#1 2008-06-01 9:35:51 pm
tremere613
SOLUTION: Windows XP sp3 nlite wireless refresh issue resolved!!!
had issue refreshing network list with wireless zero...
this is the solution that worked for me and should work for you!
1. obtain service pack 2 files:
wzcdlg.dll
wzcsapi.dll
wzscvc.dll
http://www.mediafire.com/?dnmzbvdizqe
(hope tht link works well...first time with mediafire)
2.run laptop in safe mode (keep pressing f8 before pc boots)
3.paste files into c:\windows\system32
4. restart pc
5. enjoy!
#2 2008-06-01 10:25:38 pm
Kevin108
Re: SOLUTION: Windows XP sp3 nlite wireless refresh issue resolved!!!
Wonder if this will fix the shared folders issuse too?
Kevin108.com | LewRockwell.com | VCDL.org
Eee PC 4G - 2 GB RAM, 8 GB SDHC, nLited XP SP3
#3 2008-06-10 1:26:19 am
tremere613
please sticky or at least bump...
#4 2008-06-21 8:58:56 am
zänker
Great! This solution is working for me! Thanks
#5 2008-06-21 1:41:39 pm
deftone
If you have problems with seeing shared folders on a network then it is most likely an issue with a particular service being turned off. I had this problem and solved it by going to START>Run>services.msc  and then made sure that services involving networking were not disabled and set to automatic.
[ eee 4G Surf | 1GB RAM | 999MHz | XP Pro SP3 | 16GB Patriot SDHC | 4GB Patriot Xporter XT | Holux m1200 | iGuidance 4.0 ]
[ Mods: Touchscreen | Internal: 2xUSB PORTS, Bluetooth,  8GB Patriot Xporter XT ]
#6 2008-06-21 6:15:13 pm
Masamune
And credits goes to a user on MN
"Posted by vertsyeux on Jun 01 2008 at 00:40"
Regarding Wireless Zero problem mentioned by Freestyler106..
I've loaded XP SP3 (w/nLite) on a few machines and this problem has occurred more than once - everything seems to be working but the system just doesn't see any wireless networks..
It seems there are "issues" with the WZC .DLLs provided with SP3 and the only way I could get it working was to reinstall these files from a working copy of XP SP2.
The files you need to copy are WZCDLG.DLL, WZCSAPI.DLL and WZCSVC.DLL, located in C:\WINDOWS\SYSTEM32\. You need to first stop the Wireless Zero service (Start -> Run -> Services.msc - may have to temporarily disable the service and restart the computer before Windows will allow you to overwrite the files).. After downgrading the 3 DLL files, restart the WZC service.
Now here's a weird thing.. I discovered after much messing around that disabling the "Event Log" service creates the same symptoms; I can't imagine why..
Asus EeePC900 Black (4gb+16gb) w/ Windows XP SP³ nLite @ BIOS 0802 | CPU @ 360MHz ~ 405MHz ~ 999MHz
Corsair 2GB Ram, Sandisk Ultra II 16GB SDHC4, Sandisk Ultra II 4GB SDHC4, 5200mAh
Acer Aspire ONE A110 White w/ Windows XP SP² (Oh wow, talking about slow SSD's. There is lag on EVERY SINGLE move)
500mb RAM on board + A Data 1GB Ram (EeePC900), Toshiba 4GB SDHC6
#7 2008-06-29 12:59:11 pm
Ivanzoomski
THE solution to my problem, thanks!
#8 2008-07-03 1:02:26 pm
zeavott
Can you confirm for me if you can use Dial Up Networking for this? I use DUN to connect to my Verizon phone for internet.
Thanks in advance.
Asus Eee 1002HA | Brushed Aluminum | 2GB RAM | OCZ 32GB SSD (SLC) HD | Wireless N+BT
Asus Eee 1000HA | Pearl White | 2GB RAM | Stock 160GB HD | Wireless N+BT
http://forum.eeeuser.com/viewtopic.php?id=54573
#9 2008-07-03 9:38:47 pm
Masamune
The Wireless Zero Configuration has nothing to do with dial up
#10 2008-07-13 11:48:31 pm
Buckaroo
Mahalo nui loa termere613!  I was banging my head over this one.  I just wish I'd found this post before I reloaded full XP over an nLited version.  Oh well, I'm just glad that the wireless is working now.  I'll give nLite another try when I have more time.
I agree that this should be a sticky based on the number of posts that I've seen about this issue.
Eee PC 900, 16 Gb SSD, XP SP3
#11 2008-07-13 11:55:12 pm
Rory
Sounds like a problem with a particular Nlite Session File you guys used?
Ive not yet seen any problems with the wireless on SP3 with any of my Nlite setups.
Also, there is a new version 1.4.7 Nlite which fixes some other errors with SP3 setups.
#12 2008-07-15 5:30:05 pm
Schimon
Thanks alot! Took me quite some hours to find this!
I have used the latest nLite, and obviously had the same problem anyhow.
Now i can finally connect to my wlan!
Thanks again
#13 2008-07-24 10:26:41 am
teddyruxpin2000
wzcdlg.dll
wzcsapi.dll
wzscvc.dll
4. restart pc
5. enjoy!
You magnificent ****!  This fixed it!  I love you all.
PEP
#14 2008-07-26 7:48:09 pm
Nisei
Someone please make this a sticky!!!
It has taken me many hours solving this problem and none of the people who answered my questions have pointed me to this post.
#15 2008-07-28 6:35:54 pm
twe90kid
thanks, problem solved.
Asus EEE PC 901 - White (Asia Version) cool - Mods - 2gb of ram | Black Keyboard from Fido | Samsung 80gb HS082HB
Asus 1000HE - Black US Version - Mods- 2gb of ram + ssd
#16 2008-08-02 3:44:57 pm
evanm
WOW! I can't believe that this worked!
I was just about ready to give up on the nLite XP SP3 on my 901 and restore from the CD.
Thank you very much!
Over 3GB free on the main SSD, Yipee!
Eee 901 Black / XPH SP3 / 2GB Kingston 667
Samsung HS082HB 80GB 1.8" HDD Only
#17 2008-08-05 11:02:04 am
broadcastengr
Hi! everybody.... i want to share some idea. it may help you...
Remove the Shared Documents folders from My Computer (XP)
One of the most annoying things about the new Windows XP user interface is that Microsoft saw fit to provide links to all of the Shared Documents folders on your system, right at the top of the My Computer window. I can't imagine why this would be the default, even in a shared PC environment at home, but what's even more annoying is that you cannot change this behavior through the shell: Those icons are stuck there and you have to live with it.
Until now, that is.
Simply fire up the Registry Editor and navigate to the following key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Explorer \ My Computer \ NameSpace \ DelegateFolders
You'll see a sub-key named {59031a47-3f72-44a7-89c5-5595fe6b30ee}. If you delete this, all of the Shared Documents folders (which are normally under the group called "Other Files Stored on This Computer") will be gone.
You do not need to reboot your system to see the change.
#18 2008-08-05 11:14:59 am
Rory
Until now, that is.
or you can do this:
http://www.pctools.com/guides/registry/detail/1220/
or disable all sharing: (save as .reg file):
Windows Registry Editor Version 5.00
; DISABLE SHARING
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Network]
"NoFileSharing"=dword:00000001
"NoPrintSharing"=dword:00000001
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoSharedDocuments"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Network]
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\LanmanServer\Parameters]
"AutoShareServer"=dword:00000000
"AutoShareWks"=dword:00000000
#19 2008-08-16 8:48:15 pm
rayone
wzcdlg.dll
wzcsapi.dll
wzscvc.dll
4. restart pc
5. enjoy!
Just registered to say THANK YOU!
I spent > 10hrs on this issue. It was compounded by the fact that a full install with SP3 worked where as if I used nlite it would break.
Wireless would work and would also try and connect to the 1st network... just wireless config wasn't showing any networks.
I tried tracing the issue with regmon & procexp... anyway thank you.
BUT!
I was unable to manually add a network... the Association tab was missing.
The fix:
Download KB893357
http://www.microsoft.com/downloads/deta … laylang=en
and use the files from this update.
The time has come to question everything!
#20 2008-08-17 4:19:19 am
braveheart5555
Thank God!
Well done for sorting this out! I was about to bin the nLited XP and face using fat old regular XP (SP3), when I FINALLY found this thread.
Works perfectly and I suppose is obvious.
If you're a genius!
This forum is simply outrageous... top marks and a big thank you!
Now, anyone have any idea how to get the 901 buttons working (have already installed the utility from the 901 XP driver disk)?
#21 2008-08-24 2:43:22 pm
No1
Hi, I just got a 16G 900 danish XP, and it seems to be as slow as jkkmobiles tests promised, so I expect that I will return it for at refund within the 14 days (they didn't have a display model, or rather it didn't have a battery, an OS, or even a power adaptor :-).
But the real problem is that I can't seem to connect to my wireless network. I'm using a D-Link DGL-4300, WPA-PSK, TKIP.
I've tried entering the pass phrase several times, but it still won't connect. Any one got any ideas?
EDIT: Forgot to mention, that I thought it was this issue, since Asus preinstalled it with XP SP3, but installing the three files from a danish XP Home SP2 didn't help any.
EDIT2: Nevermind I got it :-)
#22 2008-08-24 4:47:11 pm
phoenixag
THANK YOU!!! smile
I really mean it..I had nlited an SP3 XP and was really dreading it now and was going to go back, till...I decided to come to this awesome forum and do a search!
Seriously..you have saved me tons of hours of work...THANKS! smile
#23 2008-11-10 3:24:07 pm
sometsuke
THAAAAAAAANKS a lot !!!!
I h've been trying since few days to get my brand new 901 wireless connection working under XP SP 3 and my livebox untill I changed the 3 ddl files
wzcdlg.dll
wzcsapi.dll
wzcsvc.dll, as explained above in this thread.
Wonderfull and again many thanks,
Georges from Paris
#24 2009-01-01 5:28:10 am
conor143
Thank you!!!!! You are the greatest!!!!! I have been so stressed trying to get my wireless going, and this is just awesome:)
#25 2009-01-16 3:09:52 am
thiefy
is this caused by sloppy nLite user settings (people unchecking things they shouldn't) ?
i did an nLlite of xp and it installed just fine without a problem.
what is it people are doing to cause this problem?
that'd help people avoid doing it again.
eee pc 1000 black.
ubuntu 9.04 with elmurato scripts.
