Someone "intrepid" try the new ubuntu Intrepid Ibex on eeepc? They promise compatibility 100%
Yep , downloading the alternate iso right now . I will install it and report later on . ![]()
Edit : in the bug-list , it says wireless doesn't work on the eeepc . Let's see !
Thanks I'm wating your report , good luck :-)
I had forgotten it took so much time to install Ubuntu ! Now it's 2:45 a.m so I will report later on.
Ethernet works all right ; wireless not , I installed Wifi-radar but it is buggy and won't work for the moment
The eye-candy is dark-brow and in the same inspiration as Parsix . I'll post screenshots tomorrow morning...time for sleep now!
Here are some screeshots of the new Ubuntu , "Interpid Ibex":
From what I have been testing so far :
~ the installation was a little buggy , as I was told there was no CD in the CD-drive , and that there was no internet connection available
~ the booting time: (Ibex is installed on a 4G SDHC , not on the SSD )
= 70 seconds till login screen , with 4 wonderful funky orange bars instead of one
= some more 40 seconds till everything gets functional ( meaning you can surf the internet )
~ total size 2.0 G (full installation , no "skimming")
~ No more "We welcome you with drums and beats" , sound is properly established at 81% ( no noisy surprise)
~ Firefox 3 works well
~ Ekiga: no video image
~ You have to disable Compiz in order to be able tohandle window's moves correctly
~ Users and groups : buggy , sometimes authentification will failed , sometimes not
~ Atheros Wireless LAN card support present , wpa_supplicant too . No ath0 detected , wifi non bringeable by the usual "sudo ifconfig ath0 up" (answer : no such interface).
/etc/network/interfaces # This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). # The loopback network interface auto lo iface lo inet loopback
I am a young Linuxer so I'll fiddle the Wifi interface later on ! I've installed Wifi-radar but it bugges .
~ Couldn't listen to radio on Rhythmbox , I have not tried CD or USB storages .
~ I've not been testing Evolution , nor Transmission , nor Pidgin , nor games ( and I won't , they will directly go to the dustbin).
~ Login out is really buggy , you have 40 seconds of reddish vertical bars flashing.
~ No LED still on after shutdown , the soundcard is off .
~ Fn +function keys : no OSD , brightness up /down works , Wifi LED still on and not working
The eye-candy is interesting , with Ibex glacé chesnut warm colors .
But being now accustomed to Debian , I miss the double password , one for the user and one for the administrator . Sometimes in Ibex you don't even need a password to access important data that should be protected .
So , today I'll be exploring further Wireless interface , music listening abilities , webcam and video means .
PS: I must say that I am a little disappointed by the 2h45 of installation of Ibex , compared with the less than 30 minutes of Parsix ( nearly same eye-candy for the two) , Parsix having really more functional applications in video , audio , TV , security fields . I love Ubuntu , but I prefer Debian.
I installed RiceeeyTweak , so OSD are functional .
Fn + function keys are working , except Fn + F2 for Wireless , which always tell Wireless is off . And The blue LED for Wireless is always on , never off .
I desinstalled Wifi-radar and reinstalled it , as there was a sudo-to-root bug , but I still got no chance , it was still buggy and non-usable .
So no Wireless at the moment .
Merci beaucoup, thanks alot Oupsemma, your ability with linux distros is better than I (I'm new after 10 years in Windows) I think that personaly wait the final 8.10 ( I remember Canonical say that is 100% fully compatible with EEEPC) at the moment the only problem I have with the 8.04 Hardy is microfone not working or badworking in AMSN and Skype; Thank a lot for your report monseur
Not Monsieur !
You will probably want to manually compile the wireless drivers. Details in http://wiki.eeeuser.com/getting_ubuntu_ … bling_wifi
Yep, you'll need to blacklist the ath5k driver (/etc/modprobe.d/blacklist)
Then you can get the new 'madwifi' driver:
svn co http://svn.madwifi.org/madwifi/branches … l-0.10.5.6
cd madwifi-hal-0.10.5.6
make
sudo make install
reboot and you'll have a working wifi connection.
You'll still need to install the 'eee-osd' package, however to get the Fn-F2 working you'll need to modify the /etc/acpi/eee-wifi-on-off.sh file. With the new 2.6.26 kernel there's a eeepc_laptop module that exposes the eeepc acpi in a different way to the old asus_acpi or eeepc_acpi modules.
I've edited the file below:
. /usr/share/acpi-support/key-constants
# The sequence here *is* important.
unload_modules() {
modprobe -r -q ath_pci
modprobe -r -q ath_rate_sample
modprobe -r -q ath_hal
modprobe -r -q wlan_ccmp
modprobe -r -q wlan_tkip
modprobe -r -q wlan_wep
modprobe -r -q wlan_acl
modprobe -r -q wlan_scan_sta
modprobe -r -q wlan
# At least this one's straightforward.
load_modules() {
modprobe ath_pci
wifi_on() {
# Force PCI Express Hotplug to reinit
modprobe -r -q pciehp
sleep 1
# pciehp_force may be unnecessary; Xandros did it.
modprobe pciehp pciehp_force=1
sleep 1
# Switch on the hardware
# echo 1 >/proc/acpi/asus/wlan
echo 1 >/sys/devices/platform/eeepc/wlan
sleep 1
load_modules
sleep 1
/etc/init.d/networking restart
wifi_off() {
unload_modules
# echo 0 >/proc/acpi/asus/wlan
echo 0 >/sys/devices/platform/eeepc/wlan
case $1 in
on)
acpi_fakekey $KEY_PROG1
wifi_on
off)
acpi_fakekey $KEY_PROG2
wifi_off
toggle)
# STAT=`cat /proc/acpi/asus/wlan`
STAT=`/sys/devices/platform/eeepc/wlan`
if [ "$STAT" = "1" ];
then wifi_off;
else wifi_on;
esacFYI.....
There's no need for the 40-wire patch, SSD performance is identical to the various patched 2.6.24 kernels.
The microphone doesn't work properly, far too much noise. Because of the significant changes to the patch_realtek module, the 8.04 microphone patch cannot be retrofitted. I'll have a little play when I have some time.
I think I'm going to give the alpha 2 a try also... alpha 2 is what people are installing, yes?
I changed the repositories to Intrepid and updated and upgraded......risky, did it in chunks because of disk space issues.
I did a fresh install across the internet via wired network - KDE4 is looking so good on this:
http://ubuntuforums.org/showthread.php?t=866186
Umm, you should be warned that this is in no way ready, and is the very early stages of development. If your EEE explodes and bites your head off, you get to keep both bits ![]()
Don't use it for actual work, as it is very likely to break.
I tried it in virtualbox, but it kernel panicked before I got a chance to use it.
I totally agree garwaymatt. I just had a look at the ubuntu-intrepid git repository to see what's needed to port my eeepc kernel mods over.
The entire kernel infrastructure that I leveraged under hardy is missing from intrepid (the openvz, xen & rt flavours are gone too). Whether they've all been deprecated or moved to another repository, I cannot tell, but it seriously hinders my own work on the new release.
Adam, they are still there. I'm using these repositories:
deb http://archive.ubuntu.com/ubuntu/ intrepid main universe restricted multiverse
deb http://security.ubuntu.com/ubuntu/ intrepid-security universe main multiverse restricted
deb http://archive.ubuntu.com/ubuntu/ intrepid-updates universe main multiverse restricted
deb http://archive.ubuntu.com/ubuntu/ intrepid-proposed universe main multiverse restricted
deb http://archive.ubuntu.com/ubuntu/ intrepid-backports universe main multiverse restricted
Damian
Why do you say that? Many of the updates are only what are found in other distributions.
Damian
Specifically I'm looking for the intrepid equivalent code that generated such packages as "linux-image-2.6.24-18-rt", "linux-image-2.6.24-18-xen", "linux-image-2.6.24-18-openvz" in hardy.
Previously, I used git://kernel.ubuntu.com/ubuntu/ubuntu-hardy.git/debian/binary-custom.d/ directory to create the eeepc custom flavour by cloning the examples from "rt", "xen" and "openvz".
However, under intrepid's codebase, git://kernel.ubuntu.com/ubuntu/ubuntu-intrepid.git/debian/binary-custom.d/ doesn't exist. As a result, "rt", "xen" and "openvz" custom flavours are no where to be found. Even on those repositories you quoted.
Anyway, I think I have a workaround, an am building a linux-image-2.6.26-4-eeepc right now.
However, I only trust this code about as far as I can throw it ![]()
I can send you my .config as I've built a custom image using the 2.6.26-4 ubuntu diff.
The xen, openvz etc are still using 2.6.24.16.18.
I am having trouble getting intrepid to mount my internal sd card reader on my 701. I have Intrepid installed on an sd card, and if I plug a reader into any usb port on it, it works fine, if I put the sd card right into the sd reader built in, it will load grub from it, but then the kernel doesn't mount it, and I bomb out to a busybox shell after it cannot locate the root. Any ideas from you linux experts? If I boot from the reader, and plug in an sd card into the internal slot, intrepid will not mount it. It never sees it in the /dev/disk/by-* just the reader and the internal ssd is found there. I would prefer it ran from the internal reader so I don't have to plug it into the usb port and have it hanging off the side. Any suggestions?
The problem must be related to the kernel. I installed adamm's kernel onto my intrepid install and the internal sd card reader is mounted and boots just fine. Thats kind of a bummer as I would have liked to be using a newer kernel, but it is working on my internal reader now. Hopefully the ill effects from intrepid running on an older kernel won't be too bad. I hope it will be corrected before intrepid's release.
Don't know if this helps anyone, but I managed to install intrepid on my eee (701) by following these instructions: http://ubuntuforums.org/showthread.php?p=5430468 In a nutshell: download the boot image for a netinstall of Hardy, make a minimal cli installation, then modify /etc/apt-get/sources.list to intrepid and do a dist-upgrade. I tried with all sorts of alpha and current images on a USB-stick, but none would install to my SDHC. I had to update the initramfs as per these instructions http://forum.eeeuser.com/viewtopic.php?id=22653&p=1 ; maybe that's what you need to do for intrepid as well to have it boot off the SDHC? It's sad that right now, intrepid has trouble with both wireless and wired ethernet (no drivers included out of the box). However, after installing the madwifi-hal module manually on intrepid, wireless seems much more stable than in Hardy, and the new version of Network Manager appears to be much better. Overall, despite being alpha, intrepid seems quite stable and noticeably faster than hardy. The new artwork is growing on me. I really hope they can add support for the eee out of the box.
I'm currently running kubuntu intrepid with adamm's kernel and all is working fine, would be nice to be able to upgrade to a newer kernel but so far there have been no problems from using the "hardy" one. as for the readyness of intrepid the only problem i've come up against is with the kde network manager which i've had to pin to an older version, the one from hardy, as the new one doesn't work. Aside from that kde4, sound hibernate, suspend and all hotkeys are running just fine.
I have no problem with the wired ethernet in intrepid at all. I built the madwifi drivers and they worked as well. However, I still cannot boot from the internal sd reader, I have to put the sd card into a usb reader and plug it into a usb. If I don't, It tells me it cannot find root and tells me that the uuid doesn't exist. I tried updating my initramfs, but this had no effect. So If I want to boot from the internal sd reader, I have to use adams' kernel . It would be nice to use the newer one.
Installed daily image (of today, aug 27) of intrepid ibex (ubuntu 8.10) on an eee pc 701 using a usb-stick. No problem. Also, a recent update had kernel 2.6.27-1-generic and now wireless is working.
So, intrepid seems on it's way to good out-of-the-box experience with the eee.
