Bummer, I did a restore to the default OS and since then the webcam has stopped working.
Interestingly the BIOS had the webcam disabled so I enabled it.
But the system diags don't see the camera and the webcam app just gives me a blank screen, although the webcam app does turn on the green led.
the app eeecamtray seg faults for me and doing:
echo 1 > /proc/acpi/asus/camera
doesn't change a thing.
Any suggestions out there?
I'm going to put the old 512M stick back in and see if that changes anything. (doubtful)
thx in advance..
set bios to os install finished
Thanks Tuxpocket, that did it..
and in record time..
I'll update the wiki to reflect this issue (non-issue)
This is a known issue. Further discussion can be found here: http://forum.eeeuser.com/viewtopic.php?id=1455
Please use the search before posting new topics. Thank you. ![]()
Oh but I did use the search, quite extensively.
it's not in the wiki and searching for 'dead webcam', 'inactive webcam', even 'webcam' didn't turn up anything.
I didn't think to search on 'webcam black image' which gets to the discussion. Note that I was using the diagnostics to determine that the webcam was not working...
Thanks for the help..
I have a USB WebCam that lists correctly when I run Diagnostics > USB > Test as "VIMICRO Corp PCam". Is there a way to activate this external web cam for use with Skype or reording video application ?
ADDED: I also tried my Creative Optia and it also shows up correctly in Diagnostics but no connect in Skype or recording application. ????
