Hi, I'm interested in getting an eee pc but I need to first know the results of the DPC latency checker.
it can be found here http://www.thesycon.de/eng/latency_check.shtml
please post with your results + speed of cpu
thanks!
wow...mine looks bad... ![]()
BIOS: 8804
OS: Windows XP Pro with SP2
CPU: running at 630MHz
RAM: 512MB DDR2 667MHz
I ran it on mine and it stayed in the green. I had an abosute maximum of 90. This was with wireless off. With wireless on I had terrible scores. cr14mson, did you have wireless on with those scores?
I'm running at 630 MHz with 1gb of ram.
Wireless was, in fact, enabled last time. Here's my latency now that wifi has been turned off. The single red spike was from my AV, by the way. ![]()
You do realise that thats actually really good?
It's lowest score there of 7 is only 2 shy from my dual core 4200x2 lol!
My primary use for the eee pc (as a test) is as a portable music maker/audio processor stripped of all online functions.
I think with a simple usb2 interface I could actually use it for gigging, at least practising would be possible with it.
If it doesn't work then I'll use it for emulation and some pc games.
Thanks guys! ![]()
