#1 2008-08-21 8:41:36 pm
0bvious
Instant Keys: more uses
I would like to assign more flexible functions to the 901's two function keys (in windows xp). At the moment the program that is installed to deal with them only lets .exe files run.
Is it possible to assign shortcuts to them (.lnk extension)?
Or perhaps assign hotkeys to them
I would LOVE to be able to assign the ctrl+alt+DOWN hokey to one of the buttons so that when I press it the asus screen rotates - instant book mode!!!
Any ideas on how to add functions to the function buttons?
#2 2008-08-21 11:33:47 pm
Benny Lo
EEEmazing User
Re: Instant Keys: more uses
Mine is not model 901 by If it work for .exe files, I believe there some keystroke automation software could generate an .exe file for you.
I only know one call "Autoit" that could convert their keystroke batch into an exe file, may be there are some better automation program.
702 Black 8G XPP2+EWF | 2GB RAM | XPP3 on SDHC (Fat32) in internal cardreader
S101 Brown 16G XPH SP3 / Win7 RTM | 2GB RAM | 16G SDHC (Fat32)
Asus S5N Centrino XPP2 | 768M RAM | With 8 & 32GB CF Cards as HDD
ASRock N330 (Non-Ion) ITX desktop XPP3 / Win7 RTM  | 2 X 1GB RAM Dual Channel
#3 2008-08-21 11:41:31 pm
mtotho
do u know if there is a way to re-assign the first 2 buttons? i neveruse the screen off and scren resolution change feature.
Want to create your own custom computer? Have no idea where to start? Visit my SITE
Want to create your own website? Check out this site that will guide you along the way, Here
900HA | 2GHz OC | 2GB Ram | Intel 5300 WiFi N | W7
#4 2008-08-22 12:57:53 am
Kai Soto
I haven't seen it mentioned in the Eee forums before, but it's possible in Windows to assign actions to the two available function keys without using the ASUS Instant Key Utility.  That utility simply updates the two Registry keys that are used by the ACPI service, AsAcpiSvr.exe.  The same result can be achieved by editing the Registry directly.
Here's one way to assign Windows hotkey combinations to the function keys.  In this example, the third function key simulates Ctrl-Alt-Up, and the forth function key simulates Ctrl-Alt-Down.  When the Intel graphics service is running - look for igfxsrvc.exe in the Task Manager - the function keys will rotate the screen!
First, use Notepad to create a file called ctrl-alt-up.vbs, and add the following lines.  This script simulates the Ctrl-Alt-Up keypress.
set WshShell = WScript.CreateObject("WScript.Shell")
WshShell.SendKeys "^%{UP}"
Second, create another file called ctrl-alt-down.vbs that looks like this.  This script simulate the Ctrl-Alt-Down keypress.
WshShell.SendKeys "^%{DOWN}"
Before proceeding, double click on those two scripts to make sure they work as expected.  If they don't, check to see if wscript is installed.  It can usually be found at C:\WINDOWS\system32\wscript.exe.
Once the scripts are working, create a file called function_keys.reg, and add the following lines.  This file assigns the previous scripts to the two available function keys.  Note: Change the paths to match the location of your .vbs files.  If you don't specify a fully qualified path for the .vbs files, wscript will expect to find them in the %USERPROFILE% directory.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Asus\EeePC\ASUSACPI]
"QuickKey3"="C:\\WINDOWS\\system32\\wscript.exe D:\\ctrl-alt-up.vbs"
"QuickKey4"="C:\\WINDOWS\\system32\\wscript.exe D:\\ctrl-alt-down.vbs"
Double-click on function_keys.reg to apply these changes to the Registry.  Enjoy your new function key settings.
Based on some other things I tried with this Registry tweak, a function key does not have to point to an .exe file.  I was able to launch a Windows .bat file without any problems.  A .lnk file didn't work directly.  But when I wrapped the .lnk file in a .bat file, that worked fine.  Given the flexibility of .bat files and .vbs scripts, I imagine the function keys could be configured to do just about anything.
I'm not aware of any way to reassign actions to the first two function keys.  Although the names of the Registry keys above suggest that it might be possible to use "QuickKey1" and "QuickKey2", that doesn't work.  The actions are probably built directly into AsAcpiSvr.exe.
#5 2008-08-23 5:46:26 am
0bvious
Incredible.... Thanks so much for that. It is the RIGHT function that I wanted, placing the screen on its side. Your advice made it easy Cheers
Now, if there was only a way to have the mousepad invert its functions to the same direction as the screen.... then only then
UPDATE:
I found this old forum topic about rotating the screen and the mouspad at the same time, but the program it links to doesn't appear to work very well (not at all)?
Is there any way to have the registry file rotate the screen AND the mousepad at the same time? This would mean that with one button press the 901 would suddenly be a perfect 90 degree sideways version of itself.
If it is possible to change the direction of the arrow keys according to the rotation of the screen, that would also be amazing
Any ideas?
#6 2008-08-23 7:31:07 am
david_o
It rotates the screen automatically when I press ctrl+alt+arrows ...
I didn't modify any settings, just installed the latest drivers from Intel's website smile
#7 2008-08-23 9:08:11 am
ricjd
if you're running ubuntu it's quite easy to assign these keys to something
#8 2008-08-23 1:09:57 pm
Kai Soto
There is a program called EeeRotate, which is described in this post, that supposedly rotates the screen and the mouse at the same time.  Maybe that's the program you're referring to.  I couldn't get it to work on my 901 though.
However, the software that EeeRotate uses behind the scenes to rotate the mouse is a freeware program called SakasaMouse.  I found that it works very well on its own.  Once you start the program, the rotation settings can be controlled from an icon in the taskbar.  The settings are stored in a file called sakasa.ini, which lives in the same folder as sakasa.exe.  If you're using Ctrl-Alt-Right to rotate the screen, here are the .ini settings to use.
ReverseX     0
ReverseY     0
Rotate       1
RotateAngle  270
If you absolutely have to have make everything work by pressing a single function key, it probably wouldn't be too difficult to launch sakasa.exe from the same .vbs script that simulates the Ctrl-Alt-Right keypress.  I'll leave that as exercise to the reader.  smile  But if you're willing to hit a few more keys, you could just assign sakasa.exe to one of the function keys directly.  So when you want to enter "book mode", you could just hit Ctrl-Alt-Right followed by the function key.  To restore the default mouse behavior, simply terminate Sakasa from the taskbar icon.
Alternatively, check out the Graphics Scheme technique that is quoted in the same post I mentioned above.
There is also a mouse driver from MAF-Soft that supposedly sits on top of your existing mouse driver and lets you rotate the mouse axis.  I haven't tried it though.  It's trial software that "automatically deactivates after a random amount of time after each machine restart."  No thanks.
#9 2008-08-23 11:21:18 pm
assassin76
But what about the first two buttons!  How can we custom assign those buttons?  Someone should be able to figure that one out, it would be very useful.
#10 2008-08-23 11:43:06 pm
LOVE_GURU
to customize the first two buttons, install ubuntu.
EEE 901XP ZIF 60GB Samsung, 2GB Kingston PC2-5300, Windows 7 Ultimate
Dell E1405 T7200 Core 2 Duo, 4GB G.Skill PC2-6400, 200GB Seagate Momentus 7200.2, Windows Vista Ultimate 64-bit
Gateway P7805u FX Core 2 Duo P8400, 4GB DDR3, Geforce 9800M GTS 1GB, WD Scorpio Black 320GB, Windows 7 Ultimate 64-bit
#11 2008-08-24 1:39:09 am
assassin76
in windows.
#12 2008-08-24 2:18:25 am
LOVE_GURU
No, u can't install ubuntu in windows.  its a hole new operation system.
#13 2008-08-24 5:57:15 am
Kai Soto
assassin76 wrote:
But what about the first two buttons!  How can we custom assign those buttons?  Someone should be able to figure that one out.
Unfortunately, ASUS makes that difficult to do in Windows XP.  The behavior of the first two instant keys is hard-coded into the ASUS ACPI service known as AsAcpiSvr.exe.  From what I can tell by analyzing the program, it registers with the ACPI drivers to get notified when one of the instant keys is pressed.  What it does from there is mostly a mystery.  But it looks like it uses asusacpi.sys and some of the Intel graphics drivers to perform the button actions.
So, in order to customize the first two instant keys in Windows XP, someone would have to write a program that registers with the ACPI driver, detects the button presses, and then performs a custom action.  But it would be have to be done in a way that doesn't interfere with AsAcpiSvr.exe.  Otherwise, the other Fn key combinations might stop working.
Writing the custom action part of the program probably wouldn't be too bad.  Maybe it could be designed to use the "QuickKey1" and "QuickKey2" Registry entries to be consistent with the existing entries for the third and fourth buttons.
I think the ACPI part would be more challenging.  I'm not a driver developer though, so maybe it's not too bad for someone with that background.
Are there any experts out there who are familiar with Windows Driver Foundation (WDF), Windows Development Kit (WDK), or ACPI Source Language (ASL) who would be willing to take on the challenge?  Is anyone aware of a Windows tool that makes it easy to intercept ACPI events?
#14 2008-08-24 6:28:45 am
0bvious
Any idea where to start with this? I would love a one button screen/mouse rotate option
#15 2008-08-24 8:05:22 am
0bvious
OK, I got my scripts together, (thanks to Kai Soto for original scripts)
I have a script called ctrl-alt-left.vbs which contains this:
WshShell.SendKeys "^%{LEFT}"
WshShell.Run "D:\PUTLOCATIONHERE\sakasa.exe"
(note the 'PUTLOCATIONHERE' section)
I have a script called ctrl-alt-up.vbs which contains this:
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
    & "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colProcessList = objWMIService.ExecQuery _
    ("SELECT * FROM Win32_Process WHERE Name = 'sakasa.exe'")
For Each objProcess in colProcessList
    objProcess.Terminate()
Next
I then have the first script allocate to button 3 and the second script allocated to button 4. Once the mouse settings are saved into the sakasa.exe program (90 or 270 degrees depending on the screen rotation) then all I have to do to rotate my screen AND mouse is press button 3. When I want the options to go back to normal (to rorate the screen back and KILL the sakasa.exe program) I just press the 4th button.
Sweet
#16 2008-12-09 12:15:22 am
Redback
has anyone found that the touch pad sensitivity is really screwed up when using it sideways with saskamouse? I have been fiddling with it, and found it quite difficult to make small movements
901 with 32GB Runcore SSD, 2gb Corsair Ram.
Coming soon: Touchscreen, Internal 3G/HSDPA, GPS
#17 2009-02-24 6:49:28 pm
ffb
This thread is really helpful!
The only thing that would be nice to get working is rotated multitouch. If that could work that would be awesome.
#18 2009-09-12 4:55:39 pm
JDazell
FYI
The EeeRotate program works like a charm under Windows 7.   Sorry but the multitouch still does not rotate with the touch pad.  Oh well the rest works great.
EeePC 900A-v1103 | Win7RC | 2GB Transcend DDR2 | 32 GB Super Talent SATA II SSD | 8GB PQI SDHC  big_smile
