#1 2008-07-24 11:27:09 am
rev3nant
Eee PC 901 Model List
Since it turned out newer 901s don't have ZIF, I thought of gathering model and revision info for future buyers (in case ZIF presence really depends on these numbers). If you don't see your Eee's model/revision (or beginning of serial number) in this list, please post.
with ZIF
Model: EEEPC901-W001X (12G, White)
Rev: 901 12
Model: EEEPC901-W002X (12G, White)
Rev: 901 12
Model: EEEPC901-W003X (12G, White)
Rev: 901 12, 901 24
Model: EEEPC901-W004X (12G, White)
Rev: 901 12
Serial: 860AAQ
Model: EEEPC901-W005X (12G, White)
Rev: 901 12
Serial: 860AAQ
Model: EEEPC901-W007X (12G, White)
Rev: 901 24
Serial: 860AAQ
Model: EEEPC901-BK002X (12G, Black)
Rev: 901 12, 901 24
Model: EEEPC901-BK002 (20G, Black)
Rev: 901 12
Serial: 870AAQ
Model: EEEPC901-BK003X (12G, Black)
Rev: 901 12
Model: EEEPC901-BK005X (12G, Black)
Rev: 901 12
Serial: 860AAQ
Model: EEEPC901-BK007X (12G, Black)
Rev: 901 24
without ZIF
Model: EEEPC901-W001 (20G, White)
Rev: 901 12
Serial: 870AAQ
Rev: 901 24
Serial: 870AAQ
Model: EEEPC901-BK001 (20G, Black)
Rev: 901 12
Serial: 87OAAQ
Rev: 901 24
Serial: 870AAQ
Model: EEEPC901-W006 (20G, White)
Model: EEEPC901-BK006 (20G, Black)
Model: EEEPC901-RP001X (12G, Pink)
Model: EEEPC901-RP002 (20G, Pink)
List of Eee PC 901 Models that have (or don't have) a ZIF socket
#2 2008-07-24 12:00:42 pm
Andrel
Re: Eee PC 901 Model List
with ZIF
Rev: 901 12
#3 2008-07-24 12:03:15 pm
Nickman1200
with ZIF
Model: EEEPC901 - BK002 (20G, Black)
Serial: 870AAQ
Rev: 12
Black Asus EEE 901, 4GB SSD + 30GB HDD + 8GB SDHC.
Dualboot: Ubuntu 8.04 on SSD, XP on HDD.
Extras: Slim DVD-R Dual-layer, BT GPS, 2GB RAM.
#4 2008-07-24 6:19:29 pm
arrc
with ZIF
Rev: 901 12
Serial: 860AAQ
#5 2008-07-24 6:43:14 pm
lunkwill336
Without ZIF
Rev: 901 24
Serial: 870AAQ
#6 2008-07-24 10:45:26 pm
designarchitect
My black XP 901 is BK-002X, Rev 901 24 with ZIF.
#7 2008-07-25 12:28:39 am
calvinsy
with zif
Rev: 901 12
Serial: 860AAQ
901 black | 2gb | 80gb samsung 1.8"zif | 8gb ssd sold | 4gb ssd removed and selling | windows 7 rc 7100
#8 2008-07-25 12:52:50 am
JazzplayerL9
Without ZIF
Rev: 901 12
Serial: 87OAAQ
#9 2008-07-25 1:34:27 am
rev3nant
Looks like serial doesn't mean anything (at least first 6 letters/numbers).
#10 2008-07-25 8:53:24 am
jdmacken
with ZIF
Rev: 901 12
#11 2008-07-25 9:37:18 am
mobelby
with ZIF
Model: EEEPC901-W005X(12G, White)
Rev: 901 12
Serial 860AAQ
901 XP White, Bios 1202, 2GB Corsair Value Select RAM
#12 2008-07-26 8:50:19 am
alppu
with ZIF
Rev: 901 12
http://www.ruoste.com/stuff/eee/asus901.jpg
#13 2008-07-29 8:52:38 pm
naviathan
Where did everyone buy their EEE?
Blue 1000HE - This thing rocks!
Ebony 901 - Back from the dead!
Linux Enthusiast, Free and Stable, it's what Windows should have been.
Hack the planet! --"Hackers" (1995)
#14 2008-07-30 4:40:10 am
James_patageul
humm just a simply question what is a zif ? cpu connector ?
thx people.
#15 2008-07-30 5:52:47 am
rev3nant
ZIF is a zero insertion force connector. Aside from other things it is used in 901s to connect 1.8" HDDs.
#16 2008-07-30 5:59:00 am
ShaqARif
I bought this one  yesterday from Micro Anvika in Harrods:
Rev: 901 12
Serial: 860AAQ
As already noted in the first post, this does have the ZIF (I opened and checked).  At around 7:30PM they had 4 left, if you can get there quick enough, you may get lucky...
---- eee pc 901 Glossy Black 1GB RAM 4/8GB SSD --------- CrunchBang Linux (adamms kernel)  ------
#17 2008-07-30 9:05:52 am
naviathan
Has anyone bought their EEE 901 from newegg and it have the zif socket?
BTW, why are we calling this a ZIF socket?  That's kind of a generic term as there are many different kinds of ZIF sockets.  Processors use a type of ZIF socket, as do most data cables used in small electronics today.  What is this interface actually?  Some kind of mini IDE I would guess?
#18 2008-07-30 11:19:04 am
rj3005
(P)ATA
EEE 702 White with internal mods: 2Gb mem, touch screen, USB Hub, 32Gb USB stick - XP
EEE 901 Black with internal mods: 2Gb mem, Zif Samsung 64Gb SLC SSD + 32Gb USB stick (internal), Novatel 3G, W7 home premium
EEE 901 White 1Gb Mem, 2X Runcore 16Gb Sata ( Second one located at the 3G area and wired to primary SSD slot) W7 home premium
#19 2008-07-30 11:27:11 am
Gadgeteerer
What's the "real" downside of not having ZIF?
Have Asus used an alternative type of connector which still allows adding a HDD, but needs a little more Force?
#20 2008-07-30 11:39:06 am
mtotho
haha no, just empty solder points for us to look at and wish we could install a hdd. bust instead you want to use alot of force and slam the eee against the wall (EIF connector-extreme insertion force)
Want to create your own custom computer? Have no idea where to start? Visit my SITE
Want to create your own website? Check out this site that will guide you along the way, Here
900HA | 2GHz OC | 2GB Ram | Intel 5300 WiFi N | W7
#21 2008-07-30 12:29:22 pm
naviathan
rj3005 wrote:
(P)ATA
Awesome, thanks for the reply.  I was hoping for SATA, but that's good to know.
#22 2008-07-30 12:33:48 pm
mtotho
naviathan wrote:
rj3005 wrote:
(P)ATA
it is pata, but u will be able to find the hard drives by searching for "zif hdd", or "1.8" hdd".
make sure the physical connector is a 40(?) pin ata zif connector.
#23 2008-07-30 12:48:17 pm
naviathan
I can find hard drive for PATA easily enough.  I was hoping for a SATA port so I could wire up an eSATA connector.
#24 2008-07-30 12:52:06 pm
mtotho
the internal interface is PATA.. it has nothing to do with the actually connector.. it is a ZIF connector, search for ZIF 1.8" hdd or ssd.
Even Sata drives of this form factor have ZIF connectors.. so either way u could not use esata
#25 2008-07-30 12:55:57 pm
naviathan
I'm not concerned with the actual connector.  If it was a SATA interface I could have built a convert cable to attach the SATA port to a bulk head eSATA connector.  Can't do that with PATA as it doesn't accept most SATA commands and isn't hot swappable.
