#1 2007-12-02 7:34:21 am
Johnx
16GB & Bluetooth Mod Complete!
Hello,
I have completed my first Eee PC modification, this modification adds Bluetooth functionality and 16GB of flash storage.
At first I intended to solder the two USB devices directly to the motherboard but after careful consideration I decided the ability to easily replace the modules should take priority.
Both ports are 5V and use the USB connections from the unused Mini PCI Express port and the USB connections from the Mini PCI Express port used by the wireless card.
Thanks to everyone on this board who guided me along the way on my first Eee PC mod!
Parts Used:
30 AWG Wire
Lots of patience
2 * Surface mount USB ports
Microsoft Bluetooth Adapter
Healthy fear of turning your Eee into steaming pile of burnt PCB
Corsair Flash Voyager 16GB
Pictures:
http://www.addison-net.co.uk/eee/01.JPG
http://www.addison-net.co.uk/eee/02.JPG
http://www.addison-net.co.uk/eee/03.JPG
http://www.addison-net.co.uk/eee/04.JPG
http://www.addison-net.co.uk/eee/05.JPG
#2 2007-12-02 7:37:01 am
Neil
Re: 16GB & Bluetooth Mod Complete!
Nice...
#3 2007-12-02 7:43:07 am
joners
@Johnx
Out of all the hacks that people have done to date this is by far the best that I have seen, fantastic work.
Wise words from the 'Engineer' - "Beta does not mean 'better', it means 'not ready'. "
#4 2007-12-02 8:15:45 am
Friko
Good job!
EEE PC 900 Pearl White owner
#5 2007-12-02 8:23:24 am
CTID
That sir, is absolute quality!!
Any chance of some details, where to solder etc??
#6 2007-12-02 11:17:40 am
seventh
great work, i'm amazed!..
Linux user #460555 | 4G/7A - 1gb ram
#7 2007-12-02 11:25:23 am
pounce
How do you have the usb connectors fixed to the board?
#8 2007-12-02 11:30:04 am
digitalfreeze
Props Johnny...that is very clean. pro
#9 2007-12-02 12:01:42 pm
psypher
Wonderful mod! Just need some more info on it now big_smile How about a detailed guide?
psyeee;  4g 701 White. Tried xp & vista, using Xp for now smile
Wants: Keyboard mod big_smile
#10 2007-12-02 12:33:36 pm
InTr4nceWeTrust
Best hack EVER.  That's SOOOO clean.  Great job.
#11 2007-12-02 12:44:17 pm
maximusz
This is fantastic!
Please post detailed instructions / photos / links so we can celebrate and duplicate your success.
#12 2007-12-02 1:23:55 pm
Crihz
Have you hot-glued those on by any chance and used the metal bushing as a ground at the same time?
For people who are willing to try this. Tnkgrl figured out how to do this mod. Here's somew of tnkgrl's pics indicating where to solder to:
http://farm3.static.flickr.com/2377/2043226462_65aa001ed1_o.jpg
http://farm3.static.flickr.com/2056/2050049105_4eadb40511_o.jpg
#13 2007-12-02 1:44:49 pm
pscl227
possible to get some close up pics so we can see exactly where to solder everything?
#14 2007-12-02 2:02:10 pm
saratat
very nice
I have some question
Does the wireless still work??
#15 2007-12-02 2:21:26 pm
TexasGuy
Banned
Maybe drop some plastic glue on the wires to fix them in place...
XP Pro on 2GB RAM, EEE PC Wallpaper
GPS USB device link
Cirago Smallest USB Bluetooth Dongle
Replaced with mini PCI-E A/B/G/N card link
#16 2007-12-02 2:26:20 pm
Crihz
saratat wrote:
very nice
Yes, the wireless will continue to work even with this mod in place because the wireless card doesn't use the USB connections present at the connector.
#17 2007-12-02 3:11:06 pm
refl3x
Very nice, looks very neat and tidy, i think i might make mine just like this. Good work.
Black Eee 4G // 2GB DDR-2 6400 // Win XP Pro // Currently Modding my Eee!
#18 2007-12-02 3:51:42 pm
Johnx
I’ve just completed my tests of the mod, happy to report that all works well. The runtime has been reduced to roughly 2 hours and 50 minutes at which point the battery is at 5% and XP commences automatic shutdown.
I spent a lot of time reviewing the information on these forums before performing this mod, primary threads consulted were:
Results of my research - by tnkgrl
http://forum.eeeuser.com/viewtopic.php?id=2355
Internal USB gadgets on miniPCIe connector – by tristand
http://forum.eeeuser.com/viewtopic.php?id=2334
#19 2007-12-02 3:56:56 pm
Johnx
They are two surface mount USB ports which I stripped from a £1 USB hub, a piece of plastic is attached to the underside to prevent the possibility of a short. The two USB ports have been soldered together to keep them in the same general position. Hot melt glue has been used to secure the ports to the board. My main concern with this was heat generated by the EEE melting it, however after a burn in under full load the USB ports are still fully secure. They are so secure that even after a burn in, with the machine quite hot its still possible to remove the USB dongles without the ports breaking away.
#20 2007-12-02 4:17:53 pm
pounce
Cool. Nice work.
I've been working on creating a simple card that fits in the pcie slot to add the usb connectors since my black model has the connector. It will basically be a U or C shaped card with the usb connectors on the pcie slot site and will screw in to the existing mount holes. I'll still have to add the leads, but will do it with pins on the board and card so I can slip them off and remove the leads as needed later if there is a use for the 2nd on board slot. If I didn't have the slot I'd do like you did and stick it down with hot glue or silicone. Good to know the hot glue works. I get impatient waiting for silicone to harden.
#21 2007-12-02 5:57:37 pm
InTr4nceWeTrust
Will disabling those specific USB ports via device manager help any with the battery life?
#22 2007-12-02 6:17:58 pm
Johnx
It's possible, I will try this at some point in the next couple of days.
John
#23 2007-12-03 1:54:02 am
Phenoum
i'll be doing this but adding a 4slot hub in the space around the screen.  I also plan to try and fit a switch where the useless modem port is  to turn the entire hub on/off to save on battery.  This will just be a simple push -on, push-off switch in the 5v power line to the hub (making sure the switch is deep enough in to avoid bumping it - think -> need a pen or pinky finger to hit it)
also i might design a door or something for the switch.... but first i need my eee.....
Arsenal FC supporter cool 4G Surf Black - 8GB Transcend SDHC - 2GB RAM
#24 2007-12-03 8:42:25 am
vinsen
@Johnx
Are u unplug the wifi card ???
#25 2007-12-03 12:44:48 pm
Johnx
vinsen wrote:
@Johnx
No, it was only removed so I could tap the unused USB connections on the min pci express slot. The wifi card still works fine smile
I've had the laptop with me at work today, pleased to report its still working well. I have followed a guide that enables Windows XP to be installed on a USB device, currently considering installing XP Pro to the 16GB flash drive and leaving the 4GB on board disabled for now. Might even have a dual boot between the stock OS and XP.
Just need to wait for my 2GB ram stick and slimline external DVD-RW now....
