Running Windows XP from a USB Drive / External Hard Drive
Posted 30 October 2007 - 04:30 AM
http://www.ngine.de/...jsp?pageid=4176
Here is a second page that I only glanced at. It may also have additional information for getting this to work. It looks like it ops for the WinPE/BartPE method and may achieve a different set of results.
http://www.tomshardw...in_your_pocket/
Anyway... good luck to those that try this. I do apologize for my misinformed comments in other posts. I may have been a little biased because I prefer Linux over XP :P
Posted 31 October 2007 - 06:47 PM
Posted 31 October 2007 - 06:54 PM
Posted 01 November 2007 - 11:28 AM
There has been alot of talk about booting from a usb drive but does the bios allow you to boot from an SD card?
I have a few 1 and 2gb sd cards i would much rather use then a pen drive so that nothing sticks out on it.
Posted 01 November 2007 - 10:54 PM
Posted 01 November 2007 - 10:55 PM
As far as O know, you can boot from an SD card.
Posted 02 November 2007 - 12:22 AM
Posted 02 November 2007 - 02:07 AM
In the last step, it need to remove all internal HD.
As we know, the SSD of eee PC is un-removable.
So I try to install XP Pro SP2 on SSD and use ghost to move to SD Card.
Then use recovery CD to restore default OS to SSD and let it boot on SD Card.
And then it will hang in the beginning windows (before login message shows) without any warning information.
Any one else use this method and success?
Can you describe the procedure?
Edited by CTHsieh, 02 November 2007 - 02:10 AM.
Posted 02 November 2007 - 04:59 AM
Posted 02 November 2007 - 05:41 AM
By the way, even I disable the SSD from BIOS, it is still detected by the installation procedure of WinXP.
So I don't know if it (SSD) can't be remove physically, will the procedure work?
Posted 02 November 2007 - 06:53 AM
#12
Posted 02 November 2007 - 12:14 PM
ba
ASUS EEE PC 1000H with OCZ Core Series V2 60GB
#13
Posted 04 November 2007 - 12:39 AM
I suggest posting detailed walkthroughs to these two threads:
- How to install XP on a USB flash drive or USB external HD:
"Running Windows XP from a USB Drive / External Hard Drive"
- How to install XP on an SD or SDHC card in the SD slot:
"Installing Windows XP on SDHC card"
Edited by silurius, 04 November 2007 - 12:44 AM.
#14
Posted 04 November 2007 - 11:07 PM
When I went to install XP pro it still listed the ssd, but it also listed my 40gb 2.5" usb hard drive. So I chose the usb drive and installed to it.
After the install was finished and the Asus drivers were installed I went back into the BIOS and changed the IDE Master setting back to Auto. This makes it so you still boot the ssd, but when you want to boot the usb just hold down Esc at bootup and choose your device.
#15
Posted 05 November 2007 - 12:01 AM
#16
Posted 27 January 2008 - 02:34 AM
