Pages: 1 2
http://www.eeepcnews.de/2008/04/18/inte … vergleich/
http://techreport.com/discussions.x/14584
http://www.engadget.com/2008/04/18/prel … tels-atom/
Isaiah and (Diamondville) Atom about the same for floating point, Isaiah much faster for arithmetic-and-logic. Celeron beats both in fpu, but it is a 1.6GHz Celeron, a quick estimate makes the 900Mhz Celeron about the same as the Atom. The Via C7 is an embarrassment (Used in HP-2133)
I think we discussed this before
I've seen that chart before. This is not the diamondville processor. The Diamondville is not the Z series, and the Z series is the one tested. If you search for the benchmarks, you will see that a site will tell you it's not the N series, which is the Diamondville processor.
These benchmarks are for the Silverthorne processor.
it was actually the n series diamondville....
it is corrected there now
Update: Damit es nicht zu weiteren Missverstaendnissen kommt, es handelt sich bei dem Intel Atom um den Diamondville core!
I guess they could be lying.
Friko - no we haven't discussed this benchmark before
someone posted a celeron 900 benchmark in the comments, obviously the platform affects the benchmark so it's not a scientific comparison but if this claim is correct
Celeron-M 900 Mhz: Alu: 3420 FPU: 4111
Then the Diamondville Atom @ 1.6GHz is actually superior to the Celeron @900Mhz in this particular benchmark. Which is good news for intel.
This has already been discussed here: http://forum.eeeuser.com/viewtopic.php?id=24850
Here is the chart that I made, with a few changes from the original posted in eeepcnews.de:
The original chart is meaningless and the data for both the Atom CPU (unconfirmed whether it's a Silverthorne or an Engineering Sample Diamonville; I believe the former) and the VIA Isaiah (ES? Power consumption?) are unverified.
The data for the Core duo (Yonah) CPU is from my Lenovo X-60.
As you can see, the Core duo architecture crushes all the other CPUs, when it comes to performance per MHz.
However, all such comparisons are meaningless unless one defines the exact power envelope for the intended application.
For eeePC class devices, this is around 5W TDP, which the Celeron-M @ 900MHz narrowly complies with.
The VIA C7M @ 1.6GHz is an 8W part and is 60% beyond the required specs.
The Silverthorne @ 1.6GHz is a 2W part and is 60% below the required specs.
The VIA Isaiah probably is a > 10W part @ 1.6GHz and so won't be used in eeePC-class devices. And for subnotebook applications it is vastly superceded by Intel Core-based CPUs.
ah, ok, apologies - I completely missed that discussion (was busy over the weekend) ![]()
Ok, I just thought it was significant that the german site posted an update claiming the bechmark was for a Diamondville Atom, not a Silverthorne.
Here's what I expect, for what it's worth:
Intel have basically been honest and the 1.6Ghz Diamondville be just a little better in performance than the 900Mhz Celeron. It will however consume less power which will give a modest battery life improvement (The cpu consumption is a small percentage of the overall chipset consumption). I think the Atom supports speed-stepping which the celeron doesn't - it runs at 900MHz fixed in the bios, the Atom will dynamically adapt. Big business is not completely stupid - why is nearly everyone choosing the atom to build their umpcs around? Hyperthreading, 64bit & Intel Virtualization all make it a far sexier processor than the Celeron @900MHz. That Via Isaiah looks promising though, and its supposed to be pin-compatible with the C7 so i wonder if the HP-2133s will be upgraded?
The Celeron-M supports Speedstep and is a surprisingly good device. The Atom Diamondville is not yet finalized (the Silverthorne is) and we have no idea about its exact performance and power requirements. As for the VIA Isaiah, looking back at the history of previous CPUs coming from VIA, I wouldn't hold my breath. I think it would be very optimistic to say that VIA will be shipping C8s in significant quantities by the end of the year.
Asus could be shipping Atom-based eeePCs by the end of the year, my earliest estimate is November. They may show something in June at Computex Taiwan, though, just to keep people waiting. Imho 900 buyers are not getting a bad deal at all (if they get the 5800mAh batteries).
dd99 wrote:
The Celeron-M supports Speedstep.
Are you sure about that , maybe under windows only? When I try to enable cpu frequency scaling in Fedora 8 it says it's unsupported.
I think we'll see the Atom based Eees this summer.
The Isaiah has a much larger TDP but many peeps will take a 1 hour hit on battery life for performance (I wouldn't)
Certain. I am running Mandriva and it scales the frequencies from 112.5MHz up to 900MHz (after I set the FSB to 100MHz). I run it at 675MHz on battery and 900MHz on line power.
Well, kudos to Mandriva then, any special configuration needed, kernel customization?
I agree with your point about not having any true idea about the Diamondville's performance. Things are very speculative and untrustworthy at the moment, it will all be made clear over the summer.
It's just the normal OOTB kernel in Mandriva 2008.1. Nothing to configure, install Mandriva and it manages the CPU Speedstep feature.
IMO, 64 bit and virtualization aren't useful for diamondville.
It's too slow, and who in the right mind will use > 4GB of memory and virtualize anything in a MID or UMPC?
"640K ought to be enough for anybody"... Yeah, sure!
Anyways, Diamondville is not intended for MIDs.
ok again
the benchmark was done on the Intel Mini-ITX Mainboard with the diamondville core!
http://vr-zone.com/articles/Intel_Atom_ … /5721.html
thats the board i tested!
I am pretty sure that the diamondville platform won't bring a big increase in battery life compared to the Celeron-M platform used in the Eee PC right now(i am talking about the cpu+the chipset)
I think it's now evident that the Atom has been somewhat over hyped. IMO it's not much more than a cost-cutting move with a fancy name.
You got it Marty,
The Atom, especially the diamondville core will be damn cheap to produce for Intel...
And of course, the Celeron-M is running out of life soon, so Intel had to act.
I am pretty sure that they will be able to produce the Atom for around 5$ which will lead to a way higher margin for Intel and also for manufacturers like Asus.
Or does someone really think that Asus will lower the price for the Atom Eee PC 900? ![]()
But Intels' marketing machinery seems to work when you look at all these comments. Postings like, that these benchmarks are a fake or that the Diamondville is not finalized are telling me a lot about the background of these users and how much Intels strategy worked out.
I am not saying that the Atom in general and specifically the Diamondville core is a bad cpu! It is just over hyped!
It will probably fastest per watt x86 CPU available. It should scale clock frequency like crazy with 16 stage pipeline (C2D has 14) and very low TDP to boot. Dual core variants should be (especially overclocked with some extra voltage) superb processors for small, efficient yet surprisingly powerful desktops.
Personally I can not wait for those mATX Atom based mainboards.
That would be nice. I could drop one of these into the Antec Aria case I'm using for my Freevo (HTPC) system. Since it's up 24x7, a cooler running, lower power system would be advantageous. I had tried an mini-ITX mobo with a Via C3 in the past, but it was simply too anemic to handle video recording/playback along with music playback.
I had hoped the Atom to at least be dualcore ![]()
http://img512.imageshack.us/img512/5102 … arkpm4.jpg
Gotta remember that there is no standard for TDP ratings (it's almost more of a marketing ploy than a solid specification), and the way this number is determined varies between manufacturers. Intel has had a very bad history of misleading people by their thermal specifications, since they take a lot of liberties when establishing testing parameters. Companies like AMD, for instance, measure theirs as the maximum power the CPU could possibly draw under the worst conditions. Intel rates theirs based on typical power draw in ideal conditions. So I think we have to give companies like VIA and AMD a break here, and wait for third-party testing to determine heat output and power draw of competing chips (so we have consistent testing methods).
kubel wrote:
...Intel rates theirs based on typical power draw in ideal conditions.
So does VIA, but they are not as specific as Intel about testing conditions. Come on, Intel is not the big bad guy and VIA and AMD are the good guys, they are all equally bad... ![]()
In any case, Asus and competition are not waiting, they have been testing Intel Atom CPUs and are working on designs at this very moment. I haven't seen any announcement of UMPC designs based on AMD CPUs or VIA forthcoming C8s, although I wish them luck: it's pretty tough going against Intel's might.
Actually the only real competition that I have seen until now for Intel's Atom 45nm CPU is from their very own Celeron-M based on an "old" 90nm process (in the UMPC power range). A relatively low-tech die shrink of the Celeron-M would yield parts with lower power consumption and higher performance (through higher clock rates), but probably Intel has some good reasons for not going that way (fab capacity, production costs, selling prices, competing products, etc).
I must say that the celeron is amazing. It is old, it is based on 90nm, and it has a tdp of only 5W and underclocked about 3W. That is amazing, the diamondville is brand new, 45nm and has a tdp of 2.4W. That´s not much in difference if you think about that the celly is much older, 90nm and so on. The performance increase doesn´t seem to be so much either. Shrink the celly to 45nm and it will perform better than the diamondville and it will have the same tdp as the diamondville.
Exactly true, but then it wouldn't be cheaper to make then the celeron, which was intel's #1 goal with Atom.
Pages: 1 2
