#1 2008-01-20 6:43:35 pm
SmallFootprint
reiserfs better?
Contemplating the small 4 GB disk on the eee, I am wondering if using a reiserfs wouldn't be better.  reiserfs uses less disk space then ext3.  By that I mean that ext3 seems to require quite a bit of space on the initial format.  reiserfs is considerably smaller.  But there has not been much discussion of that.  Any thoughts on that?
I think it is clear a journaling filesystem is essential.  Would reiserfs be preferred?  XFS?  JFS?  (please no posts about JFFS...)
I gather reiserfs has been somewhat abandoned/lacks active development, although it is a complete, stable filesystem.  I suspect this is why the major Linux distributions don't use it by default.   At least Suse Linux gave it up.  Ubuntu supports it (comes with the kernel module for it).  Alas for poor Hans.  I see that an ext4 filesystem is in the works, which will likely be an improvement on ext3.
It would be a complicated procedure switching to reiserfs, while preserving one's existing installation.
For Ubuntu:
(a) add the reiserfs module to one's initrd, so the booting kernel has access to the root filesytem when it boots.
(b) preserve the entire filesystem to a back up media.
(c) boot to a "rescue" or live CD system.
(d) reformat the disk for reiserfs, which should preserve the MBR.
(e) copy the entire filesystem back to the newly formatted disk.
(f) reboot and cross your fingers.
#2 2008-01-20 7:06:23 pm
andyk
Re: reiserfs better?
I don't really know about reiserfs, however, jfs is supposedly faster than ext2/3 and the xfs is able to handle larger files and is generally better at doing it than the other 2. I'm tempted to go with jfs when I install some variant of ubuntu...
#3 2008-01-22 10:28:21 am
DannyB
From 1999 until January 2007 (1 year ago) I have been a SuSE user.  I started with SuSE 5.2, it's been so long it is hard to remember the exact events and releases.
After about the 2nd or 3rd release after I started with SuSE 5.2 in June 1999, probably about late 2000'ish, SuSE started using ReiserFS by default.  So a major distro has used it for years.  I do not know if that is still the case.  I have not used SuSE 10 as I switched to Ubuntu.  (Although an ancient server still runs -- SuSE 9.1, which hasn't been supported for several years now.)
So I used ReiserFS for years.  I've had no troubles with it.
When I switched to Ubuntu, I switched to using Ext3.  Just want to "go with the flow" of what it seems everyone else is doing.  I haven't had any trouble with Ext3 either.  My rationale was that Ext3 can be used with Ext2 tools of live cd's if necessary.  Just about any Linux has built in support for Ext3/2, but not necessarily for JFS, XFS, or sometimes ReiserFS.  So wide compatibility and maturity seemed good reasons to me.
I would not use XFS on Eee Pc.  It's specialty is streaming really large files, eg, multimedia.  If you have a 2 GB movie file you want to play back sequentially, XFS is your filesystem.  No surprise since it was designed by Silicon Graphics for this purpose.
#4 2008-01-23 12:26:04 am
SmallFootprint
Some links on the subject:
http://www.linux.com/feature/57788
http://www.linuxquestions.org/questions … t3-434549/
http://arnofear.free.fr/linux/files/con … bench.html
http://www.debian-administration.org/articles/388
In the last link, the quote "Ext3 has the worst inital capacity (92.77%), while others FS preserve almost full partition capacity (ReiserFS = 99.83%, JFS = 99.82%, XFS = 99.95%)" confirms what I was talking about - ext3 will cost 7% more of the disk at the initial partition, or 280 MB on the eee's 4 GB disk.
Reiserfs has:
PRO:  Better performance on small files and in disk space efficiency.  Also, from time-to-time ext3 will stop the boot up and perform its lengthy disk check; I think that's its legacy ext2 property.
CON: Lacks active development; issues with administration and upgrading because Linux distributions don't use it by default.  Ext3 is probably a more conservative/robust FS.  Reiserfs will use a little more cpu in disk operations.  Mounting and unmounting take longer.
On the whole, having read the comments above and the articles, together with my experience with Suse's reiserfs, I think I favor reiserfs over ext3 by 70-30, say; I want the 280 MB back...  Perhaps with a small ext2 partition for /boot.   If one were concerned about system administration and upgrading, sticking with ext3 would be the more conservative approach.
Suse gave up on reiserfs because its development had stagnated (Hans was intransigent about development to reiserfs v. 3.  reiserfs v. 4 has its own problems.) and other Linux's did not use it.  For the purposes of a tuned-up eee running Ubuntu, however, these issues don't matter, seems to me.
Discussions of this issue on-line are endless...
#5 2008-01-23 11:11:24 am
SmallFootprint
I've now transitioned my system over to reiserfs.  The steps to do so are roughly those above, but...holy **** that was an adventure I'd rather avoid in the future.  Note that when you repartition a system the UUID changes; who knew?  Note that when you repartition you have to rerun grub-install (grub error 17).  Apparently the mount flag in /etc/fstab "errors=remount-ro" causes reiserfs to complain.  Etc. etc.
In any case, I made my disk to be one single reiserfs, one single enchilada.  Previously I had 1.28 GB of free space, now I have 1.80 GB of free space.  That freed up 0.5 GB of disk space!
I also noticed that whereas with the ext3 filesystem before writing to the disk took forever (reading was very quick), now it is rather quick.  I thought fast read/slow write was a property of flash drives!
We'll see if it was worth it in the long run...
#6 2008-01-26 6:59:50 pm
rmrubin
I have used reiserfs on multiple distributions for system and media partitions. For two or three years, I ran a two partition reiserfs raid0 with the Linux kernel raid (md), never having problems. reiserfs did seem noticable faster than ext3, disk checks anf formatting were significantly faster. Also, in my experience, Linux deals with moving mount points across diff filesystems fine (presuming you dont mess up fstab or file permissions).
File systems are implimented in the kernel, either as built-ins or modules. As such, it is not a distribution specific capability. However, because many distributions are based on modular kernels in order to be able to support ALL x86 hardware with one setup, you may have to load a module from userspace (if it is even built and available). If you are using reiserfs for root, and a modular kernel, I imagine you would have to build the fs modules into an initrd. Also, dont forget you would have to change fstab.
I usually build monolithic kernels, with all filesystem code built-in, and boot with grub so initrd stuff isnt a problem.
#7 2008-01-26 7:29:58 pm
robin
Why is that?
I can't see the need for a journaling FS on flash storage on a device with a built in UPS (battery).
Seems like unnecessary overhead to me.
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away."
--Antoine de Saint-Exupery
#8 2008-01-26 8:50:42 pm
rmrubin
Magnetic hard drives, like flash-based SSD, are also non-volatile. The issue is with how the system handles data write and transfer operations, specifically what happens if one of these operations is interrupted. The loss of data is a software issue, not hardware.
A laptop is precisely the type of environment journaling filesystems were meant for. Batteries die, and eventually fail. Sudden shock can disconnect a battery, or cause it to fail outright. Modern operating systems depend on hundreds of files to exist in an uncorrupted state just for basic functionality. There is a reason both Microsoft and likely all mainstream GNU/Linux distributions use journaling file systems as default recommendation for partition formats.
Early generation technology is prone to failure. ASUS has likely produced millions of Eee PC systems, so there is bound to be MANY failures. This isn't unusual, or even from bad decisions on the part of ASUS. There's no way of knowing if SSD failures are even caused by heavy disk writes, as opposed to manufacturing defects. Because there is already a risk of data loss from SSD failure (be it from heavy disk writing, or from being first generation mass produced SSD technology), I do not think adding another problem, like a non-journaling file system on a battery powered general use computer, is the answer.
Please see this post for ASUS Support's position on high disk write software:
http://forum.eeeuser.com/viewtopic.php?id=11802
#9 2008-01-26 10:36:03 pm
robin
I understand why Jounaling FSs exist.
But the type of usage the device is put to determines the importance of journaling, not the possibility of failure.
Everything will fail.
With my Eee, I am not logging firewall intrusions, running a database server, or creating 20k row spreadsheets.
I am using web, reviewing documents, time tracking (backed up online), email (imap), programming (saved and backed up every 5 mins).
In other words, the Eee is not my main workhorse computer.  It is my secondary device as it was intended to be.
I use XFS on my home desktop.
I also understand how operating systems work.  I have studied OS concepts as part of Comp/Sci and used Linux for more than 12 years.  Modern operating systems depend on hundreds of files but only a small handful are getting written.  e.g. /tmp/*, /var/spool, /var/log, etc. Most of this stuff gets cleaned up on next reboot anyway.
I am not worried about SSD failure.  I just don't see how it adds up when looking at cost/benefit where:
* cost is CPU, RAM, slower writes
* benefits are not corrupting that gif that is currently getting written to your browser cache when the power fails.
#10 2008-01-26 11:21:27 pm
rmrubin
...or autosaved revisions of a school paper im writing (if not the whole file), the last few notes or test values from a project I am saving, a pic I am saving after mindlessly editing for 20min, a streamed file with external logger values, a very large file being copied from someone elses usbhdd to my usbhdd... I do more than just view gifs on the web. Eee isn't even especially great for that, considering the res. I just like the idea of knowing my data is there when I get the system back. I dont mind the cpu overhead, it seems to do everything quick enough even at 650MHz.
And I actually do have interest in using Eee for embedded control, logging and interface applications. Its size/power/storage specs beg to be used that way. Maximum levels of system and data recoverability in the event of a failure is not an unusual goal for such applications. I definitely plan on using it to program/debug microcontrollers. Losing a file's worth of code could be tragic, for the moment. Pray to voodoos the db9 and db25 usb dongles work.
I also have delusions about running CAD/EDA apps on my Eee, so you may just want to ignore me outright. CadSoft EAGLE schema and pcb editors in XP weren't so bad. Dia and GIMP were okay, too. I definitely plan on using it for more than a web/pdf/doc viewer.
#11 2008-01-26 11:38:36 pm
robin
Ahhh.  Yes it makes sense for this kind of use.
Has anyone looked at the ordered journaling mode of ext3?  This is the mode where only metadata is journaled.  Should be faster and less resource intensive due to data not getting written twice.  Might be a good balance between safety and overhead.
#12 2008-01-27 4:24:33 am
SmallFootprint
My own opinion is that journaling is essential, particularly on a laptop for the reasons given above.  Things do get corrupted with a system crash, essential system files included.
"ordered" mode, I think was the default, but I can't recall precisely what that was for xubuntu.  On my Suse linux system, ordered is the default.  (cat /proc/mounts gives the answer).
For me, the compelling reason for reiserfs was saving 0.5 GB of disk space (ordered or otherwise, ext3 still consumes significant disk space when formatted; those inodes I gather).  This is not just 0.5 GB out of 4 GB, but I think of it as 0.5 GB out of the space that's available for the user after system install.  That's 0.5 GB out of 1.5 GB; formatting reiserfs increases available user disk space by 30%!
The system does seem a little faster, disk wise, although the flash disk is pretty darn fast as it is.
I agree with the notion of a monolithic kernel for the eee - there is not much reason to have the full collection of kernel modules (thinking of my ubuntu installation here).  Although perhaps for some things (madwifi?) a module might be better for resetting hardware in a peculiar state.  Having been down that sort of road many times, however (to contradict myself...), I strive to stick to stock distributions whenever possible; much less overhead in system administration, updates, upgrades, etc.
#13 2008-01-27 6:17:33 am
rmrubin
Might want to read what I figured out while compiling a monolithic kernel on Slackware:
http://forum.eeeuser.com/viewtopic.php?id=11967
I think using_dma for the SSD is turned off by default on most default Linux distribution setups. If your SSD is detected as /dev/hdc (and I'm not just wrong), then your drive is probably going really slow =(
#14 2008-01-27 6:50:12 am
sourcejedi
The adventurous can replace these four steps
with running convertfs (after booting from a rescue/live CD).  It's not been updated in three years, but it's still frickin' amazing.  It converts between linux filesystems by moving files into a sparse disk image of the new file system.  Then it turns the filesystem inside-out (that's how I think of it anyway), to write the disk image file to the physical disk.  It's able to create an image file the same size as the device because sparse files avoid allocated any space for blocks that aren't actually used.
#15 2008-01-27 9:22:36 pm
robin
Can't imagine the point of having every single USB driver compiled into the kernel.
#16 2008-01-28 2:23:20 am
rmrubin
You just need usb filesystem, ehci, uhci, mass-storage and hid built-in. You're never going to be unloading those, and you might be loading filesystem mounts from a usb device (ninja adventures, who knows), so built-in makes things neater. Everythng else you can do modular as you need it, or built-in if you know your setup will use it.
The default Xanadros kernel config actually did have EVERY usb device driver built as a module. I wonder how good the kernel module auto-loading actually is, if it does usb devices at all.
#17 2008-01-28 9:32:31 am
Artemis3
Everything would seem nice and happy, but then there is this: http://linuxmafia.com/faq/Filesystems/reiserfs.html
I think the worst issue is avoided with ordered-write strategy (most distros default to this); and its clear running fsck.reiser is a death sentence, specially if for some reason you happen to store a reiserfs image in your reiser filesystem (think qemu, vmware and friends)...
I have some desktops at work with reiserfs: my home system with ext3 and the eee pc with ext2. Eee os came with the "system" in ext2 and the "data" (/home)? with ext3. Ext2 can recover pretty well from crashes, it only takes time which journals try to avoid. Ext3 usually prevents this, but the option is available as a fallback. Ext4 is progressing and will be quite easy to convert ext2/3 to 4.
Reiser3 (the one in the kernel) is not being maintained much in favor of reiser4 (not in kernel). Unfortunately the main pusher and creator of reiserfs has urgent real life/legal troubles/being in jail issues so the fs future is unknown.
Aside from losing space to very small size files (min cluster size limit+metadata), my biggest issue with ext3 is still insisting to force fsck after 30 reboots or so. Should be quick with the ssd tho... Reiserfs on the other hand seems to just work fine, until the day you need to fsck; which should never ever occur, in theory...
