  • Index
  •  » eeeXubuntu
  •  » eeeXubuntu using finit (fastinit reimplementation)
#1 2008-02-17 8:59:18 am
Jaffa
Has anyone tried booting their eeeXubuntu install with finit?
http://helllabs.org/blog/20080205/eeepc … on-update/
Shouldn't be too hard to bootstrap only the essentials from /etc/init.d from a fastinit-like system, but don't want to duplicate any work already done on this.
Cheers,
Andrew
#2 2008-02-26 5:46:20 pm
venin
Re: eeeXubuntu using finit (fastinit reimplementation)
Please let us know if you do try it. smile
Fastinit and eeeXubuntu would be nice.
#3 2008-04-21 11:38:49 am
ShaqARif
Anybody with any joy on this?  I'm going to give it a go over the next couple of days, so if anybody has tried it already, please share your experience!
---- eee pc 901 Glossy Black 1GB RAM 4/8GB SSD --------- CrunchBang Linux (adamms kernel)  ------
#4 2008-04-22 6:33:04 pm
richardkemp
I'm just about to have a go... Though reading through it, it looks like it is beyond my abilities. I'd be really interested if someone worked it out though! I think the worst thing about eeeXubuntu compared to easy mode Xandros is boot time. The rest I love!
nLite'd XP on White 4G, 2GB of RAM
#5 2008-04-23 6:02:29 am
smurfy
hey, i also will take a look and try to get it work with eeexubuntu
#6 2008-04-24 6:57:25 pm
smurfy
ok,played a bit with the latest version (18.04.2008) of finit.
mainly played with a vmware image but my last compile works on eeepc too big_smile
what finit does:
- mount fs
- basic otherstuff
- login as a spezifc user
- startx
the problem i have with that, i have more than one user and i want to have a loginpromt.
so i started to modding the finit-alt.c file.
i started first to just replace some paths and starting /etc/init.d/gdm instead of a login and startx.
it worked, but i ran into trouble (later what kind).
so as this does not work i tried to login at tty3 (basic finit spawns only tty3) and do a startx. but startx also crashes.
so i started to stay on the console for a while and adding spawning of more than one tty and also add a respawn function if you logout.
so my status is: (working stuff)
- getting tty1-4 running (more possible but for testing 4 are enough)
- respawn a tty if you logout
- autoswitch to tty1 after boot (about 10 sec)
problems:
- gdm starts but after i login i get an error telling me i started with setuid (http://www.gtk.org/setuid.html)
- startx starts but xsession crashes with a "prng is not seeded" error. but i init the random-seed file and /dev/urandom and /dev/random
- mouse does not working but thats minor stuff. (need to load more libs)
- usplash bar only have ~5 percent and than booting is done,  how do i mod the bar and why does usplash_write displays nothing big_smile
i will post my source with installguide later i hope someone could help me with my problems
edit:
startx problem solved big_smile but gdm still does not work big_smile
#7 2008-04-25 8:04:14 am
richardkemp
Is it necessary to know C to fiddle with this? sad
#8 2008-04-25 9:08:23 am
smurfy
Short answer: Maybe smile
Long one: You must add defines and maybe add some commands big_smile Also must change Makefile.
And here my status and plans for eeexubuntu finit:
Status:
- gdm works and you can login and use firefox, update you dist...
- getting tty1-5 running (you could set it via define)
- starting some init.d scripts like hal, dbus, networking
- adding some modules to support mouse
Problems:
- terminal on the x does not work
- usplash still isnt really usefull
Plans:
- release my source big_smile
- test wlan and other eeepc special stuff.
- use a simple configfile etc. to allow customizion without knowing C
if someone could tell me what could be the problem with the terminal on x (shell does not come up) smile
#9 2008-04-25 10:53:25 am
smurfy
Ok,
x terminal problem solved big_smile i have done a quick test on my eeepc, wifi works.
only current problem is, that i dont have a loginshell on my eeepc on tty1-5, at vmware it works.
ok anyways:
http://www.smurfy.de/files/eeepc2504.tar
Installation:
Installation at your own risk big_smile (my eeexubuntu still works big_smile)
compile or simple copy my precompiled file "finit-mdv" to "/sbin/finit-mdv"
go to your /boot/grub/menu.lst and copy a boot entry
than add behind the kernel line: "init=/sbin/finit-mdv"
i will try to do more tests and optimations directly on my eee (can't restart it currently ever minute big_smile)
What should work with this version:
- a realative fast boot and start of gdm
- wifi, network and x apps (don't tested much)
What does not work is the normal reboot, shutdown stuff big_smile
#10 2008-04-25 11:19:30 am
metalshark
Sending finit-mdv the USR1 signal means shutdown and USR2 signal means reboot - you can use the kill command for this. The original EEE OS uses an ACPI Event script to achieve it.
If there is a splash screen then it'll either be in the kernel or initrd and could be removed.
The code to spawn X is:
    if (!fork()) {
        /* child process */
        vhangup();
        close(2);
        close(1);
        close(0);
        if (open("/dev/tty1", O_RDWR, 0))
            exit(1);
        sigemptyset(&act.sa_mask);
        act.sa_handler = SIG_DFL;
        sigemptyset(&nmask2);
        sigaddset(&nmask2, SIGCHLD);
        sigprocmask(SIG_UNBLOCK, &nmask2, NULL);
        for (i = 1; i < NSIG; i++)
            sigaction(i, &sa, NULL);
        dup2(0, 0);
        dup2(0, 1);
        dup2(0, 2);
        touch("/tmp/nologin");
#ifdef AGPDRV
        system("/sbin/modprobe agpgart");
        system("/sbin/modprobe " AGPDRV);
#endif
        while (access("/tmp/shutdown", F_OK) < 0) {
            debug("start X as " DEFUSER);
#ifdef DEBUG
            system("su -c startx -l " DEFUSER);
            system("/bin/sh");
#else
            system("su -c startx -l " DEFUSER " &> /dev/null");
#endif
        exit(0);
it closes pipe 0, 1 and 2 (stdin, stdout and stderr respectively), opens stdin on /dev/tty1, then duplicates the open fd (file descriptor) to stdout and stderr.
If you comment out the
        close(2);
        close(1);
        close(0);
            exit(1);
and
        dup2(0, 0);
        dup2(0, 1);
        dup2(0, 2);
lines then the terminal on X should work fine. Personally I just use /dev/tty7.
Hope this helps!
#11 2008-04-26 5:25:08 am
zache
I wrote some general overview of my testing with finit-mod and Xandros if somebody is interested.
#12 2008-04-29 12:14:43 pm
richardkemp
smurfy - I tested your finit-mdv you linked to above, thanks for your interest in this project! Unfortunately I can only help by testing what you have done...
I timed boot from pressing the on button to the time when I established a connection to my wireless network. Standard eeeXubuntu took 1 minute 23 seconds, finit-mdv took 1 minute 06 seconds. A good improvement, but I noticed it could no longer read information from my battery. And as you mentioned, shutdown does not work. I will report other issues as I find them.
Is the anything in particular I can try out to help you develop this?
On another note, may I suggest you and anyone else developing fastinit for eeeXubuntu leave the possibility of automatic log-in as I think most people use their EEE as a single-user machine for little more than portable web browsing. Not having to log in is very good in this situation. Also, how should I shut down without holding the power button and risking corrupting open files?
Thanks again for the work you have done!
#13 2008-04-29 12:48:14 pm
SteveLawUK
I like the sound of this and I'll give it a go - once I find out how...
I'd vote for single user though unless there's no difference in speed with the normal autologin and assuming that still works.
2G Surf - "A cracking little machine."
If it ain't broke, don't fix it.
#14 2008-04-29 3:49:37 pm
richardkemp
Instructions in post 9 steve!
#15 2008-04-29 3:58:58 pm
smurfy
Hey richardkemp,
thanks for your reply. I changed some stuff, i now spawn the x server like the original finit (instead of gdm).
For testing only. and i think its quite faster than gdm+autologin.
as i allready wrote, i want to make a small config file so you could edit the config file instead of recompile the executable.
i will release a new version later this week. i also playing around with a self compiled kernel, because i noticed that the time it needs from grub over kernel init to finit takes a long time.
#16 2008-04-29 4:10:02 pm
SteveLawUK
I know sorry, I meant once I get time to sit and read/play smile
#17 2008-04-29 5:20:08 pm
SteveLawUK
Okay, done it.
I timed 1:07 to desktop + wireless connected without fastinit (from the grub menu) and 0:58 with fastinit.  Not as dramatic a difference as Richard's although it probably averages about the same with fastinit (add about 7/8 seconds from power to grub?) and mine was slightly faster then Richard's beforehand tongue
To repeat Richard's question.  How are we supposed to shutdown?
#18 2008-04-29 5:41:57 pm
metalshark
Shutting down finit-alt
If you type in
kill -l
it lists the signals you may send to a process.
Finit listens on signals INT and USR1 for reboots and USR2 for shutdowns.
So the command
kill -SIGUSR2 1
will send the process with a pid (process id) of 1 a USR2 signal.
The original EEE uses BusyBox to make sure fastinit is pid 1 (last line of this quote from the finit README):
* Eeepc boot process
The essential steps in the boot process carried out in initramfs are:
ROOT=`sed 's!.*root=\([^ ]*\).*!\1!' < /proc/cmdline`
mount -t proc proc /proc
mount -t ext2 -o ro $ROOT /mnt-system
mount -t ext3 -o rw /dev/sda2 /mnt-user
mount -t unionfs -o dirs=/mnt-user=rw:/mnt-system=ro unionfs /mnt
mount --move /mnt-system /mnt/mnt
umount -l /mnt-user
umount /proc
exec switch_root /mnt /sbin/fastinit "$@" </mnt/dev/console >/mnt/dev/console
we can also check this by typing:
ps ax | grep finit-alt
and noting the pid in the left hand column (it may appear more than once, pick the lowest number and ignore the "grep finit" line).
ASUS use an /etc/acpi script to handle this called powerbtn.sh:
# /etc/acpi/powerbtn.sh
# Initiates a shutdown when the power putton has been
# pressed.
if ps -Af | grep -q '[k]desktop' && test -f /usr/bin/dcop
then
    dcop --all-sessions --all-users ksmserver ksmserver logout 1 2 2 && exit 0
elif ps -Af | grep -q 'AsusLauncher'
then
    if [ ! -f /home/user/.doingLogin ]
    then
      DISPLAY=:0 su -c /opt/xandros/bin/shutdown_dialog user &
else
    /bin/kill -SIGUSR2 1
The login screen and kdesktop bits will probably need some tinkering for other window managers. Feel free to PM me if you get stuck.
#19 2008-04-29 6:19:49 pm
richardkemp
Awesome, thanks for the updates guys. I can't wait for your next release, I tried using git before but its a bit too much at once for me so I shall be patient!
#20 2008-04-30 12:52:21 pm
smurfy
Ok, here is my newest release:)
http://www.smurfy.de/files/finit30042008b.tar.gz
i also attached a INSTALL readme file inside.
There is a precompiled version also. I hope the precompiled version also works for you, because i compiled it with hardy (on the eeepc).
only glitch so far i don't like is the reboot/shutdown stuff.
My Desktop with finit + custom kernel + gdm + crypthomedisk comes up in 40sec (from grub) with login and a long cryptsetup keyprase (i'm a two 1/2 finger typer big_smile)
#21 2008-04-30 1:37:00 pm
SteveLawUK
E: Couldn't find package libconfig0-dev
I tried the precompiled and it just hangs at the loading splash screen.
#22 2008-04-30 2:56:44 pm
smurfy
Ok, using the precompiled on gutsy causes a kernel panic.
i uploaded "finit30042008b.tar.gz" (see lastpost) with a precompiled version for hardy and gutsy.
for the missing package.. its in the universe ubuntu archive.
a "sudo apt-get install libconfig0-dev" works for me on my eeepc (hardy) and vmware (gutsy)
#23 2008-04-30 3:27:27 pm
SteveLawUK
Thanks for both!  (The universe repo wasn't activated on mine (default install)).
I'll try compiling my own first (mostly being 2G, just in case).  EDIT: loads of errors and stuff on that, I'll leave it for now smile
#24 2008-04-30 3:41:45 pm
SteveLawUK
Well that looked impressive, at first.
Normal boot is about 50 seconds to desktop from grub, and about 1 minute to 1:10 to wireless connected.
Finit left the loading splash screen at about 33 seconds (normally about 40)!  Wow! Thought I.  Now I just see a screen full of:
NetworkManager: <debug> [1209584155.xxxxxx] nm_hal_device_added(): New device added {hal udi is '/org/freedesktop/Hal/devices/pci_8086_2668_{various different things like _alsa_playback_0, _oss_pcm_0_0, etc}').
#25 2008-04-30 5:15:55 pm
smurfy
hey,
1.
the network manager also creates lots of messages like this. but mostly on tty8. (during startup) on my vmware session (where i test my code and write it) i sometimes get a message on my current tty
i really don't know why the network manager prints that debug messages.
2.
i got the "shutdown" command working. it now works and i can reboot and powerof from X big_smile
i will test it on my eee later, if it works i post the new version tomorrow.
  • Index
  •  » eeeXubuntu
