#1 2007-11-27 10:48:08 pm
Chad
Sierra 3G USB driver here! (or: I can build kernel modules!)
Using the newly released kernel source .deb, I was able to rebuild the kernel, then build the sierra.ko driver needed to properly set up the tty ports provided by my Sierra 595U.  I think I got my copy of wvdial from Debian etch, if it wasn't already loaded (might have been!)
You can get the sources here:  http://sources.sbrio.org/eee/ - the driver itself is in siera-3g-eee.tgz, and the wvdial.conf file is provided too.
By extension this means that I was able to successfully match the eee kernel's modversions!  Once installing the .deb the kernel tarball is provided in /usr/src.  I put up the Module.symvers file up as well, so that you may only have to copy in the config-2.6... file found in /boot to .config, then run make oldconfig && make prepare.  I had to build the entire kernel to produce that file. wink
In addition the other source releases from Asus are available here, un-rar'd for easier hacking.
#2 2008-01-04 1:15:46 pm
ichelle
Re: Sierra 3G USB driver here! (or: I can build kernel modules!)
Chad, thank you for your help. I too need to configure my Sierra 595U and am going nuts. Could you please provide a step-by-step for us newbs?
Thank you, I appreciate it.
#3 2008-01-13 11:31:40 am
ichelle
hi chad, sorry to be a constant bug but i really would like to get my card configured. could you please provide me newbie instructions? i'd really really really appreciate it! thank you.
