#1 2008-09-10 6:59:06 am
albkwan
Boot Xandros from USB for Dummies
To make the long story short, I have worked out a very very easy solution to boot default Xandros (Eeepc Linux) from USB which is as simple as creating the Asus EeePC System Recovery USB disk, download 2 files: easybootusb.tgz and eeepc-bootusb.tgz, unzip it to the root folder and the folder /runscripts/bootusb/ respectively of the System Recovery USB disk, and reboot. [EDIT 2009/8/16: Changed download link to www.mediafire.com.]
Then just like when you are doing system recovery with an USB flash disk, but instead of wiping out the SSD, the boot script will look for another USB flash disk or SD (not the one with the Eee PC p701L.gz rescue image) and build default Xandros there.
[NOTE: This method has been tested in my Eeepc 4G with a 701 rescue DVD (from my 4G), a 900 Linux Recovery DVD (from my friend) and a 1000H Linux iso (thanks to forum members Ectoplasm and Ottothecow). So I am pretty sure it will work on all models.]
EDIT 2008/9/28:
I have found a caveat for users of 900 or later model with /home mounted on the 2nd SSD (i.e. sdb1) and is not using the auto login. On 1st boot of the Xandros built in USB, the system will find the .firstrundone file in /home/user and will not run the firstrunwizard. Instead it will ask for a password which has not yet been created and thus cannot log in.
To overcome this, before you first boot this Xandros on USB, you need to remove the file /home/user/.firstrundone in your normal Xandros. See this wiki for more details.
For detailed explanation and steps, please refer to my web page: Eeepc Hacks: Boot Xandros from USB for Dummies
For those with a winxp version Eeepc 701 and 900 without the Linux Recovery DVD, you can still download the EeePC 701 ISO image from Eee Community at SourceForge.net. This image, however, will not fully work on a 901 and later models due to different hardware (missing hardware drivers). You will need to fix them by yourself.
For example, yesterday I built a 1000h iso on USB and run it on my 4G. Everything works fine except the network drivers. I have to download the Debian packages for the atheros swan modules (for LAN card) and atl2 modules (for wireless) from Asus update website to get the wireless working and LAN card recognised. But up to now, LAN connection is still not yet fixed.
EDIT 2008/9/28: I have already fixed this. See this thread: Howto: Fix network problem using 1000H iso on a 4G.
EeePC 4G white,
#2 2008-09-10 7:32:21 am
enCrypt
Re: Boot Xandros from USB for Dummies
When you say "Boot from USB", does this also mean it will work booting from an SD(HC) card?
Eee PC 901 / 20GB | Shiny Black | 2GB 667 Mhz RAM | nLited WinXP SP3
8GB SDHC Card
#3 2008-09-10 7:35:06 am
brucine
Maybe not such a good idea to use the recovery stick as an install stick: people not having an external usb dvd drive and having wiped xandros from the ssd (no F9) might have to use, of course not simultaneously, both a recovery disk and an install disk, which would lead to the making of two sticks, one not modified for recovery, and the other modified for your procedure.
#4 2008-09-10 9:17:54 am
Hope
albkwan,
When I made a USB recovery stick from the Recovery DVD/CD which came with my 900 Linux model,  and used it to restore.  It did not touch my 16 GB drive.  It only restored the 4 GB drive.
Others have reported in other threads that the 701 USB restore restores BOTH disks but the 900 USB restore restores only the main drive.
If this is true, will this affect this installation procedure?  Anybody try it with a 900 yet?
White EEE 900 20G | Xandros Easy Mode/Advanced Mode | Computers in my pocket: Zaurus C1000 & Zaurus C3200 | Absolute Beginners - Where to start. | Supported Hardware - WIKI List
#5 2008-09-10 9:30:27 am
Hope
albkwan,
Both links point to the same file - easybootusb.tgz
Where is the easyinstall2usb.tgz file??
#6 2008-09-10 11:53:23 am
albkwan
Hope wrote:
albkwan,
Oh! It's a typo. Because the first server blocks the download, I have changed the filename and put it up in another server. I have corrected the typo.
Yes, including SDHC, USB flash disk, USB hard disk ... , any storage device that can boot from USB.
You can use it both as Asus Eeepc System Recovery Disk and install disk for Boot Xandros from USB. Just keep a copy of the original /boot/initrd.gz, say rename it to initrd.gz.orig. And when you need to restore SSD, rename it back and then it is the original Asus Eeepc System Recovery Disk.
Hope wrote:
albkwan,
In fact, the first part of the System Recovery process is the same for both 701, 900 and 1000h (and I suppose for all Eeepc models). The bootscript boots up from USB drive, seek volume label to mount itself, then dd the p701L.gz image to sda (the 1st SSD). But the p701L image actually only contains the MBR and sda1 (the SYSTEM partition). So only MBR and sda1 is created. The only difference is the p701L.gz image for 1000h is much bigger (almost 2 GB).
It is the 2nd part of the bootscript that run fdisk to create sda2 (the USER partition), and other partitions like sda3, sda4 and format sdb1, the HOME partition, for 900 and later models with 2 SSD. For 701 models, there is no 2nd SSD, so this part of the code is missing in the original bootscript.
Now that I only want to build Xandros on an USB device (e.g. on an SDHC), I don't need partitions sda3 and sda4, and also I don't need to format sdb1, the HOME partition. And I don't touch the 1st SSD at all. But during the install process, when you are asked to select the target USB drive, you can choose to install to sdb (i.e. the 2nd SSD for 900 and later models). It is up to you.
I am not sure about the cause of the strange behaviour of the Asus System Recovery Disk reported in the forum. But what I have found out working on this hack is that the original bootscript is buggy and is not reliable. Once I have booted up with a blank SD and the Recovery USB disk plugged in, but the bootscript mounted the blank SD (instead of mounting itself) in /xan. So in the end, I have rewritten the codes for seeking volume label and mounting the Recovery disk.
Also, I have noticed that some people have reported errors like "cannot stat sda2" during the Asus System Recovery process and subsequently the fdisk process failed in creating sda2. To my opinion, this is because there are some other partitions existing in sda that was still mounted. In such case, at the end, fdisk will refuse to write the new partition table to the disk. It leads me to think that the bootscript somehow found the other partitions and mounted them, which I think is another bug.
Anyway, most of the codes have been rewritten and I have tested them section by section and also in actual creating Xandros on USB with the P701L.gz image from my 4G 701, a 900 and the 1000H hosted by Ectoplasm and Ottothecow.
The only thing I have not been able to test is with a 2nd SSD which I don't have on my 4G.
EeePC 4G white,
#7 2008-09-10 5:02:08 pm
Hope
Got a bunch of errors on bootup. EXT2-fs error bad page constant scrolling of bad page errors.
I have a pretty bad sdhc card - DaneElec 4GB SDHC - that's the card I was trying to install to.  Will try with a USB sstick later but I really don't have any good ones so don't have much hope for it.
#8 2008-09-10 7:45:28 pm
albkwan
Yes, bad SDHC cards will not work. Even if you succeed going thru the process, it will be a pain running Xandros on it.
EeePC 4G white,
#9 2008-09-14 3:41:56 am
plodr
701s do not have more than one ssd. The 4G has a 4GB ssd and the 8G has an 8GB ssd.
HP5550 networked printer
#10 2008-09-14 11:57:30 am
zupoman
When I am finished with this procedure and have a working Xandros on a USB, can I play around with the internal SSDs as I like? Like formating, repartitioning, etc.?
(on a 901)
#11 2008-09-14 12:11:17 pm
albkwan
(on a 901)
The Xandros on USB is not integrated with the SSD. So you can manipulate your SSD in whatever way you like.
I use to use this as my rescue disk and to backup and restore SSD. Especially when you are always playing around with your system, it will be very helpful to have an exact copy of your system at hand so that if you mess thing up, you can check what it is originally on your other copy and restore it.
EeePC 4G white,
#12 2008-09-14 12:30:42 pm
albkwan
UPDATE
I have worked out how to do the same for the xepc recovery disk. Same procedure but different files to download:
easybootusb-xepc.tgz  contains the boot scripts, and eeepc-bootusb-xepc.tgz contains the 4 files necessary to boot xepc.org upgraded Eeepc Linux from USB. [NB. Both 701 and 901 version are supported.] [EDIT 2009/8/16: Changed download link to www.mediafire.com.]
Same as before, unzip easybootusb-xepc.tgz  to root folder of the USB Recovery disk, and eeepc-bootusb-xepc.tgz to the folder /runscripts/bootusb-xepc/, then reboot and select 2 at the task menu.
The advantage of using the xepc recovery disk is that you will have many more free disk space, and programs are latest versions. But it runs much slower than default Xandros. So, there are pros and cons.
For creating the USB System Recovery disk from the xepc-recovery-xxx.iso, here are the steps:
1) Extract files from the xepc-recovery-xxx.iso image to your USB System Recovery disk. You can either first burn a DVD and copy from the DVD, or if you have a CD Image handling tool, you can directly extract from it.
2) Run makeboot.bat in the USB disk to make the USB disk bootable. [NB. Do not run the makeboot.bat in the DVD, you will wipe out the MBR on your desktop drive doing this.]
3) Rename vmlinuz.usb to vmlinuz. [NB. This step is only required for the 701 iso.]
4) Backup initrd.usb if you want to use it to recover your SSD later.
5) Extract the files you have downloaded to the USB disk. Pls note that initrd.usb should go to the root folder instead of to /boot.
6) IMPORTANT: Change the volume label of the USB System Recovery disk to EEEPC. Otherwise it won't be able to mount itself in /xan.
Then you are ready for building xepc recovery disk on USB.
EeePC 4G white,
#13 2008-09-17 12:19:21 pm
albkwan
Another Update: I have worked out the boot scripts for building Xandros on USB without union filesystem. See the Downloads section on my webpage for details.
EeePC 4G white,
#14 2008-09-20 12:19:35 pm
alucard_xs
Hello dudes,
I wanted to install Xandros in my SDHC 16 Go card (since I've got XP on SSD), I followed this tutorial :
http://eeepc.fire.prohosting.com/easybo … tusb.htm#4
BUt when I'm stuck on "expect to write 75305 records of 32k" ... is it long ?
I'm waiting for 10 minutes right now and no changes ...
THanks.
#15 2008-09-20 3:12:45 pm
SchneidersWay
Whats the difference/advantages to with/without unionfs?
901 80GB White  2GB RAM BIOS: 1001
8GB Sandisk Extreme III 20MB/sec SDHC.
#16 2008-09-21 12:00:24 am
albkwan
It depends on which iso you are using and the speed of your SDHC. The 1000H iso is almost 2GB whereas the 901 and 701 iso are slightly less than 1GB, it will take double the time to write this to your SDHC.
Also, when I tested this with a Class 6 SDHC and with a mini-SD, the time difference is almost 4x.
The advantage in using unionfs is the possibility to F9 restore which many beginners have found this very useful. But with a SDHC, you can easily backup the contents of the SDHC in your desktop, so unionfs is not that necessary.
Also, unionfs will make it very difficult to tweak your system. Upgrading software will take up much more additional space. So, if you are the kind who want to tweak your system very often (and have the knowledge to do this), then prehaps no unionfs is better. But if you just want to use the Eeepc as it is, then unionfs is better.
Another point: Unionfs is very sensitive to filesystem errors. So, running default Xandros with unionfs on a poor quality SDHC is a pain.
EeePC 4G white,
#17 2008-09-21 9:58:42 am
albkwan
alucard_xs wrote:
Hello dudes,
THanks.
Tonight, while doing this again. I found that there is a HUGE speed difference between the built-in SD card slot and using an external SD card reader with the same Class 6 SDHC and the same source USB flash disk, same p701L image.
Doing it with an external card reader is less than 5 mins but doing it with the built-in card slot takes more than 30 mins and resulted in errors.
EeePC 4G white,
#18 2008-09-24 10:31:44 am
ralmino
I did the whole process successfully.
The system booted up ok.
Unfortunately it shows a user password screen before I enter Xandros.
I tried to use my root password, but it didnīt work out.
Does anybody know which password is it?
Is it a default password?
Thanks,
Romulo
#19 2008-09-24 9:13:08 pm
albkwan
Thanks,
Romulo
This is strange! Are you really booting off USB now?
Since this is a new installation, it should be running the first run wizard and ask you to set your user name, password etc, just like when you first purchase your Eeepc.
EeePC 4G white,
#20 2008-09-27 3:22:27 am
zelig
I followed the instructions and have it all on a 4gb sdhc it boots to a command prompt
grub>
Should it go further and otherwise, what should i type at the prompt?
White 701 4G Surf, 1Gb. White 1000H, 2gb, 80Gb, Logitech V470
#21 2008-09-27 10:33:52 am
albkwan
grub>
Do you mean your new EeePC Linux on USB boots to the grub> shell mode or the Asus EeePC Recovery USB disk boot to this?
In any case, this would mean the boot loader has failed somehow. Probably installation was not completed. May be there was errors copying the files. Try to do it all over again. If you have an external card reader, better do it with your SDHC in the external card reader. The internal one is not so reliable copying large amount of data.
EeePC 4G white,
#22 2008-09-27 3:41:07 pm
Hope
@albkwan
I succeeded in creating a Xandros sd boot disk by using a USB media card reader.  It was much faster to create and the sd card seems to work okay,  but it is just an original Xandros with nothing modified.  How do I copy over my disk 1 and disk 2 files over to make it an exact mirror of my VERY modified Easy Mode Xandros?
I tried Acronis but it only gives me the choice of restoring to the physical disk 1 and disk 2 NOT the sd card.
I also tried something crazy like trying to reinstall Opera to the sd card,  but it asked for a password and the one I use for my main Xandros install does not work.  What is the password?
You said you use this as a mirror copy of your setup...how do you do that?
#23 2008-09-27 8:41:32 pm
albkwan
If you have not removed unionfs, you only need to copy disk2 (i.e. sda2) to the SD. Depending whether you have built your SD with or without unionfs, the approach will be different.
1) If your Xandros on SD is also with unionfs, then it is very simple. Just mount your sda2 and copy everything (including hidden files) to the 2nd partition in your SD. Say, if you have your SD in an external card reader, it should be something like /dev/sdc2 mounted in /media/XXX/USER_USB. Then run these commands in a terminal:
sudo mkdir /mnt/sda2
sudo mount /dev/sda2 /mnt/sda2
Then open a root file manager (by sudo XandrosFileManager), select [View] > [Show Hidden Files], Then copy everything (except the folder where you have mounted your SD and sda2, otherwise it will be recursive copying) to sdc2.
2) If your Xandros on SD is without unionfs, then it is much more complicated. See this wiki for instructions: Merging changes from partition 2 into partition 1. But be careful not to overwrite the files necessary to boot from USB, i.e. /boot/initramfs-usb-xxx-eeepc.img, /boot/grub/menu.lst, (and /sbin/scanuser.sh, /sbin/formatuser.sh if you are using unionfs).
NB. Remember, the Advanced Desktop does not work well with Booting Xandros from USB. Try to enable icewm start menu instead if you want to have some kind of start menu like the Advanced Desktop.
It is the password you enter at the first run booting up the SD card, not the password of the main Xandros in your SSD.
The Xandros on USB is just the same as the Xandros on the SSD. You can install programs, even "Add/Remove Software" (though not recommended). Anything you have been doing so far on your Eeepc, you can do it there.
EeePC 4G white,
#24 2008-09-27 11:55:18 pm
zelig
albkwan wrote:
grub>
Linux on USB (sdhc card) boots to grub>
Okay. I did it on the internal sd card reader so I'll try it again on an external and report back. Thanks
#25 2008-09-28 8:08:51 am
albkwan
Hope and Romulo,
Do you have a 900 or later model with 2 SSDs? Have you seen the firstrunwizard booting up Xandros from USB?
Just occur to me that if you still have default Xandros running in your SSD, At first bootup of the Xandros on USB, it will be able to find the old files in /home (sdb1) and so will not run the firstrunwizard. In the case of Romulo, if you are used to logging in with password, then you will not be able to log in because password has not yet been set.
To overcome this situation, boot up from your normal Xandros and copy the file /etc/shadow to the corresponding location in sdc1 or sdc2. Or better still, chroot into sdc1 to set password. See this wiki for instructions: Change password procedure.
albkwan
EeePC 4G white,
