Pages: 1 2
Does anyone have a copy of the Madwifi patch for the eeepc's card? It was pulled because they weren't immediately able to verify the source of the HAL, but I'd like to test it anyway. It's known to work....
i've uploaded it to my site...
http://www.kisslog.com/tmp/patch
Ok so then how would we do this? Would we do everything the same in this code except change the location of the patch to the url above? So would it look like this?
sudo apt-get install build-essential wget 'http://www.kisslog.com/tmp/patch' wget http://snapshots.madwifi.org/madwifi-ng/madwifi-ng-r2756-20071018.tar.gz tar zxvf madwifi-ng-r2756-20071018.tar.gz cd madwifi-ng-r2756-20071018 patch -p0 < ../patch make clean make sudo make install reboot
right? If not will someone tell us how to get it working. I need to get the WiFi on Ubuntu up and running too.
Yes Elusid, I believe that should be an accurate way of rebuilding this driver.
Since I can't be sure if the sources will become available at madwifi.org again, I too have created a backup tarball. The tarball has the snapshot, the eee patch, and the optional injection patch in it.
http://quaggaspace.org/eee/madwifi-eee.tar.bz2
It is what I am presently using on the eee. YMMV.
Much thanks.
Anybody else wonder why the pulled it?
in short: they don't trust (yet) the person who has submitted the (partially binary) patch.
from http://madwifi.org/ticket/1679
<quote>
Sorry to be the party pooper, but I am removing the patch from this ticket until we know the origin of it, and the patch submitter has contacted the developers of this project to co-ordinate the availability of this new code for public consumption.
Scott Raynel has attempted to contact the two mail addresses from Atheros on this ticket in order to receive more information about the situation.
It is, in our opinion, not very responsible to allow an unknown blob to be made available like this. We have no way of knowing what this blob does, and we never will, because its not transparent. But we do _need_ to be informed by the blob vendor what changes it brings.
Hope for understanding.
</qote>
has anyone make this work? performance?
Search the forums. A whole lot of people are using this. It works very, very well. They even found out that the patch was actually from Atheros (the people who wrote the original HAL blob) so all's well with the world.
If it works well and it is actually from Atheros then are they going to repost it?
They're working with Atheros to integrate the patches into madwifi -current. In the meantime, they continue to be available from the usual suspects.
sudo apt-get install build-essential wget 'http://www.kisslog.com/tmp/patch' wget http://snapshots.madwifi.org/madwifi-ng/madwifi-ng-r2756-20071018.tar.gz tar zxvf madwifi-ng-r2756-20071018.tar.gz cd madwifi-ng-r2756-20071018 patch -p0 < ../patch make clean make sudo make install rebootright? If not will someone tell us how to get it working. I need to get the WiFi on Ubuntu up and running too.
I'm new to forum, and thought I'd introduce myself with a problem after lurking for ages ![]()
I have a nice fresh Debian install that I'm trying to get the wireless drivers working on. I've followed the above process and all looks well during the make, I can see the modules are loaded, but unfortunately when I type "iwconfig" I am unable to see the wifi0 device that is needed to configure the rest of it.
Here are the modules I have loaded:
Module Size Used by i915 17600 1 drm 61332 2 i915 ipv6 226272 10 ppdev 8676 0 parport_pc 32132 0 lp 11012 0 parport 33256 3 ppdev,parport_pc,lp button 6672 0 ac 5188 0 battery 9636 0 dm_snapshot 15552 0 dm_mirror 19152 0 dm_mod 50232 2 dm_snapshot,dm_mirror loop 15048 0 joydev 9088 0 tsdev 7520 0 psmouse 35016 0 serio_raw 6660 0 rtc 12372 0 snd_hda_intel 17332 0 snd_hda_codec 137856 1 snd_hda_intel snd_pcm_oss 38368 0 snd_mixer_oss 15200 1 snd_pcm_oss snd_pcm 68676 3 snd_hda_intel,snd_hda_codec,snd_pcm_oss snd_timer 20996 1 snd_pcm snd 47012 6 snd_hda_intel,snd_hda_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer soundcore 9248 1 snd snd_page_alloc 9640 2 snd_hda_intel,snd_pcm atl2 32856 0 pcspkr 3072 0 i2c_i801 7468 0 i2c_core 19680 1 i2c_i801 ath_pci 98600 0 wlan 182256 1 ath_pci ath_hal 279328 1 ath_pci intel_agp 22140 1 agpgart 29896 3 drm,intel_agp evdev 9088 2 ext2 59048 2 mbcache 8356 1 ext2 usb_storage 71840 0 sd_mod 19040 3 ata_piix 13576 2 ahci 17636 0 libata 89396 2 ata_piix,ahci scsi_mod 124168 4 usb_storage,sd_mod,ahci,libata generic 4868 0 [permanent] ide_core 110504 2 usb_storage,generic ehci_hcd 28136 0 uhci_hcd 21164 0 usbcore 112644 4 usb_storage,ehci_hcd,uhci_hcd thermal 13608 0 processor 28840 1 thermal fan 4804 0
but when i use iwconfig i get:
~# iwconfig lo no wireless extensions. eth0 no wireless extensions. sit0 no wireless extensions.
In the dmesg output i can see the following error:
MadWifi: HAL ABI mismatch; driver expects 0x7013100, HAL reports 0x7090300
Does anyone know how i can fix this?
I'd gather from that error that the ath_hal module or the ath_pci module isn't getting installed properly. The driver is looking for a ath_hal that matches it and instead finds one which doesn't.
I believe there is an unload/uninstall script in the madwifi release. You might want to run that to "purge" any old madwifi cruft which is hanging around. Then recompile/reinstall the module and run a depmod -ae and then load the module.
Thanks Quagga, I've given that a try and it has got rid of the error from dmesg, but still no wifi0 device is created. All I see in dmesg now is:-
ath_hal: module license 'Proprietary' taints kernel. ath_hal: 0.10.2.2-ATHEROS (AR5210, AR5211, AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2133, RF2425) wlan: 0.8.4.2 (svn r2756) ath_pci: 0.9.4.5 (svn r2756)
It looks as if everything is OK, I certainly don't see any errors, so I'm a little bemused :S
Once I have this set up I will pretty much have a fully configured Debian install!
Hmm, at this point I'm guessing maybe its something with udev not creating the device? What happens if you ifconfig wlan0 up?
You might need someone running Debian proper (I'm an Ubuntu user) to comment. I'm not sure what that isn't taking.
You may need to use the madwifi tools to create the device.
Try:
sudo wlanconfig wlan create wlandev wifi0
NOTE: if you don't have wlanconfig, then you don't have madwifi tools installed.
I am running Xubuntu so just a guess.
Incidently, I am having some serious issues with trying to create an Ad-hoc connection to a windows PC using the madwifi drivers.
It worked perfectly well with NDiswrapper and NetworkManager (apart from the CPU usage issue).
I have tried the following link (which contains some very very useful info on wifi config commands) : https://help.ubuntu.com/community/WifiDocs/Adhoc
But it still doesn't fix the issue.
I can "see" that wlan0 is up and working and the signal is being received but on the windows PC it doesn't recognise that anything is connected and therefor won't connect itself.
Has anyone tried Ad-Hoc with the madwifi drivers?
I gave up on NetworkManger. The lovely software was just dropping the connection on the eee for no reason. Just poof and offline. I went the old fashioned way and run pre-up scripts in /etc/network/interfaces that pull wpa_supplicant up. Rock solid.
I've never done ad-hoc I'm afraid (and don't have a Windows box either). However, if all else fails I suppose you could set the eee up as an access point. Madwifi should support that as well.
darrylmg: I managed to do it adhoc with the modprobe ath_pci autocreate=adhoc and wifiradar.
Thanks for the tips, quagga. I've downloaded the patch you posted and it runs great. I haven't encountered any issues with the Gnome network manager yet either (touch wood)! ![]()
I wonder if anyone can be bothered making this into a Deb package?
Darn it!!! I've just returned back to ndiswrapper today!
Don't suppose you would mind pm'ing me the extact instructions you used?
Are you connecting to a Windows PC with it?
I did try the method you seem to have used, and I could seem to connect (iwconfig showed a signal strength greater than 0 and a cell number.) but the Windows PC didn't think so and I couldn't ping the Windows PC from the eee, or t'other way round.
Thanks ever so much.
Well, the problem is that you'd be making a package which has to replace drivers in another package (the kernel package). I suppose it is do-able but I'm not sure how to do that. Anyway, I find that just dropping the updated drivers into the Ubuntu kernel works pretty well and isn't super complicated.
Try:Code:
sudo wlanconfig wlan create wlandev wifi0NOTE: if you don't have wlanconfig, then you don't have madwifi tools installed.
Thanks for the suggestion, the tools are all installed, the crux of the problem is that there is no wifi0 device created so the above command fails with a "no such device error". I'll see if the madwifi people can help when I have time, otherwise I'll have to resort to ndiswrapper for the time being ![]()
Fudance wrote:
Try:Code:
I am running Xubuntu so just a guess.Thanks for the suggestion, the tools are all installed, the crux of the problem is that there is no wifi0 device created so the above command fails with a "no such device error". I'll see if the madwifi people can help when I have time, otherwise I'll have to resort to ndiswrapper for the time being
I think that may be to do with the modprobe ath_pci.
Just make sure that the ath_pci and ath_hal are definately not blacklisted in any of the /etc/modprobe.d/blacklist* files.
You can then manually run the modprobe command:
$ sudo modprobe ath_pci autocreate=none
You can then manually run the modprobe command:Code:
Oooo, well it wasn't blacklisted, but dding "autocreate=none" has done the trick and created all the devices. Now to test whether I can get the wireless to actually work.
Many thanks ![]()
Yep, seems to have done the trick. I need to install WPA_supplicant, but thats no bother. Thanks for everyones help.
Pages: 1 2
