#1 2008-03-19 10:27:18 am
Surfer Dude
640x480 image capture in Xandros.
Although the webcam on the eee is rated at 640x480, I can only seem to capture still images at 320x240, I've searched the forum, read the manual, and looked through the options in ucview, and still no sucess, there must be a simple solution, but I have not found it, hence this rather dumb question, thanks.
Eeepc 701, 4gb, 511 bios
Linux - Debian Lenny
#2 2008-03-19 12:37:13 pm
mrmot
Re: 640x480 image capture in Xandros.
I'd like to know as well. wink
Search and Wiki first, Question later!
#3 2008-03-19 8:15:10 pm
Surfer Dude
Just to add, I have also searched the wiki, no luck.
bios - stock 401
model - 7c
#4 2008-03-19 9:34:19 pm
Surfer Dude
I have not found anyway of changing the resolution from 320x240 using the default software on the eee, so ended up having to edit the ini file to give me a resolution of 640x480, this is not very elegant because if i want to reduce it again to say 320x240, another ini editing job is required. anyway, if anyone else needs to do this, the file to edit is /etc/ucview/default.ini (as root)
#5 2008-03-20 7:41:20 am
mrmot
This is now wikified. Thanks!
#6 2008-03-20 9:06:53 am
Niel1952
It shouldn't be too difficult to write a script for this.  The simplest would be to have three files /etc/ucview/default.ini, /etc/ucview/default.ini.320x240 and /etc/ucview/default.ini.640x480 and putting the relevant information in the latter two files.  The script would then copy whichever of the latter two files you wanted over  /etc/ucview/default.ini.
I'm sure there are cleverer ways of feeding the information into the ini file by means of a script, however.
