My eeePC makes no sound unless connected through headphones? Doesn't it have internal speakers?
Maybe the speakers are muted or the volume is low.
From the manual...
Mute the speaker: <Fn> + <F7>
Reduce Speaker Volume: <Fn> + <F8>
Increase Speaker Volume: <Fn> + <F9>
Thanks Andy... I muted, then unmuted, and now they work??? Who cares why!!
I had the same problem, even restarting the eeepc didn't help.
Solution, while eeepc is on, plug the headphone back in and unplug it again till it enable the internal speakers.
I too discovered the mute and then unmute work around. At first I thought it was because I installed Opera and it caused the problem. This, however, was not the case.
At any rate, for reasons unknown the mute button needs to be clicked and then un-clicked to re-enable the sound. This is clearly a bug
