#1 2008-01-21 9:05:13 pm
dsr1205
Good boot configuration for fast boot
Anyone know what startup services are required and which ones arent? like i need the fn commant thing running but i bet i dont need all like 70 processes running. anyone know what can stay and what can go?
Black 4G Eee PC XP SP2 - 1GB ram - 16GB SDHC -
Possible touchscreen in future.
Dota player us east: dsr1205
#2 2008-01-22 1:15:57 pm
ptopping
Re: Good boot configuration for fast boot
I have AsTray, AsAcpiSvr, avgnt (Avari AntiVir), SynTPStart, cfmon(not essential but a pain to remove and doesn't alter things that much). Everything ticks away nicely and boots in about 25secs.
While your at it take a look at this thread for aps
http://forum.eeeuser.com/viewtopic.php?id=10387&p=1
#3 2008-01-22 3:13:37 pm
ruairiSpain
I spent a few hours with BootVis and the main gain was when I changed from DHCP to fix IP.  Went from 50sec boot to about 30sec.
BootVis is useful to see what is slowing things down, but don't bother with it's optimisation options, XP already has this built in.
#4 2008-01-22 4:26:45 pm
bay_wolf
Can you elaborate on what you mean by changing from DHCP to fix IP?
Regards
#5 2008-01-22 10:46:29 pm
Fluffywings
Bootvis does not work for SSD.
In fact, all it does is decrease the life of you SSD.
#6 2008-01-23 11:48:23 am
dankind
Regards
I believe he means he changed his network settings so that his IP is set statically/manually instead of requesting one from the router.
4G 701 Rev.7B running XP
"I live in my own little world. But it's OK. They know me here."
#7 2008-01-29 5:16:07 pm
dolzenko
My 2c:
I removed everything except for SynTPStart.exe , it's the one which does "mouse-wheel from touchpad" (i.e. when this field to right on your touchpad scrolls document).
I suspect that AsAcpiSvr.exe only draws nice "message windows" when you're adjusting LCD brightness, or volume, or turning WiFi on and off, i hardly need this so it's disabled too.
P.S. Probably i disabled something which would break WiFi functionality but i haven't tried that yet
#8 2008-01-29 5:25:33 pm
Molly
EEEmazing User
"ctfmon(not essential but a pain to remove and doesn't alter things that much)"
CTFMON is very easy to get rid off:
1. disable CTFMON with AutoRuns or MSCONFIG.
2. Control Panel > Regional and Language Options > Languages > Details > Advanced > check the box that says "Turn off advanced text services."
Done!
Eee PC 701 4G Blk, 405-990 MHz, 2 GB Corsair DDR2 RAM 667 MHz - Custom XP Pro SP3
#9 2008-01-29 6:36:26 pm
joners
Done!
Thanks for that!
Id being meaning to turn that off at boot for ages but never got round to finding out how to do it. Thanks!
Wise words from the 'Engineer' - "Beta does not mean 'better', it means 'not ready'. "
