Can't change permissions on SD card
Posted 01 November 2007 - 12:43 PM
Posted 01 November 2007 - 01:39 PM
4G White 701a with Flash PCI-E Slot | 2 gig Ram | Gentoo | Kernel 2.6.25.4
Posted 01 November 2007 - 02:53 PM
Posted 01 November 2007 - 02:55 PM
"I can't seem to change any permissions or owners of any files on the sd card"
Fat filesystems do not support file permissions or file ownership.
Posted 01 November 2007 - 02:56 PM
Do you use console to change the permissions, or you just type su or sudo in the console and return to the File Manager trying to change the permission ?
Posted 01 November 2007 - 03:01 PM
But I guess the real problem is that I can't run programs or shell scripts off the car, I tried to put filezilla on the sd card and when I double click on it, it brings up an open with dialog. When I try to start it via console, it gives me permission errors - even on root.
Posted 01 November 2007 - 03:05 PM
This is a file in SD (Fat)
You can change permission if you are the owner (root)
You can also change the ownership
Posted 01 November 2007 - 03:09 PM
Posted 01 November 2007 - 03:10 PM
Posted 01 November 2007 - 03:17 PM
Posted 01 November 2007 - 03:19 PM
#12
Posted 01 November 2007 - 03:21 PM
#13
Posted 01 November 2007 - 03:26 PM
But if you already CD to the correct folder, then you need to check the attrib, if it is 0644 then it is not allowed to execute.
But are you sure you will use filezilla in the 480 height screen ?
In the site it mention: It is recommended to use the package management system of your distribution or to manually compile FileZilla instead.
Have you tried the Fireftp (plug-in for Firefox) ?
Edited by o2smartphone, 01 November 2007 - 03:34 PM.
#14
Posted 01 November 2007 - 03:32 PM
#15
Posted 01 November 2007 - 03:40 PM
#16
Posted 01 November 2007 - 04:27 PM
#17
Posted 03 November 2007 - 01:50 PM
#18
Posted 04 November 2007 - 10:34 AM
Even if you use root to change the permisson, it reverse back to 666 after you leave.
#19
Posted 04 November 2007 - 01:14 PM
You can see this by typing:
cat /proc/mounts
#20
Posted 04 November 2007 - 02:34 PM
cat /proc/mounts
