#1 2007-11-16 6:29:42 pm
ptopping
Huge Mouse Pointer
Is there any way of changing the enormous Arrowhead Pointer for something that looks a little more delicate?
#2 2007-11-16 8:03:13 pm
TheBronze
Re: Huge Mouse Pointer
Doesn't look like there are any to choose from in the default install. Might have to download a mouse pack or something. But really, any smaller and it will just be harder to use. I wouldn't mind getting a smaller HAND though. That thing is ridiculous!
#3 2007-11-16 8:55:22 pm
ptopping
I supose the best way is to put your fingers in a pencil sharpener
#4 2007-11-16 11:41:27 pm
Aztec
Lol that was actually really funny, especially considering the small keyboard on the EEE makes it true for many people.
And no I don't know of any way to change the pointer. In advanced desktop mode there are a couple different pointer sets, but they all appear to be the same one just with different names. I'm not sure about basic mode.
#5 2007-11-17 5:24:56 am
addik
From the wiki:
"Install xcursor-theme: sudo apt-get install xcursor-themes, then choose them in Control Center → Peripheral devices → Mouse → Cursor Theme, then restart X."
Works nicely!
#6 2007-11-17 7:11:19 am
mralistair
when i try that i get an error
E: Couldn't find package xcursor-themes
#7 2007-11-17 8:44:34 am
Alpha4
When I try to select a different Cursor theme I get...nothing! Stays the same as default i.e. big black arrow and hand.
Here's what I did:
Added a couple of repos (as mentioned here in other threads).
Did the 'apt-get update' thing.
Used Synaptic to select, download and install XCursor.
Rebooted.
Opened Console window (ctrl+T)
Typed 'kcontrol' to bring up Control Center (sic).
Navigated to Peripherals/Mouse/Pointer Themes.
Selected smaller white arrow theme and Apply.
Read "Restart X" dialogue popup box and clicked 'OK'.
Pressed Ctrl+Alt+backspace to Restart X.
UI comes back and Cursor Theme is exactly the same as before I went through this whole rigmarole (i.e. big black arrow/hand).
Rebooted, just in case... still no change.
Whole repos/Synaptic procedure worked a treat for downloading and installing VLC, so I can't see the problem.
Can anyone tell me what I'm doing wrong here please? Cheers.
#8 2007-12-07 1:25:46 pm
3lj
came here to ask exactly the same question
i am running fluxbox on the inital xandros setup, so chaning settings in kcontrol doesnt work for me either (guessing as the kde modules arnt loaded?)
any other alternate solutions?
ill start googling in the mean time !
#9 2007-12-07 1:32:56 pm
mrmot
This is going to be a guess, but it seems Easy mode uses Xfce, so searching for a method of customising that may help. I'm a KDE person myself... (and actually don't mind the big cursor, being short-sighted and sore-eyed most of the time)
Search and Wiki first, Question later!
#10 2007-12-07 4:05:34 pm
3lj
hmm, looking through the eeepc, there is a folder
/etc/X11/cursors/
and in it is a single file called eeePC.theme
that only says
[Icon Theme]
Inherits=eeePC
:-/ Is that a synax anyone has seen before/ know what it is inheriting from?
#11 2007-12-07 8:50:28 pm
3lj
tried reverting to original mode, loading up kcontrol and installing a theme, says it works and restart to take effect, i restart, and nothing sad
#12 2007-12-07 8:54:57 pm
3lj
just a query, do we need to install the stuff / go to kde advanced mode, for the stuff in kcontrol to take effect? :-S
its the only reason i can think of htis not working atm
#13 2007-12-07 9:16:01 pm
3lj
ok, i got it :-D
a selection of themes can be found here
http://www.kde-look.org/index.php?xcont … f253043087
i recomend
http://www.kde-look.org/content/show.ph … tent=31480
as it is smallest from what i see
download hte one you like, just save the tar.gz file
Launch kcontrol in terminal and navigate to Peripheral devices → Mouse → Cursor Theme
at the bottom (you may need to maximize) it says "install theme" add the tar.gz file, choose it, it will say you need to restart, hit ok, but dont restart yet.
open a terminal navigate to ~/.icons/      in it should be the theme you downloaded, eg for me it was lil-polar ... rename this folder to be default (mv lil-polar/ default) ... then restart x ... it now loads it ... tiny mouse cursor ahoy :-D
(edit, squiggle put in)
#14 2007-12-07 11:11:26 pm
Aztec
I don't have a /.icons/ directory. Where do you find that?
#15 2007-12-08 12:38:36 am
TacticalPenguin
Aztec - are you showing hidden files? anything with a . before it is hidden.
EEE Fund: Who cares I finally got it 4/16/08
I got an eee after creating the "post here when you get your eee" thread, which had over 1450 posts in it, making it the forum's largest, before I could post in it. Also, XP SP3 + 8GB transcend SDHC card + 405-999mhz eeectl
#16 2007-12-08 4:34:04 am
3lj
the ~/.icons/ folder should be in your home dir, i thoght i put in a ~ but it was late, so it may forgot, or maybe it doesnt format properly on this message board, so /home/user/.icons/
#17 2007-12-08 5:45:21 am
mrmot
Be careful when posting paths.
/.icons/ means .icons off the root of file system
Better is: ~/.icons/
Where ~ means current user home directory.
EDIT: BTW, thanks for the instructions, they worked a treat.
#18 2007-12-08 12:16:11 pm
seventh
thanks for the instructions, worked great; though sometimes (like when i hover my mouse over sd card icon on system tray) our huge black icon shows up but i can live with that..
ps: i recommend aero cursor theme from kde-look for windowz guys..
Linux user #460555 | 4G/7A - 1gb ram
#19 2007-12-08 12:22:43 pm
Bazza
Re:
...at the bottom (you may need to maximize) it says "install theme" add the tar.gz file, choose it, it will say you need to restart, hit ok, but dont restart yet.
open a terminal navigate to ~/.icons/      in it should be the theme you downloaded, eg for me it was lil-polar ... rename this folder to be default (mv lil-polar/ default)...
Following the first line of instructions, this placed lil-polar in root/.icons/ and not home/user/.icons (which doesn't exist at all - even with all files visible) here. Meanwhile, I'm at something of a loss during line 2. How does one navigate to this folder in Terminal and then rename the folder? Seems to be an assumptive step missing.
Unable to access to rename - or remove, if it comes to that.
#20 2007-12-08 1:31:13 pm
seventh
let me explain how i did (linux n00b here);
open a terminal an type cd ~/.icons/
then type mv lil-polar/ default
ps: i have home/user/.icons though..
#21 2007-12-08 4:28:19 pm
Bazza
OK, I re-did the steps as posted by 3lj  and followed seventh's addition above and, for whatever reason, it appears that home/user/.icons was set up this time and that I was able to access it. So I have a new cursor set, thanks!
(Of course, the slight drawback is that the smaller gray set rather disappears on some windows contents, so may need to look at tweaking  Control Center > Display > Theme > Colors. But I digress...)
I can only assume I got myself into Administrator mode the last time around and that's why the /.icons folder ended up in root rather than user.
Having said that, could someone remind me as to how, via Administrator mode again in Terminal, I might now delete this offending /root/.icons folder to free up room. Please, what is the syntax involved? Once into Terminal and having typed sudo bash (Enter) is it
rm /root/.icons/ (Enter)
I see no other obvious way to delete this folder. Thanks from this linux newbie.
#22 2007-12-08 6:02:39 pm
seventh
one n00b to another smile
in the advanced mode (ie kde desktop) if you open the administrator file manager (from launch>applications>system>administrator tools) and go to the root you can delete the folder with right click>delete like the old windowz way smile
#23 2007-12-08 6:33:58 pm
DeanLearner
Fluxbox Cursor
I've been mucking around with fluxbox and to set the cursor you add the following lines to /home/user/.Xdefaults (or create it if it doesnt exist)
Xcursor.theme:  whiteglass
Xcursor.size:   16
To see which cursors you have available, check the contents of /etc/X11/cursors/. Setting Xcursor.size to 16 is half the default size (which is stupidly big if you ask me!)
#24 2007-12-08 6:37:20 pm
Bazza
Huzzah! Thanks, seventh.
n00bs - Keepin' Linux Geeks on the eee real....
smile
#25 2007-12-13 7:24:48 pm
ptopping
If I may clean up to merge 3lj and sevenths instructions for Easy Mode.
Go to http://www.kde-look.org/content/show.ph … tent=31480
and download the file 31480-lil-polar.tar.tar
At this pointed I changed the tag on the end to .tar.gz
Open a terminal window (Ctrl Alt T) and type kcontrol and
navigate to Peripheral devices → Mouse → Cursor Theme.
At the bottom (you may need to maximize) it says "install theme" add the tar.gz file, choose it, it will say you need to restart, hit ok, but don't restart yet.
Open a terminal window and type cd ~/.icons/
type exit and then reboot
Thanks to all who contributed to this solution. If anyone has any further to add please do.
Regards Peter
