Truecrypt?
Posted 01 November 2007 - 11:34 PM
Thanks in advance.
Posted 02 November 2007 - 12:14 AM
Posted 14 November 2007 - 06:02 PM
You have 3 options:
1) use different software instead
2) compile your kernel on eeepc and hope it will not break ;-)
3) wait and see whether there is upgrde from Asus/Xandros.
-polo-
/home/user/My Documents/truecrypt-4.3a-source-code/Linux> sudo ./build.sh
Checking build requirements...
Linux kernel (2.6.21.4-eeepc) source directory [/usr/src/linux]: /lib/modules/2. 6.21.4-eeepc/
Error: Kernel source version in /lib/modules/2.6.21.4-eeepc/ is not 2.6.21.4-eee pc
Linux kernel (2.6.21.4-eeepc) source directory [/usr/src/linux]: /lib/modules/2. 6.21.4-eeepc/kernel/
Error: Kernel source version in /lib/modules/2.6.21.4-eeepc/kernel/ is not 2.6.2 1.4-eeepc
installation file says:
Installing TrueCrypt:
To build and install TrueCrypt, execute the following commands:
cd Linux
./install.sh
The installation script will first verify requirements for running TrueCrypt.
If successful, you will be prompted for installation options and the
installation will proceed.
Requirements for Running Truecrypt on Linux
- Linux kernel version 2.6.5 or compatible
- Device mapper (dmsetup, http://sources.redhat.com/dm) and loop device
(losetup) infrastructure, which are available in all major Linux
distributions
Edited by polocanada, 14 November 2007 - 06:03 PM.
Posted 26 November 2007 - 03:49 AM
Posted 26 November 2007 - 03:59 AM
Posted 12 December 2007 - 08:15 PM
Install dm-mod.ko in your modules directory (/lib/modules/2.6.21.4-eeepc/kernel/drivers/md for example).
"Integrate" the module: 'depmod -a'
Install truecrypt: dpkg -i truecrypt*.deb
Replace /usr/share/truecrypt/kernel/truecrypt-2.6.15.ko by my truecrypt.ko.
Have fun
PS: don't ask to me how to use it, I have never used it before, just compiled and tested ;)
EDIT: in fact, dm-crypt is not needed, removed.
Edited by Kibobo, 13 December 2007 - 08:13 AM.
Posted 13 December 2007 - 10:01 PM
Just need to work out how to use it without a GUI!
Posted 13 December 2007 - 10:09 PM
su echo $PATH?
Edited by Kibobo, 13 December 2007 - 10:12 PM.
Posted 13 December 2007 - 10:11 PM
Probably need :/sbin there too...
Posted 13 December 2007 - 10:12 PM
#12
Posted 13 December 2007 - 10:13 PM
Hmm... so it is there, then.
#13
Posted 13 December 2007 - 10:14 PM
#14
Posted 15 December 2007 - 04:56 AM
#15
Posted 15 December 2007 - 05:23 AM
#16
Posted 15 December 2007 - 09:08 AM
I use one of my Linux box under Debian Etch to compile modules and progs for the EEE.
Since Xandros OS is based on Etch, there is no problem with the libraries version (especially libc).
Edited by Kibobo, 15 December 2007 - 09:12 AM.
#17
Posted 16 December 2007 - 05:35 AM
Many Thanks, Kibobo. It works great on the Eee.
Btw, where is the place to autoload modules at boot time? /etc/modules?
#18
Posted 16 December 2007 - 09:18 AM
autoload is not necessary, truecrypt loads the right module itself.
EDIT: on my other VPC I have this message after entering the password "Failed to assign loopback device for file-hosted volume" !?
EDIT2: losetup gives me "ioctl: LOOP_SET_FD: Invalid argument"
http://forum.eeeuser...pic.php?id=2199
Really strange, I have not this problem on my other VPC, the only difference is that this one has no unionfs.
EDIT3: ok, according to my friend google, unionfs is not compatible with losetup (...)
Then, truecrypt is not compatible with the stock EEE xandros.
Edited by Kibobo, 16 December 2007 - 10:17 AM.
#19
Posted 19 December 2007 - 07:31 PM
#20
Posted 19 December 2007 - 08:35 PM
Do you mean Truecrypt is only pretending to work and not really encrypting?
How can I be sure it is working properly?
Thanks.
