pidgin 2.6.2
132 replies to this topic
#1 BL00
  • 1,055 posts
  • LocationEngland
Posted 14 September 2009 - 08:44 PM
just trying to compile pidgin
can't get
sudo apt-get build-dep pidgin
to give me any useful info, ie 0 to install/upgrade/remove
apt-cache showsrc pidgin
gave more info, and those dependencies are met
however ./configure queries
checking for GSTINTERFACES...no
checking for FARSIGHT...no
configure: error:
Dependencies for voice/video were not met.
Install the necessary gstreamer and farsight packages first.
Or use --disable-vv if you do not want voice/video support.
so while i'm googling the answer
can someone beat me to it!? :D
save me some time
didn't know pidgin even had voice/video support yet!
edit: 2.6.1 adds XMPP Voice and Video support
obviously can use the disable option too, but it'd be a shame...
edit: there's a lot of stuff in here ftp://ftp.uk.debian....an/pool/main/g/
Edited by BL00, 14 September 2009 - 08:53 PM.
Asus 901 XP/OSX/Ubuntu, Google Nexus 4
Dell Mini 10v OSX 10.6.7/Win 7 and Chrome OS Lime on USB
Xandros: amsn, kooldock, pidgin 2.6.3, wine 1.1.29, adobe flash 10
#2 BL00
  • 1,055 posts
  • LocationEngland
Posted 14 September 2009 - 08:56 PM
installed gstreamer0.10-plugins-farsight
#3 BL00
  • 1,055 posts
  • LocationEngland
Posted 14 September 2009 - 09:07 PM
Versions of packages pidgin recommends:
ii gstreamer0.10-plugins- 0.10.19-2 GStreamer plugins from the "base"
ii gstreamer0.10-plugins- 0.10.8-4.1~lenny2 GStreamer plugins from the "good"
need to check those
source: http://osdir.com/ml/...7/msg07117.html
Edited by BL00, 14 September 2009 - 09:08 PM.
#4 BL00
  • 1,055 posts
  • LocationEngland
Posted 14 September 2009 - 09:16 PM
Voice and Video support - Thanks to Mike Ruprecht and his Summer of Code project from 2008, libpurple now has a voice and video framework that can be used to add these features to our protocol plugins. Currently we support these features only on XMPP, but Mike is working on other protocols as I write this and hopes to have more protocols at least partially supported soon. The dependencies are a bit of a mess for the uninitiated, but unfortunately that's unavoidable.
source http://planet.pidgin.im/
references:
http://ubuntuforums..../t-1221824.html
http://ubuntuforums....idgin+compiling
this should be the one:
http://developer.pid...8/VoiceAndVideo
Edited by BL00, 14 September 2009 - 09:39 PM.
#5 BL00
  • 1,055 posts
  • LocationEngland
Posted 14 September 2009 - 10:08 PM
Make sure you have:
* gstreamer0.10-plugins-good yes
* gstreamer0.10-plugins-bad yes (not sure which version, but it needs to include the gstrtpbin plugin)
* gstreamer0.10-plugins-farsight >= 0.12.6 no, 0.10.2-1
in addition to the extra compiling requirements of:
* farsight2-0.10 => 0.0.8 no
* gstreamer-plugins-base-0.10 yes
If you've got everything in order, the configure script should output this line:
Build with voice and video.... yes
Additional Tips for Debian/Ubuntu Users: ΒΆ
You'll need these packages from the your Debian/Ubuntu repositories, instead of the ones listed above:
* gstreamer0.10-plugins-good same as above?
* gstreamer0.10-plugins-bad same as above?
* libgstreamer-plugins-base0.10-dev yes
In addition to these packages you'll have to get from the Debian packages site (unless you're running experimental):
* libgstfarsight0.10-0 no
* libgstfarsight0.10-dev no
* gstreamer0.10-plugins-farsight yes
while i look into that, (perhaps try stealing from lenny?) will see if it compiles without voice & video! :D
edit: for my refs
./configure --disable-vv --enable-gnutls=yes
Edited by BL00, 14 September 2009 - 11:55 PM.
#6 BL00
  • 1,055 posts
  • LocationEngland
Posted 14 September 2009 - 11:51 PM
./configure is good without voice/video
but 'make' errors with
./whiteboard.h purple.h version.h marshallers.h | /usr/bin/python ./dbus-analyze-types.py --pattern=PURPLE_DBUS_DECLARE_TYPE\(%s\) > dbus-types.h
/bin/sh: dbus-types.h: Permission denied
make[2]: *** [dbus-types.h] Error 1
make[2]: Leaving directory `/media/A/partition6/pidgin-2.6.2/libpurple'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/media/A/partition6/pidgin-2.6.2'
make: *** [all] Error 2
/media/A/partition6/pidgin-2.6.2>
any ideas for when i wake up?
am going to bed! :)
Notes:
1. running this on a live Xandros install on a 8GB usb stick in easy mode (courtesy of albkwans fab script)
2. pidgin etc removed in apt
3. compiling to an external hard drive /media/A/partition6/pidgin-2.6.2
edit: note to self :D
./configure --disable-vv --prefix=/usr --enable-gnutls=yes
Edited by BL00, 15 September 2009 - 12:17 AM.
#7 SUNNYNARULA18
  • 224 posts
Posted 15 September 2009 - 09:29 AM
i think the voice and video support is the best of the new features added to pidgin...hoping it compiles with those new features
eeepc 701 :default xandros easy mode
ATM-the theme manager for my eeepc-get bouncy icons on easy mode
#8 BL00
  • 1,055 posts
  • LocationEngland
Posted 15 September 2009 - 06:37 PM
well there's good news and bad news :D
'make' is chugging away as i type
so there should be a new version of eee pidgin soon
(which will overcome yahoo issues)
however no video/audio
audio is a possibility
however the farsight dependencies
are pretty impossible in etch :(
#9 BL00
  • 1,055 posts
  • LocationEngland
Posted 15 September 2009 - 07:33 PM
aaaaaarrrghhhhh! :mad:
#10 BL00
  • 1,055 posts
  • LocationEngland
Posted 15 September 2009 - 07:49 PM
errrr?
eeepc-bloo/home/user/My Documents/downloads> dpkg -i pidgin_2.6.2-1_i386.deb
(Reading database ... 81300 files and directories currently installed.)
Unpacking pidgin (from pidgin_2.6.2-1_i386.deb) ...
dpkg: pidgin: warning - conffile `etc/gconf' is not a plain file or symlink (= `/etc/gconf')
dpkg: pidgin: warning - conffile `etc/gconf/gconf.xml.defaults' is not a plain file or symlink (= `/etc/gconf/gconf.xml.defaults')
dpkg: error processing pidgin_2.6.2-1_i386.deb (--install):
 trying to overwrite `/usr/lib/gcc/i486-linux-gnu/4.1.2/crtendS.o', which is also in package gcc-4.1
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Errors were encountered while processing:
any ideas people?
i can feel a google coming on...
edit: might be a bug in checkinstall? clicky
Edited by BL00, 15 September 2009 - 10:55 PM.
#11 BL00
  • 1,055 posts
  • LocationEngland
Posted 16 September 2009 - 12:27 AM
yup bug in checkinstall 1.6.1
installed 1.6.0 and all was good
:) anyways pidgin 2.6.2 for the eee
:( no voice & video yet
think it will be difficult on eee/etch
will have a look, time permitting...
not had chance to test it on another machine
other than the one it was compiled on
so no promises or guarantees yet
try it at your own risk etc :D
download pidgin_2.6.2-1
follow the instructions on the link, hosted by mediafire
when downloaded, navigate to the directory to which you download
right click the file, choose install DEB file
or install it from the terminal with
happy chatting
any help/hints with the video accepted gratefully!
Edited by BL00, 16 September 2009 - 12:29 AM.
#12 SUNNYNARULA18
  • 224 posts
Posted 16 September 2009 - 06:52 AM
downloaded the compiled pidgin ...right now i have booted directly into sda1...i will check this soon by booting normally in unionfs so that i can restore if it doesnt work
#13 SUNNYNARULA18
  • 224 posts
Posted 16 September 2009 - 07:50 AM
using right click and install debfile i get a message please check your install...
dpkg gives the following errors
sudo dpkg -i pidgin_2.6.2-1_i386.deb
dpkg-deb: `pidgin_2.6.2-1_i386.deb' is not a debian format archive
 subprocess dpkg-deb --control returned error exit status 2
#14 SUNNYNARULA18
  • 224 posts
Posted 16 September 2009 - 08:07 AM
seems my download was not complete...downloaded again...the deb package seems to be proper but dpkg gives the following error now
sudo dpkg -i pidgin_2.6.2-1_i38                                        6.deb
dpkg - warning: downgrading pidgin from 1:2.0.2-0ubuntu1+                                        asus9 to 0:2.6.2-1.
(Reading database ... 64648 files and directories current                                        ly installed.)
Preparing to replace pidgin 1:2.0.2-0ubuntu1+asus9 (using                                         pidgin_2.6.2-1_i386.deb) ...
Unpacking replacement pidgin ...
dpkg: error processing pidgin_2.6.2-1_i386.deb (--install                                        ):
 trying to overwrite `/usr/share/icons/hicolor/32x32/apps                                        /pidgin.png', which is also in package pidgin-data
should i remove pidgin-data
#15 BL00
  • 1,055 posts
  • LocationEngland
Posted 16 September 2009 - 10:36 AM
this is similar to the message i got when trying to install the kanotix build
because it's not listed as 1:2.6.2, it sees it as a downgrade
remove pidgin with
sudo apt-get remove pidgin pidgin-data libpurple0
or to remove it with all config files too
sudo apt-get remove --purge pidgin pidgin-data libpurple0
it shouldn't be required really under apt/dpkg
and the former should suffice
need to look into why checkinstall lists it as such
i think there's a manual method of signing the version number
perhaps it's just a xandros foible
but it should obviously be seen as an upgrade!
Edited by BL00, 16 September 2009 - 10:40 AM.
#16 SUNNYNARULA18
  • 224 posts
Posted 16 September 2009 - 02:29 PM
well,i removed previous pidgin and friends and installed this version ...yahoo works..
#17 BL00
  • 1,055 posts
  • LocationEngland
Posted 17 September 2009 - 07:35 AM
yay! :)
thanks for being my guinea pig!
ok this should follow the pidgin naming format
and apt/dpkg should now see it as an upgrade
pidgin 2.6.2
forgot to say the audio protocol with gstreamer might work, ie Gtalk
but not the video, don't have an account to test it
#18 SUNNYNARULA18
  • 224 posts
Posted 17 September 2009 - 12:23 PM
thanks goes to you for compiling it ....any "farsight" of getting the video??
#19 BL00
  • 1,055 posts
  • LocationEngland
Posted 17 September 2009 - 02:29 PM
ha ha! :D
that's terrible muriel!
farsight as far as i can see relies on many dependencies not available in etch. the most problematic being libc6, which when upgraded, stops various other programs from working. although there are workarounds, it then starts getting messy. and most people don't want complicated! some of the libc6 issues discussed here clicky and clicky
i'm even now still getting my head round some of these dependency type issues, but reckon the only possibility would be compiling farsight on the eee etc.
Edited by BL00, 17 September 2009 - 02:47 PM.
#20 SUNNYNARULA18
  • 224 posts
Posted 17 September 2009 - 02:41 PM
that sure is messy...compiling farsight, if possible, would be a treat
