It is possible to install the Greek keyboard layout in Easy mode? I can write in Greek Language in Advanced mode, but not in Easy mode.
Thanks....
any ideas???
How did you get it working?
I installed Anthy and SCIM-Anthy to get Japanese going (an IME). I just hit ctrl-space when in any text editor and it appears in both Advanced and Easy modes...
In advanced mode, I installed the Greek keyboard layout through the KDE Control Center (Peripheral Devices -> Keyboard Layout).
Where is the Greek layout In Easy Mode?
in easy mode...
on the task bar -
right click on the input method
open scim setup
front end - global setup
change the keyboard to greek.
btw are you in athens. I'm in maroussi right now.
Changing your KeyoardLayout in xorg.conf:
Press: ctrl + alt + t
Type "sudo nano /etc/X11/xorg.conf"
Press ctrl + _ (ctrl + underline, you may need to press shift to to get the underlinekey)
Type "35" to find the line where you change the keyboard layout.
and change from "us" or what ever you se between the " " on that line, to your countries code. Im guessing "gr" since here in norway we use "no"
Press "ctrl + o" to save after youve made your change.
Now your kayboard layout will stay changed even if you reboot.
EDit : as said under greece is "gr", dunno if i was thinking germany or what ever with "ge". hehe
greece is gr
Thanks to all I installed the Greek layout in Ease mode, but it is impossible to write accented Greek characters. Any ideas???
To AndyW
I live in Mitilini town because I work in University of the Aegean.
I have the same problem too. it seems that its a bug with an old version of gtk installed in the asus linux. In fact you cant write accented characters in programs like firefox and thunderbird, but you can write accented greek characters in OO and terminal...
im trying to find a solution, do contact asus support.
My problem is that I can’t write accented Greek characters in OO. My OO writes first the accent and next the character (΄ο, ΄α ΄ε not ό, ά, έ).
Dear friends can list your xorg.conf file? (/etc/X11/xorg.conf)
Changing xorg.conf file is not enough. But take a look into thread
http://forum.eeeuser.com/viewtopic.php?id=1580
There seems to be answer for the problem. I haven't yet have time to check if that works for swedish/finnish/estonian keyboard settings, but I assume so. Greek keyboard layout should work as well.
There still seems to be no wiki entry for this. But I try to do one soon as I have time to take a look into the issue and of course, get it working
(trust me, that won't happen this week, so if someone has time for that, please...)
This keyboard layout seems to be an issue what xandros haven't thought about...
The problem is that the input method manager, SCIM, is interfering with the built-in X11 input method, so compose sequences don't work.
It's best to disable SCIM if you don't need to type Chinese - Greek accents will work fine afterwards. The easiest way is to remove the "xandros-scim" package. See the following wiki page for information:
http://wiki.eeeuser.com/howto:removeinputmethodicon
Edit: Here's the relevant section from my /etc/X11/xorg.conf:
Section "InputDevice"
Identifier "Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbLayout" "us,gr"
Option "XkbVariant" ""
Option "XkbOptions" "grp:alt_shift_toggle"
EndSectionThe last line is new, you have to add it. It's the way you toggle between the US and Greek keyboard layout. Other possibilities are (from /usr/share/X11/xkb/rules/xorg.lst):
grp:switch R-Alt switches layout while pressed. grp:lswitch Left Alt key switches layout while pressed. grp:lwin_switch Left Win-key switches layout while pressed. grp:rwin_switch Right Win-key switches layout while pressed. grp:win_switch Both Win-keys switch layout while pressed. grp:rctrl_switch Right Ctrl key switches layout while pressed. grp:toggle Right Alt key changes layout. grp:lalt_toggle Left Alt key changes layout. grp:caps_toggle CapsLock key changes layout. grp:shift_caps_toggle Shift+CapsLock changes layout. grp:alt_caps_toggle Alt+CapsLock changes layout. grp:shifts_toggle Both Shift keys together change layout. grp:alts_toggle Both Alt keys together change layout. grp:ctrls_toggle Both Ctrl keys together change layout. grp:ctrl_shift_toggle Ctrl+Shift change layout. grp:lctrl_lshift_toggle LCtrl+LShift change layout. grp:ctrl_alt_toggle Alt+Ctrl change layout. grp:alt_shift_toggle Alt+Shift change layout. grp:menu_toggle Menu key changes layout. grp:lwin_toggle Left Win-key changes layout. grp:rwin_toggle Right Win-key changes layout. grp:lshift_toggle Left Shift key changes layout. grp:rshift_toggle Right Shift key changes layout. grp:lctrl_toggle Left Ctrl key changes layout. grp:rctrl_toggle Right Ctrl key changes layout.
I think there are other ways to configure this, maybe from kcontrol, but that's what I've always done.
Adia you are the best!!!
Thank you very much.
adia thanks alot , I had tried nearly everything on the locales and still couldnt get accented characters....
thanks again
Thank you, it worked!!! Χαιρετισμούς από Ηράκλειο Κρήτης!
i have tried to change the xorg but when it reboots it stays in the screen that says starting system
the only way is from kcontrol but i have to do it everytime i boot
please help.
Hi everyone,
Pos mporo na valo tonous stis ellhnikes lekseis ?
To ellhniko pliktrologia den moy deixnei tonous.
panospc: If it doesn't start correctly after editing xorg.conf, chances are you have made some small mistake in the file's syntax. Check that all quote marks and punctuation are exactly as in the example. If in doubt, you could send here the changes you are making, so that others could check there are no errors.
d21061965: Το πλήκτρο του τόνου είναι το ";" - αφού γυρίσεις το πληκτρολόγιο στα Ελληνικά, πατάς το ";" και μετά το φωνήεν που θες. Αν εννοείς ότι πατάς τόνο αλλά δε δουλεύει, θα πρέπει να απενεργοποιήσεις το SCIM όπως αναφέρθηκε παραπάνω.
(in English: The accent key is ";" - after switching the keyboard to Greek, you hit ";" and then the vowel key you want. If you do that and accents don't work, make sure you have deactivated SCIM as mentioned above)
kalhmera dystyxws den mporesa na to kataferw.afou ekana to pwto bhma na apenergopoihsww to scim, katopin egrapsa thn entolh sudo nano /etc/x11/xorg.conf alla mou bgazei keno.please help i'm lost
Hi everyone from Ioannina! I'm about to try setting up the Greek keyboard in Easy Mode - will ask for help if I have a problem.
greek eee pc? check this out:
http://blog.edu.gr/archives/13
Everything is working.Είναι Θαυμάσια!! Ευχαριστώ....
τελειο, γραφει ελληνικα!!!!μπραβο σε οσους βοηθησαν.
