Must have Utilities for WinXP on Eee?
1016 replies to this topic
#1 CodeMonkey
  • 140 posts
Posted 18 January 2008 - 09:09 PM
Century22 has summarised the list of apps mentioned in this thread in this post
OK, we know all about the Virus and Spywares:
McAfee (or whatever)
Windows Cleanup! (must have!)
Adaware
Spybot
SpySweeper (maybe)
And the usual Suspects:
TweakUI
WinZip
Adobe
Quicktime (maybe)
But what about Eee specific utilities??
So far I have:
MoveMe (shuffles clipped windows back onto screen)
eeeClock (overclocks obviously)
So what am I missing that I really NEED to have?
I'm dying to know. ;-)
CM
Edited by Niel1952, 31 January 2009 - 05:38 AM.
Code Monkey like Fritos, Moutain Dew and Galaxy Black ASUS Eee 4G Surf with WinXP
#2 stareja
  • 190 posts
Posted 18 January 2008 - 09:47 PM
I really like the following:
Launchy (version 1.4, NOT 2.0) - I ended up uninstalling Launchy.
http://www.launchy.net/
RK Launcher
http://home.cogeco.ca/~rklauncher/
WinMover (ALT+drag in Windows)
http://www.majorgeek...over_d4961.html
Treesize Free
http://www.jam-softw...are/index.shtml
USB Disk Ejector
http://quick.mixnmoj...sb-disk-ejector
EEE Specific
EEEPC Cam Tray
http://forum.eeeuser...id=64770#p64770
And I plan on moving my TEMP/TMP folders to a RAMDISK later on tonight:
http://forum.eeeuser...ic.php?id=10004
Edited by stareja, 24 January 2008 - 02:39 PM.
The Wiki is your friend! --> http://wiki.eeeuser.com/
So is the Forum Search! --> http://forum.eeeuser.com/search.php
#3 RK
  • 104 posts
  • Locationcanada
Posted 18 January 2008 - 09:59 PM
VLC media player, light on resources, plays everything with built-in codecs.
Primary Notebook: Compaq Presario v6305 | Turion64 X2 1.6GHz | 2GB RAM | 100GB HDD | Nvidia 6150
Secondary Ultra Portable thing: Black Eee 7c /w nlited XP | 2GB RAM | 4GB SSD | 8GB SD | eeeclocked to 972MHz
#4 CodeMonkey
  • 140 posts
Posted 18 January 2008 - 10:05 PM
Hum, I'm not sure why you would need all those launchers? Just drop an icon on the desktop and be done with it. WinMover seems to do the same thing as MoveMe, so I'm good there. I do have Treesize and probably just forgot to mention it cause the name is so Stupid. And I have the Surf model so no Cam software will be necessary.
Much thanks tho for the USBDisk Eject and the Ramdisk ideas, very nice. I'll probably hold off on the Ramdisk until I get my 2GB card but I love the idea of a Blackhole drive workspace, things go in but they do NOT come out.
CM
#5 CodeMonkey
  • 140 posts
Posted 18 January 2008 - 10:07 PM
Oh sure, I have VLC, I guess in my thats more of an App than a Util. I mean, I didn't list OpenOffice or Firefox either, in case you're not into that whole brevity thing. ;-)
#6 ndondo
  • 68 posts
Posted 18 January 2008 - 10:38 PM
7zip instead of winzip or winrar
#7 stareja
  • 190 posts
Posted 19 January 2008 - 04:54 AM
"All those launchers"? There's only two and they behave very differently from each other. Also, I can't decide between them...
I also prefer to have a clean desktop. One might say spartan.
That might have been handy to know it the original post. It would have influenced my answer.
You're quite welcome. I find USBDisk Eject MUCH more useful than the native Windows eject function.
Something to keep in mind with the ramdrive TEMP space is that it can cause problems with installers that require reboots to finish. I haven't run into too many of those and I can't think of any other drawbacks, though I'm far
#8 Dragonduster
  • 396 posts
  • LocationIn ur Closet!!
Posted 19 January 2008 - 05:12 AM
i havent used the eject from windows, i just unplug the usb, it doesnt give me any msg as before.
4G Galaxy Black, 2Gb RAM, 8Gb SDHC, *xp pro SP2 nLite Office 2003, Photoshop CS2, Corel Draw X4, InDesign CS2, Dreamwaver 8*
MOBO Asus P5n32-SLI Premium, E6600 2.4Ghz, 2Gb Corsair Ram, 320Gb Maxtor, 80Gb Seagate, 80Gb Western Digital [DEAD]
#9 eeeuseeer
  • 81 posts
Posted 19 January 2008 - 06:24 AM
eeectl (overclocking, fan control and temp monitor) and moveme (working with oversized windows on the eee). check my signature (pg 11 on the eeectl thread for the updated version).
Black 4G Surf (701/7B) | 2GB RAM | 4GB SDHC | XP | eeectl | moveme
#10 ohyes
  • 306 posts
Posted 19 January 2008 - 07:01 AM
CM
I use one launcher, Launchy. Sure, you could drop an icon on the desktop. Launchy, though, makes it easy to just use the keyboard, not the trackpad, to launch apps. Much as I like my Eee, I find it easier to launch apps with the keyboard.
John
new: 1g 1000H
#11 dchao
  • 139 posts
  • LocationSF Bay Area
Posted 19 January 2008 - 07:21 AM
My must have is unusual: Microsoft Keyboard Driver (IntelliType Pro)
Why? Because by switching to XP, we have lost the Caps Lock and Num Lock indicator in the notification bar.
Microsoft IntelliType driver doesn't keep the key status in there permanently, but it will give you an onscreen visual feedback just like the other fn keys. Asus should have thought of that at the beginning.
You can download it from here:
http://www.microsoft...%20Windows%20XP
Edited by dchao, 19 January 2008 - 07:22 AM.
#12 Draconis
  • 4 posts
Posted 19 January 2008 - 07:44 AM
MediaPlayer classic is the player of choice for me. I prefer it over VLC because of the familiar interface, It's tiny and can handle anything you throw at it provided you've got the proper codec installed.
http://www.free-code...yer_Classic.htm
You may also want to look into codec packs like klite which include media player classic and will install all the codecs you will ever need to view any file including quicktime and realplayer without having to install the bloatware.
klite codec pack:
http://www.free-code..._Codec_Pack.htm
#13 Minn
  • 122 posts
  • LocationMoscow
Posted 19 January 2008 - 07:53 AM
CCleaner and FlashGet
EeePC 4GB Pearl White - Upgraded : 1GB Ram DDR-II SOLD!
EeePC 901 White 20GB + 8GB SDHC Class 6 + White USB Mouse :)
#14 dchao
  • 139 posts
Posted 19 January 2008 - 07:56 AM
Zoom Player is another good DirectShow front end. It has a good tool to help you manage filters, detecting missing decoders and then download the latest version.
http://www.inmatrix...._download.shtml
#15 Fluffywings
  • 460 posts
  • LocationSaskatchwan, Canada
Posted 19 January 2008 - 08:13 AM
All of these are free!!!
Gridmove
http://jgpaiva.donat...m/gridmove.html
Findandrunrobot (Not as pretty but more functional then Launchey)
http://www.donationc...drun/index.html
ProcessTamer
http://www.donationc...amer/index.html
SuperCopier2
http://www.softpedia...perCopier.shtml
7zip
http://www.7-zip.org/
#16 Bascule
  • 1,668 posts
  • Locationbeyond
Posted 19 January 2008 - 10:44 AM
I'll just list rather than add the URLs as they can be found easily in google:
MPlayer Classic
ScummVM
CCleaner
Stardock
Rainmeter
TweakUI
PortableApps suite
TreeSize Free
StyleXP (set custom boot screen and theme, then unloaded)
Other essentials, search this forum
R2H graphics driver
EEEPC_RES
Hitachi driver (so Rainmeter can 'see' and report on SDHC)
SetFSB (created two batch files, one to overclock and one to return and added to Stardock)
Edit: Just changed SetFSB for eeectl. Don't overclock much but I like the fan control. Good work!
Edited by Bascule, 19 January 2008 - 11:32 AM.
One day, I'll think of a really good signature.
#17 Kevin108
  • 537 posts
  • LocationPortsmouth, VA
Posted 19 January 2008 - 11:10 AM
No anti-virus and no spyware program because a little common sense goes a long way.
ACDSee32
CCleaner
Evil Player
FlashFXP
Foxit Reader
Mozilla Firefox
Mozilla Thunderbird
Pidgin
Startup Monitor
Startup Control Panel
TextPad
uTorrent
Ventrilo
VLC for extra volume in movies
WinRAR
I may add ZoneAlarm.
Kevin108.com
Eee PC 4G - 2 GB RAM, 8 GB SDHC
Windows user trying to find a Linux distro that will cooperate
#18 CodeMonkey
  • 140 posts
Posted 21 January 2008 - 02:59 PM
I'll stick with the desktop icons, they work just fine and don't take up any additional memory.
Process Tamer sounds interting, I will be testing that shortly. Do you really have to login and download a Free License Key? I would really rather not.
My issue with USB Disk Ejector is it doesn't stay in the Sys Tray, it's either a Window or closed. I would really prefer an easy to click trey icon that is easier to read and deal with than the basic Windows one. I'll probably remove this as it's not really adding anything.
A few people have recommended 7zip, which looks good if I were making Zips... but I'm not. I just need something to open them when they come my way. I suppose if it's significantly smaller or has fewer nag screens, that might be OK. Just not sure it's worth the effort at this point, thoughts?
I must be one of the lucky ones with a really quiet fan, it doesn't bother me at all so I intend to leave it alone.
Common sense vs. Every Hacker/Spammer on the internet?? No thanks. I work on PCs for a living and I see those Common Sense machines every day... in the SHOP getting fixed!
Thanks for all the suggestions guys! You have given us all something to think about.
CM
Edited by CodeMonkey, 21 January 2008 - 03:15 PM.
#19 almoore
  • 52 posts
Posted 21 January 2008 - 03:37 PM
Some of my favourite free apps are:
EditPad Lite - better than notepad for text editing
http://www.editpadpr...ditpadlite.html
Izarc - about the best compression app I have come across so far
http://www.izarc.org/
iI System Wiper - nice little cleanup app
http://iisoftware.net/
Ice Mirror - an excellent file mirroring tool - use with care - also works well for cloning SD cards (done it twice with no hitches
http://www.ice-graph...ror/IndexE.html
Al
#20 Ultimate Chicken
  • 400 posts
Posted 21 January 2008 - 03:42 PM
If you're running apps off your card reader, here's something to make your life a little easier - especially if you remove the thing a lot.
http://pegtop.net/start/
PStart is a nice little customizable menu app. The installer allows you to define a thumb drive as the destination, whereupon it acts like a portable application. Using PStart is similar to using the winDOS start menu - just drag and drop apps into it.
For best results, make the PStart.exe run on insert with autorun.inf.
