#1 2008-08-14 10:30:56 am
Julian Smart
Eee PC SDK/701 virtual machine - missing AsusLauncher.conf
I have an early 701 machine and it's evident that a few things have changed since then, especially with the way icons are installed.
So, since I need to make sure my apps do the right thing for more recent Eee PCs, I downloaded the SDK and after some messing with converting the 701 ISO to a virtual machine file, I finally got the 701 'emulator' working under VMware (on Windows XP).
I expected that the file system in the virtual machine would contain /etc/AsusLauncher/AsusLauncher.conf as documented in the SDK instructions, plus /opt/xandros/bin/update-launcher. But it doesn't - it seems to be halfway between the old 701 environment, and the new one. It does have 130x130 icons and not the 120x120 found on my older 701.
Strangely I can't find any references to this problem. Are developers not bothering with installing an icon, or have I misconfigured things?
I would be grateful if someone could post a bit of an AsusLauncher.conf file so I can check out the format and at least blindly update my installation script.
Thanks for any help!
Julian
#2 2008-08-16 12:30:48 am
Julian Smart
Re: Eee PC SDK/701 virtual machine - missing AsusLauncher.conf
A similar question was posted on the Eee PC SourceForge forum and one solution was to install the required Debian packages from http://update.eeepc.asus.com/p901/pool/. I had previously tried updating various packages via Add/Remove and that didn't do it. I downloaded and installed these packages (the order is important):
imagemagick_7%3a6.2.4.5.dfsg1-0.14_i386.deb
libxml2-utils_2.6.27.dfsg-1_i386.deb
asus-launcher-config_1.0.3-1_all.deb
I attemped to also install asus-launcher_0.173-1_i386.deb but dpkg said that this was older than the installed package.
I now have two virtual machines - one for an Eee PC with the updated launcher, and one without. Unfortunately an installation script has to deal with both situations since presumably there are millions of early Eee PCs in circulation without update-launcher. Not only that, it must detect whether to install 120x120 or 130x130 icons. For what it's worth, here is part of my current Debian post-installation script, for an application called Writer's Café. The function checks whether AsusLauncher.conf is present and if so, uses the new icon installation method copying an XML snippet, otherwise it changes simpleui.rc directly. It also checks whether old-style icons should be copied or the larger kind, by testing the size of one of the existing icons.
# Install icons for the simple interface
installeeepc_simpleui()
  XMLFOLDER=/opt/xandros/share/launcherxml
  LAUNCHERDIR=/opt/xandros/share/AsusLauncher
  NEWLAUNCHERDIR=/var/lib/AsusLauncher
  LAUNCHERCONF=/etc/AsusLauncher/AsusLauncher.conf
  SIMPLEUI=$LAUNCHERDIR/simpleui.rc
  NEWSIMPLEUI=$NEWLAUNCHERDIR/simpleui.rc
  # Test for differing icon size by looking at the file size of a PNG.
  # On early Eee PC systems (120x120 icon size) it is 11871, on later systems
  # (130x130 icon size) it is 15445.
  WEBNORMSIZE=`stat /opt/xandros/share/AsusLauncher/web_norm.png --printf "%s\n"`
  if [ "$WEBNORMSIZE" = "11871" ]; then
    ICONSIZE=120
  else
    ICONSIZE=130
  # Copy the icons
  cp -f "$INSTALLDIR/appicons/asus${ICONSIZE}x${ICONSIZE}/"*.png $LAUNCHERDIR
  if [ -f $LAUNCHERCONF ]; then
    # NEW METHOD
    # Check that /opt/xandros/share/launcherxml is in AsusLauncher.conf
    grep "launcherxml" $LAUNCHERCONF > /tmp/wctest
    if [ ! -s /tmp/wctest ]; then
      echo "/opt/xandros/share/launcherxml" >> $LAUNCHERCONF
    rm -f /tmp/wctest
    mkdir -p $XMLFOLDER
    cp $INSTALLDIR/writerscafe_eeepc.xml $XMLFOLDER
    if [ -f /opt/xandros/sbin/update-launcher ]; then
  else
    # OLD METHOD
    if [ -f $SIMPLEUI ]; then
      # Check if we've already added the parcel
      grep "Writer's Caf" $SIMPLEUI > /tmp/wctest
        cp $SIMPLEUI $SIMPLEUI.prewriterscafeinstall
        sed "s/<\/simpleui>//g" < $SIMPLEUI.prewriterscafeinstall > $SIMPLEUI.tmp
        cat $SIMPLEUI.tmp $INSTALLDIR/writerscafe_eeepc.xml > $SIMPLEUI
        echo "</simpleui>" >> $SIMPLEUI
        rm -f $SIMPLEUI.tmp
      rm -f /tmp/wctest
And a function for the Debian pre-remove script to uninstall the icon:
uninstalleeepc_simpleui()
  rm -f $LAUNCHERDIR/writerscafe_norm.png $LAUNCHERDIR/business_writerscafe_hi.png
    # NEW METHOD
    rm -f $XMLFOLDER/writerscafe_eeepc.xml
  else
    # OLD METHOD
    if [ -f $LAUNCHERDIR/simpleui.rc.prewriterscafeinstall ] ; then
      cp $LAUNCHERDIR/simpleui.rc $LAUNCHERDIR/simpleui.rc.prewriterscafeuninstall
      cp $LAUNCHERDIR/simpleui.rc.prewriterscafeinstall $LAUNCHERDIR/simpleui.rc
My XML parcel is this:
<parcel simplecat="Work" extraargs="/usr/bin/writerscafe2"
        icon="writerscafe_norm.png"
        selected_icon="writerscafe_hi.png">
        <name lang="en">Writer's Café</name>
        <name lang="zh_TW">Writer's Café</name>
        <name lang="zh_CN">Writer's Café</name>
        <desc lang="en">Creative writing tools from Anthemion Software</desc>
</parcel>
I also have a shell script for making Eee PC icons under Windows, based on information from this forum for using ImageMagick. This script is not part of the installation process, it's just a helper to create the icons in advance. To use it, install ImageMagick (and on Windows, MinGW's MSYS for running the script), and in a working directory,  create two directories asus_icons_120x120 and asus_icons_130x130 containing the blank icon PNGs found elsewhere on this forum. Also put the transparent PNG for your own app in both of these directories at the appropriate sizes, named <app>_norm.png. Then run this script passing the program name <app> and optionally a switch e.g. --large to make the 130x130 icons. The result is <group>_<app>_hi.png in one of the icon directories. In my case, I copy business_writerscafe_hi.png and writerscafe_norm.png to my distribution (categorised by icon size) and my Debian install script copies the appropriate ones to /opt/xandros/share/AsusLauncher.
# Makes Eee PC icons from a PNG passed to the script.
# The PNG needs to be of the width and height equal to iconsize below,
# and needs to have an alpha channel. In PSP you can make an alpha channel
# with:
# 1) New Mask -> From Image (using Source Opacity)
# 2) Save to Alpha Channel
# The masked part of the image needs to be positioned towards the top to make
# room for the caption that will be added by the Eee PC.
imagemagickdir="c:/program files/imagemagick"
progname=
infile=
doaccessibility=1
dobusiness=1
dohome=1
dostudent=1
iconsize=120
make_icons()
    progname_hi=${progname}'_hi'
    # "$imagemagickdir/convert" $icondir/icon_background.png  -gravity Center $infile -composite $icondir/$progname_hi.png
    if [ "$doaccessibility" = "1" ]; then
        "$imagemagickdir/convert" $icondir/accessibility_icon_background.png -gravity Center $infile -composite $icondir/accessibility_$progname_hi.png
        echo "Made $icondir/accessibility_$progname_hi.png"
    if [ "$dobusiness" = "1" ]; then
        "$imagemagickdir/convert" $icondir/business_icon_background.png -gravity Center $infile -composite $icondir/business_$progname_hi.png
        echo "Made $icondir/business_$progname_hi.png"
    if [ "$dohome" = "1" ]; then
        "$imagemagickdir/convert" $icondir/home_icon_background.png  -gravity Center $infile -composite $icondir/home_$progname_hi.png
        echo "Made $icondir/home_$progname_hi.png"
    if [ "$dostudent" = "1" ]; then
        "$imagemagickdir/convert" $icondir/student_icon_background.png  -gravity Center $infile -composite $icondir/student_$progname_hi.png
        echo "Made $icondir/student_$progname_hi.png"
usage()
    echo "Makes Eee PC icons from a transparent PNG."
    echo "Pass the root of the icon name - <root>_norm.png should already exist."
    echo "Usage: $PROGNAME rootname [ options ]"
    echo Options:
    echo "    --help               Display this help message"
    echo "    --large              Use 130x130 icons instead of 120x120"
    echo "    --home               Make home icon only"
    echo "    --accessibility      Make accessibility icon only"
    echo "    --student            Make student icon only"
    echo "    --business           Make business icon only"
    exit 1
if [ "$1" = "" ]; then
  usage
  exit
progname=$1
shift 1
# Process command line options.
for i in "$@"; do
    case "$i" in
    --large) iconsize=130 ;;
    --home) dohome=1 ; doaccessibility=0 ; dostudent=0 ; dobusiness=0 ;;
    --business) dohome=0 ; doaccessibility=0 ; dostudent=0 ; dobusiness=1 ;;
    --student) dohome=0 ; doaccessibility=0 ; dostudent=1 ; dobusiness=0 ;;
    --accessibility) dohome=0 ; doaccessibility=1 ; dostudent=0 ; dobusiness=0 ;;
        echo *** Unrecognised option $i.
        usage
        exit
    esac
done
icondir=asus_icons_${iconsize}x${iconsize}
infile=$icondir/${progname}_norm.png
if [ ! -d ./$icondir ] ; then
    echo "Cannot find $icondir."
    exit
if [ ! -f ./$infile ] ; then
    echo "Cannot find $infile."
    exit
make_icons
echo Made ${iconsize}x${iconsize} images.
Phew! Am I overcomplicating things? It seems a lot of trouble just to install an icon, but I don't see how else to cater for the different Eee PC environments in circulation.
Anyway, I now have a Debian package (built with wxWidgets using a desktop Debian Etch virtual machine) that will work on pretty much any Debian-based system, whether desktop or ultra-mobile. gOS systems and the Carphone Warehouse/Elonex Webbook use Debian packages too, but the latter uses a more-or-less standard Ubuntu distribution so the standard .desktop files and accompanying icons are all that are needed. I also distribute my app in RPM form, which should work on the SuSE-based MSI Wind and Advent 4211 Netbook - I don't know if they have a 'simplified' launcher though.
I hope this information is useful to someone.
#3 2008-09-08 9:27:31 am
eeeck
Thanks Julian! I was worried it would have to be something like that, but you seem to have figured out how to get packages installed alright both ways.
Too bad ASUS didn't come up with more packaging-friendly ideas right from the start. The documentation that comes with the software development kit lists two packages, asus-launcher-config and asus-launcher, as required for "adding your application to the ASUS product" (page 22). You're supposed to be able to install and/or update them via the "Add/Remove Software" item. Does anyone know if this is really the case (on the early models)? If so: Which package are they hidden in?
On that note: Does anyone understand how to list the updates from the "Add/Remove Software" item with aptitude on the command-line and vice-versa?
#4 2008-10-14 6:46:56 am
Rob McKay
They're not on my 701 4G but they're installed in the SDK but don't work properly although create-launcher-icons does!
The best method I've found of installing software on the eeePC was similar to Julian's method but I failed to take into account of the new method so it looks like I'm going to have to redo the packages sad
