Editted on April 9, 2008:
Up to date steps for using and advanced WPA configuration are available in the wiki here:
http://wiki.eeeuser.com/wpa_default_xandros
These wiki instructions are based off of what originated in this forum thread.
Original post:
Finally able to run wpa_supplicant in the same type of automatic way that I've been able to do with different distributions.
That is... with my own /etc/wpa_supplicant.conf (that contains a list of networks I normally use... with a mix of WEP and WPA).
ctrl_interface_group=0
eapol_version=1
#Sets AP sellection to be handled by wpa_supplicant or the driver.
# 0=driver 1=wpa_supplicant
ap_scan=1
#Begin Network Block
network={
ssid="some_secure_network"
scan_ssid=1
proto=WPA
key_mgmt=WPA-EAP
pairwise=TKIP
eap=PEAP
ca_cert="/etc/certs/CAcert.cer"
identity="myusername"
password="mypasswrd"
network={
ssid="some_other_network"
key_mgmt=NONE
wep_key0=#####
}For the WEP network... replace the ##### with your key in hex (no 0x).
Here's my steps:
1. Using the "Network" button in the "Internet" tab, created a new "Local Area Network - Wireless" with the connection wizard.
When it asked for Network name (SSID)... just put in something stupid that I would recognize latter. E.g. "Poopoohead"
Also made it to automatically start on boot... (up to you about this)
2. After it's created, clicked on "Properties" for this new network config.
Note the ID. In my case... it was "lan3"
Removed the Network name (SSID)... "Poopoohead", and clicked ok.
3. With your favorite text (only) editor... edit /etc/network/interfaces.
Just before this line... in the section with "iface lan3 inet manual":
up ifconfig $IFACE up
Insert
up wpa_supplicant -B -iath0 -Dmadwifi -c/etc/wpa_supplicant.conf
Now... this generic wireless network config will work with whatever networks I have defined in /etc/wpa_supplicant.conf
Hi Bryan,
Could you help me out with writing the file please?
I have already posted a thread about my problem. http://forum.eeeuser.com/viewtopic.php?id=1787
Thank you
vision-b wrote:
Hi Bryan,
Thank you
From the looks of it... that network configuration looks similar to the one I use at work.
Try using the options that I had in mine, just omitting the ca_cert line. if that doesn't work... you might need the certificate from your network admin. Maybe he/she would be kind enough to provide it. Then put that file in /etc/certs/
Thanks for your reply. I'll try it when I get my Eee PC next week. Does that configuration just work for WPA or can it be used with WPA2?
Not sure about that. Sorry.
Using my hack, as shown above, appears to conflict with the script that handles the acpi Lid events (what to do when closing and opening the lid). The network doesn't come back, unless you tell it to.
I'll work on a modification to my hack... and update this thread.
vision-b wrote:
Hi Bryan,
Thank you
Looking through my other machine's docs... wpa_supplicant comes with a number of example configurations, including one that may match the one you need.
Go here:
http://hostap.epitest.fi/wpa_supplicant/
Near the bottom of the page is a section called "Configuration file". This should help you out.
What needs to be put in if we are connecting to a CA server instead of storing the certs locally?
If you don't want to verify the server certificate... try just commenting out (or removing) the ca_cert line. I'm not entirely sure this will work for you, since I cannot try this myself.
A lot of explanation of this configuration file is found here
http://hostap.epitest.fi/gitweb/gitweb. … icant.conf
Bryan wrote:
vision-b wrote:
Hi Bryan,
Thank youLooking through my other machine's docs... wpa_supplicant comes with a number of example configurations, including one that may match the one you need.
Go here:
I'll have a look.
Bryan - is this on the default xandros OS or another linux?
Bryan wrote:
I hope I don't seem to "It is in the manual"-ish. I just don't have a network like yours to test out different configurations.
Good luck.
Don't worry. You've been very helpful ![]()
I'll have to try it out myself to see if it works.
Bryan wrote:
Here's my steps:
The wizard insists on asking for other settings as well, which it then places in the /etc/network/interfaces file.
What should be answered for these settings? Do any of the lines in the /etc/network/interfaces file end up conflicting with what wpa_supplicant does? I am guessing that I should just enter no encryption at all in the wizard, and let the manual wpa_supplicant.conf file take care of it. Is this correct?
Josh
Josh
I just put stuff in there that I knew I could remember to remove from the interfaces file, when I went to edit it. You're right... if you enter no encryption it should probably still work because wpa_supplicant is taking care of that overhead. Still need to put in and remove the SSID.
Thanks. I told the wizard to use no encryption at all. Here's the resulting content from my /etc/network/interfaces file (after being edited to include wpa_supplicant):
down dhclient3 -r -pf /var/run/dhclient.$IFACE.pid -lf /var/run/dhclient.$IFACE.leases $IFACE
down ifconfig $IFACE down
up dhclient3 -cf /etc/dhcp3/dhclient.$LOGICAL.conf -pf /var/run/dhclient.$IFACE.pid -lf /var/run/dhclient.$IFACE.leases $IFACE
wireless-key off
wireless-keymode open
wireless-mode auto
wireless-rate autoAnd, here's my /etc/wpa_supplicant.conf file:
eapol_version=1
ap_scan=1
fast_reauth=1
network={
ssid="MY_ESSID_HERE"
scan_ssid=1
proto=WPA
key_mgmt=WPA-EAP
pairwise=TKIP
eap=PEAP
ca_cert="/etc/certs/MY_CERTIFICATE_HERE.der"
identity="MY_USERNAME_HERE"
password="MY_PASSWORD_HERE"
phase1="peaplabel=0"
phase2="auth=MSCHAPV2"
priority=1
}I was following other articles here and tried to follow some of their suggestions. Added fast_reauth, among others.
This is for a WPA network (not WPA-PSK). I was given 4 things: a username, a password, the ESSID of the access point, and a certificate file in DER format.
I'm to use TKIP data encryption, EAP authentication, PEAP authentication type, MSCHAPv2 authentication method.
The interface seems to come up, and wpa_supplicant is called, but it just loops through and never completes the negotiation. I ran wpa_supplicant again from the command line with debugging turned on (used -d instead of -B option).
I see that it correctly discovers the access point, begins negotiation, then fails somewhere and goes back to a quiet state for a few seconds, then re-scans and loops around, picking up the access point again. It never succeeds.
The openssl messages appearing in the text spew from wpa_supplicant claim that the DER certificate was correctly parsed. Its contents appear good. I'm not really sure what the certificate is for.
There might be errors around the EAP authentication process. The text spew is very large, so don't really want to paste it here (yet). Are there any known problems with the EEEPC's supplied wpa_supplicant program being able to handle EAP? Maybe I should try to grab another version of wpa_supplicant?
BTW, is there any way to provide the Windows domain (this authentication is done through servers running Windows)?
I will most likely need to provide this to wpa_supplicant somehow, in addition to username and password. Is there a field for adding this to the wpa_supplicant.conf file?
Thanks for your help here!
Josh
I have to admit. I'm having the same problem with the WPA - EAP (PEAP) authentication.
I'm meeting with the IT guy that set up our work network tomorrow... maybe he'll be able to shed some light on this.
Same issue at my school. I'm very interested in getting this fixed.
Downloaded madwifi and wpa_supplicant from source, to try and recompile wpa_supplicant and enable all of the various PEAP combinations, since the best guess so far is that Asus forgot to include some of them. That might explain why it gives errors about an unsupported authentication method.
Tried to compile wpa_supplicant, by using the headers in madwifi, but not actually wanting to recompile madwifi (since Asus might have made some customizations).
Unfortunately, there's a version mismatch. My new wpa_supplicant compiles perfectly, but when running it, I get ioctl() errors about "Argument list too long" and so forth. So, no luck, it appears to run normally but doesn't see the wireless AP at all, since it can't correctly communicate with the madwifi driver.
I need to figure out what version of madwifi was used by Asus, and try to match that. I also could try recompiling madwifi, taking the risk of losing any Asus customizations, but would need the kernel headers to do that. Are the kernel headers available on Asus's Debian repository? Did Asus make any modifications to madwifi?
Right... in my case (for my work network), we require MSCHAPV2 authentication. Trying to insert this option into the phase2 portion gave me a "Unsupported" warning. Blah. Looks like that option wasn't compiled into xandros-wpa-supplicant.
I got similar (perhaps exactly the same) results when I tried using the wpasupplicant provided by the xnv4.xandros.com repo. I figured that whoever put together the xandros-wpa-supplicant package hacked with wpa_supplicant... but you may be right about the hack to the driver itself. If that's true... maybe those changes will trickle down into the stable version of madwifi.
It'd be nice if there was some sort of changelog that noted some of these hacks.
Check that. The xandros-wpa-supplicant changelog.Debian.gz (in /usr/share/docs/xandros-wpa-supplicant) shows that perhaps some changes for the Asus Eee PC were made. Not descriptive at all, and the package maintainer appears to be generic/anonymous. Wish I could see the source/diff.
For the driver, I looked in /usr/share/doc/atheros-swan-modules-2.6.21.4-eeepc. This package provides the kernel objects for the wireless device. Looks like there was some patching in there, as well. But it's not obvious that they're using/modifying source from madwifi.
Anyone attempted to use xsupplicant for WPA-EAP?
If not... I'll give this a go in the next day or so. I'm hoping it'll be less dependent on the device driver.
Did you have any luck finding the kernel headers for Asus's build of the EEEPC kernel? Without them, I can't recompile madwifi. So, I'm at a dead end here.
I'm unsure if it's a version clash or not. The versions of madwifi and wpa_supplicant that Asus used seem to be fairly recent. Still, it's unclear why the ioctl()'s have been shuffled around. The upstream wpa_supplicant, when compiled with the headers from the latest upstream madwifi, tries to use ioctl()'s that are not understood by Asus's kernel drivers.
I wonder how much Asus's kernel drivers differ from the upstream madwifi kernel drivers? From looking at version strings and such, I'm pretty sure they have a common ancestor in madwifi. So, isn't Asus supposed to provide source, under the GPL, for everything in madwifi (except the binary-only Atheros HAL)?
I'm currently downloading the huge zip file containing the "source" from the Asus webpage. I was hoping that it would contain the source for the wpa_supplicant, so that we might be able to compile in the necessary options for EAP. I've been downloading since yesterday... the dl rate is SLOW (~20K/s).
Looking through the forum, looks like people have been able to get EAP to work using ndiswrapper. However, the kernel supplied with the default Xandros Eeepc, does not include the ndiswrapper driver. Damnation.
Is madwifi GPL? I did a quick glance through their website, and I didn't see anything regarding GPL. Maybe a more detailed look would reveal it.
Ugh. Maybe I should just switch to (k)Ubuntu.
I know the feeling. This is getting annoying. I only have one more semester at school, but it'd be sooo nice to be able to have my little lappy in class with me. I downloaded xsupplicant, and it's vomit is a tad more useful than wpa_supplicants (although I still prefer wpa_supplicant). It seems as though TKIP is not supported through the Eee's wireless card. It's probably more that the driver Asus created doesn't support it, but that's still a huge issue, since there's really no alternative.
I may just try to install Slackware again, build the driver for the wired NIC (since it builds fine on Slack's default kernel), and then use ndiswrapper for the wifi. Oh boy.
