#1 2008-03-12 9:58:57 am
voodooboy
New 2G Surf BIOS!
Without much fanfare, ASUS has released a new verion of the bios for the 2G Surf model...v 0401.
I hope to hell this thing increases the clock speed! Gonna flash it in sometime...
U can pick it up from here:
http://update.eeepc.asus.com/bios/700-ASUS-0401.zip
Cheers!
#2 2008-03-12 10:00:36 am
eitreach
Re: New 2G Surf BIOS!
Be careful when flashing your bios - you can easily end up bricking your EEE if you aren't careful.
Give a man a fire and he's warm for the day. But set fire to him and he's warm for the rest of his life.
#3 2008-03-12 10:25:34 am
voodooboy
Well flash completed!
Unfortunately, nothing good OR bad to report...it's as if there's no change at all! But one thing that seems very interesting is the change log included in the ZIP file. It's interesting to see the additions/deletions made to the 2G Surf bios. Of special note is that in bios version 0124, Asus REMOVED the ACPI Frequency/Voltage adjustment feature. So maybe overclocking the 2G is just a matter of finding hidden BIOS strings/writing new strings rather than modifying the clockgen physically.
And until the previous version, the 2G Surf actually had the 1024x768 resolution coded into it's vbios...not that it's a particularly useable resolution.
Here is the entire change log for thoe who can't/don't want to download the zip:
********************************** 700-ASUS ************************************
    This file is for internal use only, please do not pass this file outside
ASUS directly.
Model Name          : 700-ASUS
Processor           : Intel Pentium M Dothan (Socket 478)
North Bridge        : Intel    910GML
South Bridge        : Intel    ICH6-M
Clock Generator     : Cypress    SL28442-2
Embedded Controller : EnE    KB3310QF
Flash Part          : PMC    PM25LV040
                      Winbond    W25X40
                      MXIC    25L4005A
AFUDOS Version      : 2.36
CPU MicroCode       : M206D820
PGM Filename        : 700.ROM
PES Version         : 0.30
PCB Version         : REV 2.40G
ROM Checksum        : B460
700-ASUS-0401.ROM   (HW:05 BB:31 EC:28)                               03/05/2008
Bytes Reserved: 34000    Bytes Used: 4ACBC    Bytes Free: 1344    Checksum: B460
EC Firmware Version: 079                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated EC firmware to 079.
2. Removed 1024x768 resolution.
3. Let EZ Flash, ASUS Update, CrashFree erase and program boot block, EC F/W
    areas at last, in order to enhance the shutdown protection.
4. Fixed the failure to boot to SSD when Boot Booster was enabled and LAN boot
    was set to boot first.
5. Increased the boot block version from 30 to 31.
700-ASUS-0303.ROM   (HW:05 BB:31 EC:28)                               03/05/2008
Bytes Reserved: 34000    Bytes Used: 4ACB8    Bytes Free: 1348    Checksum: 2CE2
700-ASUS-0302.ROM   (HW:05 BB:30 EC:27)                               02/25/2008
Bytes Reserved: 34000    Bytes Used: 4AC60    Bytes Free: 13A0    Checksum: 7D11
EC Firmware Version: 078                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated EC firmware to 078.
2. Fixed the incorrect AC/DC status when entering OS by Boot Booster.
3. Corrected the battery warning and low capacity.
4. Support Eee PC PM Software Spec 1.30.
5. Support Eee PC Infomation Spec 1.00.
6. Updated VBIOS to support 1024x768.
7. Fixed the bug that EC FW would always not be updated when flashing BIOS.
8. Increased the boot block version from 29 to 30.
700-ASUS-0301.ROM   (HW:05 BB:29 EC:26)                               02/20/2008
Bytes Reserved: 34000    Bytes Used: 4ABFC    Bytes Free: 1404    Checksum: E7CA
EC Firmware Version: 074                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Increased the BIOS version only.
700-ASUS-0209.ROM   (HW:05 BB:29 EC:26)                               02/14/2008
Bytes Reserved: 34000    Bytes Used: 4AC08    Bytes Free: 13F8    Checksum: A266
1. Fixed the problem that quick boot did not send Monitor Key Command to EC
    when EC version is less than 074.
2. Increased the boot block version from 28 to 29.
700-ASUS-0208.ROM   (HW:05 BB:28 EC:25)                               01/22/2008
Bytes Reserved: 34000    Bytes Used: 4AC0C    Bytes Free: 13F4    Checksum: B95A
1. Updated EC firmware to 074.
2. Force system boot to first HDD when BootBooster was enabled.
3. Improved QuickBoot function and enable it by default.
4. Removed VBIOS sign on message.
5. Changed the boot block version from 27 to 28.
6. Changed the hardware compatible version from 04 to 05.
700-ASUS-0207.ROM   (HW:04 BB:27 EC:25)                               01/14/2008
Bytes Reserved: 34000    Bytes Used: 4AB3C    Bytes Free: 14C4    Checksum: 5921
EC Firmware Version: 073                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated EC firmware to 073.
700-ASUS-0206.ROM   (HW:04 BB:27 EC:24)                               01/08/2008
Bytes Reserved: 34000    Bytes Used: 4AB38    Bytes Free: 14C8    Checksum: 47CD
EC Firmware Version: 072                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated EC firmware to 072.
2. Changed the base board version to "x.xx".
3. Revised the year of copyright strings from 2007 to 2008.
4. Changed the boot block version from 26 to 27.
700-ASUS-0205.ROM   (HW:04 BB:26 EC:23)                               12/28/2007
Bytes Reserved: 34000    Bytes Used: 4AB40    Bytes Free: 14C0    Checksum: 9BA6
EC Firmware Version: 070                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Protect the power failure bit.
2. Changed the boot block version from 25 to 26.
700-ASUS-0204.ROM   (HW:04 BB:25 EC:23)                               12/07/2007
Bytes Reserved: 34000    Bytes Used: 4AB3C    Bytes Free: 14C4    Checksum: B12D
1. Updated EC firmware to 070.
    a. Vendor updates PS/2 kernel code to fix:
       1. KBC 0xFF command would causing GPT timeout in some critical timing,
          this results PS/2 failure.
       2. Synaptic touchpad returns 3-bytes data (mouse serial number) to
          responds to 0xE9 command, but PS/2 kernel receives those data and may
          parsing as command in some of date code of TP part, TP driver will
          lost this data, driver won't be initialized, TP is dead. (reported in
          700X module)
    b. Changed SMBus host S/W timeout from 250mS to 500mS.
    c. Removed XIO, TMKBC module. (KB3310 did not supports to)
700-ASUS-0203.ROM   (HW:04 BB:25 EC:22)                               12/05/2007
Bytes Reserved: 34000    Bytes Used: 4AB3C    Bytes Free: 14C4    Checksum: 9D68
EC Firmware Version: 068                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Adjust SLP_S4 minimum assert time to 2-3 seconds.
2. Removed Ai-Flash 5 patch to solve the failure of RCD Linux installation.
700-ASUS-0202.ROM   (HW:04 BB:24 EC:22)                               12/03/2007
Bytes Reserved: 34000    Bytes Used: 4AB40    Bytes Free: 14C0    Checksum: 8AC7
1. Updated EC firmware back to 068.
2. Updated LAN boot ROM to v1.0.20.20. (2007/11/28 released)
700-ASUS-0201.ROM   (HW:04 BB:24 EC:21)                               11/28/2007
Bytes Reserved: 34000    Bytes Used: 4AA70    Bytes Free: 1590    Checksum: CAFC
EC Firmware Version: 069                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated EC firmware to 069.
2. Added USB over current detection.
3. Fixed the problem that ASUS Ai-Flash 5 could not boot to FreeDOS.
4. Updated the power button detection code in CrashFree.
5. Sync system behavior to default states when CMOS is bad.
6. Revised some BIOS strings.
7. Changed the boot block version from 23 to 24.
700-ASUS-0129.ROM   (HW:04 BB:23 EC:20)                               11/19/2007
Bytes Reserved: 34000    Bytes Used: 4A974    Bytes Free: 168C    Checksum: 1B05
1. Updated EC firmware to 068.
2. Updated battery charge/discharge tables.
3. Updated model string and DMI Type 1 System Product Name.
4. Improved KBC command confirm mechanism to avoid EC FW lost the command.
    [bkbc.asm]
5. Changed the boot block version from 22 to 23.
700-ASUS-0128.ROM   (HW:04 BB:22 EC:19)                               11/07/2007
Bytes Reserved: 34000    Bytes Used: 4B3F8    Bytes Free: C08     Checksum: 17DF
EC Firmware Version: 065                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated onboard DIMM SPD to support 512MB DRAM.
2. Changed the boot block version from 21 to 22.
3. Changed the hardware compatible version from 03 to 04.
700-ASUS-0127.ROM   (HW:03 BB:21 EC:19)                               11/01/2007
Bytes Reserved: 34000    Bytes Used: 4B3F8    Bytes Free: C08     Checksum: D627
1. Changed the shutdown key from pressing power button for 4 seconds to one
    click after CrashFree successfully recovered the BIOS.
    (BUG#=338)
2. Changed DMI Type1 System Product Name to "Eee PC".
3. Changed POST and setup menu model string to "Eee PC 2G/700"
4. Updated the discharge voltage of 2S2P 2200mA battery.
5. Fix the positions of setup tokens.
6. Changed the boot block version from 20 to 21.
700-ASUS-0126.ROM   (HW:03 BB:20 EC:19)                               10/29/2007
Bytes Reserved: 34000    Bytes Used: 4B3E4    Bytes Free: C1C     Checksum: A530
1. Fixed the problem that pressing power button for 4 seconds could not turn
    off the system after CrashFree successfully recovered the BIOS.
    (BUG#=338)
2. Fixed the bug that pressing WLAN On/Off instant key once would take no
    effect under WinXP.
    (BUG#=357)
3. Changed the boot block version from 19 to 20.
700-ASUS-0124.ROM   (HW:03 BB:19 EC:19)                               10/18/2007
Bytes Reserved: 34000    Bytes Used: 4B3FC    Bytes Free: C04     Checksum: 328D
1. Fixed that password prompt would sometimes be popped before entering setup.
2. Removed ACPI frequency/voltage adjustment method.
3. Changed the boot block version from 18 to 19.
700-ASUS-0123.ROM   (HW:03 BB:18 EC:19)                               10/12/2007
Bytes Reserved: 34000    Bytes Used: 4B400    Bytes Free: C00     Checksum: F56F
1. Updated EC firmware to 065.
2. Changed the EC firmware version string from "701" to "700".
3. Added CrashFree from USB CD-ROM.
    (BUG#=338)
4. Changed the DMI type 4 Socket Designation to "Intel CPU".
5. Fixed the problem that KB command would be sent repeatly.
6. Updated the SMBIOS Type 4 information.
7. Changed the Quick Boot skip key to F2.
8. Removed CrashFree from HDD.
9. Changed the boot block version from 18 to 19.
700-ASUS-0122.ROM   (HW:03 BB:17 EC:18)                               10/04/2007
Bytes Reserved: 34000    Bytes Used: 4B3EC    Bytes Free: C14     Checksum: 56B9
EC Firmware Version: 063                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Updated EC firmware to 063.
2. Fixed the problem that CrashFree mode would have no display output.
    (BUG#=33)
3. Fixed the problem that EC firmware woule be updated in CrashFree mode.
4. Changed the boot block version from 16 to 17.
5. Changed the hardware compatible version from 02 to 03.
700-ASUS-0121.ROM   (HW:02 BB:16 EC:17)                               09/28/2007
Bytes Reserved: 24000    Bytes Used: 4B3D4    Bytes Free: 10C2C   Checksum: E597
EC Firmware Version: 062                   VBIOS Version: 1411-2    AFUDOS: 2.36
1. Support CrashFree from HDD.
2. Fixed the problem that EZ-flash would spend 10 mins due to cache setting.
3. Fixed the problem that EZ-flash may not shut down system due to USB host not
    stop.
4. Support new battery table and 13-stage charging/discharging table.
5. Refined onboard device detection code.
6. Added delay during onboard camera detection.
7. Changed the power-on state of WLAN, speaker, and card reader.
8. Changed the boot block version from 15 to 16.
700-ASUS-0120.ROM   (HW:02 BB:15 EC:17)                               09/20/2007
Bytes Reserved: 24000    Bytes Used: 4B104    Bytes Free: 10EFC   Checksum: D70F
EC Firmware Version: 062                   VBIOS Version: 1411-2    AFUDOS: 2.35
1. Updated EC firmware to 062.
2. Updated the F1 help strings in BIOS setup utility.
3. Fixed the incorrect physical memory size reported by BIOS.
4. Removed the keyboard S3 wakeup support.
5. Fixed the failure of WinXP DTM ResStomp test.
700-ASUS-0119.ROM   (HW:02 BB:14 EC:16)                               09/12/2007
Bytes Reserved: 24000    Bytes Used: 4B040    Bytes Free: 10FC0   Checksum: 30DD
EC Firmware Version: 060                   VBIOS Version: 1411-2    AFUDOS: 2.35
1. Updated EC firmware to 060.
2. Removed setup menu items "Adjust Voltage", "CPU PLL Spread Spectrum", "LVDS
    Spread Spectrum".
3. Changed the chipset name from "I915M" to "I910GML".
    (BUG#=166)
4. Changed the base board version to "2.30G".
    (BUG#=197)
5. Changed subsystem DID of MCH and IGD to 82D9h for I910GML.
6. Fixed the problem that speaker and mic could not be used under Linux when
    modem was disabled.
7. Updated KB3310 eModule.
    * Enable EC SMI global gate when S3 resume.
    * Disable EC SMI global SMI at early BB.
8. Updated QuickBoot eModule.
    * Added eLink to disable EC SMI before restore and enable after VGA repost.
      (avoid INT10 is invoked during VGA repost due to EC SMI)
9. Updated EeePC HDPS eMoudle.
    * Always clear flag in CMOS to avoid report error during POST.
10. Updated EeePC board.
    * Add OEM BB recovery end support.
11. Removed 1680x1050 resolution in VBIOS
12. Changed PWM inverter frequency from 30KHz to 22KHz.
13. Reduced the maximal backlight brightness to 50% of the original.
14. Changed the boot block version from 13 to 14.
700-ASUS-0118.ROM   (HW:02 BB:13 EC:15)                               09/04/2007
Bytes Reserved: 24000    Bytes Used: 4B0EC    Bytes Free: 10F14   Checksum: B7BB
EC Firmware Version: 057                   VBIOS Version: 1411-2    AFUDOS: 2.35
1. Updated EC firmware to 057.
2. Auto detect the presence of onboard WLAN, camera, and modem devices.
3. Fixed the problem that EC would re-enter reset mode using DMI tool.
4. Updated ICH6-M SSID.
5. Updated KB3310 module. Removed WDT and set PXCFG WAR.
6. Fix the bug that CrashFree function would hang at D6h.
7. Fixed BIOS errors reported by Intel Self-Test utility.
8. Changed the boot block version from 12 to 13.
700-ASUS-0117.ROM   (HW:02 BB:12 EC:14)                               08/30/2007
Bytes Reserved: 24000    Bytes Used: 4AE84    Bytes Free: 1117C   Checksum: 8AC9
EC Firmware Version: 056e4                 VBIOS Version: 1411-2    AFUDOS: 2.32
1. Updated EC firmware to 056e4.
2. Fixed the bug that WLAN On/Off instant key did not take effect under Xandros
    Linux in BIOS 0116.
    (BUG#=160)
3. Require user to shutdown system after updating BIOS via EZ Flash.
4. Removed useless ATKD_SUPPORT_FLAG.
5. Modified LVPC_ACPI_SUPPORT_FLAG to support CM_ASL_PANELBRIGHT/CM_ASL_MODEM.
6. Fixed the incorrect battery capacity report after resuming from S4.
7. Updated protected block attribution.
8. Fixed BIOS errors reported by Intel Self-Test utility.
9. Updated SSID of some devices.
10. Changed the boot block version from 11 to 12.
11. Changed the hardware compatible version from 01 to 02.
700-ASUS-0116.ROM   (HW:01 BB:11 EC:13)                               08/27/2007
Bytes Reserved: 24000    Bytes Used: 4AD64    Bytes Free: 1129C   Checksum: DABA
EC Firmware Version: 056                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Fixed the bug that WLAN On/Off instant key did not take effect under OS.
    (BUG#=160)
700-ASUS-0115.ROM   (HW:01 BB:11 EC:13)                               08/22/2007
Bytes Reserved: 24000    Bytes Used: 4AD68    Bytes Free: 11298   Checksum: 496D
1. Updated EC firmware to 056.
2. Updated LAN option ROM from v1.0.20.16 to v1.0.20.17.
3. Updated POST logo.
4. Fixed the problem that CMOS might be destroyed if continually pressing keys
    during POST.
5. Updated ASUS EeePC HDPS to fix the bug that there would be no error report
    when the read image did not exist in the partition.
6. Updated QuickBoot.
7. Modified LVPC_ACPI_SUPPORT_FLAG from 0x01511 to 0x101511 to support Card
    Reader control function.
8. Changed the boot block version from 10 to 11.
700-ASUS-0114.ROM   (HW:01 BB:10 EC:12)                               08/15/2007
Bytes Reserved: 24000    Bytes Used: 4BFF8    Bytes Free: 10008   Checksum: 5A10
EC Firmware Version: 051                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Updated onboard DIMM SPD to support Hynix 256MB DRAM.
2. Removed setup menu item "OS to Install".
    (Advanced)
3. Fixed the bug that WLAN On/Off instant key did not take effect under OS.
    (BUG#=160)
4. Changed the boot block version from 09 to 10.
700-ASUS-0113.ROM   (HW:01 BB:09 EC:12)                               08/10/2007
Bytes Reserved: 24000    Bytes Used: 4C038    Bytes Free: FFC8    Checksum: CA8A
1. Updated CPU eModule. This fixed the bug that system would sometimes display
    "CMOS Settings Wrong" during POST.
    (BUG#=88)
2. Updated ASUS Library eModule.
3. Added setup menu item "OS to Install".
    (Advanced)
4. Changed the boot block version from 08 to 09.
700-ASUS-0112.ROM   (HW:01 BB:08 EC:12)                               08/09/2007
Bytes Reserved: 24000    Bytes Used: 4C0C4    Bytes Free: FF3C    Checksum: DE11
1. Updated EC firmware to 051. (2007/08/07 released)
2. Support 256MB onboard DRAM. (512MB will be no longer supported)
3. Enabled LVDS spread spectrum clock in VBIOS.
4. Added setup menu items "CPU PLL Spread Spectrum" and "LVDS Spread Spectrum".
5. Fixed the system version shown in DMI and Xandros OS.
    (BUG#=142)
6. Changed the boot block version from 07 to 08.
7. Changed the hardware compatible version from 00 to 01.
700-ASUS-0111.ROM   (HW:00 BB:07 EC:11)                               08/07/2007
Bytes Reserved: 24000    Bytes Used: 4C0E4    Bytes Free: FF1C    Checksum: 064D
EC Firmware Version: 050                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Updated EC firmware to 050. (2007/08/07 released)
2. Implemented ASUS EeePC PM Software Spec Rev1.2 template.
3. Added setup menu item "Type" for IDE devices.
    (Advanced/IDE Configuration)
4. Disabled the processor C2/C3 state support report in ACPI FADT.
5. Fixed a coding error in CBIF ACPI method which would get incorrect battery
    design capacity.
6. Removed the voltage adjustment in S3 resume path.
7. Added HDPS ACPI method to support ASUS Update.
8. Implemented VERG & QURY ACPI methods.
9. Removed Azalia controller wake PME report.
10. Refined EC access code.
11. Improved DC and AC status determination related code.
12. Fixed the bug that battery could not be detected if plugged under OS.
13. Changed the default value of setup menu item "Onboard CardReader" from
    Disabled to Enabled.
14. Adjusted the DVO timings of VBIOS.
    (BUG#=104)
700-ASUS-0110.ROM   (HW:00 BB:07 EC:09)                               08/03/2007
Bytes Reserved: 24000    Bytes Used: 5234C    Bytes Free: 9CB4    Checksum: F66A
EC Firmware Version: 048                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Enabled the processor C2 state support report and disabled the processor C3
2. Changed the boot block version from 06 to 07.
700-ASUS-0109.ROM   (HW:00 BB:06 EC:09)                               08/03/2007
Bytes Reserved: 24000    Bytes Used: 52350    Bytes Free: 9CB0    Checksum: 7227
1. Changed model name from "P700" to "700".
2. Updated EC firmware to 048. (2007/07/25 released)
    * Changed the AUO LCD default output of SCL, SDA and CSB in S5/S3/S0. (048)
    * Fixed UK key "|\" scan code losing problem. (048)
    * Added some SMI and SCI control flags for SCI/SMI event management. (047)
    * Changed the assertion timing of Battery_Normal SCI/SMI event. (047)
    * Added Battery_Normal SCI/SMI event. (046)
    * Added LVDD_EN input pin. (046)
    * Asserts nPM_PWRBTN_L for 100mS maximum for wakes up event. (046)
    * Insert a 10uS delay in force power off routine. (046)
3. Fixed the bug that system would hang at checkpoint B2h when resuming from S3
    without having Audio driver installed.
4. Updated USB eModule.
5. Updated VBIOS to remove unsupported resolutions.
6. Fixed the bug that POST screen color would sometimes be abnormal.
    (BUG#=69)
7. Disabled the processor C2/C3 state support report in ACPI FADT. This fixed
    the bug that screen would sometimes get messed up and hang after entering
    Windows operating system.
    (BUG#=106)
8. Removed setup menu item "Onboard Minicard".
    (Advanced/Onboard Devices Configuration)
    (BUG#=109)
9. Changed the boot block version from 05 to 06.
P700-ASUS-0108.ROM   (HW:00 BB:05 EC:08)                              07/26/2007
Bytes Reserved: 24000    Bytes Used: 5214C    Bytes Free: 9EB4    Checksum: A512
EC Firmware Version: 045                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Updated EC firmware to 045. (2007/07/20 released)
    * Fixed force power off bug. (045)
    * Changed the PM_PWRBTN maximum asserting time to 100mS. (045)
    * Charger LED is start to blink when battery capacity is falling to battery
      warning level. (045)
    * Supports various SPI clocks 45/33/25MHz. (044)
    * Force to reset EC when resume from reset mode. (044)
2. Use fast read command to read flash data.
3. Fixed the bug that battery warning/low/critical levels would not be updated.
4. Modify BIOS setup menu.
5. Changed the boot block version from 04 to 05.
P700-ASUS-0107.ROM   (HW:00 BB:04 EC:07)                              07/20/2007
Bytes Reserved: 24000    Bytes Used: 52D3C    Bytes Free: 92C4    Checksum: AD79
EC Firmware Version: 043                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Updated EC firmware to 043. (2007/07/17 released)
    * Added the ability to reset whole EC chip in reset mode.
    * Downgraded SPI clock from 45MHz to 33MHz in reset mode.
2. Implemented ASUS LVPC Linux PM Spec Rev08 template.
3. Updated ASUS EeePC Hidden Partition & QuickBoot module.
4. Fixed the incorrect GPIO portings in ASL code.
5. Fixed a coding error in ECWW ACPI method.
6. Added 600us delay for each EC IO operation with Index IO mode.
7. Disabled USB PORT power management support.
8. Updated AC and DC status after resuming from S3.
P700-ASUS-0106.ROM   (HW:00 BB:04 EC:06)                              07/16/2007
Bytes Reserved: 24000    Bytes Used: 52C60    Bytes Free: 93A0    Checksum: D27C
EC Firmware Version: 042                   VBIOS Version: 1411-2    AFUDOS: 2.32
1. Updated EC firmware to 042. (2007/07/13 released)
    * Fixed BAT_LL# leakage problem. (042)
    * Improved timer accuracy. (041)
2. Updated VBIOS for ASUS EeePC resolution specification.
3. Added setup menu item "Onboard Speaker Interface".
    (Security/IO Interface Security)
4. Added setup menu item "Onboard Minicard Interface".
5. Disabled CD-IN and S/PDIF-OUT pins of Azalia codec and updated verb table.
    (BUG#=25)
6. Changed ATK device HID from "ATK0100" to "ASUS010".
    (BUG#=73)
7. Updated the battery capacity detection method.
8. Restored Azalia codec verb table after resuming from S3.
9. Set AUO panel timing after resuming from S3.
10. Updated GPIO settings according to PCB 2.10G.
    (BUG#=35)
11. Changed the boot block version from 03 to 04.
P700-ASUS-0105.ROM   (HW:00 BB:03 EC:05)                              07/12/2007
Bytes Reserved: 24000    Bytes Used: 52884    Bytes Free: 977C    Checksum: EB5A
EC Firmware Version: 040                   VBIOS Version: 1411      AFUDOS: 2.32
1. Fixed the incorrect panel type setting in BIOS 0104.
    (BUG#=84, 86)
2. Changed the boot block version from 02 to 03.
P700-ASUS-0104.ROM   (HW:00 BB:02 EC:05)                              07/11/2007
Bytes Reserved: 24000    Bytes Used: 52880    Bytes Free: 9780    Checksum: CC38
1. Updated EC firmware to 040. (2007/07/11 released)
2. Synchronized BIOS setup menu items with P701.
    (BUG#=9)
3. Added Quick Boot support.
    (Boot/Boot Settings Configuration)
4. Revealed ATK device under Windows.
    (BUG#=72, 73)
5. Support flash update mechanism during POST.
6. Disabled CD-IN and S/PDIF-OUT pins of Azalia codec and updated verb table.
7. Added Intel SpeedStep support.
8. Improved battery support.
    (BUG#=70, 78)
9. Updated USB eModule.
10. Updated DMI information.
11. Implemented ASUS LVPC Linux PM Spec Rev06 template.
12. Fixed the bug that WinXP did not respond to lid status change.
    (BUG#=83)
13. Fixed the bug that CRT would have no output when setting "Video Display
    Devices" to "LCD + CRT" in BIOS setup utility.
    (BUG#=84)
14. Modified the file extension of recovery BIOS image from BIN to ROM.
15. Changed the boot block version from 01 to 02.
P700-ASUS-0103.ROM   (HW:00 BB:01 EC:04)                              07/09/2007
Bytes Reserved: 24000    Bytes Used: 48EA0    Bytes Free: 13160   Checksum: 957F
EC Firmware Version: 038
1. Updated EC firmware to 038.
2. Added setup menu item "Adjust Voltage".
3. Display CPU brand string in multi-line if it is too long.
4. Changed the boot block version from 00 to 01.
P700-ASUS-0102.ROM   (HW:00 BB:00 EC:03)                              07/05/2007
Bytes Reserved: 24000    Bytes Used: 48E7C    Bytes Free: 13184   Checksum: 7FE7
EC Firmware Version: 036                                            AFUDOS: 2.32
1. Updated EC firmware to 036.
2. Display CPU brand string in multi-line if it is too long.
3. Hided ATK device.
    (BUG#=2)
4. Removed the following setup menu items:
    * Advanced/Chipset/North Bridge/Configure DRAM Timing by SPD
    * Advanced/Chipset/North Bridge/Hyper Path2
    * Advanced/Chipset/North Bridge/Booting Graphic Adapter Priority
    * Advanced/Chipset/North Bridge/PEG Port Configuration
    * Advanced/Chipset/North Bridge/Video Function/Boot Display Device
    * Advanced/Chipset/North Bridge/Video Function/Flat Panel Type
    * Advanced/Chipset/North Bridge/Video Function/Local Flat Panel Scaling
    * Advanced/Chipset/North Bridge/Video Function/TV Connector
    * Advanced/Chipset/North Bridge/Video Function/HDTV Output
    * Advanced/Chipset/North Bridge/Video Function/TV Standard
    * Advanced/Chipset/North Bridge/TV Standard
    * Advanced/Chipset/North Bridge/Active State Power-Management
    * Advanced/Chipset/South Bridge/PCI-EX Ports Configuration
    (BUG#=9)
5. Added setup menu item "Start Battery Calibration".
    (BUG#=9)
6. Added setup menu item "Hardware Monitor".
    (BUG#=9)
7. Changed HDD to the first boot device and removable devices to the second.
    (BUG#=17)
P700-ASUS-0101.ROM   (HW:00 BB:08 EC:02)                              06/22/2007
Bytes Reserved: 24000    Bytes Used: 48C2C    Bytes Free: 133D4   Checksum: CB2F
1. Initial version. (based on P701-ASUS BIOS 0112)
2. Added CPU micro code(s):
    * M206D820 - Intel Pentium M Processor (Dothan) C0 stepping
3. Removed CPU micro code(s):
    * M206D618 - Intel Pentium M Processor (Dothan) B1 stepping
4. Removed setup menu item "Adjust FSB Speed".
    (Advanced)
5. Removed clock generator and voltage control.
#4 2008-03-12 10:30:47 am
Neil
ASUS directly.
Interesting...
#5 2008-03-12 11:26:26 am
rorkin
when updating bios.. It goes through shutdown ans says it cant read the bios image file.. resume with old bios.. what gives ??
#6 2008-03-12 11:52:24 am
cubic;archon
The new version turned up in the update manager (add/remove programs I think it's called), and I had the above issue when installing through that.
Plus, now, my wifi is really, really unreliable - practically useless! I tried selecting the previous package, got the same message, and the wifi is still horrible.
#7 2008-03-12 1:31:03 pm
cubic;archon
Having now read up on the manual process to update the BIOS, I'm giving that a try. I don't know why it failed before, but, well, an Eee without proper wifi is a bit pointless. What am I going to do, sit there playing solitaire?
#8 2008-03-12 2:55:21 pm
kytsrf
"when updating bios.. It goes through shutdown ans says it cant read the bios image file.. resume with old bios.. what gives ??"
Same here; my 2G surf has never had any updates available ever,  and now the new bios can't read bios image file.
#9 2008-03-12 10:26:54 pm
voodooboy
Ok I dunno what you guys are doing, but this is what I did:
1) Downloaded the .zip file and extracted it.
2) Started the Asus Update tool that came in the cd
3) Selected "Update from file" and pointed to the .ROM file I just extracted.
4) Followed the on-screen instructions from there on (Just clicked OK to let it reboot).
....and it pretty much took it from there. And like i reported earlier, absolutely nothing changed. Although it feels like it boots a TAD bit faster..maybe a second or 2 at best.
#10 2008-04-23 5:37:57 pm
Porkypud
I was a proud owner of the 701 for two days.  Unfortunately for the first time in my life I read the instruction manual, and got to the page that say upgrade bios....press a few buttons and then a blank screen.  The only sign of life of this unit is the yellow and blue lights.
I called Anus support line, emailed their repairs department but no reply, thats two weeks ago.
Anyone experienced similar fate as me?
#11 2008-04-23 9:30:43 pm
plodr
Yes, quite a few people.
Read this
http://wiki.eeeuser.com/howto:recoverfrombrick
HP5550 networked printer
