#1 2007-11-11 11:24:35 am
mkrishnan
Print to Pdf and cups-pdf help?
This is in the Xandros "easy" mode.
Reading off a guide for Ubuntu, my understanding was that if I install cups-pdf and reboot, then I should have a new local port to which I can print to generate PDFs.
I am able to install cups-pdf without any problems.
However, I still only see the USB port listed in the Printers item from the simple interface.
Has anyone been able to set up print-to-pdf yet? Can anyone please help me? Thank you!!! smile
Also as an aside, the default printing option is to generate postscript... I know that if I really want to, I can save .ps's and then convert them to pdf, although that seems laborious. But if I print to postscript without printing to file, the print seems to go to a black hole... where does it go?
#2 2007-11-12 10:08:48 pm
mkrishnan
Re: Print to Pdf and cups-pdf help?
Success!
Here's the walkthrough. smile
1) Add a standard repository if you haven't already. Xandros is probably safest, but I have gotten away with this one (add this line to /etc/apt/sources.list):
deb http://http.us.debian.org/debian stable main
2) Get cups-pdf
sudo apt-get install cups-pdf
3) Add a printer using the cups web-based configuration -- for some reason, the wizard does not work.
- Point your web browser to http://localhost:631/
- Add printer
- You can put in anything you want in the three blanks (follow the rules.. you can call the printer cups-pdf or print-to-pdf or pdf or something like that).
- On the next page, choose "Virtual Printer (PDF)"
- On the next page, choose Postscript
- On the next page there should be one option for a color postsript driver, so go with it and click on Add Printer.
That's it! You should now have a printer in your printers list that will generate a PDF file in the ~/PDF folder. Unfortunately, as far as I can see right now, this just auto-generates a filename and puts the file in there -- it doesn't give you a dialog or anything. But it works nicely. smile
#3 2007-11-13 12:54:23 am
o2smartphone
actually, the simple way is to name the print command as kprinter, then it will provide you with dialog.
#4 2007-11-13 2:45:15 am
Niel1952
That is cool.  Now I can create printouts of web pages as I go along.  A couple of questions, please:
1. Exactly what is meant by "name the print command as kprinter"?
2. Are there other things that one can do through similar web interfaces?
#5 2007-11-13 3:41:46 am
o2smartphone
Say you use Firefox. Select File menu, print, in printer dialog window, if no printer added, it should be PostScript/default,
select Properties ... in the white box next to Print Command, type kprinter follow by OK.
At print, make sure in the Printer name you choose Print to File (PDF) rather than the default Mail PDF File which will activate kmail.
I do not catch what you meant in item2.
#6 2007-11-13 9:33:16 am
mkrishnan
Ahhh, so kprinter can do this without cups-pdf? I didn't realize that. Good to know, although I suppose I'll leave well enough alone.
#7 2007-11-13 3:57:57 pm
Niel1952
Ok, got it.  I have now deleted the pdf printer suggested by Mohan and am using the kprinter way but it seems this kprinter way can coexist with other printers.
#8 2007-11-13 4:05:13 pm
mkrishnan
Can or cannot? The cups version coexists also... the Eee uses cups for network printing anyways. My office printer is configured via IPP and CUPS.
For that matter, isn't kprinter just a front end for cups to begin with?
#9 2007-11-13 6:25:35 pm
dewguy
Is there a way to set up kprinter as one of the printer choices so it can be picked from the printer list instead of typing it in each time?
#10 2007-11-13 7:33:53 pm
o2smartphone
why u need to type it each time ?
#11 2007-11-13 10:32:35 pm
fengzj
I followed every step and installed cups-pdf. But when I "add printer", it asks me for the username and password at the last step. Is it normal? It keeps on asking me to provide uasername and password even after I type them in. Failed to "add printer".
#12 2007-11-14 7:35:29 am
x94scorp
Doesn't OpenOffice writer do this by default?
#13 2007-11-14 9:20:30 am
mkrishnan
OpenOffice does this by default, but I'm not aware of an option in OOo to print web pages loaded in firefox to PDF. wink If such an option exists, can you please explain how to use it? smile
#14 2007-11-25 12:51:19 pm
deadDuck
I ran into this as well. It worked with "root" and my user password.
#15 2007-11-25 1:00:12 pm
mkrishnan
I don't remember being prompted for that...odd....  but I just tried it again, and I too had to put in root/my password.
#16 2007-11-25 4:44:51 pm
deadDuck
I followed the instructions and it worked well, so I've added them to the wiki. Thanks to Mohan for laying it out so well.
Please improve the wiki if you find anything that's not clear.
#17 2007-11-25 4:52:31 pm
Niel1952
Just a minor caveat about this method.  Because this method automatically names the pdf, I think it overwrites any file with the same name.
#18 2007-11-25 5:16:25 pm
mkrishnan
That appears to be correct, yes....
#19 2007-12-08 11:23:24 pm
oldtimer
mkrishnan's walk through above no longer works.  The CUPS page at "http://localhost:631/" no longer provides a "Virtual Printer (PDF)" option, so one cannot actually install the CUPS pdf printer.  Has anyone an alternative?
#20 2007-12-09 3:15:39 pm
mkrishnan
When you first point to http://localhost:631 -- what version of CUPS is reported? (it should say something like Common Unix Printing System 1.2.7 at the top).
Also did you succeed with steps 1-2? What is the result of this terminal command:
/home/user> dpkg -l | grep -i cups-pdf
ii  cups-pdf                            2.4.2-3                         PDF printer for CUPS
Is that the version of cups-pdf reported as installed?
#21 2007-12-09 3:46:38 pm
oldtimer
I seem to have succeeded with steps 1 and 2.
When I open the localhost,  it says exactly what you said, "Common UNIX Printing System 1.2.7"
And the command you suggested produces the output "ii   cups-pdf                              2.4.2-3         PDF printer for CUPS"
#22 2007-12-09 4:31:01 pm
mkrishnan
So then after you provide the name etc of the printer, what *is* in the option list?
#23 2007-12-09 4:32:44 pm
Neil
I've just run through the guide, and it is working fine for me?
#24 2007-12-09 4:45:43 pm
Neil
A little bit of tweaking to the cups-pdf settings can fix this: edit cups-pdf.conf to set Label value to 1, and it will add a unique job ID to the front of the file name, and no need to worry about duplication smile
sudo nano /etc/cups/cups-pdf.conf
Look for the setting "Label"
Uncomment it, and change its value to "1", so that the line reads
Label 1
Save the changes (Ctl+O), then exit (Ctl+X)
You should not need to restart cups for the changes to take effect, but, if you want to:
sudo /etc/init.d/cupsys restart
And, there you go smile
(cups-pdf.conf also lets you change output path settings etc.)
#25 2007-12-09 4:48:33 pm
Niel1952
If this works, I thank you.  Also may need a change to the wiki.
