LOOK! - one minute 640x480 stretch reversible hardware hack!
97 replies to this topic
#1 ziddan
  • 115 posts
Posted 31 December 2007 - 03:00 PM
I was thinking today that perhaps its possible to fool the eeepc into thinking there is an external monitor plugged in.
After a lot googling i found the answer!
People installing OSX on intel laptops have been having problems with it BSODing if an external monitor was not plugged in.
Someone found a dead simple fix for it, i tried it on my eee.
Here is how to get the eee to think a monitor is plugged in:
Posted Image
Ive inserted peices of a paperclip as per a picture from a mugan on the insanelymac forums.
Posted Image
With this the eee detects a secoundary monitor, meaning it can be set to clone mode, meaning we can get 640x480 stretched or centered as well as scrolling resolutins with the standard driver.
Edited by ziddan, 28 April 2008 - 09:17 PM.
#2 CyberTron
  • 10 posts
Posted 31 December 2007 - 03:07 PM
Would it be better to do the mod on a vga gender so user can choose to remove it and put it back anytime they want?
#3 ziddan
  • 115 posts
Posted 31 December 2007 - 03:12 PM
some have, i didnt have one of those on hand and this is very removable as well.
Took two pics with my other webcam, the quality is crap for ordinary stuff as ive removed the IR filter but it shows the wires installed in my eee and the interface where two monitors are detected (although very blurry and lowres)
Posted Image
Posted Image
#4 Fallentine
  • 198 posts
Posted 31 December 2007 - 03:25 PM
External monitor support can be disabled within windows.
Infact it can be disabled with the FN key combo.
This mod is great, unless of course you use an external monitor on a somewhat regular basis, then getting the pin connectors out would be a pain.
Though i have an idea for that. Make the pin connectors longer, and give the U end a twist. so it doesnt go in completely so it can be fingered out.
Sakura Red 901, 12GB, with perfect nlite XP pro SP3.
Future mods. 32GB Runcore SATA, Touchscreen, eSATA plug.
#5 Neil
    EEEmazing User
  • Moderators
  • 6,897 posts
  • LocationBerkshire, England
Posted 31 December 2007 - 03:28 PM
Or get a small plastic cap for the VGA connector (seen them as packaging on a couple of laptops recently, I seem to recall), and then fit the pins into that- then, it's just a case of putting on the cap, and job done :)
#6 naitsirk
  • 5 posts
cool mod! excellent work
#7 angel eyes
  • 51 posts
Posted 31 December 2007 - 05:03 PM
can you try uploading a good pic of the desktop with the 640x480 ?
#8 ziddan
  • 115 posts
Posted 31 December 2007 - 05:39 PM
I can post a printscreen but really you wont see any difference as 640x480 is still 640x480 even if its stretched, the stretching is done by the intel software/driver and therefore windows does not care about it.
Posted Image
Posted Image
#9 CrAzY
  • 57 posts
  • LocationOregon
Posted 31 December 2007 - 07:11 PM
Can you make the resolution above 640x480? Or can it reach 1024x768?
My Eee PC : [701-7C] 4G @ 900mhz (703 BIOS) | WinXP Pro (nLite) | 2GB DDR2 667 | 16GB SDHC
My Desktop PC : Intel QX6850 | 4gig DDR2 | 2x8800GTS 512mb (G92) | BlahBlahBlah
Eeelite Files | 900mhz | XP Fan Control
#10 geoelectric
  • 298 posts
Posted 31 December 2007 - 07:25 PM
That's brilliant. I love it.
Re: stretching, does it honor the driver options to display 640x480 without scaling?
I think I may go buy a m->f changer today and jumper it. This is an awesome idea.
#11 siafu
  • 191 posts
  • LocationElsewhere
Posted 31 December 2007 - 09:06 PM
sorry for my ignorance, but what is the purpose of 640x480? Is there something that requires it?
As for the hack, it looks like a simple mod that once I know what its purpose is, even I could do :)
EEE 8G / Win XP / Office 2003 / BT
Sold my EEE 4G (7B version)
#12 TheTurnipKing
  • 89 posts
Posted 01 January 2008 - 12:10 AM
It's a more "standard" resolution than the EEE's somewhat offbeat choice, is all. Presumably it would make it easier to run games, among other things.
White eeePC 4G with a gig of RAM.
#13 Malifer
  • 211 posts
Posted 01 January 2008 - 12:30 AM
tag
Macbook 13 inch, 2.2 ghz, 1 gig ram, duel boot osx leopard and xp pro
Asus F9 12 inch, 2.2 ghz, 3 gig ram, xp pro
Asus 4g --sold--
#14 geoelectric
  • 298 posts
Posted 01 January 2008 - 03:24 AM
TurnipKing:
It's more than that. It's extremely rare for a graphics card to not support 640x480. Most older games default to that resolution, and just won't run at all if it's not supported. The Eee's graphics drivers only support 640x480x16 as a minimum for Windows installation, but games request true-color and fail to start.
#15 ziddan
  • 115 posts
Posted 01 January 2008 - 10:31 AM
CrAzY: it cant make a 1024x768 desktop fit the screen, for that you need Lazertags drivers. However i think it scales down larger resolution when handling acceleratet graphics, will check when i get home.
geoelectric: I think you are asking if you can get 640x480 without stretching so ill answer that question, yes you can get 640x480 centered with black on the sides (pillarbox?).
mhthomas: i might, dont think this will be any problem though as i dont intend to wiggle the wires around. Ive put some tape over them.
And thats with the windows standard driver meaning no 3d acceleration.
Edited by ziddan, 01 January 2008 - 11:17 AM.
#16 n3rdk1d
  • 465 posts
Posted 01 January 2008 - 12:36 PM
so we can use the standard driver and have 640x480 stretched correct? AND have standby? i'd love to have 800x600 scaled so i don't have to scroll. does this do that too? prolly not huh?
#17 ziddan
  • 115 posts
Posted 01 January 2008 - 03:15 PM
n3rdk1d: standby works with this hack. 800x600 scaled does not, i too would love that with this one but i havnt looked at the drivers so i dont know.
#18 eFfeM
  • 861 posts
Posted 01 January 2008 - 03:58 PM
on xandros if you go to a higher res externally then you can pan on the local display.
To make this easily removable, I would definitely solder this into an old VGA plug.
2) you do not pretend or create the illusion that your modifications are mine. I'll be responsible for my junk, you for yours :)
#19 ziddan
  • 115 posts
Posted 01 January 2008 - 04:19 PM
eFfeM: panning works without a hitch, this mod makes the eee work just like when an external monitor is connected.
#20 siafu
  • 191 posts
  • LocationElsewhere
Posted 01 January 2008 - 10:20 PM
I need to get a glue gun or something to seal up the exposed end. Maybe something like clay that dries hard?
Suggestions?
Radio Shack is great for stuff like this!
I keep seeing commercials for "Mighty Putty" it dries hard and bonds to anything.
Edited by siafu, 01 January 2008 - 10:30 PM.
