#1 2008-12-19 5:11:12 pm
PitCritter
904HA Keyboard Question
Anybody know why the 1 and 6 keys have special symbols?  Maybe the Up and Down arrows are different too.
#2 2008-12-21 4:32:16 am
Benny Lo
Re: 904HA Keyboard Question
My S101 is the same.  You are not the first to ask.  Not knowing why, would it be used for Linux version?  There is no result from searching in the google. sad
702 Black 8G XPP2+EWF | 2GB RAM | XPP3 on SDHC (Fat32) in internal cardreader
S101 Brown 16G XPH SP3 / Win7 RTM | 2GB RAM | 16G SDHC (Fat32)
Asus S5N Centrino XPP2 | 768M RAM | With 8 & 32GB CF Cards as HDD
ASRock N330 (Non-Ion) ITX desktop XPP3 / Win7 RTM  | 2 X 1GB RAM Dual Channel
#3 2008-12-21 4:51:50 am
AlmostInvisible
SEARCH FOR THE ANSWER to life the universe and everything eee
Tough on spam , tough on the causes of spam. big_smile
Spamsters: Learn to recognise them yikes , don't talk to them neutral , just report them  smile and let's get rid of them big_smile
#4 2008-12-21 5:02:06 am
Benny Lo
AlmostInvisible wrote:
http://forum.eeeuser.com/viewtopic.php?id=54727
It seems your reference doesn't make any constructive sense.  lol
#5 2008-12-21 5:23:36 am
AlmostInvisible
same subject Benny? hmm tongue
just to show it's been talked about already and there *is* no answer
#6 2009-02-04 8:11:52 am
lifemaster
Hello everybody, does anybody know which other model's keyboards are compatible with 904ha model?
Thank you in advance smile
#7 2009-02-04 1:40:00 pm
Fluterd
The 904HA uses the same keyboard as the the 1000 series (at least the same as everything but the HE with the new keyboard and changed right shift key).
Eric
#8 2009-02-04 3:48:04 pm
lifemaster
Thank you Eric, I have 904ha with German keyboard layout, so, if I buy 1000 series keyboard with English layout, If you know, is  it easy to change, I want to change it by myself smile
#9 2009-02-09 1:42:52 pm
rodsheltra
I have apparently damaged a key retainer in an attempt to relocate my right shift key on a 904HA.  Need to obtain a new retainer.. can anyone point to a source..  thanks!
#10 2009-02-09 2:06:37 pm
Fluterd
lifemaster - I've not changed one out, but I saw a post somewhere where it showed 4 apparent points that hold the keyboard into the body...it looked easy to push those points in, pull the keyboard out, and plug in another one.
rosheltra - sounds like a question for ASUS support.
Eric
#11 2009-02-09 3:08:41 pm
AlmostInvisible
V. Easy to change the keyboard as a whole.
for the guy who wants a key part, I'd look for someone who's changing a duff keyboard who might let you have the remnants for cheap? else just buy a new keyboard.
#12 2009-02-11 6:58:03 am
lifemaster
Eric - I tried and it is realy easy to remove it, thanks for you helpful explanation. smile
#13 2009-02-11 9:06:19 am
Fluterd
Glad to have helped!
#14 2009-02-11 4:45:56 pm
lsosa54
I'll be changing a keyboard out next week  - glad it's not a complicated process.
#15 2009-03-22 10:50:45 pm
mithpower
I can confirm that the standalone keyboard that comes bundled with the eeetop also has the circles around the 1 and 6
Asus EEEPC 701 4G w/ 1gb ram running easy peasy
Asus EEETop 1602 w/ 2gb ram running stock xp home
