#1 2007-11-28 9:03:23 am
Longhorn Engineer
Ubuntu Fn Keys Operational How To
To get your Fn Keys working first install the asus_acpi via this link (thanks quagga!)
http://forum.eeeuser.com/viewtopic.php?id=3413
Open up your service manager (System>Administration>Services) and make sure both Power Management options are filled (acpid and acmd).
In terminal type the following to stick you in the right directory to edit the scripts the Fn keys will call.
cd /etc/acpi/
Edit the volume up script
sudo gedit volupbtn.sh
replace the contents with
#!/bin/bash
action= amixer set Front 3.20dB+ unmute
Edit the volume down script
sudo gedit voldownbtn.sh
#!/bin/bash
Edit the mute script
sudo gedit mutebtn.sh
#!/bin/bash
action= amixer set Front toggle
Then delete some files to prevent conflicits. These two files where messing up all the FN keys into thinking that they where brightness keys
sudo rm asus-brn-down.sh
sudo rm asus-brn-up.sh
Now we need something to read the Fn keys
Type
cd events
Edit the Volume down file
sudo gedit asus-volume-down
event=hotkey ATKD 00000014
action=/etc/acpi/voldownbtn.sh
Edit the Volume up file
sudo gedit asus-volume-up
event=hotkey ATKD 00000015
action=/etc/acpi/volupbtn.sh
Edit the mute file
sudo gedit asus-volume-mute
event=hotkey ATKD 00000013
action=/etc/acpi/mutebtn.sh
Now to have asus_acpi start up on boot
 sudo gedit /etc/modules
add the following after the last comment
asus_acpi
Restart your EEE and see if it worked! What doesn't work is wireless on/off, F5 thing, and F6 thing.
I am close to the wireless but I need some of the files from the original OS (/etc/acpi/wlan.sh) to make it work I think. I someone can email me that file I can hopefully get it to work.
The F6 key is event 00000012. F5 jey is event 00000030, 00000031, 00000032. F2 is event 00000010.
edit// I should mention that F1 and the brightness keys still work and are functional after this. The only Fn keys that don't work are F2,F5,F6. Will a little bit of hunting the script for the F5 should be found and the script for the wireless shuold be easy. I couldn't get F6 to work because I tried to get the script to run gnome-session-manager and for some reason the key function wouldn't work even tho the script worked.
#2 2007-11-28 12:37:56 pm
Shades
Re: Ubuntu Fn Keys Operational How To
My F5 only reports 30, not 31 and 32. It would be easier to create the xrandr scripts if it actually reported different acpi codes. I wonder if I have done anything wrong?
#3 2007-11-28 5:49:40 pm
Longhorn Engineer
Well the 31 and 32 events are taken from the hotkey.sh files on the original OS. I betcha if you took the files from /etc/acpi and etc/acpi/events on the original OS you could get all the scripts working. Are these files located somewhere on the install CD or do I have to install the OS to get the files?
#4 2007-11-30 10:12:05 am
gh3
i tried to have get F5 working looking at this http://forum.eeeuser.com/viewtopic.php?id=2770 but no way... any advice on how to get it working?
#5 2007-11-30 6:14:05 pm
Longhorn Engineer
OK update time
I have working
F1 Sleeps
F3-F4 Brightness
F5 changes video output (swaps between LCD External LCD/External)
F6 opens gnome-system-monitor
F7-F9 volume
Closing the Lid puts it into sleep mode
Hitting the power button brings up the shutdown choices
Only thing that doesn't work 100% is the dam wireless on/off
I know how it turns off but getting it working after turning it back on is troublesome.
#6 2007-11-30 6:43:50 pm
Shades
Nice! I hope you will let us know how you did it when it's all done.
#7 2007-11-30 7:38:16 pm
mobad
I found this http://forum.eeeuser.com/viewtopic.php?id=2890 a while ago, I haven't tried it but I hope this will fix the wireless issues.
#8 2007-11-30 7:48:09 pm
benob
I used scripts from http://cliffhacks.blogspot.com/ along with the binary drivers (no ndiswrapper). it supports wifi on/off and suspend. for the hotkeys, I literally copied the xandros file to my ubuntu and it works great.
#9 2007-11-30 8:04:41 pm
Longhorn Engineer
where did you get the driver from?
#10 2007-11-30 10:20:13 pm
samiux
Hi Longhorn Engineer,
You can get the source code of the wireless driver at ftp://ftp.asus.com/pub/ASUS/EeePC/701
Samiux
#11 2007-11-30 11:10:06 pm
mobad
Samiux
...No you can't, at least not that I can see.  There is the LAN driver and the modem driver and unless you mean the kernel than it's not there.  If it exists, a link would be greatly appreciated.
#12 2007-12-01 5:49:53 pm
Greenie
the driver works using this version of madwifi with a patch (all from the eeeuser ubuntu wiki)
http://snapshots.madwifi.org/madwifi-ng … 018.tar.gz
http://madwifi.org/attachment/ticket/16 … format=raw
originally from here: http://madwifi.org/ticket/1192#comment:186
EDIT:
Longhorn Engineer: This driver seems to work fine coming back after suspend, so this should work awesomely with your acpi shortcut button howto, which when i get five minutes i will sort out for my eee smile
/ Black Eee 901 (Ubuntu 9.10/Moblin V2) / 2GB RAM /
#13 2007-12-01 7:32:07 pm
SuperDad
I updated all the scripts, with mixed results.
Volume down (f9) works, but volume up (f8) doesn't do anything.  Mute (f7) will mute the volume if it's on, but it won't turn it back on if it's already muted.
F1 Sleep and f11 NumLock, both seem to work.
What kind of mistakes can I look for?
I'm not entirely sure that I properly installed the acpi module from Quagga's instructions.  Is there a way that I can check that?
#14 2007-12-01 7:39:52 pm
Greenie
if the asus_acpi.ko file compiled correctly, and was copied over the previous asus_acpi.ko, then it will be working.
its most probably a mistype or spelling mistake in the files you edited, when i did it, everything worked except volume down until i re-copied the text from the tutorial in.. i spent ages looking at the file wondering what was wrong.
#15 2007-12-01 8:43:32 pm
SmallFootprint
#!/bin/bash
SHOULD BE "3.20dB-" i.e. sound to go down by 3.2 dB.
#!/bin/bash
I have set this, and can monitor the changes that occur to the mixer using "alsamixergui" and can see that it does
indeed toggle the Front channel, but it does not toggle the actual sound being played, e.g. an mp3 file played with Totom; odd.  Toggling the "Headset" option toggles the headset sound o.k.
Type
cd events
F5 key is event 00000030, 00000031, 00000032.
Will a little bit of hunting the script for the F5 should be found ....
Well, one script would be "xrandr --output VGA --right-of LVDS --mode 1024x768".   Or just "xrandr --auto" should work to toggle between vga out and LCD as one plugged/unplugged VGA.  Is this a matter of just editing "/etc/acpi/events/videobtn" and "/etc/acpi/videobtn.sh"to give it the right event number?  What does it mean to have three event numbers?  Does it cycle between them (LCD, VGA, LCD&VGA?)?
And I see one can see the events using "cat /var/log/acpid"!  That's useful...
#16 2007-12-01 9:00:49 pm
samiux
Please post your hard work here, thanks.  I am waiting for it for a long time.
Samiux
#17 2007-12-01 9:05:36 pm
samiux
The wireless driver is here :
http://wiki.eeeuser.com/ubuntu#wireless … fi_drivers
Samiux
#18 2007-12-01 9:23:27 pm
mobad
Can anyone post updated scripts?  That would be great.
#19 2007-12-01 9:29:01 pm
Longhorn Engineer
I will once I am 100% certain they are working.
I will post the entire files so all you will have to do is drop them in and they *should* work if you have everything installed correctly.
Wifi button is still sketchy but it is working about 90% of the time.
Update on Wifi!
Ok I figured out that it only doesn't work on the first turn on of the wifi
That is if you do
Off-On it doesn't work but if you do
Off-On-Off-On it does work...How strange.. so I just modified the script and had it run the "on" function twice in a row and it worked. I am going to have to go through and see what really is the problem.
#20 2007-12-01 10:04:11 pm
SuperDad
#!/bin/bash
Sweet, thanks dude, that worked for me.
So if the volume up, volume down and sleep keys are working, can I assume I correctly made and copied the asus_acip.ko?
I appreciate all the help given here.
#21 2007-12-01 10:36:10 pm
Longhorn Engineer
SuperDad in a day or so I will make a sleek how to on how to get the hotkeys up in running on the EEE. Just have to do some more testing before I release the scripts.
#22 2007-12-01 10:52:17 pm
SmallFootprint
So one way, at least to get video out with the hot key:
(1) edit /etc/acpi/events/videobtn to read
event=hotkey ATKD 00000030
action=/etc/acpi/videobtn.sh
(2) edit /etc/acpi/videobtn.sh to read
action= xrandr -display :0.0 --output VGA --right-of LVDS --mode 1024x768
Then either reboot or restart the /etc/init.d/acpid daemon (learned that one the hardway).  This turns on my VGA out.
It would be nicer to have it toggle VGA-out on/VGA-out off....  Perhaps a fancy script of some kind?
In my case, I like this key because I can use it right before giving a presentation, rather than fumble with some line command.  And in this case, what happens after the presentation is not so critical; I can turn VGA-out off by hand.  But it would be nice to have a toggle...
#23 2007-12-01 11:26:59 pm
Longhorn Engineer
smallfootprint
my scripts toggle the video to LCD, VGA/LCD, VGA
They default to 800x600 on VGA but you can change it by going to the display settings and change the resolution there.
#24 2007-12-02 10:02:07 am
gh3
OK update time
I have working
F1 Sleeps
F3-F4 Brightness
F7-F9 volume
can you post here or in wiki how to get these things working?
#25 2007-12-02 2:42:28 pm
Longhorn Engineer
I will once I get it all done. Right now my wifi script is working but its kinda hack and slash. Also F6 is causing problems because gnome-system-monitor only wants to open once per session by the way I am calling it.
