ways:
pin 1 connects to pin 2 when pressed
or, pins 1&2 connects to 3&4 when pressed
since the switch is not a toggle switch, it should be perfectly safe to wire the reed switch parallel to it
i'll check thoses pinouts soon.
goodluck, also why do you want to do this?
<900XP - 320mhz<-->1251Mhz[stable] - XP Pro Vol Licence\Windows 7 Ultimate - bluetooth via 10 pin - tablet+touchscreen - 4Gb SSD+ 2gb SD+ 160gb SATA 2.5"<---built in >==SOLD yikes
I now own a HP 2133, but thinking of buying a 901 from a friend
#4 2008-12-26 2:48:37 am
AlmostInvisible
tact switches are usually spst with 1&2 contacting 3&4 when pressed.
the 5th one (in the middle) is just the frame top (earth) of the switch.
the trouble with a reed switch switch is it's not momentary like the tact switch and the eee prob won't respond correctly if the tact (or reed) is held down. I've never tried holding down *after a start up , but you know what happens when you hold it down whilst running.
So unless you're gonna remove the magnet as soon as you've contacted it won't work as required imho
SEARCH FOR THE ANSWER to life the universe and everything eee
Tough on spam , tough on the causes of spam. big_smile
Spamsters: Learn to recognise them yikes , don't talk to them neutral , just report them  smile and let's get rid of them big_smile
#5 2008-12-26 2:57:18 am
peregrinefalc0n
because, like many of the modders will answer, i can and its fun big_smile
Just wanna learn and try something new, ya kno'?
Thanks everyone! I'd test it myself but I'm just not sure how...
Although, I do have my own (never used) multimeter.. wanna teach me how to check it instead? wink
#6 2008-12-26 3:12:48 am
AlmostInvisible
if you want tongue lol
put the meter to low resistance range (or beep continuity (<200ohms scale) if it has such a setting)
cross the two probes together in your hand and the display will register zero ohms (close to 0.0 on the display), it won't read exactly 0 as the leads have some slight resistance.
With no power attached to the eee and no battery installed, position one probe on 3 4 or 5 (they are all tied together anyway on the pcb) and the other probe on 1 (and afterwards on 2)
when the button is pressed , the meter will (should) read 0 or near enough.
check again with no 2 terminal and the same should happen.
checking across 1 and 2 without the button being pressed should also display 0 ohms.
(If the meter does have beep continuity setting, the meter will beep as well as displaying 0)
HTH ask if you need any more help.. but remember the reed is not momentary, so as I say this ain't gonna work unless you remove the magnet once you have closed the contacts one time.
#7 2008-12-26 3:26:44 am
Vinhtvu2
It should work with a reedswitch... I used reed switch to turn on LEDs and lights before.... the longer you hold the magnet there, the longer the reed stays contact.... so therefore, it works just like a normal temp contact switch....
If you "swipe" the magnet through real quick... it should act as if you press the button and release.... which powers it on....
A "hard"  poweroff would be holding the magnet there for four seconds..... should work easily....
I plan on testing this mod out... I got the reed switch already.... guess I'll take the multimeter to it and see what pins connect and will try it out.... subscribe if interested....
#8 2008-12-26 4:16:38 am
peregrinefalc0n
Yeah, theoretically it should work perfectly for my application. I'll have the reed switch hidden beneath the casing & the magnet hidden within my watch's band so the laptop powers on with a simple swipe of the magnet big_smile
Keep us posted about the pin connection, thanks.
Thanks for the short writeup on how to do the test! I'll check, but just not right now. its 4:16 AM over here and I really need to sleep, haha.
#9 2008-12-26 7:20:53 am
Redback
The only question I have is WHY?
901 with 32GB Runcore SSD, 2gb Corsair Ram.
Coming soon: Touchscreen, Internal 3G/HSDPA, GPS
#10 2008-12-26 7:26:31 am
AlmostInvisible
so he can simply swipe his (concealed) magnet over the reed switch location and start (or shut down) the PC without touching it in a james bond stylee ? wink
Keyless 'ignition'? big_smile
#11 2008-12-26 1:18:23 pm
Vinhtvu2
I am tired of people asking why in the 'hacks and mods' section.............
The answer is "WHY NOT?"
Because we can.... because it's different.... because it might be challenging..... if everyone asked "Why" and dont just try new things..... we would be far less technologically advance.... probably still in the dark age.....
It's exploration......... it's trying to do something no-one has done.... it's breaking the barrier.....
Okay sometime I ask why also...... but that's only when it's ridiculous like stripping the 901 to save 2 ounce from it..... or try to watercool an Eee....... I guess there is a limit....... this one is still in the sane boundary in my book...
#12 2008-12-26 1:28:02 pm
peregrinefalc0n
Ditto and kudos to Vinhtvu2. big_smile
#13 2008-12-26 2:02:47 pm
The_Kid
This is actually kind of useful. Keeps people from using your computer unless they know how it works.
http://www.cryolanparty.com/  --  A LAN Party I'm staff on, check us out!
900A in 900 black matte case, black 701SD with pink lid
#14 2008-12-26 3:18:37 pm
barry99705
Isn't that why most of us use linux?  big_smile
#15 2008-12-26 4:50:28 pm
peregrinefalc0n
HAHA... so true.
So has anyone made any real progress on this? My reed switches have been ordered but I haven't tested the connections yet.. (My multimeter battery died. Grawr...)
#16 2008-12-26 4:56:30 pm
AlmostInvisible
what progress do you want ! roll big_smile
you open it up, you solder in a reed switch across the terminals I've mentioned, insulate it and put it in a suitible place in the cab, put it back together and voila you're done. It's the most basic of switches.
I'd suggest soldering wires to the reed, stick some heatshrink on the bare leads and don't bend the leads on it at all so you don't break the glass seal and thus ruin the switch.
Just get on with it wink
#17 2008-12-26 6:17:17 pm
Redback
Why not?
Because it achieves nothing.
Reed switches are not mysterious objects, connecting them to stuff is not exactly a technological breakthrough.
How annoying is it to have to carry a random magnet around all the time to turn on your laptop?
I'm all for pushing the envelope and doing new things, but you should try to do something that is actually worthwhile.
#18 2008-12-26 6:24:13 pm
RandyLude92
EEEmazing User
if you read up on peregrine's other thread about the "peregrin3" project you would know WHY he wants to do this, he's attempting to turn the eee into a very *james bond-ish* (not to be confused with bondage) actual *note-book* the magnet you seem to be so puzzeled about would be placed discretely in a watch/wristband/ring of some kind as per what peregrine has posted in the previous weeks in other such threads, with many of us contributing to the process.
so yet again i raise vinhtvu2's question as to WHY NOT?
hacks and mods are about improving/personalizing your device... if this is how someone wants to do it then why not support it? who knows what else this could inspire, and we shouldn't stifel that if we really endrse hacks or mods of any kind.
"modding is for fun and learning, i've learned to have lots of fun"
#19 2008-12-26 8:05:31 pm
AYE-SUS THIS
don't wish to put an axe in the works but if this switch works when a magnet gets close.. a word of warning it might not be a good idea to put the laptop on top of a speaker cabinet after the mod.. i mean you'll be writing about battery drainage soon.. as it fires up out of the blue ;-)
By the way i love the idea though.
* HOT Wireless upgrade MIMO 300mbp for sale! http://forum.eeeuser.com/viewtopic.php?id=39818
* Hot VGA driver I developed for your Eee 700, 900, 901 & 1000! http://forum.eeeuser.com/viewtopic.php?id=24848
* Added cool 2nd internal SD card reader! http://forum.eeeuser.com/viewtopic.php?id=33841
* Now starting the multiple Micro SD mod this is hot :-) http://forum.eeeuser.com/viewtopic.php?id=35500
#20 2008-12-26 11:32:38 pm
Haku
I've just thought of a minor 'upgrade' to my idea of using a reed switch:
Use the reed switch in series with the main power switch.
That way you hold your wristwatch strap/modified USB key or whatever with a built-in magnet next to where the reed switch is hidden, then you can press the power button as normal - people will automatically assume the power button works as normal. If you just wave your wrist or whatever next to the laptop and it powers on people will may be interested in how it switched on when you didn't press the power button. Plus it means you can't accidentally trigger the power button by holding a magnet next to the reed switch.
You could also wire in a second (or maybe third) reed switch in parallel with the first so you don't always hold the magnet in the same place, another layer of security through obscurity.
AYE-SUS THIS, generally speaker magnets aren't powerful enough to affect a reed switch unless maybe you were to hold the reed switch right up to the cone center or the center-back of the speaker box, magnetism power decreases exponentally, reed switches need to be about 1cm away from a small (ie 4mm sized) powerful magnet to turn on.
Furthermore a lot of speakers sold nowadays are magnetically shielded, notably computer ones and 5.1 setups - I've got a large Yamaha center speaker sitting on my 28" widescreen CRT and it doesn't affect the screen because of it's sheilding.
AlmostInvisible is right about the fragility of the glass, I've broken too many by bending the legs right next to the glass, if you need to bend it then use pliers to hold the leg right next to the glass and then bend the leg.
Redback, you have to remember that most people don't think like us modders/hackers/builders so they wouldn't automatically think of magnet powered switches to covertly switch on a device. And I like that, it means you can do some really neat behind-the-scenes stuff and most people won't have a clue how you did it, but the flip side is most people wouldn't appreciate the effort involved in the behind-the-scenes stuff even if you told them.
#21 2008-12-27 4:14:56 am
AlmostInvisible
yeah get another reed wired in series with the other one and have a small magnet surgically implanted in each wrist, fit the reeds either side of the cab, then do the spiderman wrist action when you want to do the business lol
having two switches (and needing two magnets) will remove the chance of accidental operation. wink
#22 2008-12-27 9:30:11 am
RandyLude92
EEEmazing User
and magnets on the wrist are good for arthritis too!
#23 2008-12-28 3:02:47 am
peggyjay
got around to opening my eee up today =]
the pinouts are 1&2 connect to 3&4 when pressed(effectively grounding 1&2)
so i got out my soldering iron, brushed off the dust, and set to work.
heres the instructions to do it my way, once your done you will be able to use the button or the magnet
http://i44.tinypic.com/33lgl5c.jpg
1. bend 1 side of the reed switch to a 45 degree angle, and solder to pin 1
2. take a small peice of wire and solder bettwen the other side of the reed switch and pin 3 of the button
http://i40.tinypic.com/11l3o0i.jpg
3. use tape or heatshrink to protect from shorts(optional)
4. screw your eee back up, sit back, and marvel at your fantastic work
is this the easiest mod or what? (once you get you hands on a reed switch that is)
also, am i the first one to do this? it works great, now better not forget my magnet.
#24 2008-12-28 3:47:27 am
EEE T
Nice job peggyjay!!
Haku wrote:
...........another layer of security through obscurity.
If we wanted to get really obscure, we could bypass the power button and use two mercury switches in series that are mounted on opposite sides of the EEE, opposing eachother in such a way that when you spin the EEE, the centrifugal force will pull the Mercury out to make momentary contact for startup.  But this will have people throwing up their EEE spinning it in the air like pizza dough, or flipping the EEE over on its screen lid and spinning it on the table to start it. smile
Second Try: 701 4GB, 2Gb RAM, Win XP Home SP2, Black w/ White Keyboard
Internal Mods: GoSpeed Almost Solderless Hub, Bluetooth 2.0, 16Gb Corsair USB Drive, Kiddshop Touchscreen
#25 2008-12-28 4:52:24 am
AlmostInvisible
I did suggest don't chop or bend or solder too close to the glass entry (okay I only said about not bending the leads tongue )
the reed has much more chance to fail during soldering and subsequent use. they are a delicate thing .. it only takes a bit of strain on the lead for it to break the glass seal and lose the vacuum or even twist one of the blades slightly causing premature failure of the contacts. you have been 'warned' wink
