Hi to all,
i have an italian version, 4ee. My Russian GF loved it immediatly and want it, but she asked if i can put on the cirillic fonts in openoffice. I tried putting russian, but typing on keyboard i get always latin letters. Somebody can find a solution?
Many thanks and sorry for my english
thanks
Alex
That seems u need to install Russian Keyboard ( Start >Control panel> Keyboard) after that u can type russian when u press Alt+Shift (Switch between English (or whatever) and Russian typing mode)
Thanks, but i didnt install WIndows, i have the original OS.
thanks
Alex
in Xandrox u need to install russian package
try to use searching
No, you don't need to install anything. All the fonts are already installed in xandrox. You just need to add a couple of lines to /etc/X11/xorg.conf
1. open terminal (Ctrl+Alt+t)
2. become root
sudo -i
3. backup your old config file in case you screw up
cp /etc/X11/xorg.conf /etc/X11/xorg.conf.eee-orig
4. open the file in an editor
nano /etc/X11/xorg.conf
5. Scroll down to section "InputDevice" with identifier "Keyboard"
6. Change line
Option "XkbLayout" "us"
to
Option "XkbLayout" "us,ru"
(make sure there are no spaces between us and ru
7. Change line
Option "XkbVariant" ""
to
Option "XkbVariant" ",winkeys"
8. If you want to assign a button to switch between languages, you need to add one more line
Option "XkbOptions" "grp:lwin_toggle"
9. Save
Ctrl+O (in nano. May be Ctrl+S if you use kwrite - I don't know)
10. Exit nano
Ctrl+X
11. Restart X
Ctrl+Alt+Backspace
This makes the "HOME" button switch languages instead of showing desktop. I don't usually use this button, so it was a good choice for me. If you want to use a different button for that, you will need to do some research as to how your desired button is called in xorg
Also, the above will setup the layout similar to windows russian layout. If you need something different, use different XkbVariant (like "phonetic" or other)
If the lines you need to change are different from what I show here (I suppose they are if you installed Italian), then don't just copy my lines. Instead, add the ",ru" and ",winkeys" part to your existing lines. Again, make sure you don't insert spaces after comma
probably you do not have russian keyboard and i sugest you to use 'phonetic' keyboard layout:
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us,ru(phonetic)"
# Option "XkbVariant" "us,"
Option "XkbOptions" "grp:lwin_toggle,lv3:ralt_switch,grp_led:scroll"
EndSection
and probably, you might need italian layout, not us, so try also Option "XkbLayout" "it,ru(phonetic)" (i think, it is ok for Italy)
Hi guys, thanks to all....
im little "scared" to do what u said... im so ignorant in linux and im worry to make problem to her EEE. Now she is with me in Italy, but in 2 days she go back in Russia (kurgan).
I think its better IT + RU version, but i dont want make mistake.... Some suggestion to make the modify easier?
Many thanks to all again
Alex
Well, it should not break your eee unless you change display options. But even then there are ways to fix everything. As long as you make backup of xorg.conf, you should not get in trouble.
Another thing that I can suggest is to enable advanced mode (http://wiki.eeeuser.com/howto:getkde). There you can go to Launch menu > Control Center and then select Peripheral Devices > Keyboard Layout.
There double-clink on Russia (make sure there is checkmark at "Enable keyboard layouts")
Now clink on "Xkb Options" tab, and select the combination of keys that work best for you.
I think you may need to reboot to get it working.
Egor
Egor
i made all perfect as u said but i didnt enter in advanced mode, i opened terminal (ctr+alt+t) then i wrote sudo kcontrol, i entered in keyboard etc etc.......
Now she can switch from italian tu russian only clicking on the flag in tray.
Many thanks to all
Alex
It is more easy than they write look this link you will do it in 3 minutes. i puut 3 languages including RUSSIAN
http://forum.eeeuser.com/viewtopic.php?id=12038 and
http://wiki.eeeuser.com/howto:change_ke … anced_mode
if you read this too pages you will succeed.
MmeStPerle, that worked perfectly. I didn't want to edit anything but wanted the russian to be worked. Now that's great you had the solution. Thumbs up buddy!
Hey MmeStPerle, I've read the pages you referred to http://forum.eeeuser.com/viewtopic.php?id=12038 and
http://wiki.eeeuser.com/howto:change_ke … anced_mode. Thats really great.
Thank you.![]()
