Can somebody help me? My webcam just shows as black when I try to open Cheese or wxCam.
Hi
just have a look at
https://help.ubuntu.com/community/EeePC
there should be help for your webcam troubleshooting.
At first i would suggest to check, if the webcam ist enabled in bios ![]()
I had no problem with using the webcam under ubuntu 8.4. It just works out of the box.
I've also found it works out of the box. But for some reason it didn't work initially, and it turned out that it was switched off in the bios - no idea how this happened as it was definitely on a few days before the installation.
hi guys,
I already checked it in the wiki and ubuntu community pages. it still won't show anything. when i start cheese, the light turns on on my eee, but the screen is just black.
strange this is that, it is enabled in bios.
i might have to reinstall, but i already downloaded so many programs! is there any way to backup just the programs? n00b alert
yes i have the same problem... 3 installations in a row now... one time i made sure to set it to Start first and then Finised after... other times i think left it just "finished" the whole time during installation....
it is definitely enabled in bios... and just like he said... green light on... black screen... compiz and metacity (in ubuntu 8.04 working in 7.10)
nobody else with this problem?!
Yes I have exactly the same problem but in 7.10
Seem to have the same problem, but for me the light is not on so it might be disabled in the BIOS. I'll check when I have a chance. I wonder why it would be deactivated by installing Ubuntu.
For those which have it activated in the BIOS but still not working, have you tried EasyCam2? (https://help.ubuntu.com/community/EasyCam)
Thanks for the advice...
I have now installed the asus modules as per the instructions on the wiki... still no positive results.
if I do the "sudo echo 1 >....." command, i get permission denied, which is strange, but it has a 1 in the file so it should be on.
I also tried the easycam2 program but it says "no camera found" when I run it. Any one else have success?
SOOO Frustrating!!!!! haha... it is now by far my biggest problem on the eeepc... small sound/microphone issues being second. (by the way the CPU scaling thing from the wiki is really cool)
Same problem here. It's activated in the BIOS, when I run cheese the LED next to the cam comes on, but the 'take a photo' or 'start recording' buttons remain greyed out. When I disable the cam by echoing 0 into /proc/acpi/asus/camera, cheese shows a test image. It would seem that cheese detects something at least.
Anyone know which device is actually the webcam? In other words, how to tell it's actually there? The webcam was disabled in the BIOS when I installed 8.04, could that be a factor?
Managed to get it to work by updating the uvcvideo driver, as described here: https://answers.launchpad.net/ubuntu/+question/19770
In short, I followed the steps below. luvcview and cheese now work, camorama doesn't (yet?)
1. sudo aptitude install subversion
2. svn co svn://svn.berlios.de/linux-uvc/linux-uvc/trunk linux-uvc
3. cd linux-uvc
4. sudo make
5. sudo make install
6. sudo modprobe -r uvcvideo
7. sudo mv /lib/modules/$(uname -r)/ubuntu/media/usbvideo/uvcvideo.ko /lib/modules/$(uname -r)/ubuntu/media/usbvideo/uvcvideo.ko.original
8. sudo cp uvcvideo.ko /lib/modules/$(uname -r)/ubuntu/media/usbvideo/uvcvideo.ko
9. sudo modprobe uvcvideo
man u got my hopes up
but no, even that didn't work for me ![]()
I also tried upgrading the bios, not expecting much.. when the camera was automatically set to disabled after the upgrade, i thought maybe this my lucky day.. so i tried enabling it again... but same old results
ahhhh.....
my next idea is to wait for the new 8.04 ubuntu-eee and hope that the installation will somehow trigger it back on ![]()
Thanks ijdod, that worked perfectly for me :-D
I was getting just a black screen before updating the drivers. Oh, and I also had to enable it in the BIOS - don't know why that got changed.
Just as a note: The correct way to run the echo command on ubuntu is: echo 1 | sudo tee /proc/acpi/asus/camera
This is to stop people using sudo bash, which is heavily recommended against by the Ubuntu devs.
if I do the "sudo echo 1 >....." command, i get permission denied, which is strange, but it has a 1 in the file so it should be on.Just as a note: The correct way to run the echo command on ubuntu is: echo 1 | sudo tee /proc/acpi/asus/camera
Makes sense! Thanks for that ![]()
To Hobbes828, have you checked that 'uvcvideo' actually loaded and did you put it in 'modules' if you rebooted?
lsmod | grep uvcvideo:
uvcvideo 58116 0
compat_ioctl32 2304 1 uvcvideo
videodev 29440 1 uvcvideo
v4l1_compat 15492 2 uvcvideo,videodev
v4l2_common 18304 2 uvcvideo,videodev
usbcore 146028 6 uvcvideo,usb_storage,libusual,ehci_hcd,uhci_hcd
also i don't seem to have any "camera" listed under my asus subdirectory right now.... should i the try to rebuild the asus acpi modules? (perhaps this is because i just today updated linux-kernel-image and modules?, though now im mostly bs-ing)
thanks for the patience and help ![]()
uvcvideo 58116 0
I'd recompile or redownload your 'uvcvideo' as the memory footprint of yours differs to the working one of mine. I'd just follow ijdod's instructions above and see if it works.
3. cd linux-uvc
4. sudo make
Works! Thank you very much!
Thank you - That cured my web cam woes too (not that I had any, but as there is a web cam, it was annoying it didn't work). Strikes me as odd that the new module is close to 10 times bigger than the original tho!
/Zilver
3. cd linux-uvc
4. sudo make
this worked for me but i think the webcam is a lot slower then it was with xandros... does anyone else have the same problem??
Using what? With Cheese I get ~3-4 fps, but with luvcview 25-30 fps.
/Zilver
For me webcam in uvcview works perfectly, but in Skype 2.0.0.68 video window is blank and LED is not lit. Described here http://forum.eeeuser.com/viewtopic.php?id=24945
Installing linux-uvc from svn hasn't resolved the problem, all the same. What is wrong?
Hey again... I am still sitting in the same situation... no webcam functionality...
I have since installed eeebuntu just for fun and the off chance it might change my webcam status.. but to no avail....
I downloaded and compiled the uvcvideo driver, loaded it again... if i disable the camera in bios i can't even open ucview(can't find compatible camera)... but if it is enabled, seems to detect the camera, i choose (and have tried both settings UVUY or whatever), but nothing showing up, just little green led for my troubles... cheese also doesn't work.
and compiz is off in case that was your thought.... any steps for me to take left for me to diagnose the problem? I mean this is 3 installs running now and same annoying problem.
I've made clean Ubuntu installation with only Skype final 2.0.0.68
When I start skype from terminal and run test of video in settings, I get this error:
Skype V4L2: Could not find a suitable capture format Skype V4L2: Could not find a suitable capture format Starting the process... Skype Xv: Xv ports available: 1 Skype XShm: XShm support enabled Skype Xv: Using Xv port 86 Skype Xv: No suitable overlay format found
Who have worked video in Skype, please, check your Skype version and run it from console to post here program output when starting video test.
