UPDATE:
Best compliment ever! I showed my eee PC 900 with fingerprintreader and mentioned that I built it into the machine myself. She refused to believe me! I repeatedly told her that I built it in, but she still refused to believe me! I went online and showed her this thread with pictures, step by step, and she refused to believe me! The final picture convinced her because it showed my cat Natalie and the eee PC with fingerprintreader both on it.
Original post:
Hello again,
As promised, the continuation of my journey into breaking the eee PC 900 in interesting and novel ways.
I hope it is not against forum policy to post so many pictures, but at least they're hosted off-site, so I hope it's okay. They do provide a lot of good information for people wanting to modify their own eee PC 900's.
The first picture shows the standard swipe-style fingerprintreader that I used. It is the Eikon digital privacy manager which comes with a software package by Upek. I prefer the Upek package over most other fingerprintreader packages I've seen so far because it allows me to assign applications to fingers, login at windows, it has some linux support and it tracks my passwords for websites in both IE and Firefox (though not Firefox 3.0 yet - they're working on that at the moment). The device's outward appearance makes it seem rather bulky, but the actual electronics inside of it are really quite small.
I pried the casing open with a flatheader screwdriver and found the embedded electronics and took them out. The first thing you should notice about the wires is that there are 5 of them instead of the usual 4 for USB, but that's because the fifth one is just grounding. You don't necessarily need to connect it, but you can if you want. The second thing you should notice is that the order of the wires is wrong. The usual order of the colours is red white green black. This one has the d+ and d- of the USB pins reversed, so it now is in the order of red green white black. So I had to make sure I switched the d- and d+ wires when I soldered this device to my Asus eee PC's main PCB.
I wanted the fingerprintreader in the area left of the touchpad, so I took the eee PC apart and found some sort of shielding there. There are no electronics behind this part of the shielding, but there is something there, some kind of foam, which I suspect is there to make the eee PC sound less plasticky and less hollow when tapped on. Makes it seem more solid. Kind of like old telephone handsets had a big piece of metal in it because it made the phone 'feel' like it had 'quality'. I could be wrong, though
Anyways, I pried it open gently.
There are these little plastic round tabs that stick out - they were in my way so I had to remove a few of those to fit the chip in. I couldn't remove the piece of shielding entirely because it's stuck very firmly to the rest of the shieldingparts. So I just folded it over to make room to work.
I made a bit of a rough sketch of where I wanted the reader to show up. I had the smartness to think of which way to mount the reader, since it only reads fingerprints in one direction Could be kind of annoying if you mount it wrong and you have to 'swipe forward', so to speak. ![]()
I drilled some 4mm holes in the cover. Painful moment as now I knew there was no going back. The fingerprintreader bar in my fingerprintreader is ~ 17mm long and ~5mm wide, so I took a mm margin so I had some room to work with when filing the rest of the area down to just the right size. The plastic is rather thick, about 2 to 3mm.
After an hour of carefully filing the area down to a large enough size to accomodate the fingerprintreaderbar I finally managed to squeeze it in. You can see that the plastic of the cover is rather thick - the reader is sort of sunk down about a millimeter. The edges were sharp so I filed them down to create a small bevel. It doesn't need to be perfectly flat - once you put your finger on it, the skin of your fingertips sort of sinks down into the beveled slot a little. No problem at all and there's no need to press hard or anything. No sharp edges anymore either after I filed it down. This picture shows what it looked like before I created the beveled edges.
Because I filed it down gently I made it possible to actually have to squeeze the fingerprintbar into place - it keeps itself into place now. It's stuck. But, I wanted some more certainty that it wouldn't just plop out once I started using it so I drew two lines of hot glue along the edges.
To connect the reader I needed to use a USB port. The eee PC 900 has, like most eee PC models, 2 unused USB ports in the mini-PCIe ports. If your model has only one mini-PCIe port, that's okay. The electronics to connect the USB ports are very likely still there, but the connector just isn't soldered on. So just use the 8th and 9th pin (counted from the left if you look at the picture below) and there you have your USB data pins. In my eee PC 900 I have a mini-PCIe port that is taken up by the wifi card (just visible at the top of this picture, with the yellow tape over it) and a mini-PCIe port that is taken up by the 16GB add-on flashcard. (4GB onboard SSD, 16GB add-on card SSD = 20GB) The important thing is that both mini-PCIe ports have data- and data+ ports for USB connectivity, but the wifi and SSD cards are not using them. So you can use them without losing functionality. In this picture I temporarily removed the SSD card to solder the wires and to make a photo of it to show you. In this picture, the 8th mini-PCIe pin, counted from the left, is the data+ wire. The 9th pin, to the right of it, is the data- pin. As you can see, I did not solder them to the pins of the mini-PCIe connector. That's because the two contacts points I have used are connected to those pins on the PCB, and I didn't want to risk unsettling or damaging the mini-PCIe slot itself. But you can solder them to the mini-PCIe connector itself (pin 8 and 9) or if you don't have the mini-PCIe connector, just use the empty spots on the PCB to solder the wires on to. At the moment I have the mini-PCIe USB ports on the Wificard's mini-PCIe port hooked up to my bluetooth module, and I have these mini-PCIe USB ports on the SSD add-on card's mini-PCIe port hooked up to the fingerprintreader.
Yeah, I'm not too proud of these wires running around, but eh.. it does the job and it works. As you can see I placed the SSD add-on card back into it's mini-PCIe slot. The soldered wires from the previous picture are hidden underneath that add-on card (the left one. the right card is the memorycard)
And then... I totally blew it. I had my bluetooth module drawing 5volts power from the same port that the webcam draws its power from. That worked fine. Apparently though some people had problems with the webcam not working anymore because the bluetooth module was pulling too much power from that powersupply so.. I thought.. let's try another 5v trace. I found one, or so I thought, and shorted out a piece of SMD electronics on the main PCB. Nothing serious, but my webcam port, left USB port and bluetooth module were all out at the same time. The item I blew was fortunately a very simple piece of electronics that the eee PC can do without just fine. There's probably some very technical reason why that item is there, but I decided not to be technical
and I removed the dead part so the shortcircuit would disappear and my USB ports would function again. Then I soldered the bluetooth module and the fingerprintreader all to the same 5volt trace that the webcam uses to get its power. In the picture below you can see the wire that goes to the fingerprintreader (going down) and the wire going to the bluetooth module (going to the right). Where they are soldered together is the webcam's 5volt trace. The contactpoint to the right of it (between the soldered wires and the black IC) used to be connected to the same contactpoint that the soldered wires are on by what is, I think, an SMD capacitor which, I also think, was designed to filter out 'noise' from the powersupply to the webcam. I had to remove it because it was causing a shortcircuit. I don't have one spare, so, whatever. The webcam works, the bluetooth works, the reader works. Even after hours of stresstesting. In any case, there are no discernible adverse effects AND it was caused by my own stupidity for having connected the fingerprintreader to a wrong trace elsewhere on the main PCB. Had I connected it here in the first place, everything would almost certainly have been fine. In case you're wondering, my bt module takes ~200ma and my fingerprintreader ~100ma. Only leaves 200ma for the webcam (assuming there is a 500ma cap on this supply trace), but as I said, things are working great so far.
I needed a ground for the reader, and since I had already used the ground before for my bluetooth module when I had it connected close to the touchpad (i moved it to the VGA port due to bad bluetooth reception) I decided to use the same bluetooth connector ground again. On the main PCB of the eee PC 900 you will find the BT_CON text next to a row of unused contactpoints. Probably it is in use in the new eee PC 901 with built-in bluetooth. In my case, I just needed the ground so I hooked it up... right there;
I used some of my colourful and haute couture yellow plastic tape to cover the exposed area of the fingerprintreader so there would be little to no chance of a short circuit. Then I folded the shielding back and molded it somewhat back into its original shape. Ofcourse it bulges out, but that's okay, because there's loads of space (relatively speaking) underneath there. No problemo. I sort of rolled the wires together into a bundle to keep them together when putting the cover back on.
Omgomgomg a blue light, I didn't expect that. :-P Also, you can see the beveled edges around the fingerprintreader. It's slightly embedded, slightly deeper than the surface of the eee PC, but as it is, it works fantastically. Just swipe, and voila, it works. I was quite happy when, after disassembling/reassembling the eee PC 5 times, it finally worked.
And it does look rather sleek, even if I do say so myself.
My cat especially thinks it looks fantastic. She's so fascinated by it (as you can tell from the picture), and also annoyed that I didn't play much with her today. Perhaps it's time again to pay more attention to her. ![]()
If you have any questions, please don't hesitate to ask.
If you want to give me lots of money, please hesitate even less. ![]()
You are very brave... Hope the damage that happened won't affect your machine in the future!
Looks very nice (would've looked nicer on a black Eee PC though!). So where's the new location of the bluetooth module?
I'm confident it won't affect the eee PC at all. I've seen broken harddrives that wouldn't start at all but short out the power supply simply because an SMD capacitor shorted out. Removing it resolved the problem instantly. The only thing I need to take care of now is not introduce big power surges to the left USB port - but USB ports generally do not like that kind of abuse anyways. I figure if there's a jolt of power big enough to hurt the electronics of this port, then it would be big enough to damage any USB port, so it doesn't really make a difference.
I'm going to link you back to my other post on this forum that shows where the bluetooth module was originally placed, but, more importantly, where it is now. It's the first picture in the post that you'll want to see:
http://forum.eeeuser.com/viewtopic.php?id=33838
edit: Also.. I have a black laptop and the fingerprint smudges are just too much of a bother. It may sound contradictory, but the white laptop remains cleaner a lot longer. At least, so it seems to me. But I agree that for pure looks, black is great. I just wanted something different for once. I found a nice matching logitech v470 white/silver mouse that matches it very nicely....... now I just wish those green lights were blue lights. I love blue lights!
Wow, I knew it was possible! I was thinking the same thing when I bought my Eee...
WHere'd you get that finger print reader? think I'll have to steal this mOd!
Well, you have gone this far... doesnt hurt to change them LEDs :p
I got it off eBay, actually. For some reason they don't sell the "Eikon Digital Privacy Manager USB Fingerprint Reader" here in the Netherlands. When I bought a Sony laptop, the fingerprintreader came built-in. It was a TouchChip Biometric device (same as the one I now have built into my eee PC) with the Upek Software Suite. It really works quite remarkably well. So for my desktop computer at home I bought that same fingerprintreader too. Apparently it is then branded as an Eikon Digital Privacy Manager, but it contains the same reader and uses the same software. So for my desktop I got the Eikon device too, so I could simply export all my passwords from the laptop and import them on my desktop and vice-versa, to keep the passwords synchronized over both computers. Back then (about one and a half year ago) I had to order mine from a store in the USA and had to have it delivered to a friend of mine in the USA, because they wouldn't send it to me directly..bah.
Fortunately, when I looked on eBay last week there was a seller that had bought a batch of them and was selling them from the UK, and they were shipping to the Netherlands. When I last looked on eBay I couldn't find that same location anymore, but maybe you live in the USA. If you do, it should be easier for you to get the Eikon.
Yeah, I think I will. I'm going to wait with that though. Opening and closing the eee PC all the time does tend to create some wear and tear. I'll wait until I have a suitable mini USB hub and am able to get my hands on an 8,9inch touchpanel before I replace the lights with blue LEDs. I am wondering though.. these are the supertiny SMD versions of the LEDS, so I'll need to get some of those from somewhere. Maybe my local electronics store has some or can get me some. Actually... I changed my mind. I love how the macintosh laptops have white lights in them.. I think I'll go for a set of white SMD LEDs if I can find them!
Looks nice! I didnt think you would jump right in and throw one mod in after another, great job. ![]()
Only thing that pussles me is, why havnt you mounted a USB hub?
It would make it som much easier to add more mods in the future. Personally i intend on using a hub with my 900.
But i am deffinetly thinking about adding a fingerprint reader of my own now.
Only thing that puzzles me is, why haven't you mounted a USB hub?
It would make it so much easier to add more mods in the future. Personally I intend on using a hub with my 900.
But I am definitely thinking about adding a fingerprint reader of my own now.
I just fell in love with the eee PC when I got it. I love how it is a complete normal PC that can do everything a desktop PC can do. I especially like the fact that there's tons of USB ports of which some are unused. The reason I didn't build a USB port in yet is because I didn't see the need for one at first - I only needed one USB port for the bluetooth module. And..well...then I needed a second one for the fingerprintreader, which is also available. Now, though, I have run out of ports! So yeah.. next step is to hook up a USB hub and wiring the bluetooth module, fingerprintreader and (yet to come) touchpanel controller to it.
I've always been one to poke around with cool electronics to make it just that little bit cooler. This is just a fantastically hackable little machine that does more than I had expected. It's slowly coming closer to replacing my Sony laptop entirely. It may not have the processing power that my laptop does, but it has enough to do what I need it to do.
Now with the fingerprintreader, I can load all my TrueCrypt encrypted filecontainers onto this eee PC and open them with a single swipe of one of my fingers. I made my own little scripts that tie-in with the fingerprintreader so that when I swipe, for example, my lefthand middlefinger, the reader will run my script and pass the password for the TrueCrypt container to it, and if it checks out, the TrueCrypt container is opened and the programs and files hidden within can be accessed. It's quite secure since in none of my scripts the passwords are stored - the fingerprintreader that cares of that with its fingerprint protected blowfish encrypted passwordsafe.
How about this?
http://cgi.ebay.com/Transcend-8GB-Biome … dZViewItem
http://www.pcuniverse.com/Transcend-Jet … d/p4326551
Looks pretty wicked... combined with 8 gig flash drive... save me some more room... and it'll take one less USB on my hub... pretty wicked...
Dont know what kind of software it would use though..... I think i'll go ahead and order it
Vinhtvu2 wrote:
How about this?
Havnt this one been used in the 701?
If so there should be no reason not to use it in a 900 ![]()
It would probably work. The connection in the hinge is probably made with some wires, or could be made with some wires. Looks like it's reasonably doable to get this hooked up. I'm not too sure about the quality of the reader itself or how it integrates into your programs. You might want to investigate that first before choosing this item. So far I've found 2 unused USB ports in the eee PC 900, with a potential third one.. so.. it's not like there's shortage of USB ports, and if you need more, a small USB hub will do the trick just fine.
Great idea - that has inspired me to place one in a 2G surf.
Might have to go in sideways.
How much was the unit and where did you get it from ?
Got it off eBay, cost around 60 euros. Yes, that might be a bit more expensive than some, but I wanted this particular model because of the underlying software.
Nice work!
The end cosmetics with the beveling you did on the case, etc, are fantastic.
Thanks ![]()
I'm not exactly proud of the work I did because with the knowledge I now have of the eee PC 900 I could have done things even better, but still, I'm quite happy all the electronics are working well! ![]()
So I got my fingerprint reader in last week. It's actually a unit pulled from an IBM laptop, but it's a Upek chipset.
I plugged it into my HP laptop with Windows MCE and it ran fine.
But when I plug it into the Eee, I get an Unknown Device error... when I plug it into my PC, get the same error.
I am thinking it's because I am running WIndows XP pro on both the Eee and my PC, and MCE on my HP laptop... idk
Did your Upek work as soon as you plug it in? what windows are you using?
It is necessary to use the correct software package, the Protector Suite. If the reader came from a laptop, look on the website of the manufacturer of the laptop and get the software there.
