#1 2008-08-27 2:22:35 pm
lasertech
HD vents!?
Ok, so I noticed my 1000H was getting a bit warm on the bottom after putting a 7200RPM drive in it.
So I checked the vents on the bottom, not getting any airflow out.
After removing the bottom cover, the silver "shield" that is in there completely covers the vents for the HD.
So after cutting away the material covering the vents, my HD temps are alot happier.
Next thing is to maybe place a small sheet of copper on the HD... I'll report back later on how/if that works.
1000H-2GB RAM-64GB OCZ CORE SSD-GIGABYTE AIRCRUISER N300 WLAN, ALFA USB WiFI + Cantenna
XP Tablet Edition\VISTA\Ubuntu 8.10\Backtrack 3
#2 2008-08-27 3:18:31 pm
AlmostInvisible
Re: HD vents!?
what's the performance change like?
and do you still have the 1 sec tick and flash from the drive light
SEARCH FOR THE ANSWER to life the universe and everything eee
Tough on spam , tough on the causes of spam. big_smile
Spamsters: Learn to recognise them yikes , don't talk to them neutral , just report them  smile and let's get rid of them big_smile
#3 2008-08-27 3:32:49 pm
lasertech
Re: HD vents!?
Performance from the 5400 drive? I never ran the stock drive in it...
Well, the tick is subjective, I have sidebar gadgets monitoring software health and I notice a blink every once in a while.
Sometimes every second or two, sometimes not for 5-10 seconds.
#4 2008-08-27 3:36:40 pm
AlmostInvisible
Re: HD vents!?
naw this is a repetitive 'knawing at yer soul' tick tick tick lol
near enough (just timed roughly for 15secs, 15/16 ticks) 1 a second
ah shame you didn't experience the 5400 speed so you could compare sad never mind wink
#5 2008-08-27 3:56:30 pm
htwingnut
Re: HD vents!?
I thought the power draw from a 7200RPM drive is much higher than a 5400RPM drive, and will definitely create more heat. Battery life will decrease significantly from the 7200RPM unless you can find me one that has a continuous amp draw of 500mA or less.
Acer 1410: SU3500 | 4GB RAM | 250GB 5400RPM | Logitech VX Nano | Win 7 Home Premium x64
Sager NP8662: C2D P9700 2.8GHz | GTX 260m GT 1GB | 4GB DDR2 800MHz | 500GB 7200RPM | Win 7 Ultimate x64
#6 2008-08-27 4:04:25 pm
lasertech
Re: HD vents!?
THe draw is 2X that of the stock drive, but that's what I had laying around.
I plan on getting one closer to the voltages of the stock one.
More heat or not, cutting the material that was covering my vents made a big difference.
#7 2008-08-27 5:00:03 pm
j1huynh
Re: HD vents!?
Please let me know where I can get that copper sheet also.  I am interested using a copper sheet and some thermal paste to help cool the bottom also.
Thanks.
#8 2008-08-27 6:59:35 pm
AlmostInvisible
Re: HD vents!?
next best thing is ally and probably easier to source wink
#9 2008-08-27 11:53:26 pm
markntravis
Re: HD vents!?
The cooling fan only blows air out the left side.
The vent on the front side of the cover is there to draw air in and over the HDD and out the side.  By removing the metal
covering the air is now drawn in, crosses over the end of the HDD and exits as before.  I don't think it was a good idea and
the consequences may not be known right away.
Fine Ebony 1000H|WD Scorpio Black 320GB 7200 RPM|2GB G.SKILL DDR-2 800 PC2-6400
1000HE Keyboard|OS is Windows 7 Home Premium
*I missed my Pearl White 702 8G so I recently purchased a Pearl White 701SD*
Acer Aspire Revo R3600 Atom 330 w/ION
#10 2008-08-28 7:01:15 am
dougeeebear
Re: HD vents!?
I'm curious as to what may be compromised by removing the metal shield.
Asus EeePC 1000H - WinXP Home SP3, 64GB Super Talent 150/100 SSD
"If it ain't broke, fiddle with it until it breaks, then fiddle with it until you get it fixed"
#11 2008-08-28 8:16:25 am
NoelstoyZ
Re: HD vents!?
I did this modification myself but i didn't remove the whole metal shield, i just cut off the piece that was blocking the vent holes on that panel. It helps, it used to heat up a bit but after the modification it brought my temp down really well specially when you put a load on this little thing.
The metal shield helps distribute the heat like a cooper heatsink to bring the heat down but an extra vent hole for it to breathe will certainly not hurt either. Just my 2cents.
I am not a hater just don't push me - 2Pac
Asus G50Vt-X5 | Vista | Centrino 2 | 4GB Ram 800 | 320GB + 320GB 7200 | Nvidia 9800M GS (mine)
Asus X83Vb-X2 | Vista | Centrino | 4GB Ram 800 | 250gb 5400 | Nvidia 9300M GS(my daughter's)
Eee PC on the way?.... My daughter can't make up her mind...Sold the last 2 1000H for the newer atoms coming
#12 2008-08-28 8:17:55 am
dougeeebear
Re: HD vents!?
I had the same thing... I finally figured out it was caused by MobileMeter sampling the HD every second for reporting the HD temp.
I disabled that option in MobileMeter, and it has stopped.
#13 2008-08-28 8:20:30 am
lasertech
Re: HD vents!?
I've been custom cooling PCs for over a decade, and know very well how airflow works.
My CPU temps have dropped by an insignificant amount, but my HD stays on average 5 degrees Celsuis cooler.
If heat ever becomes an issue, and I doubt it will, it will be time to do a custom cooling setup for this little bugger.
j1huynh, You can usually get copper sheets at a hobby or craft store, maybe even some hardware stores.
#14 2008-08-28 3:20:18 pm
AlmostInvisible
Re: HD vents!?
the level of RFI in the room you're in wink big_smile
#15 2008-08-28 4:07:55 pm
markntravis
Re: HD vents!?
Who knows.  I'm sure there is a reason.  Asus didn't put it there just because they had some extra laying around.
#16 2008-08-28 4:54:00 pm
LOVE_GURU
Re: HD vents!?
RF shield most probably.
EEE 901XP ZIF 60GB Samsung, 2GB Kingston PC2-5300, Windows 7 Ultimate
Dell E1405 T7200 Core 2 Duo, 4GB G.Skill PC2-6400, 200GB Seagate Momentus 7200.2, Windows Vista Ultimate 64-bit
Gateway P7805u FX Core 2 Duo P8400, 4GB DDR3, Geforce 9800M GTS 1GB, WD Scorpio Black 320GB, Windows 7 Ultimate 64-bit
#17 2008-09-16 2:09:41 pm
Paul Mathews
Re: HD vents!?
I cut out the vent at the bottom and have found some interesting things.  It seems my HD temp has gone down some, but the system temp seems to be afected much much more. My system temp was at worst 60c+, now it's 45 under load while I am playing an mp3, listening to an itunes podcast and doing a spybot scan all at the same time smile..... Oh and typing this in Firefox :p
My hd and Cpu is stuck at 50c, so that's nice for a laptop i guess, i can see many destop PCs frying under that load, but for a laptop it seems pretty good.
/PS It's spring in Australia at the moment and I have no Aircon on and the ambient temp is 22c, though thats taken off a alarmclock. yikes
Will have to see what the temps do If i take the bottom cover of completley.
Bye.
#18 2008-09-16 2:55:08 pm
radioactivecheese
Re: HD vents!?
I just cut off the sheilding over the vent, I think my hdd spin noise is a lot more noticeable now... sad that sheild is also a bit of a sound dampener I think.
desktop: custom build core2duo e6600, xp pro + ubuntu 8.04, 400GB HDD, 2GB ram, nvidia 7950gt
eee: 1000h xp home + ubuntu eee,  2GB ram
sometime soon: 701 4g for a car pc project
#19 2008-09-17 1:26:14 am
radicalDREAMZ
Re: HD vents!?
could you post a picture of what you cut ?
#20 2008-09-17 2:17:57 am
radioactivecheese
Re: HD vents!?
This shows the vent holes from the out side.
http://i2.photobucket.com/albums/y1/brynrac/WedSep1701-02-55.jpg
This shows where I cut the foil. I just used an exactoknife/razor. I cut off quite a bit more than needed as you can see.
http://i2.photobucket.com/albums/y1/brynrac/WedSep1701-03-35.jpg
Sorry for any grainy/blurriness, blame my eee's webcam and subpar lighting for that.
#21 2008-09-17 11:55:39 am
lasertech
Re: HD vents!?
I'm glad to see that this is working out for more than just myself! smile
#22 2008-09-17 1:12:02 pm
cbutters
Re: HD vents!?
Also, is the hard drive noisier after cutting the metal out?
#23 2008-09-17 1:20:09 pm
markntravis
Re: HD vents!?
Why would this make the HDD noisier?
#24 2008-09-17 1:25:31 pm
radicalDREAMZ
Re: HD vents!?
i just tried it, and damn it does signifigantly lower the temp of the entire eee. less heat, less fan on , less noise!  props for you guys  (:
#25 2008-09-17 1:28:33 pm
ViciousXUSMC
Re: HD vents!?
Because there is less materiel for sound dampening.  It does not make the drive itself louder but allows more of the sound to escape so it sounds louder.
And yes you will hear it more as a few people already stated that did the mod.
Toss a nice quiet WD Scorpio 5400rpm drive with AAM in there and it should not be a issue, I could barly hear my 250gb WD drive when I held it up to my ear with no case on it.
